#1 2016-12-06 20:00
temuop
Some problems with keyboard.
Hi I used Q4OS for 1 month, love it so much. And now some issues that I can't search how to fix on the internet.
1. My laptop is HP 8460p. My Fn key only work on:
Fn + F3: suspend
Fn+ F6, F7: I can adjust volume but i want a volume bar appear while pressing the key.
And no more Fn keys work, so i can't adjust the brightness without TDEpowersave .
I can't take screen shot without KSnapshot too. KSnapshot is too bad for me sad
Keyboard shotcut of Konsole is Ctrl+T, like "Open new tab" on Chrome, cant fint how to change it sad
#2 2016-12-07 10:15
Re: Some problems with keyboard.
As far as we know volume bar is not available for Trinity desktop.
temuop wrote:
... i can't adjust the brightness without TDEpowersave
We will try to check, if there is any possible option and let you know, if so.
Press 'printscreen' key to grab a screenshot to the clipboard, then right click on the desktop and select "Paste Clipboard Contents" and then select a filename to save it to.
temuop wrote:
Keyboard shortcut of Konsole is Ctrl+T, like "Open new tab" on Chrome, cant fint how to change it
Go to -> Control panel -> Regional and Accessibility -> Keyboard shortcuts -> Command shortcuts tab -> and define your command shortcuts.
#3 2016-12-07 14:15
temuop
Oh the way to Screen shot so special big_smile thank you Sir
#4 2017-03-06 12:38
NoBackup
I have a similar issue, although TDEpowersave  shows in my case that the screen brightness can not be adjusted
Works fine in windows 10 and each *Unbuntu distro (16.4.x 16.10)..
The laptop is a Mi Notebook Air 12"
let me know if I need to generate any logs / reports... I really like this distro and wanted to start using it for my team, as the laptop only comes with Chinese windows license, which is useless to us ..
#5 2017-03-07 09:18
Please run the following command in terminal to generate debug files:
$ reportq4
and send it via e-mail support@q4os.org or attach it here to analyze. You can add attachment by 'post reply -> choose file'
#6 2017-03-12 07:55
NoBackup
Ok did that (soory nooby)  where do i collect the files ?
#7 2017-03-12 08:15
If you run the command in Konsole/Terminal it shows you where the file has been created.
robin@poppy:~$ reportq4
Report is saved in file: "/home/robin/Documents/qreport.tar.gz"
robin@poppy:~$
If you did it by going Menu>Run>qreport4 it will be in the same place.
#8 2017-03-12 10:08
NoBackup
Thanks for that
here the file its from a LiveUSB boot as not being able to adjust the screen made it to difficult on the original install
qreport.tar.gz
#9 2017-03-17 14:58
NoBackup
so  just checked also on mx x250 (thinkpad) same thing ... but also works in all other distros
#10 2017-03-17 15:16
Just out of interest, have you tried with the Scorpion Live CD - much later kernel than Orion - closer to 'buntu 16.04 etc?
#11 2017-03-21 11:23
NoBackup
Yep tried that same issue
now trying another distro based on umbuntu but with TDE  ... lets see
#12 2017-03-21 11:53
The other place to look with Q4OS will be in ACPI.
In Synaptic make sure you have the following installed:-
acpi
acpi-fakekey
acpi-support   comments show this * On some laptops, set screen brightness.
acpi-support-base
acpid
Follow that with a reboot
I think that installing acpi or acpi-support will pick the others up but that's what you need to wind up with. I have these installed to keep thermal info correct - stops fans overspeeding.
