#26 2018-02-20 16:56
D.P.W.
Re: error messages
Dai_trying wrote:
As you do not appear to have apt running any processes I would have to leave this one for the dev team as it looks like their updater you are using and I have no experience with it.
Ok thanks for trying will the dev team see my message on this forum or do i need to contact them ? if so how ?
Thanks again for your time and effort.
#27 2018-02-20 17:01
Re: error messages
You're welcome, and I'm sure the dev team will read this and respond when they can, if you don't get any reply after a while you could email them, but they are usually quite attentive to forum posts. smile
#28 2018-02-20 17:23
Re: error messages
@D.P.W.
Please run following commands in terminal:
$ df -h
$ sudo apt-get check
$ sudo dpkg --audit
and post output here to analyze
#29 2018-02-21 15:40
D.P.W.
Re: error messages
@D.P.W.
$ df -h
$ sudo dpkg --audit
I have done as you asked this is what i got
Filesystem      Size  Used Avail Use% Mounted on
udev            1.9G     0  1.9G   0% /dev
tmpfs           382M  5.8M  377M   2% /run
/dev/sda2        28G  4.9G   22G  19% /
tmpfs           1.9G   16M  1.9G   1% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
/dev/sda3       262G  133M  248G   1% /home
tmpfs           382M  8.0K  382M   1% /run/user/1000
david@laptop:~$ sudo apt-get check
Reading package lists... Done
Building dependency tree
david@laptop:~$ sudo dpkg --audit
david@laptop:~$
as you can see for the last command i did not get anything at all i would also like to add that to get Q4OS to start up i had to do this again
fsck /dev/sda2 then reboot
#30 2018-02-21 16:07
Re: error messages
Looks good, now run commands:
$ mount
$ check-apt-busy
$ sudo sh /usr/share/apps/q4os_system/bin/qapt_fix.sh
#31 2018-02-21 16:31
D.P.W.
Re: error messages
$ mount
$ check-apt-busy
this is what i got
david@laptop:~$ mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=1939524k,nr_inodes=484881,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=391052k,mode=755)
/dev/sda2 on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2461)
mqueue on /dev/mqueue type mqueue (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
/dev/sda3 on /home type ext4 (rw,relatime,errors=remount-ro,data=ordered)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=391048k,mode=700,uid=1000,gid=1000)
david@laptop:~$ check-apt-busy  for this one i got nothing
david@laptop:~$ sudo sh /usr/share/apps/q4os_system/bin/qapt_fix.sh
[sudo] password for david:
Waiting for package system to be released ..
Seems ready, will be checked once more.
Now safe ready.
Done.
Checking package system ..
Package system ok.
#32 2018-02-21 16:49
Re: error messages
Looks good as well, now run:
$ /opt/program_files/q4os-update-manager/bin/updatemgr.exu
and report back
$ /usr/share/apps/q4os_system/bin/qapt_lock.exu --lock
are you able to lock apt using the command above ?
#33 2018-02-21 17:00
D.P.W.
Re: error messages
and report back
i get this message do i click on yes or no
The following packages were automatically installed and are no longer required:
   libc-dev-bin (2.24-11+deb9u1)
   linux-libc-dev (4.9.65-3+deb9u2)
   manpages-dev (4.10-2)
#34 2018-02-21 17:04
D.P.W.
Re: error messages
and report back
i get this when i type in the second command
david@laptop:~$ /usr/share/apps/q4os_system/bin/qapt_lock.exu --lock
Locked OK
Waiting for stdin
#35 2018-02-21 19:07
Re: error messages
Ok, reboot and run in terminal:
$ sudo apt-get autoremove
your system should be fine now.
#36 2018-02-22 16:27
D.P.W.
Re: error messages
Hi after doing the above i got this is it what i should have got ?
The following packages will be REMOVED:
  libc-dev-bin linux-libc-dev manpages-dev
0 upgraded, 0 newly installed, 3 to remove and 0 not upgraded.
After this operation, 8,783 kB disk space will be freed.
W: Not using locking for read only lock file /var/lib/dpkg/lock
W: chown to _apt:root of directory /var/cache/apt/archives/partial failed - Setu        pAPTPartialDirectory (30: Read-only file system)
W: chmod 0700 of directory /var/cache/apt/archives/partial failed - SetupAPTPart        ialDirectory (30: Read-only file system)
W: Not using locking for read only lock file /var/cache/apt/archives/lock
Do you want to continue? [Y/n] y
dpkg: error: unable to access dpkg status area: Read-only file system
W: Problem unlinking the file /var/log/apt/eipp.log.xz - FileFd::Open (30: Read-        only file system)
W: Could not open file /var/log/apt/eipp.log.xz - open (17: File exists)
W: Could not open file '/var/log/apt/eipp.log.xz' - EIPP::OrderInstall (17: File        exists)
E: Could not create temporary file for /var/lib/apt/extended_states - mkstemp (3        0: Read-only file system)
E: Failed to write temporary StateFile /var/lib/apt/extended_states
E: Sub-process dpkg --set-selections returned an error code (2)
E: Couldn't record the approved state changes as dpkg selection states
#37 2018-02-22 16:50
D.P.W.
Re: error messages
Hi after doing the above i got this is it what i should have got ? also i can no longer open synaptic package or libre office how do i get them working again ?
#38 2018-02-23 20:36
Re: error messages
Looks more like a hardware issue. If you want to try to investigate it more, run following commands, one right after each other:
$ mount
and post output here. We will check it and post back.
We would also recommend you to boot from the live media and run hard drive scan from terminal:
$ sudo badblocks -s /dev/sda
it will scan the hard drive for physically damaged blocks.
#39 2018-02-25 16:24
D.P.W.
Re: error messages
$ mount
This is the results of hard drive scan i have only pasted the top and bottom half if i am looking at it right no damage was found so does that mean my hard drive is ok ?
Checking for bad blocks (read-only test):   0.00% done, 0:00 elapsed. (0/0/0 err        55293544done, 11:35 elapsed. (0/0/0 errors)
55293545done, 11:37 elapsed. (1/0/0 errors)
55293546done, 11:40 elapsed. (2/0/0 errors)
55293547done, 11:43 elapsed. (3/0/0 errors)
55293548done, 11:45 elapsed. (4/0/0 errors)
55293549done, 11:48 elapsed. (5/0/0 errors)
55293550done, 11:51 elapsed. (6/0/0 errors)
55293551done, 11:53 elapsed. (7/0/0 errors)
55293552done, 11:56 elapsed. (8/0/0 errors)
55293553done, 11:59 elapsed. (9/0/0 errors)
55293554done, 12:01 elapsed. (10/0/0 errors)
55293555done, 12:04 elapsed. (11/0/0 errors)
55293556done, 12:07 elapsed. (12/0/0 errors)
55293557done, 12:09 elapsed. (13/0/0 errors)
55293558done, 12:12 elapsed. (14/0/0 errors)
55293559done, 12:15 elapsed. (15/0/0 errors)
55293560done, 12:17 elapsed. (16/0/0 errors)
55293561done, 12:20 elapsed. (17/0/0 errors)
55293562done, 12:23 elapsed. (18/0/0 errors)
63743868done, 14:17 elapsed. (19/0/0 errors)
63743869done, 14:19 elapsed. (20/0/0 errors)
272621827one, 2:01:06 elapsed. (303/0/0 errors)
272657496one, 2:01:10 elapsed. (304/0/0 errors)
272657497one, 2:01:13 elapsed. (305/0/0 errors)
272657498one, 2:01:16 elapsed. (306/0/0 errors)
272657499one, 2:01:18 elapsed. (307/0/0 errors)
272659816one, 2:01:22 elapsed. (308/0/0 errors)
272659817one, 2:01:24 elapsed. (309/0/0 errors)
272659818one, 2:01:27 elapsed. (310/0/0 errors)
272659819one, 2:01:30 elapsed. (311/0/0 errors)
272659820one, 2:01:33 elapsed. (312/0/0 errors)
272659821one, 2:01:36 elapsed. (313/0/0 errors)
272659822one, 2:01:38 elapsed. (314/0/0 errors)
272659823one, 2:01:41 elapsed. (315/0/0 errors)
272661516one, 2:01:45 elapsed. (316/0/0 errors)
272661517one, 2:01:47 elapsed. (317/0/0 errors)
272661518one, 2:01:50 elapsed. (318/0/0 errors)
272661519one, 2:01:53 elapsed. (319/0/0 errors)
272661520one, 2:01:55 elapsed. (320/0/0 errors)
272661521one, 2:01:58 elapsed. (321/0/0 errors)
272661522one, 2:02:01 elapsed. (322/0/0 errors)
272661523one, 2:02:03 elapsed. (323/0/0 errors)
done
adminq@debian:~$
#40 2018-02-25 17:21
D.P.W.
Re: error messages
$ mount
This is what i got when i ran the above commands
david@laptop:~$ sudo apt-get autoremove
0 upgraded, 0 newly installed, 0 to remove and 72 not upgraded.
de=755)
e=000)
ime)
e,cpu,cpuacct)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,re        latime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime        ,perf_event)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,de        vices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,fr        eezer)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,mem        ory)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blki        o)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpu        set)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=37,pgrp=1,time        out=0,minproto=5,maxproto=5,direct,pipe_ino=11543)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=391048k,mode=7        00,uid=1000,gid=1000)
david@laptop:~$
#41 2018-02-26 09:06
Re: error messages
Forgive me for butting in on this, but the original post was identical to an issue I had on my machine a few weeks back. The drive had developed some bad sectors and was mounting read only. Smartmontools was ideal for testing the drive which I have wiped and reinstalled, which should ignore bad sectors, but no way will it be used for anything other than experimenting with installs.
I would seriously suggest that replacing the drive might save a whole lot of back and forth over an issue that cannot be resolved by the current approach smile
@D.P.W Out of interest, have you modified your /etc/fstab file at any time?
#42 2018-02-26 09:54
Re: error messages
Looks like your harddrive is sometimes mounted read only. The command 'sudo apt-get autoremove' failed for the first time, while second time passed well. It would show some kind of hardware problem. Please follow bin's advice from his post above https://www.q4os.org/forum/viewtopic.ph … 174#p12174
#43 2018-02-26 09:56
D.P.W.
Re: error messages
Hi i have not knowingly modified my  etc/fstab file unless it has been done while following instructions sent to me via this forum.
Have you looked at my hard drive scan results ? am i right in saying that no faults have been found ?
#44 2018-02-26 10:15
Re: error messages
Yes, found no faults, but it doesn't mean it's faultless.
#45 2018-02-26 10:40
jackdanielsesq
Re: error messages
DPW
Looks like a truncated file system - you need to run gparted, et al, .. repair/reformat the file system
Then setup a partition somewhere where there was little activity - end of the drive & install the O/S
Some of us do not always have the luxury of running out to Newegg or Prime for that new HHD/SSD
I have repaired many of our servers this way  ... I am currently on such a HHD - its perfect
Only MSFT cares about C:\ - Unix not so much
Regards
Jack
#46 2018-02-26 10:40
D.P.W.
Re: error messages
Hi thank you all for your advice i do not have a spare hard drive but i do have a 32GB memory stick can i plug this into my laptop and install/run Q4OS from it ? so i can test it out before getting a new hard drive.
#47 2018-02-26 10:42
jackdanielsesq
Re: error messages
Hi ...
See my previous post
Regards
Jack
#48 2018-02-26 10:51
D.P.W.
Re: error messages
jackdanielsesq wrote:
DPW
Regards
Jack
Hi how do i do the above ?
