NEW Wireless Workstation Thin Client PC ARM A9 dual core 1ghz 512M RAM 512M Flash 1080P HDMI RDP 7.0 Thin client computer linux
http://www.aliexpress.com/item/NEW-Wire … 2705892204
No Longer Using Q4OS
Yes, it should work in general, as we prepare Q4OS ARM port, based on Debian Jessie armhf architecture. The CPU Cortex A9 is compatible, 512M memory is sufficient. The question is, if all drivers, wifi, etc ... will work. The only way to ascertain it, is test Q4OS directly on this hardware. Also, we don't know, if the hardware is unlocked for loading custom systems.
Q4OS Team, Thank You ! I will contact the manufacture find out if unit is "NOT LOCKED". And, get one - stay tuned.
Bobby
Bobby, this is better! Test it please!
Just a joke. It is too expensive.
But this is definitely worth to test. It has CPU: INTEL C1037U 1.8GHz, not Arm.
Heck, I actually like the look of this box better. Better yet, for $4 more it comes with a Com Port. I have a device that needs to be connected to a Com Port. Both Arduino and RaspberryPiv use USB for programming. Sounds interesting. So many decisions, so many choices.
Well, if I were you, I would buy this one. Those China devices often have bugs and defects, and also come with very poor support. That is why they cost so little.
But if you still want to experiment please do it. Just do not forget about HEATSINKS or COPPER! Otherwise keep your fire extinguisher ready
All for your experiments!
Hi Rademes, Understand about the China Syndrome Buying. Tried that with OBD-II code readers that never worked.
The Q4OS RaspPii pre-installed device you linked will work for me on my own projects but,
? What about a chrome book that's only $134 that I can install Q4OS ARM on and market to others. Chrome/Arm Dual Boot instructions here: Dual Boot ARM / Chromebook
C11 Chromebook link: http://archlinuxarm.org/platforms/armv7 … mebook-c11
Will this run Q4OS ARM ?
Architecture = ARMv7l Cortex-A17 | Processor Rockchip RK3288 1.8GHz
RAM = 2048MB
NAND = 16384MB
SD = Micro SD
USB = 2
Wireless =B/G/N/AC
Looks good, but Q4OS is not based on Arch linux. So the only way to be sure that it will work is test it.
Also, what about support there?
On the other side the Q4OS RaspPii pre-installed device I linked is 100% compatible with Q4OS. If it will work fine for your projects as you said, then i still would NOT recommend to buy anything else. There is a big chances that you will pay twice. Also keep in mind that it is ARM architecture, which is different than x86-64, so you will need quality support at the first time. I can`t advice more, because I don`t know your ARM architectures OS knowledge level.
Also, buying Q4OS device you will support Q4OS development! As I can see you always were looking for different methods to support Q4OS.
Yes, You are correct ! The Q4OS.org device is on my to-buy-list and will happen soon. However, I can't recommend this device to others as like you say, additional ARM knowledge is required and I don't have it.
What I need is a very cheap mainstream alternative that is dual Boot WinOS or Google Chrome and Boot Q4OS.
I mainly help poor people (like me = its my niche) and these people can scrape together $100 but, not $300+.
Q4OS can be an effective tool in getting people off of WinOS in large numbers but, it has to be a viable consumer option.
1. Good Price
2. Boot both a WinOS or GoogleOS and Q4OS.
3. Name they can relate to: Google does that.
(IMO) Without the large numbers of people using and spreading word about this great Linux Distro, the mega bucks that are needed will not be available to speed up development.
Mega Users = Mega Bucks ? Am I wrong ?
RAM = 2048MB
NAND = 16384MB
SD = Micro SD
USB = 2
Wireless =B/G/N/AC
If it works with Arch Linux, It should very probably run Q4OS as well.
