#1 2017-08-16 18:48
Luissousa
About terminal information
Can you tell me why I cann't download the sound file from realtek when I go to terminal tray that informs that the download cann't be opened because there is a failiure of authentification?                   The command line that appears is    su: failiure of authentification
       With no further details and hoping to hear from you soon, I below subscribe,
                   Luis Sousa
#2 2017-08-17 01:27
JimW
Re: About terminal information
Unless I am mistaken, that is a failure to authenticate the su
Did you enter the correct password? Maybe try sudo?
#3 2017-08-18 02:21
What hardware are you using as Realtek has decent support with Linux with recent kernels 4.4 or newer. I run some older laptops with Realtek sound and they all work fine. Much older Realtek will need the ALSA drivers and much newer Realtek will need 4.10 or newer kernel.
