#1 2017-09-30 02:23
danielboon
Kodi Upgrade
I have kodi installed version 16.1 dfsg1-2~bpo8+2 and i would like to know of the possibility on upgrading to Krypton. Is it possible in this version?
root@q4os-desktop:~# inxi -F
System:    Host: q4os-desktop Kernel: 4.9.0-0.bpo.3-amd64 x86_64 (64 bit)
           Desktop: N/A Distro: Debian GNU/Linux 8
Machine:   System: Gigabyte product: N/A
           Mobo: Gigabyte model: F2A88XM-HD3 v: x.x
           Bios: American Megatrends v: FA date: 01/08/2015
CPU:       Dual core AMD A4-7300 APU with Radeon HD Graphics (-MCP-) cache: 2048 KB
           Clock Speeds: 1: 2600 MHz 2: 3500 MHz
Graphics:  Card: NVIDIA Device 1288
           Display Server: X.org 1.16.4 driver: nvidia
           tty size: 80x25 Advanced Data: N/A for root
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
           driver: snd_hda_intel
           Card-2 NVIDIA Device 0e0f driver: snd_hda_intel
           Card-3 DigiTech driver: USB Audio
           Sound: Advanced Linux Sound Architecture v: k4.9.0-0.bpo.3-amd64
Network:   Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169
           IF: eth0 state: up speed: 100 Mbps duplex: full
           mac: fc:aa:xxxxxxxxxxxx
Drives:    HDD Total Size: 480.1GB (7.0% used)
           ID-1: /dev/sda model: KINGSTON_SV300S3 size: 480.1GB
Partition: ID-1: / size: 25G used: 5.9G (26%) fs: ext4 dev: /dev/sda8
           ID-2: /home size: 99G used: 8.7G (10%) fs: ext4 dev: /dev/sda9
           ID-3: swap-1 size: 8.59GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 9.0C mobo: N/A gpu: 32C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 187 Uptime: 6:26 Memory: 810.5/7931.0MB
           Client: Shell (bash) inxi: 2.1.28
I do believe that i read somewhere if it was Orion it was not possible but scorpion was.
#2 2017-09-30 09:22
Re: Kodi Upgrade
I haven't used Orion in a while but Kodi 17.1 is in Scorpion repository (and deb-multimedia) but you could first check to see if it is available from the backports repository by typing
apt-cache policy kodi
in a terminal and it will tell you  if it is.
If there is a newer version available from backports you would have to install it specifically as backports will not install by default, you could do this with the command
sudo apt-get -t jessie-backports install kodi
#3 2017-09-30 15:31
danielboon
Re: Kodi Upgrade
Dai, tks for the commands. I believe I will just stay at the version 16.1 for I have no other option plus this version is just fine. Per the command you listed
root@q4os-desktop:~# apt-cache policy kodi
kodi:
  Installed: 16.1+dfsg1-2~bpo8+2
  Candidate: 16.1+dfsg1-2~bpo8+2
  Version table:
 *** 16.1+dfsg1-2~bpo8+2 0
        100 http://ftp.debian.org/debian/ jessie-backports/main amd64 Packages
        100 /var/lib/dpkg/status
As you can see there is no other option. The
deb-multimedia
That is where i had a issue and you suggested I comment that out. I believe krypton may be in that one but it has unmet dependencies so it throws errors when you make the attempt. Besides 16.1 I can use the tvheadend pvr and stream live tv thu the old version. It works on Krypton also if you can build the tvheadend progam in other debian OS too.
#4 2017-09-30 17:57
Re: Kodi Upgrade
Probably a wise choice smile although Scorpion is very close to being the stable version and that would give you 17.1 if you wanted it.
dai@scorpionmain:~$ apt-cache policy kodi
kodi:
  Installed: (none)
  Candidate: 2:17.1+dfsg1-3
  Version table:
     5:17.4-dmo1+deb9u1 100
        100 http://www.deb-multimedia.org stretch/main amd64 Packages
        100 http://www.deb-multimedia.org stretch/main i386 Packages
     2:17.1+dfsg1-3 500
        500 http://ftp.debian.org/debian stretch/main amd64 Packages
As you can see it is in the main repo for stretch.
#5 2017-09-30 20:33
danielboon
Re: Kodi Upgrade
May I ask what is the link for
scorpion
and can it be a permanent install? When I downloaded this I though it was the latest OS.
Only real problem I have of now with QT4 is either in browser or kodi and also when i am viewing live tv thru vlc "which i did see a fix for that in settings of vlc" the video will freeze until I move the mouse then the video catches up. Audio is never out always up to date. Other Versions of Debian meaning Debian9 or kde5 i do not have that problem.
#6 2017-09-30 20:49
Re: Kodi Upgrade
Download page for Scorpion can be found here, as to the video freezing I haven't noticed any myself, but I've been using scorpion so maybe it isn't affected. smile
EDIT:
and yes it can be a "permanent" install
#7 2017-10-01 04:41
Re: Kodi Upgrade
Also no issues with scorpion and video use.
