#1 2021-08-05 14:29
Jovin
Cannot Access BIOS after install
Hi All
I recently installed Q4OS on an old Toshiba laptop and have discovered that I can no longer access the BIOS or boot device menu. Any key presses at power on are not recognized (usually F2 but I have tried all Fn keys and del) and the machine goes straight to Q4OS start up. I have also tried with no HDD installed just USB boot key and no boot media at all but without the HDD I just get a blinking cursor and no response to any key press.
Any ideas on what has happened or solutions to regain at least a boot device option?
Many thanks
John
#2 2021-08-06 06:20
Re: Cannot Access BIOS after install
Option1 - Hold the f2 key down before you power up and keep it down until you get the BIOS prompt
Option2 - Do as above but holding the ESC key down before power up.
#3 2021-08-06 10:46
Jovin
Thanks for reply but already tried. :-(
Just results in continual beeping as in a stuck key. When holding F2 as well as beeping just get a blank screen then on release of key the O/S boots.
When holding Esc same blank screen and beeping then on release goes to GRUB menu with only option being normal boot or Q4OS recovery mode.
#4 2021-08-06 22:19
doge_guide
try pressing F2 repeatedly right when you boot up
always willing to help people besides karens <3
#5 2021-08-07 05:38
Please provide information about the make and model of Toshiba
I recall a machine - I think it was a Sony but it's a while back - where the BIOS was accessed by what turned out to be a boot menu that was loaded at Windows start rather than from system boot - or something like that. Wiping the disk resulted in a different BIOS access screen.
On your machine it is possible that the actual BIOS access key sequence was disabled in the BIOS relying on a secondary disk based menu to get there.
#6 2021-08-07 22:06
doge_guide
@doge_guide the same problem happened to me and that was the fix
