#1 2017-03-12 18:47
ghostdawg
K3B Won't Burn Medium
Everytime I open k3b to burn an ISO image, the Burn Medium dialog is stuck with the message, " Please insert an empty CD-R(W) medium". I have a blank DVD-R disc loaded. The disc is seen by the file manager as blanked. I can't continue at this point. I tried unloading reloading the disc but get the same message. Any ideas what's going on?
Dell Optiplex 760 - Quad Core | 4gb | 250gb | Mageia 5, Salix 14.2, Q4OS
Lenovo Thinkpad T420 | 4gb | 120gb | Mageia 5, Debian Testing
#2 2017-03-13 07:22
Re: K3B Won't Burn Medium
Curious - if you open Control Centre>Peripherals>Hardware Device Manager>Disk does it show your optical drive as a DVD+/- RW drive?
What does it show in k3b settings>devices?
Is it possible that you are using an 8Gb double sided or similar? I recall having problems with these back in the day and had to use brasero to create dvds
#3 2017-03-13 16:42
ghostdawg
Yes, it show the optical drive as a DVD+/- RW drive.
It show the disc as empty and if I add a disc with info, it show the info.
No, these are normal 4.7gb HP discs.
When I booted into another distro (Void Linux) it burned the disc with no issues, using Brasero program.
Thnx.
#4 2017-03-15 13:32
ghostdawg
Here is info from when I start K3b from the command line:
$ /opt/trinity/bin/k3b &
[1] 24875
saptech@ghostdawg8:~$ tdecore (TDEAction): WARNING: TDEActionCollection::TDEActionCollection( TQObject *parent, const char *name, TDEInstance *instance )
sh: 1: tdeiso_info: not found
volname: Invalid argument
Mapping udi /sys/devices/pci0000:00/0000:00:1f.2/ata4/host3/target3:0:0/3:0:0:0/block/sr0//dev/sr0 to device /dev/sr0
/dev/sr0 resolved to /dev/sr0
/dev/sr0 is block device (0)
/dev/sr0 seems to be cdrom
bus: 3, id: 0, lun: 0
(K3bDevice::Device) /dev/sr0: init()
(K3bDevice::Device) /dev/sr0 feature: CD Mastering
(K3bDevice::Device) /dev/sr0 feature: CD Track At Once
(K3bDevice::Device) /dev/sr0 feature: CD-RW Media Write Support
(K3bDevice::Device) /dev/sr0 feature: DVD Read (MMC5)
(K3bDevice::Device) /dev/sr0 feature: DVD+R
(K3bDevice::Device) /dev/sr0 feature: DVD+RW
(K3bDevice::Device) /dev/sr0 feature: DVD+R Double Layer
(K3bDevice::Device) /dev/sr0 feature: DVD-R/-RW Write
(K3bDevice::Device) /dev/sr0 feature: Rigid Restricted Overwrite
(K3bDevice::Device) /dev/sr0 unknown profile: 2
(K3bDevice::Device) /dev/sr0: dataLen: 60
(K3bDevice::Device) /dev/sr0: checking for TAO
(K3bDevice::Device) /dev/sr0: checking for SAO
(K3bDevice::Device) /dev/sr0: checking for SAO_R96P
(K3bDevice::Device) /dev/sr0: checking for SAO_R96R
(K3bDevice::Device) /dev/sr0: checking for RAW_R16
(K3bDevice::Device) /dev/sr0: checking for RAW_R96P
(K3bDevice::Device) /dev/sr0: checking for RAW_R96R
(K3bDevice::Device) /dev/sr0: GET PERFORMANCE dataLen = 88
(K3bDevice::Device) /dev/sr0: GET PERFORMANCE successful with reported length: 84
(K3bDevice::Device) /dev/sr0:  Number of supported write speeds via GET PERFORMANCE: 5
(K3bDevice::Device) /dev/sr0 : 22160 KB/s
(K3bDevice::Device) /dev/sr0 : 16620 KB/s
(K3bDevice::Device) /dev/sr0 : 11080 KB/s
(K3bDevice::Device) /dev/sr0 : 8310 KB/s
(K3bDevice::Device) /dev/sr0 : 5540 KB/s
(K3bDevice::DeviceManager) setting current write speed of device /dev/sr0 to 22160
(K3bDevice::DeviceManager) dev /dev/sr0 already found
(K3bDevice::DeviceManager) found config entry for devicetype: Optiarc DVD+-RW AD-7200S
First sec data area: 43:41:33 (LBA 196608) (402653184
Last sec data area: 554:28:03 (LBA 2495103) (5109970944 Bytes)
Last sec layer 1: 00:00:00 (LBA 0) (0 Bytes)
Layer 1 length: 00:00:01 (LBA 1) (2048 Bytes)
Layer 2 length: 554:28:03 (LBA 2495103) (5109970944 Bytes)
DiskInfo:
Mediatype:       DVD-R Sequential
Current Profile: DVD-R Sequential
Disk state:      empty
Empty:           1
Rewritable:      0
Appendable:      0
Sessions:        0
Tracks:          0
Layers:          1
Capacity:        510:46:46 (LBA 2298496) (4707319808 Bytes)
Remaining size:  510:46:46 (LBA 2298496) (4707319808 Bytes)
Used Size:       00:00:00 (LBA 0) (0 Bytes)
Devices:
Blockdevice:    /dev/sr0
Generic device:
Vendor:         Optiarc
Description:    DVD+-RW AD-7200S
Version:        101A
Write speed:    22160
Profiles:       DVD-ROM, DVD-R Sequential, DVD-R Dual Layer Sequential, DVD-RAM, DVD-RW Restricted Overwrite, DVD-RW Sequential, DVD+RW, DVD+R, DVD+R Dual Layer, CD-ROM, CD-R, CD-RW
Read Cap:       DVD-ROM, DVD-R, DVD-R Sequential, DVD-R Dual Layer, DVD-R Dual Layer Sequential, DVD-R Dual Layer Jump, DVD-RW, DVD-RW Restricted Overwrite, DVD-RW Sequential, DVD+RW, DVD+R, DVD+RW Dual Layer, DVD+R Dual Layer, CD-ROM, CD-R, CD-RW
Write Cap:      DVD-R, DVD-R Sequential, DVD-R Dual Layer, DVD-R Dual Layer Sequential, DVD-RW, DVD-RW Restricted Overwrite, DVD-RW Sequential, DVD+RW, DVD+R, DVD+R Dual Layer, CD-R, CD-RW
Writing modes:  SAO, TAO, RAW, SAO/R96P, SAO/R96R, RAW/R16, RAW/R96P, RAW/R96R, Restricted Overwrite
Reader aliases: /dev/sr0
tdecore (TDEAction): WARNING: TDEActionCollection::operator+=(): function is severely deprecated.
