#1 2022-03-07 04:04
gilbertoav
Post-install problem - libfreehand-0.1-1 - error 80 - desktop profiler
USB Install
Trinity Desktop
Tried The full profile and the basic profile, both with error 80
After suscessfully installed Q4OS 4 on my old notebook I can´t complete the install of the desktop profiler. I am getting inconsistency in the libfreehand-0.1-1 and as of consequence the system cannot install libreoffice and some of the apps, therefore not completing the profile configuration.
The print and the report generated by the system can be found in the link bellow.
1drv.ms/u/s!AtnCYxa_3ld7nhuCp6CIQTzfd5Vl?e=Rl5bQy
Thanks for your help.
#2 2022-03-07 11:39
Re: Post-install problem - libfreehand-0.1-1 - error 80 - desktop profiler
Please run in terminal:
$ sudo apt-get install -f
$ sudo apt-get check
$ sudo dpkg --audit
and post back the result. If all the commands pass well run desktop profiler once again and attach "reportq4" debug file as described here https://www.q4os.org/forum/viewtopic.php?id=3502
