#1 2018-02-06 16:27
trapper
screen keyboard [solved]
Hallo,
I need a screen keyboard (Bildschirmtastatur)
I tried to install caribou with synaptic.
Find it nowhere.
"Execute command" also does not work.
How i can fix it?
Thanks in advance
#2 2018-02-06 20:12
Re: screen keyboard [solved]
I would recommend florence, it can be installed using either synaptic package manager or using sudo apt install florence in a terminal and can be found at Start -> Programs -> Accessories -> Lost & Found -> Florence Virtual Keyboard It might not be the best screen keyboard available but it is one I have use din the past.
The menu locations seems a bit strange to me but that is where I found it after installing to check it still worked ok.
#3 2018-02-06 21:50
trapper
Thank you, it works fine.
#4 2018-02-06 23:39
Happy to help smile
#5 2018-02-07 00:07
Just tried Florence as I hadnt used it before, works fine.
#6 2018-02-07 00:12
I can't remember why I needed it but it did come in useful some time back and stuck in my mind for if I ever needed it again smile
#7 2018-02-07 00:30
Many distros have screen keyboards built in by default.
