#26 2017-12-31 21:44
Re: Q4OS Live Stick WIFI connect
Q4OS is very good but PCLinuxOS is excellent as well and one of the friendliest ive been around.  When i first started with Linux in 2006 or so there were a lot of Linux snobs that didnt want to be troubled with helping crossover users such as myself. Ubuntu and Mepis forums were great back then.
#27 2018-06-07 03:28
C1Steve
I'm back.
I forgot about Q4OS but now I re-discovered it and it seems excellent.
I know nothing about LINUX. I need to learn.
I am a WINDOWS DOS person wanting to move to LINUX. I am a retired mainframes system manager.
Q4OS automatically detects WIFI and all the close by hotspots and I can sign in on 3 PCS
On the 4th it says:
Wireless network card detected
Wifi support enabled
But then I see NO hotspots at all
I will need step by step instructions to get going.
Once I am running on all systems I can start learning.
Driver issues possibly ??
The system is a MSI U230 Light "old" AMD MV 40 processor
and a DOS program I ran says the wireless card is from REALTEK
but no other information.
Could Q4OS in some way tell me what exactly the situation is.
C1Steve
#28 2018-06-07 07:26
Hi Steve, you could install the inxi package and then post some output here, you can install it either by using Synaptic Package Manager or by using this command in a Konsole
sudo apt install inxi
Once installed if you type in a Konsole this command
inxi -n
it should give some output that will tell us a  little about your network card, post it here and we should be able to help.
#29 2018-06-07 18:07
C1Steve
Can I do this from the LIVE USB?
Thanks C1Steve appreciate the help.
#30 2018-06-07 18:29
Yes that should work ok.
#31 2018-06-07 19:50
C1Steve
I get the following message:
"unable to locate package inxi"
C1Steve
#32 2018-06-07 19:58
You have only followed half the instructions, please install it first and then it will work.
EDIT: Sorry you will need to run
sudo apt update
first and then it will work. Sorry my bad...
#33 2018-06-08 04:23
C1Steve
"sudo apt update" yields
a whole bunch of err:1
a whole bunch of w: failed to fetch http://ftp.debian. .......
Of course that wouldn't work because it already needs wifi.
C1Steve
#34 2018-06-08 08:49
It looks like I have not understood the problem correctly, sorry, again my bad...
Do you have a wired connection you could use for installation (or to diagnose the problem at least)?
#35 2018-06-08 16:42
C1Steve
I can rig up something but it will be Monday.
What should I do after I connect the cable.
Thank you for your support.
C1Steve
#36 2018-06-08 16:59
You're welcome smile
Once you have a cable connected it will automatically pick up the network and you can install inxi and post the output of inxi -F after updating apt of course with sudo apt update. There is no need to upgrade as this is only for the live session and changes will be lost at reboot/shutdown.
#37 2018-06-09 03:04
C1Steve
Thanks, I am partitioning a multi-boot system I have and I want to provide
a partition for Q4OS.
What type of partition should it be?
How big should it be? I will double or triple this.
Is a swap partition necessary.
C1Steve
#38 2018-06-09 07:22
1. type = ext4 (there are other options but I always use this and it would be the default if you let the installer handle everything for you)
2. size = This would be entirely subjective, if you don't give enough room you would need to jump through some hoops later on to extend it, I use a non-standard method and usually assign anywhere from 10Gb (bare minimum) up to whatever space is available. keep in mind that if you want to install a lot of software to the system as well as keeping your documents/files etc then you would need to provide enough hdd space for this. The majority of my installations are between 20-30Gb for the OS and then I keep a separate partition for all my documents/files so that in the event of a re-installation (I do a lot of testing) I only have to add my data partition to a fresh install to have all my data available.
3. swap = Technically this is not a requirement but I do not run any systems without it, I usually use the equivalent space to my RAM capacity (between 2 and 4Gb on most of my machines) and this appears to be pretty much the norm from what I have read.
#39 2018-06-09 19:20
C1Steve
I will use 32767 then. And if swap becomes necessary I will carve it out of that.
C1Steve
#40 2018-06-09 22:16
C1Steve
here is the information:
Card1: Realink RT3090 Wireless 80211.N
1T/1R PCIE
If: WLP2050 State Down
MAC 40:61:86:A3:A5:A7
So does this mean it is down because it isn't configured (properly)
Or because there is an hardware problem? Or what?
C1Steve
#41 2018-06-09 22:53
Is that the full output?
can you post the output of
sudo rfkill list
Also you should install firmware-misc-nonfree (if it is not already installed)
sudo apt install firmware-misc-nonfree
#42 2018-06-10 03:40
C1Steve
adding to previous
sudo rfkill list
0: phy0: wireless lan
    soft blocked no
    hard blocked yes
after installing firmware
0 upgraded
0 newly installed
0 to to remove and
5 not upgraded
then inxi -n again and it is still down
C1Steve
#43 2018-06-10 09:17
Is there a switch to turn on/off WiFi?
On my laptop I can turn off WiFi using Fn+PrtScr although this particular key combination is unlikely to work for you but there might be a similar function with yours.
Also have you checked in the bios to make sure there is no option that has disabled the WiFi?
You could try
rfkill unblock all
but I would imagine it not to have any effect as it is hard blocked (hardware) and not soft blocked (software)
#44 2018-06-10 19:04
C1Steve
Good info that hard blocked means hardware disabled.
I tried the two function keys that might have trrned it on/off but no joy.
There are no settings in bios concerning wifi one way or the other.
It would be too complicated to dis-assemble the NETBOOK IT IS to put
in another wifi card, the last time I tried that I bricked another netnook.
I am going to look around for a USB STICK wifi adapter.
C1Steve, thanks
#45 2018-06-10 19:26
C1Steve
It WORKS it WORKS now.
After power cycle rebooting and hitting FCT-F8 that turned wifi on and now it is fine.
I should have thought of that long ago, anyway.
Thank you for reminding me of the FCT keys.
C1Steve
#46 2018-06-10 19:48
Great news! I'm glad we got it sorted, and you are very welcome smile
