#1 2017-03-12 15:45
Werner Holtfreter
Screen Saver and Power Control dependencies
Hello,
I wish to start the standard screen saver "Analog clock" after some minutes and after a additional short time should switch off the monitors.
But I found out, it works only well, if the screen saver time delay is smaller than the switch off delay. In all other cases (equal or greater), the screen saver freezes and, could be, switch off do not work. Seems to be a bug.
It is also important to know: Screen saver delay and switch off delay are counted additional.
Configuration which works:
TrinityControlCenter --> Appearance&Themes --> ScreenSaver --> [X]Start_automatically 3min + [X]Hide active windows from saver (I don't know the meaning of the last default setting)
AND
TrinityControlCenter --> Peripherals --> PowerControl --> [X]Enable --> all 4 min
#2 2017-03-12 17:07
Re: Screen Saver and Power Control dependencies
Yes, it looks like a bug, we will check it in detail and possibly report at TDE bugtracker.
