Hallo,
I need a screen keyboard (Bildschirmtastatur)
I tried to install caribou with synaptic.
Find it nowhere.
"Execute command" also does not work.
How i can fix it?
Thanks in advance
I would recommend florence, it can be installed using either synaptic package manager or using sudo apt install florence in a terminal and can be found at Start -> Programs -> Accessories -> Lost & Found -> Florence Virtual Keyboard It might not be the best screen keyboard available but it is one I have use din the past.
The menu locations seems a bit strange to me but that is where I found it after installing to check it still worked ok.
Thank you, it works fine.
Happy to help
Just tried Florence as I hadnt used it before, works fine.
I can't remember why I needed it but it did come in useful some time back and stuck in my mind for if I ever needed it again
Many distros have screen keyboards built in by default.
