#26 2017-10-09 15:51
fasn
Re: " xvideo no adpaptor"
Dai_trying wrote:
You will have to install the kernel manually (using apt-get) the Q4OS script will not work even with backports enabled.
sudo apt-get install linux-image-4.12.0-0.bpo.2-amd64
i have done what you 've said, and now i should do some check as the early reply post said?
#27 2017-10-09 15:54
Yes, first make sure you have rebooted the machine and then you could post the output of inxi -F and we can take it from there...
#28 2017-10-09 16:00
fasn
inxi -F
System:    Host: qie Kernel: 4.12.0-0.bpo.2-amd64 x86_64 (64 bit)
           Desktop: KDE Plasma 3 Distro: Debian GNU/Linux 9 (stretch)
Machine:   Device: desktop Mobo: MSI model: H110M PRO-VD (MS-7996) v: 1.0
           UEFI [Legacy]: American Megatrends v: 2.D0 date: 07/21/2017
CPU:       Dual core Intel Pentium G4560 (-HT-MCP-) cache: 3072 KB
           clock speeds: max: 3500 MHz 1: 2672 MHz 2: 2761 MHz 3: 3035 MHz
           4: 1460 MHz
Graphics:  Card: Intel Device 5902
           Resolution: 1680x1050@59.97hz
           GLX Renderer: Mesa DRI Intel Kabylake GT1
           GLX Version: 3.0 Mesa 13.0.6
Audio:     Card Intel Sunrise Point-H HD Audio driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.12.0-0.bpo.2-amd64
Network:   Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169
           IF: enp1s0 state: up speed: 100 Mbps duplex: full
           mac: 4c:cc:6a:cd:16:4c
Drives:    HDD Total Size: 188.1GB (2.5% used)
           ID-1: /dev/sdb model: ADATA_SP600 size: 64.0GB
           ID-2: /dev/sda model: KINGSTON_SUV400S size: 120.0GB
           ID-3: USB /dev/sdc model: Flash_Disk size: 4.0GB
Partition: ID-1: / size: 22G used: 4.5G (23%) fs: ext4 dev: /dev/sda5
Sensors:   System Temperatures: cpu: 40.0C mobo: 29.8C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 186 Uptime: 10 min Memory: 1206.2/7879.7MB
#29 2017-10-09 16:05
Your graphics look like they are all set correctly now, hopefully it all works ok. smile
#30 2017-10-09 16:08
fasn
didn't i need install intel graphic driver manually? and the scrolling of webpage is not like that smooth as on "ubuntu" or "q4os 1.8.7"
#31 2017-10-09 16:47
You might be able to install a newer graphic driver if it is available, but I cannot see one from my machine and I have backports enabled. As for whether it will be as smooth as Q4OS 1.8.7, I would imagine that as the software is tested more and updates are made it will improve although I cannot say why Ubuntu would run any smoother, but Q4OS 1.8.7 is a very tried and tested version and will likely run with least issues but that comes with the issue of not being able to set video correctly which is what brought us to the current situation. If you are dual booting with Ubuntu you could have a look to see what versions of the kernel and graphics drivers are although I am guessing you would need to compile any newer versions if you wanted them before they become available in the repositories.
Registered users online in this topic: 0, guests: 3
