#1 2018-07-14 18:39
pucho-ar
Sophos antivirus installation
Hi
I plan to install Sophos antivirus in Q4OS and I need to make two queries:
1- Is the same procedure detailed in this article (for linux ubuntu)? h-t-t-p-s://ubunlog.com/sophos-instala-antivirus-terminal/
2- In a PC with 1GB of RAM will affect its speed of work ?. (the pc is used for web browsing, email and some work with office suite, not at all demanding).
regards
#2 2018-07-14 19:31
Re: Sophos antivirus installation
Hello!
Any anti-virus will affect overall performance, because it consumes resources for on access scanning module, web traffic scanning module, heuristics mogule...etc.
I would not suggest installing any anti-virus software on PC with less than 2GB RAM.
As for Sophos Antivirus, I tried to install it on Q4OS back in 2016 and I was not successful with it. So I tried several another antiviruses: ClamAv, eScan, Comodo, ESET, DrWeb. So far, I think that for Linux, the best anti-virus is DrWeb.
I am not speaking about it`s malware detection abilities, because Linux is not Windows, it is much much harder to write malware for Linux, I am speaking about performance, functionality, usage easiness, support, available documentation. So after several months of testing I suggest to use DrWeb. Currently I use Linux Mint 18, and DrWeb works very well on it, and back in 2016 it was working well on Q4OS too.
Please check these thread and post:
https://www.q4os.org/forum/viewtopic.php?id=834
https://www.q4os.org/forum/viewtopic.php?pid=4093#p4093
Also Q4OS Team has made an installer for DrWeb Antivirus:
https://www.q4os.org/forum/viewtopic.php?pid=6520#p6520
and the installer worked perfectly:
https://www.q4os.org/forum/viewtopic.php?pid=6527#p6527
Sorry, I haven`t tested it on Q4OS 2.5.
Also you can follow these instructions to install it from universal package:
https://download.geo.drweb.com/pub/drwe … n/html/en/
#3 2018-07-16 15:37
pucho-ar
Hello
Thanks for your post! I will read each one of your links.
Thank you very much and greetings
