#51 2018-04-01 19:23
Re: Can't open boot menu [Solved]
q4osfan wrote:
Oh - thanks!
You are welcome smile
q4osfan wrote:
Do I just put the original 'install' USB in and run - then it gives me the option of creating a partition automatically, I suppose?
Not quite automatically but you will be able to resize/create partitions on your HDD during the installation process
q4osfan wrote:
By the way, is there a way in this forum where you tag a reply as "Solution" and "Thanks"?
You can go to the Original Post and edit the title and add [solved] to the beginning
q4osfan wrote:
Anyway, I want to THANK you very much for all your help!!
Best wishes smile
You are very welcome, I'm glad we managed to resolve it (eventually smile )
q4osfan wrote:
PS. I suppose the Nvidia graphics card is defect and not usable?
I would guess this card may have been the cause of the original problem, but you could try it in another machine to test it out.
#52 2018-04-01 19:26
q4osfan
Final thanks! smile
