#1 2017-06-09 09:26
cpcnw
[FIXED] Edit off redundant menu item
Hi All,
I removed an item via cli
sudo apt-get --purge autoremove packagename
rather than Synaptics and its left an entry on the menu.
How do I edit it out?
Thanks
#2 2017-06-09 09:32
Re: [FIXED] Edit off redundant menu item
It could depend on the package removed, but most apps have its menu shortcuts stored in '/usr/share/applications/some_app.desktop' file. So you probably need to remove or edit it. You can just add 'Hidden=true' line into the shortcut to remove related entry from the start menu. However, most applications should remove its menu entries on uninstallation, so it could indicate some kind of glitch.
#3 2017-06-09 09:36
cpcnw
'/usr/share/applications/some_app.desktop' <- checked its not in there?
#4 2017-06-09 09:39
We would need to know what package, to be able to check it.
#5 2017-06-09 10:34
cpcnw
it was fotoxx installed via Synaptic - left a stale entry on graphics menu
#6 2017-06-09 22:13
Have you rebooted?  Many times that removes it  but typically using complete removal doesnt leave a stale entry with Synaptic.
#7 2017-06-09 23:41
You need to uninstall 'fotoxx' and 'ufraw' packages to get rid of menu entries of complete fotoxx dependencies. Just run in terminal:
$ sudo apt-get autoremove fotoxx ufraw
and report back.
Alternatively remove both, fotoxx ufraw, packages using Synaptic.
#8 2017-06-12 07:01
cpcnw
sysadmin@q4os-desktop:~$ sudo apt-get autoremove fotoxx ufraw
Reading package lists... Done
Building dependency tree
Package 'fotoxx' is not installed, so not removed
Package 'ufraw' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Anyway to edit it out of the menu manually?
Its just an entry with no icon
#9 2017-06-12 07:25
You may find a .desktop file in ~./local/share/applications
It is possible to edit the menus directly but I really really wouldn't go there (here be dragons!)
What may work is to force the menus to re-read by switching between menu styles. That can be done by just right click on the menu button and switch to a different style. For example I always run Classic so would switch to Kickoff.
This can also be done via Control Centre>Desktop>Panels>Menus
#10 2017-06-12 07:25
Well, first we need to know, what the shortcut actually is. Navigate to the redundant entry thru the start menu -> right click on it -> select 'Add item to desktop'. Hover mouse over the desktop shortcut created and paste its name here.
#11 2017-06-12 09:13
As well as the Dev's advice I would do a search for anything fotoxx related, I use mlocate for this (not installed by default) first run
sudo updatedb
after installing mlocate if necessary, and then run
locate fotoxx
to see what files are on the system with fotoxx in their name. This will give you the .deb packages in /var/cache/apt/archives along with any.desktop files and also anything else (including your own data files if they have "fotoxx" somewhere in their name). If it lists a .desktop file then use the location given to either delete or edit (add hidden-true to the end of that file).
#12 2017-06-12 10:40
cpcnw
Correct!
Removed from here and now sorted.
Thanks all smile
