#1 2023-10-28 19:42
Toshiba3000
[SOLVED] Librtmp1 package cannot be removed
Doing the last apt-get upgrade few days ago from now I have done on my computer, a retained package cannot be upgraded:
First:
..#Apt-get upgrade
Results:
Following packages have been retained:
librtmp1
0 upgraded, 0 new will be installed, 0 removed, and 1 not upgraded
Next, I tried this to know more about retained packages:
#sudo apt-get —with-new-pkgs upgrade librtmp1,
Brings me a clarify message:
Cannot install some packages. This could means you ask for an impossible situation or, if you are using the unstable distro, some packages needed are not created still, or have been taken from “Incoming”. Next information can help to fix the situation:
Following packages has dependencies not solved:
Librtmp1: Depend on: libhogweed4 but it is not installable
               Depend on: libnettle6 but it is not installable
E: Broken packages.
I tried to fix this way:
apt remove (all packages about above),
And
Apt install (same way like trying to remove them).
I tried both commands but I have no luck about any of them.
I think my supposed upgradable package must be trapped on a possible upgrade I cannot download or remove, Also, I cannot install or remove packages which depend on librmp1 because are not installed. Ideas how to fix it are welcome. Thank you in advance.
#2 2023-10-28 20:16
Re: [SOLVED] Librtmp1 package cannot be removed
Please post output of commands:
$ qrepolist
$ apt-cache policy librmp1
and also post a brief info about your system, see https://www.q4os.org/forum/viewtopic.php?id=3502
#3 2023-10-29 01:47
Toshiba3000
my qrepolist output:
root@q4os-desktop:/home/jpablo# qrepolist
deb http://q4os.org/q4repo q4os-4-0-cn main
deb http://q4os.org/qtderepo bullseye basic main
deb http://deb.debian.org/debian bullseye main contrib non-free
deb http://security.debian.org/debian-security bullseye-security main contrib non-free
deb http://deb.debian.org/debian bullseye-updates main contrib non-free
deb http://www.deb-multimedia.org buster main non-free
deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
my librtmp1 output (I think you did not ask for librmp1 (a "t" key is missing), Debian can't locate)
root@q4os-desktop:/home/jpablo# apt-cache policy librmp1
N: No se ha podido localizar el paquete librmp1
root@q4os-desktop:/home/jpablo# apt-cache policy librtmp1
librtmp1:
  Instalados: 2.4+20151223.gitfa8646d.1-2+b2
  Candidato:  2:2.4~20160119.gitfa8646dae-dmo5
  Tabla de versión:
     2:2.4~20160119.gitfa8646dae-dmo5 500
        500 http://www.deb-multimedia.org buster/main i386 Packages
*** 2.4+20151223.gitfa8646d.1-2+b2 500
        500 http://deb.debian.org/debian bullseye/main i386 Packages
        100 /var/lib/dpkg/status
root@q4os-desktop:/home/jpablo# inxi -Fxxx
System:
  Host: q4os-desktop Kernel: 5.10.0-26-686-pae i686 bits: 32 compiler: gcc
  v: 10.2.1 Desktop: Trinity R14.0.12 tk: Qt 3.5.0 info: kicker wm: Twin 3.0
  dm: TDM Distro: Q4OS 4.12.1-n1 base: Debian GNU/Linux 11 (bullseye)
Machine:
  Type: Other-vm? System: TOSHIBA product: S3000-X4 v: PS301E-000K8-EN
  serial: Y1429276C Chassis: type: 1 serial: N/A
  Mobo: Null model: ATW01 v: Null serial: 0123456789AB BIOS: TOSHIBA v: 1.00
  date: 10/20/2001
Battery:
  ID-1: BAT1 charge: 34.9 Wh condition: 59.2/59.2 Wh (100%) volts: 14.8/14.8
  model: TOSHIBA PA3098U type: Li-ion serial: 3658Q status: Unknown
CPU:
  Info: Single Core model: Celeron (Coppermine) bits: 32 type: MCP
  arch: P6 III Coppermine rev: A L1 cache: 32 KiB L2 cache: 128 KiB
  flags: pae sse bogomips: 1860
  Speed: 930 MHz min/max: N/A volts: 3.3 V Core speed (MHz): 1: 930
Graphics:
  Device-1: Intel 82830M/MG Integrated Graphics vendor: Toshiba driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:3577 class ID: 0300
  Display: server: X.Org 1.20.11 driver: loaded: intel
  unloaded: fbdev,modesetting,vesa resolution: 1024x768~60Hz s-dpi: 113
  OpenGL: renderer: Mesa DRI Intel 830M x86/MMX/SSE v: 1.3 Mesa 20.3.5
  direct render: Yes
Audio:
  Device-1: Intel 82801CA/CAM AC97 Audio vendor: Toshiba
  driver: snd_intel8x0 v: kernel bus ID: 00:1f.5 chip ID: 8086:2485
  class ID: 0401
  Sound Server: ALSA v: k5.10.0-26-686-pae
Network:
  Message: No Device data found.
  Device-1: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
  driver: r8188eu bus ID: 1-1:2 chip ID: 0bda:8179 class ID: 0000
  serial: 00E04C0001
  IF: wlxd03745d7d837 state: up mac: d0:37:45:d7:d8:37
Bluetooth:
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
  driver: btusb v: 0.8 bus ID: 2-2.1.3:4 chip ID: 0a12:0001 class ID: e001
  Report: ID: hci0 state: up running pscan bt-v: 2.1 lmp-v: 4.0 sub-v: 22bb
  hci-v: 4.0 rev: 22bb address: 00:1A:7D:DA:71:13
Drives:
  Local Storage: total: 149.06 GiB used: 69.9 GiB (46.9%)
  ID-1: /dev/sda model: BT58SSD07N size: 119.24 GiB speed: <unknown>
  rotation: SSD serial: BN28042700018 rev: 254P temp: 40 C scheme: MBR
  ID-2: /dev/sdb model: SDCFXPS-032G size: 29.82 GiB speed: <unknown>
  serial: PAZ101416185326 rev: 1.05 scheme: MBR
Partition:
  ID-1: / size: 66.67 GiB used: 55.7 GiB (83.5%) fs: ext4 dev: /dev/sda5
Swap:
  ID-1: swap-1 type: partition size: 975 MiB used: 403 MiB (41.3%)
  priority: -2 dev: /dev/sda6
Sensors:
  Message: No sensors data was found. Is sensors configured?
Info:
  Processes: 172 Uptime: 6h 31m wakeups: 1 Memory: 991 MiB
  used: 538.7 MiB (54.4%) Init: systemd v: 247 runlevel: 5
  target: graphical.target Compilers: gcc: 10.2.1 alt: 10 Packages:
  apt: 2538 Shell: Bash (sudo) v: 5.1.4 running in: konsole inxi: 3.3.01
#4 2023-10-29 09:07
Mixed sources will nearly always give you a headache, changing deb-multimedia source to bullseye would be a start, you should then have the packages you need and be able to upgrade.
#5 2023-10-29 12:15
@Toshiba3000
We have received the debug info via e-mail. As mentioned, we would also recommend to change the Apt source:
from "buster" to "bullseye" and run:
$ sudo apt update
#6 2023-11-07 23:55
Toshiba3000
I used nano to edit and Kate to identify the name of the folder where the source is (multimedia.list):
$ nano /etc/apt/sources.list.d/multimedia.list
Once there, I did what your last post suggested. Everything now works fine.
Thanks a lot. Solved.
