#1 2018-05-14 21:04
Henrys cat
Q4os Boot Up Process Fails
I have Q4OS installed on a Windows 10 PC and used the Windows installer to install it.  I've been impressed with it and all was going fine until I tried to start Q4OS yesterday. The boot up process starts but just after the Ramdisc initialisation the process comes to a halt with these lines:-
Mount: mounting /dev/loop0 on/root failed: Invalid argument
Mount: Mounting/hoston/root/mnt/host failed: No such file or directory - this line is repeated four times
run-init: current directory on the same filesystem as the root: error 0
Target filesystem doesn't have request /sbin/init.
I've been using Q4OS to run Kodi which has been very stable and has worked perfectly unlike the Windows version.  I may have corrupted the Q4OS installation as I inadvertently used the shutdown option in the Kodi 'Quit' menu which shuts down the PC very quickly instead of shutting down via the Q4OS shutdown process.  This has also coincided with some big updates to Windows 10 but I suspect the former as the cause.
I have tried replacing all the files in the Debian directory from my last Windows system image back-up but the problem still persists even with restored files from a back-up.  Are there files elsewhere that I'm not aware of that need restoring?
If all else fails I could re-install Q4OS.  If I did that would I be able to use my existing root.disk file or the one from my last back-up to avoid having to set everything again?
#2 2018-05-14 21:18
Re: Q4os Boot Up Process Fails
We would recommend you to do the following:
- Backup the "root.disk" file.
- Uninstall Q4OS. Just launch the "q4os-winsetup.exe" installer and the Q4OS uninstall wizard starts.
- Perform new Q4OS installation, run "q4os-winsetup.exe" again and follow this guide https://www.q4os.org/dqa014.html.
- Replace the "root.disk" file with the backed up one.
- Q4OS should boot now, if the system structure within the "root.disk" file is not corrupted.
#3 2018-05-15 07:23
Henrys cat
Thanks for the reply.  Will give it a try and let you know if it works.
#4 2018-05-22 08:08
Henrys cat
I've tried out what you have recommended but the installation still refuses to run giving the same error messages as in my original post.  I get the dual boot screen but Q4OS doesn't get any further than the error messages.  It's not my root.disk file that's causing the problem as the one that is installed by Q4OS does not work either.  I'll stick to using Q4OS on my old Toshiba laptop PC for the moment which works well running from a Compact Flash card in the PCMIA socket.  Below is the wubi-2.4-rev325.log.  Does it give any clues as to what the problem is?
05-14 12:27 INFO   root: === wubi 2.4 rev325 ===
05-14 12:27 DEBUG  root: Logfile is c:\users\pc\appdata\local\temp\wubi-2.4-rev325.log
05-14 12:27 DEBUG  root: sys.argv = ['main.pyo', '--exefile="C:\\Users\\Simon\\Downloads\\q4os-winsetup.exe"']
05-14 12:27 DEBUG  CommonBackend: data_dir=C:\Users\pc\AppData\Local\Temp\pylF105.tmp\data
05-14 12:27 DEBUG  WindowsBackend: 7z=C:\Users\pc\AppData\Local\Temp\pylF105.tmp\bin\7z.exe
05-14 12:27 DEBUG  WindowsBackend: startup_folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
05-14 12:27 DEBUG  CommonBackend: Fetching basic info...
05-14 12:27 DEBUG  CommonBackend: original_exe=C:\Users\Simon\Downloads\q4os-winsetup.exe
05-14 12:27 DEBUG  CommonBackend: platform=win32
05-14 12:27 DEBUG  CommonBackend: osname=nt
05-14 12:27 DEBUG  CommonBackend: language=en_GB
05-14 12:27 DEBUG  CommonBackend: encoding=cp1252
05-14 12:27 DEBUG  WindowsBackend: arch=amd64
05-14 12:27 DEBUG  CommonBackend: Parsing isolist=C:\Users\pc\AppData\Local\Temp\pylF105.tmp\data\isolist.ini
05-14 12:27 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-i386
05-14 12:27 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-amd64
05-14 12:27 DEBUG  WindowsBackend: Fetching host info...
05-14 12:27 DEBUG  WindowsBackend: registry_key=Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi
05-14 12:27 DEBUG  WindowsBackend: windows version=vista
05-14 12:27 DEBUG  WindowsBackend: windows_version2=Windows 10 Enterprise
05-14 12:27 DEBUG  WindowsBackend: windows_sp=None
05-14 12:27 DEBUG  WindowsBackend: windows_build=17134
05-14 12:27 DEBUG  WindowsBackend: gmt=0
05-14 12:27 DEBUG  WindowsBackend: country=GB
05-14 12:27 DEBUG  WindowsBackend: timezone=Europe/London
05-14 12:27 DEBUG  WindowsBackend: windows_username=pc
05-14 12:27 DEBUG  WindowsBackend: user_full_name=pc
05-14 12:27 DEBUG  WindowsBackend: user_directory=
05-14 12:27 DEBUG  WindowsBackend: windows_language_code=1033
05-14 12:27 DEBUG  WindowsBackend: windows_language=English
05-14 12:27 DEBUG  WindowsBackend: processor_name=Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
05-14 12:27 DEBUG  WindowsBackend: bootloader=vista
05-14 12:27 DEBUG  WindowsBackend: system_drive=Drive(C: hd 24010.6484375 mb free ntfs)
05-14 12:27 DEBUG  WindowsBackend: drive=Drive(C: hd 24010.6484375 mb free ntfs)
05-14 12:27 DEBUG  WindowsBackend: drive=Drive(D: cd 0.0 mb free )
05-14 12:27 DEBUG  WindowsBackend: drive=Drive(E: hd 1197236.75 mb free ntfs)
05-14 12:27 DEBUG  WindowsBackend: drive=Drive(F: hd 333380.523438 mb free ntfs)
05-14 12:27 DEBUG  WindowsBackend: drive=Drive(G: hd 2082.359375 mb free ntfs)
05-14 12:27 DEBUG  WindowsBackend: EFI boot = False
05-14 12:27 DEBUG  WindowsBackend: uninstaller_path=E:\debian\uninstall-wubi.exe
05-14 12:27 DEBUG  WindowsBackend: previous_target_dir=E:\debian
05-14 12:27 DEBUG  WindowsBackend: previous_distro_name=Q4OS Scorpion
05-14 12:27 DEBUG  WindowsBackend: keyboard_id=134809609
05-14 12:27 DEBUG  WindowsBackend: keyboard_layout=gb
05-14 12:27 DEBUG  WindowsBackend: keyboard_variant=
05-14 12:27 DEBUG  CommonBackend: python locale=('en_GB', 'cp1252')
05-14 12:27 DEBUG  CommonBackend: locale=en_GB.UTF-8
05-14 12:27 DEBUG  WindowsBackend: total_memory_mb=2047.99999905
05-14 12:27 DEBUG  CommonBackend: Searching for local ISOs
05-14 12:27 DEBUG  Distro:   checking Q4OS Scorpion ISO C:\Users\Simon\Downloads\5cj977a.iso
05-14 12:27 ERROR  WindowsBackend: Error executing command
>>command=C:\Users\pc\AppData\Local\Temp\pylF105.tmp\bin\7z.exe l C:\Users\Simon\Downloads\5cj977a.iso
>>retval=2
>>stderr=
7-Zip 9.20  Copyright (c) 1999-2010 Igor Pavlov  2010-11-18
Error: C:\Users\Simon\Downloads\5cj977a.iso: Can not open file as archive
Errors: 1
>>stdout=
Traceback (most recent call last):
  File "\lib\wubi\backends\win32\backend.py", line 542, in get_iso_file_names
  File "\lib\wubi\backends\common\utils.py", line 68, in run_command
Exception: Error executing command
>>retval=2
>>stderr=
Errors: 1
>>stdout=
05-14 12:27 DEBUG  WindowsBackend: command >>C:\Users\pc\AppData\Local\Temp\pylF105.tmp\bin\7z.exe l C:\Users\Simon\Downloads\5cj977a.iso
05-14 12:27 DEBUG  Distro:     does not contain any file
05-14 12:27 DEBUG  CommonBackend: Searching for local CDs
05-14 12:27 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pylF105.tmp is a valid Q4OS Scorpion CD
05-14 12:27 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pylF105.tmp\install.386\install.bat
05-14 12:27 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pylF105.tmp\install.amd\install.bat
05-14 12:27 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-14 12:27 DEBUG  Distro:     dir does not exist
05-14 12:27 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-14 12:27 DEBUG  Distro:     does not contain E:\install.386\install.bat
05-14 12:27 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-14 12:27 DEBUG  Distro:   checking whether F:\ is a valid Q4OS Scorpion CD
05-14 12:27 DEBUG  Distro:     does not contain F:\install.386\install.bat
05-14 12:27 DEBUG  Distro:     does not contain F:\install.amd\install.bat
05-14 12:27 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-14 12:27 DEBUG  Distro:     does not contain G:\install.386\install.bat
05-14 12:27 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-14 12:27 INFO   root: Already installed, running the uninstaller...
05-14 12:27 INFO   root: Running the uninstaller...
05-14 12:27 INFO   CommonBackend: This is the uninstaller running
05-14 12:27 DEBUG  WindowsFrontend: __init__...
05-14 12:27 DEBUG  WindowsFrontend: on_init...
05-14 12:27 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pylF105.tmp\translations, languages=['en_GB', 'en']
05-14 12:27 INFO   WindowsFrontend: Operation cancelled
05-14 12:27 DEBUG  WindowsFrontend: frontend.quit
05-14 12:27 DEBUG  WindowsFrontend: frontend.on_quit
05-14 12:27 DEBUG  root: application.on_quit
05-14 12:27 INFO   root: sys.exit
05-15 19:08 INFO   root: === wubi 2.4 rev325 ===
05-15 19:08 DEBUG  root: Logfile is c:\users\pc\appdata\local\temp\wubi-2.4-rev325.log
05-15 19:08 DEBUG  root: sys.argv = ['main.pyo', '--exefile="C:\\Users\\Simon\\Downloads\\q4os-winsetup.exe"']
05-15 19:08 DEBUG  CommonBackend: data_dir=C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\data
05-15 19:08 DEBUG  WindowsBackend: 7z=C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\bin\7z.exe
05-15 19:08 DEBUG  WindowsBackend: startup_folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
05-15 19:08 DEBUG  CommonBackend: Fetching basic info...
05-15 19:08 DEBUG  CommonBackend: original_exe=C:\Users\Simon\Downloads\q4os-winsetup.exe
05-15 19:08 DEBUG  CommonBackend: platform=win32
05-15 19:08 DEBUG  CommonBackend: osname=nt
05-15 19:08 DEBUG  CommonBackend: language=en_GB
05-15 19:08 DEBUG  CommonBackend: encoding=cp1252
05-15 19:08 DEBUG  WindowsBackend: arch=amd64
05-15 19:08 DEBUG  CommonBackend: Parsing isolist=C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\data\isolist.ini
05-15 19:08 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-i386
05-15 19:08 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-amd64
05-15 19:08 DEBUG  WindowsBackend: Fetching host info...
05-15 19:08 DEBUG  WindowsBackend: registry_key=Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi
05-15 19:08 DEBUG  WindowsBackend: windows version=vista
05-15 19:08 DEBUG  WindowsBackend: windows_version2=Windows 10 Enterprise
05-15 19:08 DEBUG  WindowsBackend: windows_sp=None
05-15 19:08 DEBUG  WindowsBackend: windows_build=17134
05-15 19:08 DEBUG  WindowsBackend: gmt=0
05-15 19:08 DEBUG  WindowsBackend: country=GB
05-15 19:08 DEBUG  WindowsBackend: timezone=Europe/London
05-15 19:08 DEBUG  WindowsBackend: windows_username=pc
05-15 19:08 DEBUG  WindowsBackend: user_full_name=pc
05-15 19:08 DEBUG  WindowsBackend: user_directory=
05-15 19:08 DEBUG  WindowsBackend: windows_language_code=1033
05-15 19:08 DEBUG  WindowsBackend: windows_language=English
05-15 19:08 DEBUG  WindowsBackend: processor_name=Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
05-15 19:08 DEBUG  WindowsBackend: bootloader=vista
05-15 19:08 DEBUG  WindowsBackend: system_drive=Drive(C: hd 23972.3828125 mb free ntfs)
05-15 19:08 DEBUG  WindowsBackend: drive=Drive(C: hd 23972.3828125 mb free ntfs)
05-15 19:08 DEBUG  WindowsBackend: drive=Drive(D: cd 0.0 mb free )
05-15 19:08 DEBUG  WindowsBackend: drive=Drive(E: hd 1197236.75 mb free ntfs)
05-15 19:08 DEBUG  WindowsBackend: drive=Drive(G: hd 2082.359375 mb free ntfs)
05-15 19:08 DEBUG  WindowsBackend: EFI boot = False
05-15 19:08 DEBUG  WindowsBackend: uninstaller_path=E:\debian\uninstall-wubi.exe
05-15 19:08 DEBUG  WindowsBackend: previous_target_dir=E:\debian
05-15 19:08 DEBUG  WindowsBackend: previous_distro_name=Q4OS Scorpion
05-15 19:08 DEBUG  WindowsBackend: keyboard_id=134809609
05-15 19:08 DEBUG  WindowsBackend: keyboard_layout=gb
05-15 19:08 DEBUG  WindowsBackend: keyboard_variant=
05-15 19:08 DEBUG  CommonBackend: python locale=('en_GB', 'cp1252')
05-15 19:08 DEBUG  CommonBackend: locale=en_GB.UTF-8
05-15 19:08 DEBUG  WindowsBackend: total_memory_mb=2047.99999905
05-15 19:08 DEBUG  CommonBackend: Searching for local ISOs
05-15 19:08 DEBUG  Distro:   checking Q4OS Scorpion ISO C:\Users\Simon\Downloads\5cj977a.iso
05-15 19:08 ERROR  WindowsBackend: Error executing command
>>command=C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\bin\7z.exe l C:\Users\Simon\Downloads\5cj977a.iso
>>retval=2
>>stderr=
Errors: 1
>>stdout=
>>retval=2
>>stderr=
Errors: 1
>>stdout=
05-15 19:08 DEBUG  WindowsBackend: command >>C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\bin\7z.exe l C:\Users\Simon\Downloads\5cj977a.iso
05-15 19:08 DEBUG  Distro:     does not contain any file
05-15 19:08 DEBUG  CommonBackend: Searching for local CDs
05-15 19:08 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp is a valid Q4OS Scorpion CD
05-15 19:08 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\install.386\install.bat
05-15 19:08 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\install.amd\install.bat
05-15 19:08 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-15 19:08 DEBUG  Distro:     dir does not exist
05-15 19:08 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-15 19:08 DEBUG  Distro:     does not contain E:\install.386\install.bat
05-15 19:08 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-15 19:08 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-15 19:08 DEBUG  Distro:     does not contain G:\install.386\install.bat
05-15 19:08 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-15 19:08 INFO   root: Already installed, running the uninstaller...
05-15 19:08 INFO   root: Running the uninstaller...
05-15 19:08 INFO   CommonBackend: This is the uninstaller running
05-15 19:08 DEBUG  WindowsFrontend: __init__...
05-15 19:08 DEBUG  WindowsFrontend: on_init...
05-15 19:08 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\translations, languages=['en_GB', 'en']
05-15 19:09 INFO   root: Received settings
05-15 19:09 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\translations, languages=['en_GB', 'en']
05-15 19:09 DEBUG  TaskList: # Running tasklist...
05-15 19:09 DEBUG  TaskList: ## Running Remove bootloader entry....
05-15 19:09 DEBUG  WindowsBackend: Removing bcd entry {a4f2141e-39e0-11e8-afce-001583741eb9}
05-15 19:09 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi VistaBootDrive
05-15 19:09 DEBUG  WindowsBackend: undo_bootini C:
05-15 19:09 DEBUG  WindowsBackend: undo_configsys Drive(C: hd 23972.3828125 mb free ntfs)
05-15 19:09 DEBUG  WindowsBackend: undo_bootini E:
05-15 19:09 DEBUG  WindowsBackend: undo_configsys Drive(E: hd 1197236.75 mb free ntfs)
05-15 19:09 DEBUG  WindowsBackend: undo_bootini G:
05-15 19:09 DEBUG  WindowsBackend: undo_configsys Drive(G: hd 2082.359375 mb free ntfs)
05-15 19:09 DEBUG  TaskList: ## Finished Remove bootloader entry.
05-15 19:09 DEBUG  TaskList: ## Running Remove target dir....
05-15 19:09 DEBUG  CommonBackend: Deleting E:\debian
05-15 19:09 DEBUG  TaskList: ## Finished Remove target dir.
05-15 19:09 DEBUG  TaskList: ## Running Remove registry key....
05-15 19:09 DEBUG  TaskList: ## Finished Remove registry key.
05-15 19:09 DEBUG  TaskList: # Finished tasklist
05-15 19:09 INFO   root: Almost finished uninstalling
05-15 19:09 INFO   root: Finished uninstallation
05-15 19:09 DEBUG  CommonBackend: Fetching basic info...
05-15 19:09 DEBUG  CommonBackend: original_exe=C:\Users\Simon\Downloads\q4os-winsetup.exe
05-15 19:09 DEBUG  CommonBackend: platform=win32
05-15 19:09 DEBUG  CommonBackend: osname=nt
05-15 19:09 DEBUG  WindowsBackend: arch=amd64
05-15 19:09 DEBUG  CommonBackend: Parsing isolist=C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\data\isolist.ini
05-15 19:09 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-i386
05-15 19:09 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-amd64
05-15 19:09 DEBUG  WindowsBackend: Fetching host info...
05-15 19:09 DEBUG  WindowsBackend: registry_key=Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi
05-15 19:09 DEBUG  WindowsBackend: windows version=vista
05-15 19:09 DEBUG  WindowsBackend: windows_version2=Windows 10 Enterprise
05-15 19:09 DEBUG  WindowsBackend: windows_sp=None
05-15 19:09 DEBUG  WindowsBackend: windows_build=17134
05-15 19:09 DEBUG  WindowsBackend: gmt=0
05-15 19:09 DEBUG  WindowsBackend: country=GB
05-15 19:09 DEBUG  WindowsBackend: timezone=Europe/London
05-15 19:09 DEBUG  WindowsBackend: windows_username=pc
05-15 19:09 DEBUG  WindowsBackend: user_full_name=pc
05-15 19:09 DEBUG  WindowsBackend: user_directory=
05-15 19:09 DEBUG  WindowsBackend: windows_language_code=1033
05-15 19:09 DEBUG  WindowsBackend: windows_language=English
05-15 19:09 DEBUG  WindowsBackend: processor_name=Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
05-15 19:09 DEBUG  WindowsBackend: bootloader=vista
05-15 19:09 DEBUG  WindowsBackend: system_drive=Drive(C: hd 23968.375 mb free ntfs)
05-15 19:09 DEBUG  WindowsBackend: drive=Drive(C: hd 23968.375 mb free ntfs)
05-15 19:09 DEBUG  WindowsBackend: drive=Drive(D: cd 0.0 mb free )
05-15 19:09 DEBUG  WindowsBackend: drive=Drive(E: hd 1229247.75 mb free ntfs)
05-15 19:09 DEBUG  WindowsBackend: drive=Drive(G: hd 2082.359375 mb free ntfs)
05-15 19:09 DEBUG  WindowsBackend: EFI boot = False
05-15 19:09 DEBUG  WindowsBackend: uninstaller_path=None
05-15 19:09 DEBUG  WindowsBackend: previous_target_dir=None
05-15 19:09 DEBUG  WindowsBackend: previous_distro_name=None
05-15 19:09 DEBUG  WindowsBackend: keyboard_id=134809609
05-15 19:09 DEBUG  WindowsBackend: keyboard_layout=gb
05-15 19:09 DEBUG  WindowsBackend: keyboard_variant=
05-15 19:09 DEBUG  WindowsBackend: total_memory_mb=2047.99999905
05-15 19:09 DEBUG  CommonBackend: Searching for local ISOs
05-15 19:09 DEBUG  Distro:   checking Q4OS Scorpion ISO C:\Users\Simon\Downloads\5cj977a.iso
05-15 19:09 DEBUG  Distro:     does not contain any file
05-15 19:09 DEBUG  CommonBackend: Searching for local CDs
05-15 19:09 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp is a valid Q4OS Scorpion CD
05-15 19:09 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\install.386\install.bat
05-15 19:09 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\install.amd\install.bat
05-15 19:09 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-15 19:09 DEBUG  Distro:     dir does not exist
05-15 19:09 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-15 19:09 DEBUG  Distro:     does not contain E:\install.386\install.bat
05-15 19:09 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-15 19:09 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-15 19:09 DEBUG  Distro:     does not contain G:\install.386\install.bat
05-15 19:09 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-15 19:09 INFO   root: Running the installer...
05-15 19:10 DEBUG  WinuiInstallationPage: target_drive=E:, installation_size=32000MB, distro_name=Q4OS Scorpion, language=en_GB, locale=en_GB.UTF-8, username=simon
05-15 19:10 INFO   root: Received settings
05-15 19:10 DEBUG  CommonBackend: Searching for local CD
05-15 19:10 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp is a valid Q4OS Scorpion CD
05-15 19:10 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\install.amd\install.bat
05-15 19:10 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-15 19:10 DEBUG  Distro:     dir does not exist
05-15 19:10 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-15 19:10 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-15 19:10 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-15 19:10 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-15 19:10 DEBUG  CommonBackend: Searching for local ISO
05-15 19:10 DEBUG  Distro:   checking Q4OS Scorpion ISO C:\Users\Simon\Downloads\5cj977a.iso
05-15 19:10 DEBUG  Distro:     does not contain any file
05-15 19:10 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pyl8C94.tmp\translations, languages=['en_GB', 'en']
05-15 19:10 DEBUG  TaskList: # Running tasklist...
05-15 19:10 DEBUG  TaskList: ## Running select_target_dir...
05-15 19:10 ERROR  TaskList: Cannot install into E:\debian.
There is another file or directory with this name.
Please remove it before continuing.
  File "\lib\wubi\backends\common\tasklist.py", line 197, in __call__
  File "\lib\wubi\backends\win32\backend.py", line 83, in select_target_dir
Exception: Cannot install into E:\debian.
05-15 19:10 DEBUG  TaskList: # Cancelling tasklist
05-15 19:10 DEBUG  TaskList: # Finished tasklist
05-15 19:10 ERROR  root: Cannot install into E:\debian.
  File "\lib\wubi\application.py", line 58, in run
  File "\lib\wubi\application.py", line 132, in select_task
  File "\lib\wubi\application.py", line 158, in run_installer
05-15 19:11 INFO   root: === wubi 2.4 rev325 ===
05-15 19:11 DEBUG  root: Logfile is c:\users\pc\appdata\local\temp\wubi-2.4-rev325.log
05-15 19:11 DEBUG  root: sys.argv = ['main.pyo', '--exefile="C:\\Users\\Simon\\Downloads\\q4os-winsetup.exe"']
05-15 19:11 DEBUG  CommonBackend: data_dir=C:\Users\pc\AppData\Local\Temp\pylCA5F.tmp\data
05-15 19:11 DEBUG  WindowsBackend: 7z=C:\Users\pc\AppData\Local\Temp\pylCA5F.tmp\bin\7z.exe
05-15 19:11 DEBUG  WindowsBackend: startup_folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
05-15 19:11 DEBUG  CommonBackend: Fetching basic info...
05-15 19:11 DEBUG  CommonBackend: original_exe=C:\Users\Simon\Downloads\q4os-winsetup.exe
05-15 19:11 DEBUG  CommonBackend: platform=win32
05-15 19:11 DEBUG  CommonBackend: osname=nt
05-15 19:11 DEBUG  CommonBackend: language=en_GB
05-15 19:11 DEBUG  CommonBackend: encoding=cp1252
05-15 19:11 DEBUG  WindowsBackend: arch=amd64
05-15 19:11 DEBUG  CommonBackend: Parsing isolist=C:\Users\pc\AppData\Local\Temp\pylCA5F.tmp\data\isolist.ini
05-15 19:11 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-i386
05-15 19:11 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-amd64
05-15 19:11 DEBUG  WindowsBackend: Fetching host info...
05-15 19:11 DEBUG  WindowsBackend: registry_key=Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi
05-15 19:11 DEBUG  WindowsBackend: windows version=vista
05-15 19:11 DEBUG  WindowsBackend: windows_version2=Windows 10 Enterprise
05-15 19:11 DEBUG  WindowsBackend: windows_sp=None
05-15 19:11 DEBUG  WindowsBackend: windows_build=17134
05-15 19:11 DEBUG  WindowsBackend: gmt=0
05-15 19:11 DEBUG  WindowsBackend: country=GB
05-15 19:11 DEBUG  WindowsBackend: timezone=Europe/London
05-15 19:11 DEBUG  WindowsBackend: windows_username=pc
05-15 19:11 DEBUG  WindowsBackend: user_full_name=pc
05-15 19:11 DEBUG  WindowsBackend: user_directory=
05-15 19:11 DEBUG  WindowsBackend: windows_language_code=1033
05-15 19:11 DEBUG  WindowsBackend: windows_language=English
05-15 19:11 DEBUG  WindowsBackend: processor_name=Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
05-15 19:11 DEBUG  WindowsBackend: bootloader=vista
05-15 19:11 DEBUG  WindowsBackend: system_drive=Drive(C: hd 23631.3710938 mb free ntfs)
05-15 19:11 DEBUG  WindowsBackend: drive=Drive(C: hd 23631.3710938 mb free ntfs)
05-15 19:11 DEBUG  WindowsBackend: drive=Drive(D: cd 0.0 mb free )
05-15 19:11 DEBUG  WindowsBackend: drive=Drive(E: hd 1229247.75 mb free ntfs)
05-15 19:11 DEBUG  WindowsBackend: drive=Drive(G: hd 2082.359375 mb free ntfs)
05-15 19:11 DEBUG  WindowsBackend: EFI boot = False
05-15 19:11 DEBUG  WindowsBackend: uninstaller_path=None
05-15 19:11 DEBUG  WindowsBackend: previous_target_dir=None
05-15 19:11 DEBUG  WindowsBackend: previous_distro_name=None
05-15 19:11 DEBUG  WindowsBackend: keyboard_id=134809609
05-15 19:11 DEBUG  WindowsBackend: keyboard_layout=gb
05-15 19:11 DEBUG  WindowsBackend: keyboard_variant=
05-15 19:11 DEBUG  CommonBackend: python locale=('en_GB', 'cp1252')
05-15 19:11 DEBUG  CommonBackend: locale=en_GB.UTF-8
05-15 19:11 DEBUG  WindowsBackend: total_memory_mb=2047.99999905
05-15 19:11 DEBUG  CommonBackend: Searching for local ISOs
05-15 19:11 DEBUG  Distro:   checking Q4OS Scorpion ISO C:\Users\Simon\Downloads\5cj977a.iso
05-15 19:11 ERROR  WindowsBackend: Error executing command
>>command=C:\Users\pc\AppData\Local\Temp\pylCA5F.tmp\bin\7z.exe l C:\Users\Simon\Downloads\5cj977a.iso
>>retval=2
>>stderr=
Errors: 1
>>stdout=
>>retval=2
>>stderr=
Errors: 1
>>stdout=
05-15 19:11 DEBUG  WindowsBackend: command >>C:\Users\pc\AppData\Local\Temp\pylCA5F.tmp\bin\7z.exe l C:\Users\Simon\Downloads\5cj977a.iso
05-15 19:11 DEBUG  Distro:     does not contain any file
05-15 19:11 DEBUG  CommonBackend: Searching for local CDs
05-15 19:11 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pylCA5F.tmp is a valid Q4OS Scorpion CD
05-15 19:11 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pylCA5F.tmp\install.386\install.bat
05-15 19:11 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pylCA5F.tmp\install.amd\install.bat
05-15 19:11 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-15 19:11 DEBUG  Distro:     dir does not exist
05-15 19:11 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-15 19:11 DEBUG  Distro:     does not contain E:\install.386\install.bat
05-15 19:11 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-15 19:11 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-15 19:11 DEBUG  Distro:     does not contain G:\install.386\install.bat
05-15 19:11 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-15 19:11 INFO   root: Running the installer...
05-15 19:11 DEBUG  WindowsFrontend: __init__...
05-15 19:11 DEBUG  WindowsFrontend: on_init...
05-15 19:11 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pylCA5F.tmp\translations, languages=['en_GB', 'en']
05-15 19:11 DEBUG  WinuiInstallationPage: target_drive=E:, installation_size=32000MB, distro_name=Q4OS Scorpion, language=en_GB, locale=en_GB.UTF-8, username=simon
05-15 19:11 INFO   root: Received settings
05-15 19:11 DEBUG  TaskList: # Running tasklist...
05-15 19:11 DEBUG  TaskList: ## Running select_target_dir...
05-15 19:11 INFO   WindowsBackend: Installing into E:\debian
05-15 19:11 DEBUG  TaskList: ## Finished select_target_dir
05-15 19:11 DEBUG  TaskList: ## Running create_dir_structure...
05-15 19:11 DEBUG  CommonBackend: Creating dir E:\debian
05-15 19:11 DEBUG  CommonBackend: Creating dir E:\debian\disks
05-15 19:11 DEBUG  CommonBackend: Creating dir E:\debian\install
05-15 19:11 DEBUG  CommonBackend: Creating dir E:\debian\install\boot
05-15 19:11 DEBUG  CommonBackend: Creating dir E:\debian\disks\boot
05-15 19:11 DEBUG  CommonBackend: Creating dir E:\debian\disks\boot\grub
05-15 19:11 DEBUG  CommonBackend: Creating dir E:\debian\install\boot\grub
05-15 19:11 DEBUG  TaskList: ## Finished create_dir_structure
05-15 19:11 DEBUG  TaskList: ## Running create_uninstaller...
05-15 19:11 DEBUG  WindowsBackend: Copying uninstaller C:\Users\Simon\Downloads\q4os-winsetup.exe -> E:\debian\uninstall-wubi.exe
05-15 19:11 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi UninstallString E:\debian\uninstall-wubi.exe
05-15 19:11 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi InstallationDir E:\debian
05-15 19:11 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi DisplayName Q4OS Scorpion
05-15 19:11 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi DisplayIcon E:\debian\Q4OS Scorpion.ico
05-15 19:11 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi DisplayVersion 2.4-rev325
05-15 19:11 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi Publisher Q4OS Scorpion
05-15 19:11 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi URLInfoAbout https://q4os.org
05-15 19:11 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi HelpLink http://www.ubuntu.com/support
05-15 19:11 DEBUG  TaskList: ## Finished create_uninstaller
05-15 19:11 DEBUG  TaskList: ## Running create_preseed_diskimage...
05-15 19:11 DEBUG  TaskList: ## Finished create_preseed_diskimage
05-15 19:11 DEBUG  TaskList: ## Running get_diskimage...
05-15 19:11 DEBUG  TaskList: New task download
05-15 19:11 DEBUG  TaskList: ### Running download...
05-15 19:11 DEBUG  downloader: downloading https://sourceforge.net/projects/q4os/f … oop.img.xz > E:\debian\disks\q4os-2.4-x64-loop.img.xz
05-15 19:11 DEBUG  downloader: Download start filename=E:\debian\disks\q4os-2.4-x64-loop.img.xz, url=https://sourceforge.net/projects/q4os/files/stable/q4os-2.4-x64-loop.img.xz, basename=q4os-2.4-x64-loop.img.xz, length=382653804, text=None
05-15 19:18 DEBUG  downloader: download finished (read 23748608 bytes)
05-15 19:18 DEBUG  TaskList: ### Finished download
05-15 19:18 ERROR  TaskList: [Errno 4] Socket Error: [Errno 10054] An existing connection was forcibly closed by the remote host
  File "\lib\wubi\backends\common\downloader.py", line 77, in download
  File "\lib\urlgrabber\grabber.py", line 927, in urlgrab
  File "\lib\urlgrabber\grabber.py", line 845, in _retry
  File "\lib\urlgrabber\grabber.py", line 915, in retryfunc
  File "\lib\urlgrabber\grabber.py", line 1208, in _do_grab
  File "\lib\urlgrabber\grabber.py", line 1274, in read
  File "\lib\urlgrabber\grabber.py", line 1253, in _fill_buffer
URLGrabError: [Errno 4] Socket Error: [Errno 10054] An existing connection was forcibly closed by the remote host
05-15 19:18 ERROR  TaskList: Non fatal error [Errno 4] Socket Error: [Errno 10054] An existing connection was forcibly closed by the remote host in task download
05-15 19:18 ERROR  TaskList: [Error 32] The process cannot access the file because it is being used by another process: 'E:\\debian\\disks\\q4os-2.4-x64-loop.img.xz'
  File "\lib\wubi\backends\common\backend.py", line 600, in get_diskimage
  File "\lib\wubi\backends\common\backend.py", line 397, in download_diskimage
WindowsError: [Error 32] The process cannot access the file because it is being used by another process: 'E:\\debian\\disks\\q4os-2.4-x64-loop.img.xz'
05-15 19:18 DEBUG  TaskList: # Cancelling tasklist
05-15 19:18 DEBUG  TaskList: # Finished tasklist
05-15 19:18 ERROR  root: [Error 32] The process cannot access the file because it is being used by another process: 'E:\\debian\\disks\\q4os-2.4-x64-loop.img.xz'
05-15 19:24 INFO   root: === wubi 2.4 rev325 ===
05-15 19:24 DEBUG  root: Logfile is c:\users\pc\appdata\local\temp\wubi-2.4-rev325.log
05-15 19:24 DEBUG  root: sys.argv = ['main.pyo', '--exefile="E:\\debian\\uninstall-wubi.exe"']
05-15 19:24 DEBUG  CommonBackend: data_dir=C:\Users\pc\AppData\Local\Temp\pyl4C8F.tmp\data
05-15 19:24 DEBUG  WindowsBackend: 7z=C:\Users\pc\AppData\Local\Temp\pyl4C8F.tmp\bin\7z.exe
05-15 19:24 DEBUG  WindowsBackend: startup_folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
05-15 19:24 DEBUG  CommonBackend: Fetching basic info...
05-15 19:24 DEBUG  CommonBackend: original_exe=E:\debian\uninstall-wubi.exe
05-15 19:24 DEBUG  CommonBackend: platform=win32
05-15 19:24 DEBUG  CommonBackend: osname=nt
05-15 19:24 DEBUG  CommonBackend: language=en_GB
05-15 19:24 DEBUG  CommonBackend: encoding=cp1252
05-15 19:24 DEBUG  WindowsBackend: arch=amd64
05-15 19:24 DEBUG  CommonBackend: Parsing isolist=C:\Users\pc\AppData\Local\Temp\pyl4C8F.tmp\data\isolist.ini
05-15 19:24 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-i386
05-15 19:24 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-amd64
05-15 19:24 DEBUG  WindowsBackend: Fetching host info...
05-15 19:24 DEBUG  WindowsBackend: registry_key=Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi
05-15 19:24 DEBUG  WindowsBackend: windows version=vista
05-15 19:24 DEBUG  WindowsBackend: windows_version2=Windows 10 Enterprise
05-15 19:24 DEBUG  WindowsBackend: windows_sp=None
05-15 19:24 DEBUG  WindowsBackend: windows_build=17134
05-15 19:24 DEBUG  WindowsBackend: gmt=0
05-15 19:24 DEBUG  WindowsBackend: country=GB
05-15 19:24 DEBUG  WindowsBackend: timezone=Europe/London
05-15 19:24 DEBUG  WindowsBackend: windows_username=pc
05-15 19:24 DEBUG  WindowsBackend: user_full_name=pc
05-15 19:24 DEBUG  WindowsBackend: user_directory=C:\Users\pc
05-15 19:24 DEBUG  WindowsBackend: windows_language_code=1033
05-15 19:24 DEBUG  WindowsBackend: windows_language=English
05-15 19:24 DEBUG  WindowsBackend: processor_name=Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
05-15 19:24 DEBUG  WindowsBackend: bootloader=vista
05-15 19:24 DEBUG  WindowsBackend: system_drive=Drive(C: hd 23640.6757812 mb free ntfs)
05-15 19:24 DEBUG  WindowsBackend: drive=Drive(C: hd 23640.6757812 mb free ntfs)
05-15 19:24 DEBUG  WindowsBackend: drive=Drive(D: cd 0.0 mb free )
05-15 19:24 DEBUG  WindowsBackend: drive=Drive(E: hd 1229219.46875 mb free ntfs)
05-15 19:24 DEBUG  WindowsBackend: drive=Drive(G: hd 2082.359375 mb free ntfs)
05-15 19:24 DEBUG  WindowsBackend: EFI boot = False
05-15 19:24 DEBUG  WindowsBackend: uninstaller_path=E:\debian\uninstall-wubi.exe
05-15 19:24 DEBUG  WindowsBackend: previous_target_dir=E:\debian
05-15 19:24 DEBUG  WindowsBackend: previous_distro_name=Q4OS Scorpion
05-15 19:24 DEBUG  WindowsBackend: keyboard_id=134809609
05-15 19:24 DEBUG  WindowsBackend: keyboard_layout=gb
05-15 19:24 DEBUG  WindowsBackend: keyboard_variant=
05-15 19:24 DEBUG  CommonBackend: python locale=('en_GB', 'cp1252')
05-15 19:24 DEBUG  CommonBackend: locale=en_GB.UTF-8
05-15 19:24 DEBUG  WindowsBackend: total_memory_mb=2047.99999905
05-15 19:24 DEBUG  CommonBackend: Searching for local ISOs
05-15 19:24 DEBUG  CommonBackend: Searching for local CDs
05-15 19:24 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pyl4C8F.tmp is a valid Q4OS Scorpion CD
05-15 19:24 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl4C8F.tmp\install.386\install.bat
05-15 19:24 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl4C8F.tmp\install.amd\install.bat
05-15 19:24 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-15 19:24 DEBUG  Distro:     dir does not exist
05-15 19:24 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-15 19:24 DEBUG  Distro:     does not contain E:\install.386\install.bat
05-15 19:24 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-15 19:24 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-15 19:24 DEBUG  Distro:     does not contain G:\install.386\install.bat
05-15 19:24 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-15 19:24 INFO   root: Running the uninstaller...
05-15 19:24 INFO   CommonBackend: This is the uninstaller running
05-15 19:24 DEBUG  WindowsFrontend: __init__...
05-15 19:24 DEBUG  WindowsFrontend: on_init...
05-15 19:24 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pyl4C8F.tmp\translations, languages=['en_GB', 'en']
05-15 19:25 INFO   root: Received settings
05-15 19:25 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pyl4C8F.tmp\translations, languages=['en_GB', 'en']
05-15 19:25 DEBUG  TaskList: # Running tasklist...
05-15 19:25 DEBUG  TaskList: ## Running Remove bootloader entry....
05-15 19:25 DEBUG  WindowsBackend: Could not find bcd id
05-15 19:25 DEBUG  WindowsBackend: undo_bootini C:
05-15 19:25 DEBUG  WindowsBackend: undo_configsys Drive(C: hd 23640.6757812 mb free ntfs)
05-15 19:25 DEBUG  WindowsBackend: undo_bootini E:
05-15 19:25 DEBUG  WindowsBackend: undo_configsys Drive(E: hd 1229219.46875 mb free ntfs)
05-15 19:25 DEBUG  WindowsBackend: undo_bootini G:
05-15 19:25 DEBUG  WindowsBackend: undo_configsys Drive(G: hd 2082.359375 mb free ntfs)
05-15 19:25 DEBUG  TaskList: ## Finished Remove bootloader entry.
05-15 19:25 DEBUG  TaskList: ## Running Remove target dir....
05-15 19:25 DEBUG  CommonBackend: Deleting E:\debian
05-15 19:25 DEBUG  TaskList: ## Finished Remove target dir.
05-15 19:25 DEBUG  TaskList: ## Running Remove registry key....
05-15 19:25 DEBUG  TaskList: ## Finished Remove registry key.
05-15 19:25 DEBUG  TaskList: # Finished tasklist
05-15 19:25 INFO   root: Almost finished uninstalling
05-15 19:25 INFO   root: Finished uninstallation
05-15 19:25 DEBUG  root: application.quit
05-15 19:25 DEBUG  WindowsFrontend: frontend.quit
05-15 19:25 DEBUG  WindowsFrontend: frontend.on_quit
05-15 19:25 DEBUG  root: application.on_quit
05-15 19:25 INFO   root: sys.exit
05-15 19:26 INFO   root: === wubi 2.4 rev325 ===
05-15 19:26 DEBUG  root: Logfile is c:\users\pc\appdata\local\temp\wubi-2.4-rev325.log
05-15 19:26 DEBUG  root: sys.argv = ['main.pyo', '--exefile="C:\\Users\\Simon\\Downloads\\q4os-winsetup.exe"']
05-15 19:26 DEBUG  CommonBackend: data_dir=C:\Users\pc\AppData\Local\Temp\pyl3D5.tmp\data
05-15 19:26 DEBUG  WindowsBackend: 7z=C:\Users\pc\AppData\Local\Temp\pyl3D5.tmp\bin\7z.exe
05-15 19:26 DEBUG  WindowsBackend: startup_folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
05-15 19:26 DEBUG  CommonBackend: Fetching basic info...
05-15 19:26 DEBUG  CommonBackend: original_exe=C:\Users\Simon\Downloads\q4os-winsetup.exe
05-15 19:26 DEBUG  CommonBackend: platform=win32
05-15 19:26 DEBUG  CommonBackend: osname=nt
05-15 19:26 DEBUG  CommonBackend: language=en_GB
05-15 19:26 DEBUG  CommonBackend: encoding=cp1252
05-15 19:26 DEBUG  WindowsBackend: arch=amd64
05-15 19:26 DEBUG  CommonBackend: Parsing isolist=C:\Users\pc\AppData\Local\Temp\pyl3D5.tmp\data\isolist.ini
05-15 19:26 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-i386
05-15 19:26 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-amd64
05-15 19:26 DEBUG  WindowsBackend: Fetching host info...
05-15 19:26 DEBUG  WindowsBackend: registry_key=Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi
05-15 19:26 DEBUG  WindowsBackend: windows version=vista
05-15 19:26 DEBUG  WindowsBackend: windows_version2=Windows 10 Enterprise
05-15 19:26 DEBUG  WindowsBackend: windows_sp=None
05-15 19:26 DEBUG  WindowsBackend: windows_build=17134
05-15 19:26 DEBUG  WindowsBackend: gmt=0
05-15 19:26 DEBUG  WindowsBackend: country=GB
05-15 19:26 DEBUG  WindowsBackend: timezone=Europe/London
05-15 19:26 DEBUG  WindowsBackend: windows_username=pc
05-15 19:26 DEBUG  WindowsBackend: user_full_name=pc
05-15 19:26 DEBUG  WindowsBackend: user_directory=
05-15 19:26 DEBUG  WindowsBackend: windows_language_code=1033
05-15 19:26 DEBUG  WindowsBackend: windows_language=English
05-15 19:26 DEBUG  WindowsBackend: processor_name=Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
05-15 19:26 DEBUG  WindowsBackend: bootloader=vista
05-15 19:26 DEBUG  WindowsBackend: system_drive=Drive(C: hd 23646.3046875 mb free ntfs)
05-15 19:26 DEBUG  WindowsBackend: drive=Drive(C: hd 23646.3046875 mb free ntfs)
05-15 19:26 DEBUG  WindowsBackend: drive=Drive(D: cd 0.0 mb free )
05-15 19:26 DEBUG  WindowsBackend: drive=Drive(E: hd 1229247.75 mb free ntfs)
05-15 19:26 DEBUG  WindowsBackend: drive=Drive(G: hd 2082.359375 mb free ntfs)
05-15 19:26 DEBUG  WindowsBackend: EFI boot = False
05-15 19:26 DEBUG  WindowsBackend: uninstaller_path=None
05-15 19:26 DEBUG  WindowsBackend: previous_target_dir=None
05-15 19:26 DEBUG  WindowsBackend: previous_distro_name=None
05-15 19:26 DEBUG  WindowsBackend: keyboard_id=134809609
05-15 19:26 DEBUG  WindowsBackend: keyboard_layout=gb
05-15 19:26 DEBUG  WindowsBackend: keyboard_variant=
05-15 19:26 DEBUG  CommonBackend: python locale=('en_GB', 'cp1252')
05-15 19:26 DEBUG  CommonBackend: locale=en_GB.UTF-8
05-15 19:26 DEBUG  WindowsBackend: total_memory_mb=2047.99999905
05-15 19:26 DEBUG  CommonBackend: Searching for local ISOs
05-15 19:26 DEBUG  Distro:   checking Q4OS Scorpion ISO C:\Users\Simon\Downloads\5cj977a.iso
05-15 19:26 ERROR  WindowsBackend: Error executing command
>>command=C:\Users\pc\AppData\Local\Temp\pyl3D5.tmp\bin\7z.exe l C:\Users\Simon\Downloads\5cj977a.iso
>>retval=2
>>stderr=
Errors: 1
>>stdout=
>>retval=2
>>stderr=
Errors: 1
>>stdout=
05-15 19:26 DEBUG  WindowsBackend: command >>C:\Users\pc\AppData\Local\Temp\pyl3D5.tmp\bin\7z.exe l C:\Users\Simon\Downloads\5cj977a.iso
05-15 19:26 DEBUG  Distro:     does not contain any file
05-15 19:26 DEBUG  CommonBackend: Searching for local CDs
05-15 19:26 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pyl3D5.tmp is a valid Q4OS Scorpion CD
05-15 19:26 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl3D5.tmp\install.386\install.bat
05-15 19:26 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl3D5.tmp\install.amd\install.bat
05-15 19:26 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-15 19:26 DEBUG  Distro:     dir does not exist
05-15 19:26 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-15 19:26 DEBUG  Distro:     does not contain E:\install.386\install.bat
05-15 19:26 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-15 19:26 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-15 19:26 DEBUG  Distro:     does not contain G:\install.386\install.bat
05-15 19:26 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-15 19:26 INFO   root: Running the installer...
05-15 19:26 DEBUG  WindowsFrontend: __init__...
05-15 19:26 DEBUG  WindowsFrontend: on_init...
05-15 19:26 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pyl3D5.tmp\translations, languages=['en_GB', 'en']
05-15 19:27 DEBUG  WinuiInstallationPage: target_drive=E:, installation_size=32000MB, distro_name=Q4OS Scorpion, language=en_GB, locale=en_GB.UTF-8, username=simon
05-15 19:27 INFO   root: Received settings
05-15 19:27 DEBUG  CommonBackend: Searching for local CD
05-15 19:27 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pyl3D5.tmp is a valid Q4OS Scorpion CD
05-15 19:27 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl3D5.tmp\install.amd\install.bat
05-15 19:27 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-15 19:27 DEBUG  Distro:     dir does not exist
05-15 19:27 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-15 19:27 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-15 19:27 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-15 19:27 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-15 19:27 DEBUG  CommonBackend: Searching for local ISO
05-15 19:27 DEBUG  Distro:   checking Q4OS Scorpion ISO C:\Users\Simon\Downloads\5cj977a.iso
05-15 19:27 DEBUG  Distro:     does not contain any file
05-15 19:27 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pyl3D5.tmp\translations, languages=['en_GB', 'en']
05-15 19:27 DEBUG  TaskList: # Running tasklist...
05-15 19:27 DEBUG  TaskList: ## Running select_target_dir...
05-15 19:27 INFO   WindowsBackend: Installing into E:\debian
05-15 19:27 DEBUG  TaskList: ## Finished select_target_dir
05-15 19:27 DEBUG  TaskList: ## Running create_dir_structure...
05-15 19:27 DEBUG  CommonBackend: Creating dir E:\debian
05-15 19:27 DEBUG  CommonBackend: Creating dir E:\debian\disks
05-15 19:27 DEBUG  CommonBackend: Creating dir E:\debian\install
05-15 19:27 DEBUG  CommonBackend: Creating dir E:\debian\install\boot
05-15 19:27 DEBUG  CommonBackend: Creating dir E:\debian\disks\boot
05-15 19:27 DEBUG  CommonBackend: Creating dir E:\debian\disks\boot\grub
05-15 19:27 DEBUG  CommonBackend: Creating dir E:\debian\install\boot\grub
05-15 19:27 DEBUG  TaskList: ## Finished create_dir_structure
05-15 19:27 DEBUG  TaskList: ## Running create_uninstaller...
05-15 19:27 DEBUG  WindowsBackend: Copying uninstaller C:\Users\Simon\Downloads\q4os-winsetup.exe -> E:\debian\uninstall-wubi.exe
05-15 19:27 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi UninstallString E:\debian\uninstall-wubi.exe
05-15 19:27 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi InstallationDir E:\debian
05-15 19:27 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi DisplayName Q4OS Scorpion
05-15 19:27 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi DisplayIcon E:\debian\Q4OS Scorpion.ico
05-15 19:27 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi DisplayVersion 2.4-rev325
05-15 19:27 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi Publisher Q4OS Scorpion
05-15 19:27 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi URLInfoAbout https://q4os.org
05-15 19:27 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi HelpLink http://www.ubuntu.com/support
05-15 19:27 DEBUG  TaskList: ## Finished create_uninstaller
05-15 19:27 DEBUG  TaskList: ## Running create_preseed_diskimage...
05-15 19:27 DEBUG  TaskList: ## Finished create_preseed_diskimage
05-15 19:27 DEBUG  TaskList: ## Running get_diskimage...
05-15 19:27 DEBUG  TaskList: New task download
05-15 19:27 DEBUG  TaskList: ### Running download...
05-15 19:27 DEBUG  downloader: downloading https://sourceforge.net/projects/q4os/f … oop.img.xz > E:\debian\disks\q4os-2.4-x64-loop.img.xz
05-15 19:27 DEBUG  downloader: Download start filename=E:\debian\disks\q4os-2.4-x64-loop.img.xz, url=https://sourceforge.net/projects/q4os/files/stable/q4os-2.4-x64-loop.img.xz, basename=q4os-2.4-x64-loop.img.xz, length=382653804, text=None
05-15 19:36 DEBUG  downloader: download finished (read 52682752 bytes)
05-15 19:36 DEBUG  TaskList: ### Finished download
05-15 19:36 ERROR  TaskList: [Errno 4] Socket Error: [Errno 10054] An existing connection was forcibly closed by the remote host
05-15 19:36 ERROR  TaskList: Non fatal error [Errno 4] Socket Error: [Errno 10054] An existing connection was forcibly closed by the remote host in task download
05-15 19:36 ERROR  TaskList: [Error 32] The process cannot access the file because it is being used by another process: 'E:\\debian\\disks\\q4os-2.4-x64-loop.img.xz'
05-15 19:36 DEBUG  TaskList: # Cancelling tasklist
05-15 19:36 DEBUG  TaskList: # Finished tasklist
05-15 19:36 ERROR  root: [Error 32] The process cannot access the file because it is being used by another process: 'E:\\debian\\disks\\q4os-2.4-x64-loop.img.xz'
05-15 19:43 INFO   root: === wubi 2.4 rev325 ===
05-15 19:43 DEBUG  root: Logfile is c:\users\pc\appdata\local\temp\wubi-2.4-rev325.log
05-15 19:43 DEBUG  root: sys.argv = ['main.pyo', '--exefile="E:\\debian\\uninstall-wubi.exe"']
05-15 19:43 DEBUG  CommonBackend: data_dir=C:\Users\pc\AppData\Local\Temp\pyl82A1.tmp\data
05-15 19:43 DEBUG  WindowsBackend: 7z=C:\Users\pc\AppData\Local\Temp\pyl82A1.tmp\bin\7z.exe
05-15 19:43 DEBUG  WindowsBackend: startup_folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
05-15 19:43 DEBUG  CommonBackend: Fetching basic info...
05-15 19:43 DEBUG  CommonBackend: original_exe=E:\debian\uninstall-wubi.exe
05-15 19:43 DEBUG  CommonBackend: platform=win32
05-15 19:43 DEBUG  CommonBackend: osname=nt
05-15 19:43 DEBUG  CommonBackend: language=en_GB
05-15 19:43 DEBUG  CommonBackend: encoding=cp1252
05-15 19:43 DEBUG  WindowsBackend: arch=amd64
05-15 19:43 DEBUG  CommonBackend: Parsing isolist=C:\Users\pc\AppData\Local\Temp\pyl82A1.tmp\data\isolist.ini
05-15 19:43 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-i386
05-15 19:43 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-amd64
05-15 19:43 DEBUG  WindowsBackend: Fetching host info...
05-15 19:43 DEBUG  WindowsBackend: registry_key=Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi
05-15 19:43 DEBUG  WindowsBackend: windows version=vista
05-15 19:43 DEBUG  WindowsBackend: windows_version2=Windows 10 Enterprise
05-15 19:43 DEBUG  WindowsBackend: windows_sp=None
05-15 19:43 DEBUG  WindowsBackend: windows_build=17134
05-15 19:43 DEBUG  WindowsBackend: gmt=0
05-15 19:43 DEBUG  WindowsBackend: country=GB
05-15 19:43 DEBUG  WindowsBackend: timezone=Europe/London
05-15 19:43 DEBUG  WindowsBackend: windows_username=pc
05-15 19:43 DEBUG  WindowsBackend: user_full_name=pc
05-15 19:43 DEBUG  WindowsBackend: user_directory=
05-15 19:43 DEBUG  WindowsBackend: windows_language_code=1033
05-15 19:43 DEBUG  WindowsBackend: windows_language=English
05-15 19:43 DEBUG  WindowsBackend: processor_name=Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
05-15 19:43 DEBUG  WindowsBackend: bootloader=vista
05-15 19:43 DEBUG  WindowsBackend: system_drive=Drive(C: hd 23633.6835938 mb free ntfs)
05-15 19:43 DEBUG  WindowsBackend: drive=Drive(C: hd 23633.6796875 mb free ntfs)
05-15 19:43 DEBUG  WindowsBackend: drive=Drive(D: cd 0.0 mb free )
05-15 19:43 DEBUG  WindowsBackend: drive=Drive(E: hd 1229191.625 mb free ntfs)
05-15 19:43 DEBUG  WindowsBackend: drive=Drive(G: hd 2082.359375 mb free ntfs)
05-15 19:43 DEBUG  WindowsBackend: EFI boot = False
05-15 19:43 DEBUG  WindowsBackend: uninstaller_path=E:\debian\uninstall-wubi.exe
05-15 19:43 DEBUG  WindowsBackend: previous_target_dir=E:\debian
05-15 19:43 DEBUG  WindowsBackend: previous_distro_name=Q4OS Scorpion
05-15 19:43 DEBUG  WindowsBackend: keyboard_id=134809609
05-15 19:43 DEBUG  WindowsBackend: keyboard_layout=gb
05-15 19:43 DEBUG  WindowsBackend: keyboard_variant=
05-15 19:43 DEBUG  CommonBackend: python locale=('en_GB', 'cp1252')
05-15 19:43 DEBUG  CommonBackend: locale=en_GB.UTF-8
05-15 19:43 DEBUG  WindowsBackend: total_memory_mb=2047.99999905
05-15 19:43 DEBUG  CommonBackend: Searching for local ISOs
05-15 19:43 DEBUG  CommonBackend: Searching for local CDs
05-15 19:43 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pyl82A1.tmp is a valid Q4OS Scorpion CD
05-15 19:43 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl82A1.tmp\install.386\install.bat
05-15 19:43 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl82A1.tmp\install.amd\install.bat
05-15 19:43 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-15 19:43 DEBUG  Distro:     dir does not exist
05-15 19:43 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-15 19:43 DEBUG  Distro:     does not contain E:\install.386\install.bat
05-15 19:43 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-15 19:43 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-15 19:43 DEBUG  Distro:     does not contain G:\install.386\install.bat
05-15 19:43 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-15 19:43 INFO   root: Running the uninstaller...
05-15 19:43 INFO   CommonBackend: This is the uninstaller running
05-15 19:43 DEBUG  WindowsFrontend: __init__...
05-15 19:43 DEBUG  WindowsFrontend: on_init...
05-15 19:43 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pyl82A1.tmp\translations, languages=['en_GB', 'en']
05-15 19:43 INFO   root: Received settings
05-15 19:43 DEBUG  TaskList: # Running tasklist...
05-15 19:43 DEBUG  TaskList: ## Running Remove bootloader entry....
05-15 19:43 DEBUG  WindowsBackend: Could not find bcd id
05-15 19:43 DEBUG  WindowsBackend: undo_bootini C:
05-15 19:43 DEBUG  WindowsBackend: undo_configsys Drive(C: hd 23633.6796875 mb free ntfs)
05-15 19:43 DEBUG  WindowsBackend: undo_bootini E:
05-15 19:43 DEBUG  WindowsBackend: undo_configsys Drive(E: hd 1229191.625 mb free ntfs)
05-15 19:43 DEBUG  WindowsBackend: undo_bootini G:
05-15 19:43 DEBUG  WindowsBackend: undo_configsys Drive(G: hd 2082.359375 mb free ntfs)
05-15 19:43 DEBUG  TaskList: ## Finished Remove bootloader entry.
05-15 19:43 DEBUG  TaskList: ## Running Remove target dir....
05-15 19:43 DEBUG  CommonBackend: Deleting E:\debian
05-15 19:43 DEBUG  TaskList: ## Finished Remove target dir.
05-15 19:43 DEBUG  TaskList: ## Running Remove registry key....
05-15 19:43 DEBUG  TaskList: ## Finished Remove registry key.
05-15 19:43 DEBUG  TaskList: # Finished tasklist
05-15 19:43 INFO   root: Almost finished uninstalling
05-15 19:43 INFO   root: Finished uninstallation
05-15 19:43 DEBUG  root: application.quit
05-15 19:43 DEBUG  WindowsFrontend: frontend.quit
05-15 19:43 DEBUG  WindowsFrontend: frontend.on_quit
05-15 19:43 DEBUG  root: application.on_quit
05-15 19:43 INFO   root: sys.exit
05-15 22:19 INFO   root: === wubi 2.4 rev325 ===
05-15 22:19 DEBUG  root: Logfile is c:\users\pc\appdata\local\temp\wubi-2.4-rev325.log
05-15 22:19 DEBUG  root: sys.argv = ['main.pyo', '--exefile="E:\\debian\\uninstall-wubi.exe"']
05-15 22:19 DEBUG  CommonBackend: data_dir=C:\Users\pc\AppData\Local\Temp\pyl391D.tmp\data
05-15 22:19 DEBUG  WindowsBackend: 7z=C:\Users\pc\AppData\Local\Temp\pyl391D.tmp\bin\7z.exe
05-15 22:19 DEBUG  WindowsBackend: startup_folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
05-15 22:19 DEBUG  CommonBackend: Fetching basic info...
05-15 22:19 DEBUG  CommonBackend: original_exe=E:\debian\uninstall-wubi.exe
05-15 22:19 DEBUG  CommonBackend: platform=win32
05-15 22:19 DEBUG  CommonBackend: osname=nt
05-15 22:19 DEBUG  CommonBackend: language=en_GB
05-15 22:19 DEBUG  CommonBackend: encoding=cp1252
05-15 22:19 DEBUG  WindowsBackend: arch=amd64
05-15 22:19 DEBUG  CommonBackend: Parsing isolist=C:\Users\pc\AppData\Local\Temp\pyl391D.tmp\data\isolist.ini
05-15 22:19 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-i386
05-15 22:19 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-amd64
05-15 22:19 DEBUG  WindowsBackend: Fetching host info...
05-15 22:19 DEBUG  WindowsBackend: registry_key=Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi
05-15 22:19 DEBUG  WindowsBackend: windows version=vista
05-15 22:19 DEBUG  WindowsBackend: windows_version2=Windows 10 Enterprise
05-15 22:19 DEBUG  WindowsBackend: windows_sp=None
05-15 22:19 DEBUG  WindowsBackend: windows_build=17134
05-15 22:19 DEBUG  WindowsBackend: gmt=0
05-15 22:19 DEBUG  WindowsBackend: country=GB
05-15 22:19 DEBUG  WindowsBackend: timezone=Europe/London
05-15 22:19 DEBUG  WindowsBackend: windows_username=pc
05-15 22:19 DEBUG  WindowsBackend: user_full_name=pc
05-15 22:19 DEBUG  WindowsBackend: user_directory=
05-15 22:19 DEBUG  WindowsBackend: windows_language_code=1033
05-15 22:19 DEBUG  WindowsBackend: windows_language=English
05-15 22:19 DEBUG  WindowsBackend: processor_name=Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
05-15 22:19 DEBUG  WindowsBackend: bootloader=vista
05-15 22:19 DEBUG  WindowsBackend: system_drive=Drive(C: hd 23647.828125 mb free ntfs)
05-15 22:19 DEBUG  WindowsBackend: drive=Drive(C: hd 23647.828125 mb free ntfs)
05-15 22:19 DEBUG  WindowsBackend: drive=Drive(D: cd 0.0 mb free )
05-15 22:19 DEBUG  WindowsBackend: drive=Drive(E: hd 1229191.875 mb free ntfs)
05-15 22:19 DEBUG  WindowsBackend: drive=Drive(G: hd 2082.359375 mb free ntfs)
05-15 22:19 DEBUG  WindowsBackend: EFI boot = False
05-15 22:19 DEBUG  WindowsBackend: uninstaller_path=None
05-15 22:19 DEBUG  WindowsBackend: previous_target_dir=None
05-15 22:19 DEBUG  WindowsBackend: previous_distro_name=None
05-15 22:19 DEBUG  WindowsBackend: keyboard_id=134809609
05-15 22:19 DEBUG  WindowsBackend: keyboard_layout=gb
05-15 22:19 DEBUG  WindowsBackend: keyboard_variant=
05-15 22:19 DEBUG  CommonBackend: python locale=('en_GB', 'cp1252')
05-15 22:19 DEBUG  CommonBackend: locale=en_GB.UTF-8
05-15 22:19 DEBUG  WindowsBackend: total_memory_mb=2047.99999905
05-15 22:19 DEBUG  CommonBackend: Searching for local ISOs
05-15 22:19 DEBUG  CommonBackend: Searching for local CDs
05-15 22:19 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pyl391D.tmp is a valid Q4OS Scorpion CD
05-15 22:19 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl391D.tmp\install.386\install.bat
05-15 22:19 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pyl391D.tmp\install.amd\install.bat
05-15 22:19 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-15 22:19 DEBUG  Distro:     dir does not exist
05-15 22:19 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-15 22:19 DEBUG  Distro:     does not contain E:\install.386\install.bat
05-15 22:19 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-15 22:19 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-15 22:19 DEBUG  Distro:     does not contain G:\install.386\install.bat
05-15 22:19 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-15 22:19 INFO   root: Running the uninstaller...
05-15 22:19 ERROR  root: No previous target dir found, exiting
05-15 22:19 DEBUG  root: application.quit
05-15 22:19 DEBUG  root: application.on_quit
05-15 22:19 INFO   root: sys.exit
05-15 22:21 INFO   root: === wubi 2.4 rev325 ===
05-15 22:21 DEBUG  root: Logfile is c:\users\pc\appdata\local\temp\wubi-2.4-rev325.log
05-15 22:21 DEBUG  root: sys.argv = ['main.pyo', '--exefile="E:\\Temp\\q4os-winsetup.exe"']
05-15 22:21 DEBUG  CommonBackend: data_dir=C:\Users\pc\AppData\Local\Temp\pylA89B.tmp\data
05-15 22:21 DEBUG  WindowsBackend: 7z=C:\Users\pc\AppData\Local\Temp\pylA89B.tmp\bin\7z.exe
05-15 22:21 DEBUG  WindowsBackend: startup_folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
05-15 22:21 DEBUG  CommonBackend: Fetching basic info...
05-15 22:21 DEBUG  CommonBackend: original_exe=E:\Temp\q4os-winsetup.exe
05-15 22:21 DEBUG  CommonBackend: platform=win32
05-15 22:21 DEBUG  CommonBackend: osname=nt
05-15 22:21 DEBUG  CommonBackend: language=en_GB
05-15 22:21 DEBUG  CommonBackend: encoding=cp1252
05-15 22:21 DEBUG  WindowsBackend: arch=amd64
05-15 22:21 DEBUG  CommonBackend: Parsing isolist=C:\Users\pc\AppData\Local\Temp\pylA89B.tmp\data\isolist.ini
05-15 22:21 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-i386
05-15 22:21 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-amd64
05-15 22:21 DEBUG  WindowsBackend: Fetching host info...
05-15 22:21 DEBUG  WindowsBackend: registry_key=Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi
05-15 22:21 DEBUG  WindowsBackend: windows version=vista
05-15 22:21 DEBUG  WindowsBackend: windows_version2=Windows 10 Enterprise
05-15 22:21 DEBUG  WindowsBackend: windows_sp=None
05-15 22:21 DEBUG  WindowsBackend: windows_build=17134
05-15 22:21 DEBUG  WindowsBackend: gmt=0
05-15 22:21 DEBUG  WindowsBackend: country=GB
05-15 22:21 DEBUG  WindowsBackend: timezone=Europe/London
05-15 22:21 DEBUG  WindowsBackend: windows_username=pc
05-15 22:21 DEBUG  WindowsBackend: user_full_name=pc
05-15 22:21 DEBUG  WindowsBackend: user_directory=C:\Users\pc
05-15 22:21 DEBUG  WindowsBackend: windows_language_code=1033
05-15 22:21 DEBUG  WindowsBackend: windows_language=English
05-15 22:21 DEBUG  WindowsBackend: processor_name=Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
05-15 22:21 DEBUG  WindowsBackend: bootloader=vista
05-15 22:21 DEBUG  WindowsBackend: system_drive=Drive(C: hd 23650.1132812 mb free ntfs)
05-15 22:21 DEBUG  WindowsBackend: drive=Drive(C: hd 23650.1132812 mb free ntfs)
05-15 22:21 DEBUG  WindowsBackend: drive=Drive(D: cd 0.0 mb free )
05-15 22:21 DEBUG  WindowsBackend: drive=Drive(E: hd 1229186.25 mb free ntfs)
05-15 22:21 DEBUG  WindowsBackend: drive=Drive(G: hd 2082.359375 mb free ntfs)
05-15 22:21 DEBUG  WindowsBackend: EFI boot = False
05-15 22:21 DEBUG  WindowsBackend: uninstaller_path=None
05-15 22:21 DEBUG  WindowsBackend: previous_target_dir=None
05-15 22:21 DEBUG  WindowsBackend: previous_distro_name=None
05-15 22:21 DEBUG  WindowsBackend: keyboard_id=134809609
05-15 22:21 DEBUG  WindowsBackend: keyboard_layout=gb
05-15 22:21 DEBUG  WindowsBackend: keyboard_variant=
05-15 22:21 DEBUG  CommonBackend: python locale=('en_GB', 'cp1252')
05-15 22:21 DEBUG  CommonBackend: locale=en_GB.UTF-8
05-15 22:21 DEBUG  WindowsBackend: total_memory_mb=2047.99999905
05-15 22:21 DEBUG  CommonBackend: Searching for local ISOs
05-15 22:21 DEBUG  CommonBackend: Searching for local CDs
05-15 22:21 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pylA89B.tmp is a valid Q4OS Scorpion CD
05-15 22:21 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pylA89B.tmp\install.386\install.bat
05-15 22:21 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pylA89B.tmp\install.amd\install.bat
05-15 22:21 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-15 22:21 DEBUG  Distro:     dir does not exist
05-15 22:21 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-15 22:21 DEBUG  Distro:     does not contain E:\install.386\install.bat
05-15 22:21 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-15 22:21 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-15 22:21 DEBUG  Distro:     does not contain G:\install.386\install.bat
05-15 22:21 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-15 22:21 INFO   root: Running the installer...
05-15 22:21 DEBUG  WindowsFrontend: __init__...
05-15 22:21 DEBUG  WindowsFrontend: on_init...
05-15 22:21 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pylA89B.tmp\translations, languages=['en_GB', 'en']
05-15 22:21 DEBUG  WinuiInstallationPage: target_drive=E:, installation_size=32000MB, distro_name=Q4OS Scorpion, language=en_GB, locale=en_GB.UTF-8, username=simon
05-15 22:21 INFO   root: Received settings
05-15 22:21 DEBUG  TaskList: # Running tasklist...
05-15 22:21 DEBUG  TaskList: ## Running select_target_dir...
05-15 22:21 ERROR  TaskList: Cannot install into E:\debian.
05-15 22:21 DEBUG  TaskList: # Cancelling tasklist
05-15 22:21 DEBUG  TaskList: # Finished tasklist
05-15 22:21 ERROR  root: Cannot install into E:\debian.
05-15 22:22 INFO   root: === wubi 2.4 rev325 ===
05-15 22:22 DEBUG  root: Logfile is c:\users\pc\appdata\local\temp\wubi-2.4-rev325.log
05-15 22:22 DEBUG  root: sys.argv = ['main.pyo', '--exefile="E:\\Temp\\q4os-winsetup.exe"']
05-15 22:22 DEBUG  CommonBackend: data_dir=C:\Users\pc\AppData\Local\Temp\pylCAB4.tmp\data
05-15 22:22 DEBUG  WindowsBackend: 7z=C:\Users\pc\AppData\Local\Temp\pylCAB4.tmp\bin\7z.exe
05-15 22:22 DEBUG  WindowsBackend: startup_folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
05-15 22:22 DEBUG  CommonBackend: Fetching basic info...
05-15 22:22 DEBUG  CommonBackend: original_exe=E:\Temp\q4os-winsetup.exe
05-15 22:22 DEBUG  CommonBackend: platform=win32
05-15 22:22 DEBUG  CommonBackend: osname=nt
05-15 22:22 DEBUG  CommonBackend: language=en_GB
05-15 22:22 DEBUG  CommonBackend: encoding=cp1252
05-15 22:22 DEBUG  WindowsBackend: arch=amd64
05-15 22:22 DEBUG  CommonBackend: Parsing isolist=C:\Users\pc\AppData\Local\Temp\pylCAB4.tmp\data\isolist.ini
05-15 22:22 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-i386
05-15 22:22 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-amd64
05-15 22:22 DEBUG  WindowsBackend: Fetching host info...
05-15 22:22 DEBUG  WindowsBackend: registry_key=Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi
05-15 22:22 DEBUG  WindowsBackend: windows version=vista
05-15 22:22 DEBUG  WindowsBackend: windows_version2=Windows 10 Enterprise
05-15 22:22 DEBUG  WindowsBackend: windows_sp=None
05-15 22:22 DEBUG  WindowsBackend: windows_build=17134
05-15 22:22 DEBUG  WindowsBackend: gmt=0
05-15 22:22 DEBUG  WindowsBackend: country=GB
05-15 22:22 DEBUG  WindowsBackend: timezone=Europe/London
05-15 22:22 DEBUG  WindowsBackend: windows_username=pc
05-15 22:22 DEBUG  WindowsBackend: user_full_name=pc
05-15 22:22 DEBUG  WindowsBackend: user_directory=C:\Users\pc
05-15 22:22 DEBUG  WindowsBackend: windows_language_code=1033
05-15 22:22 DEBUG  WindowsBackend: windows_language=English
05-15 22:22 DEBUG  WindowsBackend: processor_name=Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
05-15 22:22 DEBUG  WindowsBackend: bootloader=vista
05-15 22:22 DEBUG  WindowsBackend: system_drive=Drive(C: hd 23650.4375 mb free ntfs)
05-15 22:22 DEBUG  WindowsBackend: drive=Drive(C: hd 23650.4375 mb free ntfs)
05-15 22:22 DEBUG  WindowsBackend: drive=Drive(D: cd 0.0 mb free )
05-15 22:22 DEBUG  WindowsBackend: drive=Drive(E: hd 1229242.125 mb free ntfs)
05-15 22:22 DEBUG  WindowsBackend: drive=Drive(G: hd 2082.359375 mb free ntfs)
05-15 22:22 DEBUG  WindowsBackend: EFI boot = False
05-15 22:22 DEBUG  WindowsBackend: uninstaller_path=None
05-15 22:22 DEBUG  WindowsBackend: previous_target_dir=None
05-15 22:22 DEBUG  WindowsBackend: previous_distro_name=None
05-15 22:22 DEBUG  WindowsBackend: keyboard_id=134809609
05-15 22:22 DEBUG  WindowsBackend: keyboard_layout=gb
05-15 22:22 DEBUG  WindowsBackend: keyboard_variant=
05-15 22:22 DEBUG  CommonBackend: python locale=('en_GB', 'cp1252')
05-15 22:22 DEBUG  CommonBackend: locale=en_GB.UTF-8
05-15 22:22 DEBUG  WindowsBackend: total_memory_mb=2047.99999905
05-15 22:22 DEBUG  CommonBackend: Searching for local ISOs
05-15 22:22 DEBUG  CommonBackend: Searching for local CDs
05-15 22:22 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pylCAB4.tmp is a valid Q4OS Scorpion CD
05-15 22:22 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pylCAB4.tmp\install.386\install.bat
05-15 22:22 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pylCAB4.tmp\install.amd\install.bat
05-15 22:22 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-15 22:22 DEBUG  Distro:     dir does not exist
05-15 22:22 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-15 22:22 DEBUG  Distro:     does not contain E:\install.386\install.bat
05-15 22:22 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-15 22:22 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-15 22:22 DEBUG  Distro:     does not contain G:\install.386\install.bat
05-15 22:22 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-15 22:22 INFO   root: Running the installer...
05-15 22:22 DEBUG  WindowsFrontend: __init__...
05-15 22:22 DEBUG  WindowsFrontend: on_init...
05-15 22:22 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pylCAB4.tmp\translations, languages=['en_GB', 'en']
05-15 22:24 DEBUG  WinuiInstallationPage: target_drive=E:, installation_size=32000MB, distro_name=Q4OS Scorpion, language=en_GB, locale=en_GB.UTF-8, username=simon
05-15 22:24 INFO   root: Received settings
05-15 22:24 DEBUG  CommonBackend: Searching for local CD
05-15 22:24 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pylCAB4.tmp is a valid Q4OS Scorpion CD
05-15 22:24 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pylCAB4.tmp\install.amd\install.bat
05-15 22:24 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-15 22:24 DEBUG  Distro:     dir does not exist
05-15 22:24 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-15 22:24 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-15 22:24 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-15 22:24 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-15 22:24 DEBUG  CommonBackend: Searching for local ISO
05-15 22:24 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pylCAB4.tmp\translations, languages=['en_GB', 'en']
05-15 22:24 DEBUG  TaskList: # Running tasklist...
05-15 22:24 DEBUG  TaskList: ## Running select_target_dir...
05-15 22:24 INFO   WindowsBackend: Installing into E:\debian
05-15 22:24 DEBUG  TaskList: ## Finished select_target_dir
05-15 22:24 DEBUG  TaskList: ## Running create_dir_structure...
05-15 22:24 DEBUG  CommonBackend: Creating dir E:\debian
05-15 22:24 DEBUG  CommonBackend: Creating dir E:\debian\disks
05-15 22:24 DEBUG  CommonBackend: Creating dir E:\debian\install
05-15 22:24 DEBUG  CommonBackend: Creating dir E:\debian\install\boot
05-15 22:24 DEBUG  CommonBackend: Creating dir E:\debian\disks\boot
05-15 22:24 DEBUG  CommonBackend: Creating dir E:\debian\disks\boot\grub
05-15 22:24 DEBUG  CommonBackend: Creating dir E:\debian\install\boot\grub
05-15 22:24 DEBUG  TaskList: ## Finished create_dir_structure
05-15 22:24 DEBUG  TaskList: ## Running create_uninstaller...
05-15 22:24 DEBUG  WindowsBackend: Copying uninstaller E:\Temp\q4os-winsetup.exe -> E:\debian\uninstall-wubi.exe
05-15 22:24 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi UninstallString E:\debian\uninstall-wubi.exe
05-15 22:24 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi InstallationDir E:\debian
05-15 22:24 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi DisplayName Q4OS Scorpion
05-15 22:24 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi DisplayIcon E:\debian\Q4OS Scorpion.ico
05-15 22:24 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi DisplayVersion 2.4-rev325
05-15 22:24 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi Publisher Q4OS Scorpion
05-15 22:24 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi URLInfoAbout https://q4os.org
05-15 22:24 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi HelpLink http://www.ubuntu.com/support
05-15 22:24 DEBUG  TaskList: ## Finished create_uninstaller
05-15 22:24 DEBUG  TaskList: ## Running create_preseed_diskimage...
05-15 22:24 DEBUG  TaskList: ## Finished create_preseed_diskimage
05-15 22:24 DEBUG  TaskList: ## Running get_diskimage...
05-15 22:24 DEBUG  TaskList: New task download
05-15 22:24 DEBUG  TaskList: ### Running download...
05-15 22:24 DEBUG  downloader: downloading https://sourceforge.net/projects/q4os/f … oop.img.xz > E:\debian\disks\q4os-2.4-x64-loop.img.xz
05-15 22:24 DEBUG  downloader: Download start filename=E:\debian\disks\q4os-2.4-x64-loop.img.xz, url=https://sourceforge.net/projects/q4os/files/stable/q4os-2.4-x64-loop.img.xz, basename=q4os-2.4-x64-loop.img.xz, length=382653804, text=None
05-15 22:30 DEBUG  TaskList: ### Finished download
05-15 22:30 DEBUG  downloader: download finished (read 382653804 bytes)
05-15 22:30 DEBUG  TaskList: ## Finished get_diskimage
05-15 22:30 DEBUG  TaskList: ## Running extract_diskimage...
05-15 22:31 DEBUG  TaskList: ## Finished extract_diskimage
05-15 22:31 DEBUG  TaskList: ## Running choose_disk_sizes...
05-15 22:31 DEBUG  WindowsBackend: total size=32000
  root=31744
  swap=256
  home=0
  usr=0
05-15 22:31 DEBUG  TaskList: ## Finished choose_disk_sizes
05-15 22:31 DEBUG  TaskList: ## Running expand_diskimage...
05-15 22:35 DEBUG  TaskList: ## Finished expand_diskimage
05-15 22:35 DEBUG  TaskList: ## Running create_swap_diskimage...
05-15 22:35 DEBUG  TaskList: ## Finished create_swap_diskimage
05-15 22:35 DEBUG  TaskList: ## Running modify_bootloader...
05-15 22:35 DEBUG  TaskList: New task modify_bcd
05-15 22:35 DEBUG  TaskList: ### Running modify_bcd...
05-15 22:35 DEBUG  WindowsBackend: modify_bcd Drive(C: hd 23650.4375 mb free ntfs)
05-15 22:35 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi VistaBootDrive {a51f3f34-56bb-11e8-8faa-c3f679d49f6f}
05-15 22:35 DEBUG  TaskList: ### Finished modify_bcd
05-15 22:35 DEBUG  WindowsBackend: modify_bcd Drive(E: hd 1229242.125 mb free ntfs)
05-15 22:35 DEBUG  WindowsBackend: BCD has already been modified
05-15 22:35 DEBUG  WindowsBackend: modify_bcd Drive(G: hd 2082.359375 mb free ntfs)
05-15 22:35 DEBUG  TaskList: ## Finished modify_bootloader
05-15 22:35 DEBUG  TaskList: ## Running diskimage_bootloader...
05-15 22:35 DEBUG  WindowsBackend: Copying C:\Users\pc\AppData\Local\Temp\pylCAB4.tmp\winboot -> E:\debian\winboot
05-15 22:35 DEBUG  TaskList: ## Finished diskimage_bootloader
05-15 22:35 DEBUG  TaskList: # Finished tasklist
05-15 22:35 INFO   root: Almost finished installing
05-15 22:35 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pylCAB4.tmp\translations, languages=['en_GB', 'en']
05-15 22:36 INFO   root: Finished installation
05-15 22:36 INFO   root: Rebooting
05-15 22:36 DEBUG  TaskList: # Running tasklist...
05-15 22:36 DEBUG  TaskList: ## Running reboot...
05-15 22:36 DEBUG  TaskList: ## Finished reboot
05-15 22:36 DEBUG  TaskList: # Finished tasklist
05-15 22:36 DEBUG  root: application.quit
05-15 22:36 DEBUG  WindowsFrontend: frontend.quit
05-15 22:36 DEBUG  WindowsFrontend: frontend.on_quit
05-15 22:36 DEBUG  root: application.on_quit
05-15 22:36 INFO   root: sys.exit
05-15 22:44 INFO   root: === wubi 2.4 rev325 ===
05-15 22:44 DEBUG  root: Logfile is c:\users\pc\appdata\local\temp\wubi-2.4-rev325.log
05-15 22:44 DEBUG  root: sys.argv = ['main.pyo', '--exefile="E:\\debian\\uninstall-wubi.exe"']
05-15 22:44 DEBUG  CommonBackend: data_dir=C:\Users\pc\AppData\Local\Temp\pylE61B.tmp\data
05-15 22:44 DEBUG  WindowsBackend: 7z=C:\Users\pc\AppData\Local\Temp\pylE61B.tmp\bin\7z.exe
05-15 22:44 DEBUG  WindowsBackend: startup_folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
05-15 22:44 DEBUG  CommonBackend: Fetching basic info...
05-15 22:44 DEBUG  CommonBackend: original_exe=E:\debian\uninstall-wubi.exe
05-15 22:44 DEBUG  CommonBackend: platform=win32
05-15 22:44 DEBUG  CommonBackend: osname=nt
05-15 22:44 DEBUG  CommonBackend: language=en_GB
05-15 22:44 DEBUG  CommonBackend: encoding=cp1252
05-15 22:44 DEBUG  WindowsBackend: arch=amd64
05-15 22:44 DEBUG  CommonBackend: Parsing isolist=C:\Users\pc\AppData\Local\Temp\pylE61B.tmp\data\isolist.ini
05-15 22:44 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-i386
05-15 22:44 DEBUG  CommonBackend:   Adding distro Q4OS Scorpion-amd64
05-15 22:44 DEBUG  WindowsBackend: Fetching host info...
05-15 22:44 DEBUG  WindowsBackend: registry_key=Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi
05-15 22:44 DEBUG  WindowsBackend: windows version=vista
05-15 22:44 DEBUG  WindowsBackend: windows_version2=Windows 10 Enterprise
05-15 22:44 DEBUG  WindowsBackend: windows_sp=None
05-15 22:44 DEBUG  WindowsBackend: windows_build=17134
05-15 22:44 DEBUG  WindowsBackend: gmt=0
05-15 22:44 DEBUG  WindowsBackend: country=GB
05-15 22:44 DEBUG  WindowsBackend: timezone=Europe/London
05-15 22:44 DEBUG  WindowsBackend: windows_username=pc
05-15 22:44 DEBUG  WindowsBackend: user_full_name=pc
05-15 22:44 DEBUG  WindowsBackend: user_directory=C:\Users\pc
05-15 22:44 DEBUG  WindowsBackend: windows_language_code=1033
05-15 22:44 DEBUG  WindowsBackend: windows_language=English
05-15 22:44 DEBUG  WindowsBackend: processor_name=Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
05-15 22:44 DEBUG  WindowsBackend: bootloader=vista
05-15 22:44 DEBUG  WindowsBackend: system_drive=Drive(C: hd 23638.5585938 mb free ntfs)
05-15 22:44 DEBUG  WindowsBackend: drive=Drive(C: hd 23638.5585938 mb free ntfs)
05-15 22:44 DEBUG  WindowsBackend: drive=Drive(D: cd 0.0 mb free )
05-15 22:44 DEBUG  WindowsBackend: drive=Drive(E: hd 1197231.15625 mb free ntfs)
05-15 22:44 DEBUG  WindowsBackend: drive=Drive(G: hd 2082.359375 mb free ntfs)
05-15 22:44 DEBUG  WindowsBackend: EFI boot = False
05-15 22:44 DEBUG  WindowsBackend: uninstaller_path=E:\debian\uninstall-wubi.exe
05-15 22:44 DEBUG  WindowsBackend: previous_target_dir=E:\debian
05-15 22:44 DEBUG  WindowsBackend: previous_distro_name=Q4OS Scorpion
05-15 22:44 DEBUG  WindowsBackend: keyboard_id=134809609
05-15 22:44 DEBUG  WindowsBackend: keyboard_layout=gb
05-15 22:44 DEBUG  WindowsBackend: keyboard_variant=
05-15 22:44 DEBUG  CommonBackend: python locale=('en_GB', 'cp1252')
05-15 22:44 DEBUG  CommonBackend: locale=en_GB.UTF-8
05-15 22:44 DEBUG  WindowsBackend: total_memory_mb=2047.99999905
05-15 22:44 DEBUG  CommonBackend: Searching for local ISOs
05-15 22:44 DEBUG  CommonBackend: Searching for local CDs
05-15 22:44 DEBUG  Distro:   checking whether C:\Users\pc\AppData\Local\Temp\pylE61B.tmp is a valid Q4OS Scorpion CD
05-15 22:44 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pylE61B.tmp\install.386\install.bat
05-15 22:44 DEBUG  Distro:     does not contain C:\Users\pc\AppData\Local\Temp\pylE61B.tmp\install.amd\install.bat
05-15 22:44 DEBUG  Distro:   checking whether D:\ is a valid Q4OS Scorpion CD
05-15 22:44 DEBUG  Distro:     dir does not exist
05-15 22:44 DEBUG  Distro:   checking whether E:\ is a valid Q4OS Scorpion CD
05-15 22:44 DEBUG  Distro:     does not contain E:\install.386\install.bat
05-15 22:44 DEBUG  Distro:     does not contain E:\install.amd\install.bat
05-15 22:44 DEBUG  Distro:   checking whether G:\ is a valid Q4OS Scorpion CD
05-15 22:44 DEBUG  Distro:     does not contain G:\install.386\install.bat
05-15 22:44 DEBUG  Distro:     does not contain G:\install.amd\install.bat
05-15 22:44 INFO   root: Running the uninstaller...
05-15 22:44 INFO   CommonBackend: This is the uninstaller running
05-15 22:44 DEBUG  WindowsFrontend: __init__...
05-15 22:44 DEBUG  WindowsFrontend: on_init...
05-15 22:44 INFO   WinuiPage: appname=wubi, localedir=C:\Users\pc\AppData\Local\Temp\pylE61B.tmp\translations, languages=['en_GB', 'en']
05-15 22:44 INFO   root: Received settings
05-15 22:44 DEBUG  TaskList: # Running tasklist...
05-15 22:44 DEBUG  TaskList: ## Running Remove bootloader entry....
05-15 22:44 DEBUG  WindowsBackend: Removing bcd entry {a51f3f34-56bb-11e8-8faa-c3f679d49f6f}
05-15 22:44 DEBUG  registry: Setting registry key 2147483650 Software\Microsoft\Windows\CurrentVersion\Uninstall\Wubi VistaBootDrive
05-15 22:44 DEBUG  WindowsBackend: undo_bootini C:
05-15 22:44 DEBUG  WindowsBackend: undo_configsys Drive(C: hd 23638.5585938 mb free ntfs)
05-15 22:44 DEBUG  WindowsBackend: undo_bootini E:
05-15 22:44 DEBUG  WindowsBackend: undo_configsys Drive(E: hd 1197231.15625 mb free ntfs)
05-15 22:44 DEBUG  WindowsBackend: undo_bootini G:
05-15 22:44 DEBUG  WindowsBackend: undo_configsys Drive(G: hd 2082.359375 mb free ntfs)
05-15 22:44 DEBUG  TaskList: ## Finished Remove bootloader entry.
05-15 22:44 DEBUG  TaskList: ## Running Remove target dir....
05-15 22:44 DEBUG  CommonBackend: Deleting E:\debian
05-15 22:44 DEBUG  TaskList: ## Finished Remove target dir.
05-15 22:44 DEBUG  TaskList: ## Running Remove registry key....
05-15 22:44 DEBUG  TaskList: ## Finished Remove registry key.
05-15 22:44 DEBUG  TaskList: # Finished tasklist
05-15 22:44 INFO   root: Almost finished uninstalling
05-15 22:44 INFO   root: Finished uninstallation
05-15 22:44 DEBUG  root: application.quit
05-15 22:44 DEBUG  WindowsFrontend: frontend.quit
05-15 22:44 DEBUG  WindowsFrontend: frontend.on_quit
05-15 22:44 DEBUG  root: application.on_quit
05-15 22:44 INFO   root: sys.exit
#5 2018-05-22 08:23
Re: Q4os Boot Up Process Fails
It looks you have installed Q4OS on multiple logical Windows disks some way. So, we would recommend you to clean previous installations manually. Proceed the following:
- Backup the desired 'root.disk' file.
- Download the latest winsetup.exe installer from here https://www.q4os.org/downloads1.html
- Proceed Q4OS uninstallation. Launch the "q4os-winsetup.exe" installer, the Q4OS uninstall wizard starts.
- Manually delete 'debian' directory on all logical disks, e.g. 'c:\debian', 'd:\debian', 'e:\debian', etc...
- Now, perform new Q4OS installation, run "q4os-winsetup.exe" again, follow this guide https://www.q4os.org/dqa014.html.
- Boot the new installation to check it.
- Optionally replace the "root.disk" file with the backed up one.
- Q4OS should boot now, if the system structure within the "root.disk" file is not corrupted.
- Please post a result here.
#6 2018-06-19 09:25
Henrys cat
I have tried the above and installed Q4OS on my 'e' drive with 64Gb allocated.  Installation went fine, but after choosing Q4OS in the boot menu the installation boot up stalls with the same error message as in my original post.  I've uninstalled Q4OS again and will have to give it up as a bad job as I'm not prepared to waste any more time on it.  I don't know what it is that is stopping Q4OS from running, there appears to be no traces of previous installations on any drive.  It's still working fine on my laptop PC.
#7 2018-07-08 18:50
Henrys cat
I have finally discovered the reason why Q4OS would install but not complete the boot process on my PC.  The NTFS 'E' partition it was installed to was corrupted in some unknown way that disc checking tools in Windows 10 completely missed.
This discovery came about after I made space for another Linux distribution.  I backed up all the data on my 'E' partition, then deleted it and created a 64Gb partition for the new version of Linux.  I then re-created a new NTFS 'E' partition and restored all the previous files.  After being unimpressed by this new Linux distro I thought I'd give Q4OS another try.  I NTFS formatted the now vacant 64Gb partition and used the Windows 10 installer to install Q4OS.  Lo-and-behold it installed and booted up without a problem.  I now have Windows 10 and Q4OS happily residing with each other and am in the process of setting up a HTPC using Q4OS and Kodi.  I'm a complete beginner with Linux but have installed the Windows XP theme for Q4OS so everything looks familiar.
