#1 2017-02-21 21:42
rafaelramos
Error 70 when install Full Profile in 1.8.2 version on Raspberry Pi 3
I made a new installation of version 1.8.2 on Raspberry Pi 3 today, but I'm having a "Error 70" constant when I try to install the Full Profile...
I noticed a new mirror address (mirror.nbtelecom.com.br), which I do not remember seeing previously, and the system can not connect...
This same address of "nbtelecom.com.br" also causes problems to install the applications in the Software Center...
#2 2017-02-21 22:19
Re: Error 70 when install Full Profile in 1.8.2 version on Raspberry Pi 3
Most likely, it is not Q4OS, but a local mirror issue. External Raspbian mirror might get an update just during the Full profile installation, so we would recommend you to repeat the installation a few moments later.
In addition you should check, if you are using a proxy server or other mirroring software.
You can check Apt proxy settings in terminal:
$ apt-config dump | grep -i proxy
#3 2017-02-22 16:06
rafaelramos
Not yet... I'm not using a proxy server...
The same problem: "Unable to connect mirror.nbtelecom.com.br:http:"
I can't install the Full Profile and some applications...
I will break a time and test again in a few days.
#4 2017-02-22 18:53
It could be helpful, if you would post here or send by e-mail the log file '/tmp/.dskprofiler-user_name.tmp.log'.
#5 2017-02-22 20:21
There are known occassional issues with 'mirror.nbtelecom.com.br' Raspbian mirror, see for example https://www.raspberrypi.org/forums/view … 6&t=142736 . Unfortunately this is completely outside of Q4OS, you could report a Raspbian bug here https://bugs.launchpad.net/raspbian
#6 2017-02-24 15:00
rafaelramos
This is my ".dskprofiler.tmp.log":
Checking Q4OS Desktop ...
Checking SW database ...
Locking SW database ...
Checking Internet ...
Testing SW database ...
Reading package lists... 14%
Reading package lists... Done
Building dependency tree
Reading state information... 0%
Update SW database ...
0% [Working]
0% [Connecting to mirrordirector.raspbian.org] [Connecting to q4os.org (81.95.9
Get:1 http://q4os.org q4os-rpi-1-0-cn InRelease [2,501 B]
100% [Connecting to mirrordirector.raspbian.org (93.93.128.193)] [1 InRelease 2
100% [Connecting to mirrordirector.raspbian.org (93.93.128.193)] [Connecting to
100% [1 InRelease gpgv 2,501 B] [Waiting for headers] [Waiting for headers] [Co
100% [Waiting for headers] [Waiting for headers] [Connecting to archive.raspber
Get:2 http://mirrordirector.raspbian.org jessie InRelease [14.9 kB]
21% [2 InRelease 1,241 B/14.9 kB 8%] [Waiting for headers] [Connecting to archi
Get:3 http://q4os.org raspbian-jessie InRelease [2,495 B]
83% [2 InRelease 12.8 kB/14.9 kB 86%] [3 InRelease 1,132 B/2,495 B 45%] [Connec
89% [2 InRelease 12.8 kB/14.9 kB 86%] [Connecting to archive.raspberrypi.org (9
89% [3 InRelease gpgv 2,495 B] [2 InRelease 12.8 kB/14.9 kB 86%] [Waiting for h
97% [2 InRelease 14.3 kB/14.9 kB 96%] [Waiting for headers] [Waiting for header
100% [2 InRelease gpgv 14.9 kB] [Waiting for headers] [Waiting for headers]
Get:4 http://archive.raspberrypi.org jessie InRelease [22.9 kB]
50% [2 InRelease gpgv 14.9 kB] [Waiting for headers] [4 InRelease 1,448 B/22.9
63% [Waiting for headers] [4 InRelease 7,240 B/22.9 kB 32%]
Get:5 http://q4os.org q4os-rpi-1-0-cn/main armhf Packages [6,045 B]
60% [Waiting for headers] [5 Packages 1,071 B/6,045 B 18%] [4 InRelease 8,192 B
70% [Waiting for headers] [Waiting for headers] [4 InRelease 8,192 B/22.9 kB 36
70% [5 Packages gzip 0 B] [Waiting for headers] [Waiting for headers] [4 InRele
100% [4 InRelease gpgv 22.9 kB] [Waiting for headers] [Waiting for headers]
Get:6 http://mirrordirector.raspbian.org jessie/main armhf Packages [8,981 kB]
1% [4 InRelease gpgv 22.9 kB] [6 Packages 1,205 B/8,981 kB 0%] [Waiting for hea
1% [6 Packages 18.6 kB/8,981 kB 0%] [Waiting for headers]
Get:7 http://archive.raspberrypi.org jessie/main armhf Packages [144 kB]
1% [6 Packages 69.3 kB/8,981 kB 1%] [Waiting for headers] [7 Packages 1,448 B/1
Get:8 http://q4os.org raspbian-jessie/main armhf Packages [238 kB]
2% [6 Packages 121 kB/8,981 kB 1%] [8 Packages 1,068 B/238 kB 0%] [7 Packages 3
3% [6 Packages 162 kB/8,981 kB 2%] [8 Packages 40.7 kB/238 kB 17%] [7 Packages
6% [6 Packages 246 kB/8,981 kB 3%] [8 Packages 96.8 kB/238 kB 41%]
6% [7 Packages gzip 0 B] [6 Packages 249 kB/8,981 kB 3%] [8 Packages 96.8 kB/23
6% [6 Packages 262 kB/8,981 kB 3%] [8 Packages 96.8 kB/238 kB 41%] [Connecting
Get:9 http://archive.raspberrypi.org jessie/ui armhf Packages [54.8 kB]
8% [6 Packages 353 kB/8,981 kB 4%] [8 Packages 217 kB/238 kB 91%] [9 Packages 3
9% [6 Packages 362 kB/8,981 kB 4%] [9 Packages 30.9 kB/54.8 kB 56%]
9% [8 Packages gzip 0 B] [6 Packages 362 kB/8,981 kB 4%] [9 Packages 30.9 kB/54
9% [8 Packages gzip 0 B] [6 Packages 376 kB/8,981 kB 4%] [Waiting for headers]
9% [6 Packages 376 kB/8,981 kB 4%] [Waiting for headers] [Connecting to archive
9% [9 Packages gzip 0 B] [6 Packages 376 kB/8,981 kB 4%] [Waiting for headers]
9% [6 Packages 382 kB/8,981 kB 4%] [Waiting for headers] [Connecting to archive
11% [6 Packages 576 kB/8,981 kB 6%] [Waiting for headers] [Connecting to archiv
14% [6 Packages 831 kB/8,981 kB 9%] [Waiting for headers] [Waiting for headers]
14% [6 Packages 866 kB/8,981 kB 10%] [Waiting for headers] [Waiting for headers
Ign http://q4os.org q4os-rpi-1-0-cn/main Translation-en_US
14% [6 Packages 883 kB/8,981 kB 10%] [Waiting for headers] [Connecting to archi
15% [6 Packages 900 kB/8,981 kB 10%] [Waiting for headers] [Connecting to archi
Ign http://q4os.org q4os-rpi-1-0-cn/main Translation-en_US.UTF-8
15% [6 Packages 921 kB/8,981 kB 10%] [Waiting for headers] 163 kB/s 49s
Ign http://q4os.org raspbian-jessie/main Translation-en_US
15% [6 Packages 944 kB/8,981 kB 11%] [Waiting for headers] [Connecting to archi
15% [6 Packages 967 kB/8,981 kB 11%] [Waiting for headers] [Waiting for headers
Ign http://q4os.org raspbian-jessie/main Translation-en_US.UTF-8
16% [6 Packages 1,041 kB/8,981 kB 12%] [Connecting to archive.raspberrypi.org (
21% [6 Packages 1,462 kB/8,981 kB 16%] [Waiting for headers]
Ign http://archive.raspberrypi.org jessie/main Translation-en_US
21% [6 Packages 1,467 kB/8,981 kB 16%] 75.5 kB/s 1min 39s
21% [6 Packages 1,517 kB/8,981 kB 17%] 75.5 kB/s 1min 38s
Ign http://archive.raspberrypi.org jessie/main Translation-en_US.UTF-8
22% [6 Packages 1,569 kB/8,981 kB 17%] 75.5 kB/s 1min 38s
Ign http://archive.raspberrypi.org jessie/ui Translation-en_US
22% [6 Packages 1,627 kB/8,981 kB 18%] 75.5 kB/s 1min 37s
23% [6 Packages 1,685 kB/8,981 kB 19%] 75.5 kB/s 1min 36s
Ign http://archive.raspberrypi.org jessie/ui Translation-en_US.UTF-8
26% [6 Packages 1,984 kB/8,981 kB 22%] 114 kB/s 1min 1s
33% [6 Packages 2,597 kB/8,981 kB 29%] 128 kB/s 49s
45% [6 Packages 3,791 kB/8,981 kB 42%] 75.9 kB/s 1min 8s
48% [6 Packages 4,051 kB/8,981 kB 45%] 89.4 kB/s 55s
60% [6 Packages 5,155 kB/8,981 kB 57%] 36.4 kB/s 1min 45s
68% [6 Packages 5,987 kB/8,981 kB 67%] 82.4 kB/s 36s
70% [6 Packages 6,099 kB/8,981 kB 68%] 47.2 kB/s 1min 1s
71% [6 Packages 6,206 kB/8,981 kB 69%] 47.2 kB/s 58s
75% [6 Packages 6,606 kB/8,981 kB 74%] 37.6 kB/s 1min 3s
99% [6 Packages 8,893 kB/8,981 kB 99%] 211 kB/s 0s
100% [Working] 211 kB/s 0s
100% [6 Packages xz 0 B] [Waiting for headers] 211 kB/s 0s
Get:10 http://mirrordirector.raspbian.org jessie/contrib armhf Packages [37.5 kB]
100% [6 Packages xz 0 B] [10 Packages 2,657 B/37.5 kB 7%] 211 kB/s 0s
100% [6 Packages xz 0 B] 211 kB/s 0s
Get:11 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [70.3 kB]
99% [6 Packages xz 0 B] [11 Packages 4,104 B/70.3 kB 6%] 211 kB/s 0s
Get:12 http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1,356 B]
100% [6 Packages xz 0 B] [12 Packages 1,356 B/1,356 B 100%] 211 kB/s 0s
100% [6 Packages xz 0 B] [Waiting for headers] 100 kB/s 0s
100% [Waiting for headers] 100 kB/s 0s
100% [10 Packages xz 0 B] [Waiting for headers] 100 kB/s 0s
100% [11 Packages xz 0 B] [Waiting for headers] 100 kB/s 0s
100% [12 Packages xz 0 B] [Waiting for headers] 100 kB/s 0s
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_US.UTF-8
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_US
100% [Working]
100% [Working]
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_US.UTF-8
100% [Working]
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_US
100% [Working]
100% [Working]
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_US.UTF-8
100% [Working]
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_US
100% [Working]
100% [Working]
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_US.UTF-8
100% [Working]
Fetched 9,576 kB in 2min 18s (68.9 kB/s)
Reading package lists... 99%
Simulation ...
Reading package lists... 100%
alsa-utils is already the newest version.
alsa-utils set to manually installed.
bzip2 is already the newest version.
console-setup is already the newest version.
dosfstools is already the newest version.
eject is already the newest version.
eject set to manually installed.
kbd is already the newest version.
kbd set to manually installed.
nfs-common is already the newest version.
udisks2 is already the newest version.
udisks2 set to manually installed.
unzip is already the newest version.
libarts1-audiofile-trinity is already the newest version.
libarts1-audiofile-trinity set to manually installed.
libarts1-mpeglib-trinity is already the newest version.
libarts1-mpeglib-trinity set to manually installed.
The following extra packages will be installed:
adwaita-icon-theme artsbuilder-trinity at-spi2-core bc cdparanoia cdrdao
cgroup-bin cgroup-tools coinor-libcbc3 coinor-libcgl1 coinor-libclp1
coinor-libcoinmp1 coinor-libcoinutils3 coinor-libosi1 colord colord-data
cups-browsed cups-client cups-common cups-core-drivers cups-daemon
cups-filters cups-filters-core-drivers cups-ppdc cups-server-common
dictionaries-common docbook-xml dvd+rw-tools emacsen-common enchant
epiphany-browser-data evince evince-common exfat-fuse firebird2.5-common
firebird2.5-common-doc firebird2.5-server-common fonts-dejavu-extra
fonts-freefont-ttf fonts-lyx fonts-opensymbol fonts-sil-gentium
fonts-sil-gentium-basic fonts-stix freepats gconf-service gconf2
gconf2-common gcr genisoimage gettext-base ghostscript gir1.2-glib-2.0
gnome-accessibility-themes gnome-desktop3-data gnome-icon-theme
gnome-icon-theme-symbolic gnome-keyring gnome-themes-standard
gnome-themes-standard-data gnome-user-guide gnustep-base-common
gnustep-base-runtime gnustep-common growisofs gsfonts gstreamer0.10-gconf
gstreamer0.10-x gstreamer1.0-alsa gstreamer1.0-omx gstreamer1.0-x
gtk2-engines-pixbuf gvfs gvfs-common gvfs-daemons gvfs-libs hunspell-en-us
hwdata iceowl-extension iso-codes jackd2 k3b-data-trinity liba52-0.7.4
libaa1 libabw-0.1-1 libakode2 libao-common libarchive13 libasprintf0c2
libass5 libatk-bridge2.0-0 libatk1.0-0 libatk1.0-data libatspi2.0-0
libauthen-sasl-perl libavahi-glib1 libavahi-gobject0 libavc1394-0
libavcodec56 libavdevice55 libavfilter5 libavformat56 libavresample2
libavutil54 libbasicusageenvironment0 libblas-common libblas3
libboost-date-time1.55.0 libboost-system1.55.0 libcaca0 libcairo-gobject2
libcairo-perl libcairo2 libcanberra-gtk3-0 libcanberra-gtk3-module
libcanberra0 libcdaudio1 libcddb2 libcdio-cdda1 libcdio-paranoia1 libcdio13
libcdr-0.1-1 libcgroup1 libchromaprint0 libclucene-contribs1
libclucene-core1 libcmis-0.4-4 libcolamd2.8.0 libcolord2 libcolorhug2
libcroco3 libcupscgi1 libcupsfilters1 libcupsimage2 libcupsmime1
libcupsppdc1 libcurl3-gnutls libdatrie1 libdc1394-22 libdca0
libdirac-encoder0 libdirectfb-1.2-9 libdjvulibre-text libdjvulibre21 libdv4
libdvbpsi9 libe-book-0.1-1 libebml4 libenca0 libenchant1c2a
libencode-locale-perl libeot0 libept1.4.12 libetonyek-0.1-1 libevdocument3-4
libevview3-3 libexif12 libexiv2-12 libexttextcat-2.0-0 libexttextcat-data
libfbclient2 libfbembed2.5 libfftw3-double3 libfile-basedir-perl
libfile-copy-recursive-perl libfile-desktopentry-perl libfile-listing-perl
libfile-mimeinfo-perl libflac++6 libflite1 libfluidsynth1 libfont-afm-perl
libfontembed1 libfreehand-0.1-1 libfreerdp-cache1.1 libfreerdp-client1.1
libfreerdp-codec1.1 libfreerdp-common1.1.0 libfreerdp-core1.1
libfreerdp-crypto1.1 libfreerdp-gdi1.1 libfreerdp-locale1.1
libfreerdp-primitives1.1 libfreerdp-rail1.1 libfreerdp-utils1.1 libfribidi0
libgck-1-0 libgconf-2-4 libgcr-3-common libgcr-base-3-1 libgcr-ui-3-1 libgd3
libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libgeoclue0 libgfortran3
libgirepository-1.0-1 libgksu2-0 libgles1-mesa libgles2-mesa libglew1.10
libglib-perl libgltf-0.0-0 libgme0 libgnome-desktop-3-10
libgnome-keyring-common libgnome-keyring0 libgnustep-base1.24 libgomp1
libgphoto2-6 libgphoto2-l10n libgphoto2-port10 libgpm2 libgraphite2-3
libgroupsock1 libgs9 libgs9-common libgsm1 libgstreamer-plugins-bad0.10-0
libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base0.10-0
libgstreamer-plugins-base1.0-0 libgstreamer0.10-0 libgstreamer1.0-0
libgtk-3-0 libgtk-3-bin libgtk-3-common libgtk2-perl libgtk2.0-0
libgtk2.0-bin libgtk2.0-common libgtkglext1 libgtop2-7 libgtop2-common
libgusb2 libgutenprint2 libgxps2 libharfbuzz-icu0 libharfbuzz0b
libhsqldb1.8.0-java libhtml-form-perl libhtml-format-perl
libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl
libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl
libhttp-message-perl libhttp-negotiate-perl libhunspell-1.3-0 libhyphen0
libiec61883-0 libieee1284-3 libijs-0.35 libio-html-perl
libio-socket-ssl-perl libiso9660-8 libjack-jackd2-0
libjavascriptcoregtk-3.0-0 libjbig2dec0 libjson-glib-1.0-0
libjson-glib-1.0-common libk3b3-trinity libkate1 libkipi0-trinity
libkpathsea6 liblangtag-common liblangtag1 liblapack3 liblircclient0
liblivemedia23 libltdl7 liblua5.2-0 liblwp-mediatypes-perl
liblwp-protocol-https-perl liblzo2-2 libmailtools-perl libmatroska6
libmhash2 libmimic0 libmjpegutils-2.1-0 libmms0 libmodplug1 libmpcdec6
libmpeg2-4 libmpeg2encpp-2.1-0 libmpg123-0 libmplex2-2.1-0 libmspub-0.1-1
libmtp-common libmtp-runtime libmtp9 libmwaw-0.3-3 libmythes-1.2-0
libnautilus-extension1a libneon27-gnutls libnet-dbus-perl libnet-http-perl
libnet-smtp-ssl-perl libnet-ssleay-perl libnotify4 libnspr4 libnss3 libobjc4
libodfgen-0.1-1 libofa0 libopenal-data libopenal1 libopencv-calib3d2.4
libopencv-contrib2.4 libopencv-core2.4 libopencv-features2d2.4
libopencv-flann2.4 libopencv-highgui2.4 libopencv-imgproc2.4
libopencv-legacy2.4 libopencv-ml2.4 libopencv-objdetect2.4
libopencv-video2.4 libopenjpeg5 libopus0 liborc-0.4-0 liborcus-0.8-0
libpam-gnome-keyring libpango-1.0-0 libpango-perl libpango1.0-0
libpangocairo-1.0-0 libpangoft2-1.0-0 libpangox-1.0-0 libpangoxft-1.0-0
libpci3 libperl4-corelibs-perl libpoppler-glib8 libpoppler-qt5-1
libpoppler46 libpostproc52 libproxy-tools libpython3.4 libqpdf13 libqt4-dbus
libqt4-xml libqt5core5a libqt5dbus5 libqt5gui5 libqt5printsupport5
libqt5sql5 libqt5sql5-sqlite libqt5svg5 libqt5widgets5 libqt5xml5 libqtcore4
libqtdbus4 libqtgui4 libraptor2-0 librarian0 librasqal3 librdf0
libreoffice-avmedia-backend-gstreamer libreoffice-base libreoffice-base-core
libreoffice-base-drivers libreoffice-calc libreoffice-common
libreoffice-core libreoffice-draw libreoffice-impress
libreoffice-java-common libreoffice-math libreoffice-report-builder-bin
libreoffice-sdbc-firebird libreoffice-sdbc-hsqldb libreoffice-style-galaxy
libreoffice-writer libresid-builder0c2a librest-0.7-0 librevenge-0.0-0
librsvg2-2 librsvg2-common librtmp1 libsane libsane-common libsane-extras
libsane-extras-common libsbc1 libschroedinger-1.0-0 libsdl-image1.2
libsdl1.2debian libsecret-1-0 libsecret-common libservlet2.5-java libshine3
libshout3 libsidplay1 libsidplay2 libslv2-9 libsoundtouch0
libsoup-gnome2.4-1 libspandsp2 libspectre1 libspeex1 libspeexdsp1 libsrtp0
libssh-4 libssh2-1 libstartup-notification0 libswscale3 libtag1-vanilla
libtag1c2a libtdegames1-trinity libthai-data libthai0 libtheora0
libtie-ixhash-perl libtimedate-perl libtwolame0 libupnp6 liburi-perl
libusageenvironment1 libv4l-0 libv4l2rds0 libv4lconvert0 libva-drm1
libva-x11-1 libva1 libvcdinfo0 libvisio-0.1-1 libvisual-0.4-0
libvisual-0.4-plugins libvlc5 libvlccore8 libvncclient0 libvo-aacenc0
libvo-amrwbenc0 libvpx1 libvte-2.90-9 libvte-2.90-common libwavpack1
libwayland-cursor0 libwayland-egl1-mesa libwebkitgtk-3.0-0
libwebkitgtk-3.0-common libwebp5 libwildmidi-config libwildmidi1
libwinpr-crt0.1 libwinpr-crypto0.1 libwinpr-dsparse0.1
libwinpr-environment0.1 libwinpr-file0.1 libwinpr-handle0.1 libwinpr-heap0.1
libwinpr-input0.1 libwinpr-interlocked0.1 libwinpr-library0.1
libwinpr-path0.1 libwinpr-pool0.1 libwinpr-registry0.1 libwinpr-rpc0.1
libwinpr-sspi0.1 libwinpr-synch0.1 libwinpr-sysinfo0.1 libwinpr-thread0.1
libwinpr-utils0.1 libwnck-3-0 libwnck-3-common libwpd-0.10-10 libwpg-0.3-3
libwps-0.3-3 libwww-perl libwww-robotrules-perl libx11-protocol-perl
libx264-142 libxcb-composite0 libxcb-icccm4 libxcb-image0 libxcb-keysyms1
libxcb-randr0 libxcb-render-util0 libxcb-shm0 libxcb-util0 libxcb-xkb1
libxcb-xv0 libxkbcommon-x11-0 libxkbcommon0 libxml-parser-perl
libxml-twig-perl libxml-xpathengine-perl libxres1 libxvidcore4 libyajl2
libyelp0 libzbar0 libzvbi-common libzvbi0 lp-solve ncompress
notification-daemon p11-kit p11-kit-modules p7zip-full pciutils pigpio
poppler-data poppler-utils printer-driver-gutenprint python-crypto
python-dbus python-dbus-dev python-gi python-ldb python-ntdb python-samba
python-tdb python3-dbus python3-gi python3-software-properties python3-uno
qdbus qjackctl qpdf qpdfview-djvu-plugin qpdfview-ps-plugin qtchooser
qtcore4-l10n qttranslations5-l10n rarian-compat samba-common-bin sane-utils
sgml-base sgml-data squeak-plugins-scratch squeak-vm ssl-cert
tdegames-card-data-trinity unar uno-libs3 update-inetd ure vlc-data vlc-nox
vlc-plugin-notify vlc-plugin-samba wodim xdg-utils xfonts-encodings
xfonts-mathml xfonts-utils xml-core yelp yelp-xsl zenity zenity-common zoo
Suggested packages:
rar cups-bsd printer-driver-hpcups hplip cups-pdf smbclient xpp ispell
aspell hunspell wordlist docbook docbook-dsssl docbook-xsl docbook-defguide
cdrskin unrar nautilus gconf-defaults-service cdrkit-doc ghostscript-x
gnustep-base-doc frei0r-plugins gvfs-backends gwenview-i18n
openoffice.org-hunspell openoffice.org-core calendar-google-provider
isoquery jack-tools meterbridge normalize-audio toolame sox movixmaker-2
vcdimager libesd0 libesd-alsa0 lrzip libdigest-hmac-perl libgssapi-perl
libbluray-bdj libfont-freetype-perl libcanberra-gtk0 libcanberra-pulse
libchromaprint-tools python-acoustid libdv-bin oss-compat libdvdcss2
libenchant-voikko exiv2 libfftw3-bin libfftw3-dev freerdp-x11 libgd-tools
geoclue glew-utils gphoto2 gtkam gpm gstreamer-codec-install
gnome-codec-install gstreamer0.10-tools gstreamer1.0-tools libgtk2-perl-doc
gutenprint-locales java-virtual-machine libhsqldb1.8.0-java-gcj
libdata-dump-perl lirc libcrypt-ssleay-perl libportaudio2 opus-tools
qt4-qtconfig raptor2-utils rasqal-utils librdf-storage-postgresql
librdf-storage-mysql librdf-storage-sqlite librdf-storage-virtuoso
redland-utils hyphen-hyphenation-patterns imagemagick
graphicsmagick-imagemagick-compat libreoffice-gnome libreoffice-kde
libreoffice-grammarcheck libreoffice-help-4.3 libreoffice-l10n-4.3
mythes-thesaurus openclipart-libreoffice pstoedit unixodbc
gstreamer1.0-ffmpeg default-jre gcj-jre openjdk-7-jre openjdk-6-jre
java5-runtime jre libreoffice-officebean libreoffice-gcj
libreoffice-report-builder libjtds-java libreoffice-mysql-connector
libmyodbc libmysql-java libreoffice-sdbc-postgresql odbc-postgresql
libpg-java libsqliteodbc tdsodbc mdbtools ocl-icd-libopencl1
libreoffice-style-crystal libreoffice-style-hicontrast
libreoffice-style-oxygen libreoffice-style-sifr libreoffice-style-tango
fonts-crosextra-caladea fonts-crosextra-carlito librsvg2-bin hpoj
sidplay-base xsidplay slv2-jack libspectre1-dbg speex srtp-utils
libauthen-ntlm-perl libunicode-map8-perl libunicode-string-perl
xml-twig-tools p7zip-rar fonts-japanese-mincho fonts-ipafont-mincho
fonts-japanese-gothic fonts-ipafont-gothic fonts-arphic-ukai
fonts-arphic-uming fonts-nanum gutenprint-doc python-crypto-dbg
python-crypto-doc python-dbus-doc python-dbus-dbg python-gi-cairo
python3-dbus-dbg pulseaudio-utils heimdal-clients unpaper pulseaudio
sgml-base-doc perlsgml w3-recs opensp libxml2-utils
squeak-plugins-scratch-dbg etoys openssl-blacklist dwww menu deborphan
apt-xapian-index tasksel software-properties-gtk pike7.8 pike7.6 pike
videolan-doc gvfs-bin debhelper
Recommended packages:
tdegraphics-tdefile-plugins-trinity kipi-plugins-trinity myspell-en-us
hunspell-dictionary myspell-dictionary libk3b3-extracodecs-trinity
adwaita-icon-theme apt-transport-https ark-trinity artsbuilder-trinity
at-spi2-core bc bluej cdparanoia cdrdao cgroup-bin cgroup-tools
coinor-libcbc3 coinor-libcgl1 coinor-libclp1 coinor-libcoinmp1
coinor-libcoinutils3 coinor-libosi1 colord colord-data cups cups-browsed
cups-client cups-common cups-core-drivers cups-daemon cups-filters
cups-filters-core-drivers cups-ppdc cups-server-common dictionaries-common
docbook-xml dvd+rw-tools emacsen-common enchant epiphany-browser
epiphany-browser-data evince evince-common exfat-fuse exfat-utils
firebird2.5-common firebird2.5-common-doc firebird2.5-server-common
fonts-dejavu fonts-dejavu-extra fonts-freefont-ttf fonts-lyx
fonts-opensymbol fonts-sil-gentium fonts-sil-gentium-basic fonts-stix
freepats gconf-service gconf2 gconf2-common gcr gdisk genisoimage
geoip-database gettext-base ghostscript gir1.2-glib-2.0 gksu
gstreamer0.10-plugins-bad gstreamer0.10-plugins-base
gstreamer0.10-plugins-good gstreamer0.10-plugins-ugly gstreamer0.10-x
gstreamer1.0-alsa gstreamer1.0-libav gstreamer1.0-omx
gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good
gstreamer1.0-plugins-ugly gstreamer1.0-x gtk2-engines gtk2-engines-pixbuf
gvfs gvfs-common gvfs-daemons gvfs-libs gwenview-i18n-trinity
gwenview-trinity hunspell-en-us hwdata icedove iceowl-extension iso-codes
jackd jackd2 k3b-data-trinity k3b-i18n-trinity k3b-trinity kbounce-trinity
kcalc-trinity kmag-trinity kmines-trinity kolourpaint-trinity kpat-trinity
krec-trinity ksnapshot-trinity liba52-0.7.4 libaa1 libaacs0 libabw-0.1-1
libakode2 libao-common libao4 libarchive13 libarts1-akode-trinity
libasprintf0c2 libass5 libatk-bridge2.0-0 libatk1.0-0 libatk1.0-data
libatspi2.0-0 libauthen-sasl-perl libav-tools libavahi-glib1
libavahi-gobject0 libavc1394-0 libavcodec56 libavdevice55 libavfilter5
libavformat56 libavresample2 libavutil54 libbasicusageenvironment0
libblas-common libblas3 libbluray1 libboost-date-time1.55.0
libboost-system1.55.0 libcaca0 libcairo-gobject2 libcairo-perl libcairo2
libcanberra-gtk3-0 libcanberra-gtk3-module libcanberra0 libcdaudio1 libcddb2
libcdio-cdda1 libcdio-paranoia1 libcdio13 libcdr-0.1-1 libcgroup1
libchromaprint0 libclucene-contribs1 libclucene-core1 libcmis-0.4-4
libcolamd2.8.0 libcolord2 libcolorhug2 libcroco3 libcupscgi1 libcupsfilters1
libcupsimage2 libcupsmime1 libcupsppdc1 libcurl3-gnutls libdatrie1
libdc1394-22 libdca0 libdirac-encoder0 libdirectfb-1.2-9 libdjvulibre-text
libdjvulibre21 libdv4 libdvbpsi9 libdvdnav4 libdvdread4 libe-book-0.1-1
libebml4 libenca0 libenchant1c2a libencode-locale-perl libeot0 libept1.4.12
libetonyek-0.1-1 libevdocument3-4 libevview3-3 libexif12 libexiv2-12
libexttextcat-2.0-0 libexttextcat-data libfaad2 libfbclient2 libfbembed2.5
libfftw3-double3 libfile-basedir-perl libfile-copy-recursive-perl
libfile-desktopentry-perl libfile-listing-perl libfile-mimeinfo-perl
libflac++6 libflite1 libfluidsynth1 libfont-afm-perl libfontembed1
libmhash2 libmimic0 libmjpegutils-2.1-0 libmms0 libmodplug1 libmp3lame0
libmp4v2-2 libmpcdec6 libmpeg2-4 libmpeg2encpp-2.1-0 libmpg123-0
libmplex2-2.1-0 libmspub-0.1-1 libmtp-common libmtp-runtime libmtp9
libmwaw-0.3-3 libmythes-1.2-0 libnautilus-extension1a libneon27-gnutls
libnet-dbus-perl libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl
libnotify4 libnspr4 libnss3 libobjc4 libodfgen-0.1-1 libofa0 libopenal-data
libopenal1 libopencore-amrnb0 libopencore-amrwb0 libopencv-calib3d2.4
libpaper-utils libpci3 libperl4-corelibs-perl libpoppler-glib8
libpoppler-qt5-1 libpoppler46 libpostproc52 libproxy-tools libpython3.4
libqpdf13 libqt4-dbus libqt4-xml libqt5core5a libqt5dbus5 libqt5gui5
libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite libqt5svg5 libqt5widgets5
libqt5xml5 libqtcore4 libqtdbus4 libqtgui4 libraptor2-0 librarian0
librasqal3 librdf0 libreoffice libreoffice-avmedia-backend-gstreamer
libreoffice-base libreoffice-base-core libreoffice-base-drivers
libreoffice-calc libreoffice-common libreoffice-core libreoffice-draw
libreoffice-impress libreoffice-java-common libreoffice-math
libreoffice-report-builder-bin libreoffice-sdbc-firebird
libreoffice-sdbc-hsqldb libreoffice-style-galaxy libreoffice-writer
libresid-builder0c2a librest-0.7-0 librevenge-0.0-0 librsvg2-2
notification-daemon nuscratch omxplayer oracle-java8-jdk p11-kit
p11-kit-modules p7zip-full pciutils pigpio policykit-1-gnome poppler-data
poppler-utils printer-driver-gutenprint python-crypto python-dbus
python-dbus-dev python-gi python-ldb python-ntdb python-samba python-tdb
q4os-wallpapers qdbus qjackctl qpdf qpdfview qpdfview-djvu-plugin
qpdfview-ps-plugin qpdfview-translations qtchooser qtcore4-l10n
qttranslations5-l10n rarian-compat raspberrypi-artwork rsync samba-common
samba-common-bin sane-utils scratch sgml-base sgml-data
software-properties-common squeak-plugins-scratch squeak-vm ssl-cert
synaptic tdegames-card-data-trinity twolame unar uno-libs3 unrar-free
update-inetd ure v4l-utils va-driver-all vlc vlc-data vlc-nox
xfonts-mathml xfonts-utils xml-core yelp yelp-xsl zenity zenity-common zip
zoo
The following packages will be upgraded:
ntfs-3g
1 upgraded, 622 newly installed, 0 to remove and 21 not upgraded.
Inst libasprintf0c2 (0.19.3-2 Raspbian:stable [armhf])
Inst libgpm2 (1.20.4-6.1 Raspbian:stable [armhf])
Inst libpci3 (1:3.2.1-3 Raspbian:stable [armhf])
Inst libcupsmime1 (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Inst ssl-cert (1.0.35 Raspbian:stable [all])
Inst bc (1.06.95-9 Raspbian:stable [armhf])
Inst cups-daemon (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Inst libatk1.0-data (2.14.0-1 Raspbian:stable [all])
Inst libatk1.0-0 (2.14.0-1 Raspbian:stable [armhf])
Inst libatspi2.0-0 (2.14.0-1 Raspbian:stable [armhf])
Inst libatk-bridge2.0-0 (2.14.0-2 Raspbian:stable [armhf])
Inst libxcb-shm0 (1.10-3 Raspbian:stable [armhf])
Inst libcairo2 (1.14.0-2.1+deb8u2+rpi1 Raspberry Pi Foundation:stable [armhf])
Inst libcairo-gobject2 (1.14.0-2.1+deb8u2+rpi1 Raspberry Pi Foundation:stable [armhf])
Inst libgdk-pixbuf2.0-common (2.31.1-2+deb8u5 Raspbian:stable [all])
Inst libgdk-pixbuf2.0-0 (2.31.1-2+deb8u5 Raspbian:stable [armhf])
Inst libgtk-3-common (3.14.5-1+deb8u1rpi1rpi1g Raspberry Pi Foundation:stable [all]) []
Inst libcolord2 (1.2.1-1+b2 Raspbian:stable [armhf]) []
Inst libjson-glib-1.0-common (1.0.2-1 Raspbian:stable [all]) []
Inst libjson-glib-1.0-0 (1.0.2-1 Raspbian:stable [armhf]) []
Inst libthai-data (0.1.21-1 Raspbian:stable [all]) []
Inst libdatrie1 (0.2.8-1 Raspbian:stable [armhf]) []
Inst libthai0 (0.1.21-1 Raspbian:stable [armhf]) []
Inst libpango-1.0-0 (1.36.8-3+rpi1 Raspberry Pi Foundation:stable [armhf]) []
Inst libgraphite2-3 (1.3.6-1~deb8u1 Raspbian:stable [armhf]) []
Inst libharfbuzz0b (0.9.35-2 Raspbian:stable [armhf]) []
Inst libpangoft2-1.0-0 (1.36.8-3+rpi1 Raspberry Pi Foundation:stable [armhf]) []
Inst libpangocairo-1.0-0 (1.36.8-3+rpi1 Raspberry Pi Foundation:stable [armhf]) []
Inst libsoup-gnome2.4-1 (2.48.0-1 Raspbian:stable [armhf]) []
Inst librest-0.7-0 (0.7.92-3 Raspbian:stable [armhf]) []
Inst libwayland-cursor0 (1.11.0-2 Raspberry Pi Foundation:stable [armhf]) []
Inst libxkbcommon0 (0.4.3-2 Raspbian:stable [armhf]) []
Inst libgtk-3-0 (3.14.5-1+deb8u1rpi1rpi1g Raspberry Pi Foundation:stable [armhf]) []
Inst libgtk-3-bin (3.14.5-1+deb8u1rpi1rpi1g Raspberry Pi Foundation:stable [armhf]) []
Inst libcroco3 (0.6.8-3 Raspbian:stable [armhf]) []
Inst librsvg2-2 (2.40.5-1+deb8u2 Raspbian:stable [armhf]) []
Inst librsvg2-common (2.40.5-1+deb8u2 Raspbian:stable [armhf]) []
Inst adwaita-icon-theme (3.14.0-2 Raspbian:stable [all])
Inst gnome-themes-standard-data (3.14.2.2-1rpi1rpi1g Raspberry Pi Foundation:stable [all])
Inst libgtk2.0-common (2.24.25-3+deb8u1 Raspbian:stable [all])
Inst libgtk2.0-0 (2.24.25-3+deb8u1 Raspbian:stable [armhf])
Inst gnome-themes-standard (3.14.2.2-1rpi1rpi1g Raspberry Pi Foundation:stable [armhf])
Inst libopus0 (1.1-2 Raspbian:stable [armhf])
Inst libjack-jackd2-0 (1.9.10+20140719git3eb0ae6a~dfsg-2 Raspbian:stable [armhf])
Inst python-dbus-dev (1.2.0-2 Raspbian:stable [all])
Inst python-dbus (1.2.0-2+b1 Raspbian:stable [armhf])
Inst jackd2 (1.9.10+20140719git3eb0ae6a~dfsg-2 Raspbian:stable [armhf])
Inst libdvdread4 (5.0.0-1 Raspbian:stable [armhf])
Inst libflac++6 (1.3.0-3 Raspbian:stable [armhf])
Inst libk3b3-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst wodim (9:1.1.11-3 Raspbian:stable [armhf])
Inst cdparanoia (3.10.2+debian-11 Raspbian:stable [armhf])
Inst genisoimage (9:1.1.11-3 Raspbian:stable [armhf])
Inst libao-common (1.1.0-3 Raspbian:stable [armhf])
Inst libao4 (1.1.0-3 Raspbian:stable [armhf])
Inst cdrdao (1:1.2.3-2 Raspbian:stable [armhf])
Inst k3b-data-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [all])
Inst k3b-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst k3b-i18n-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [all])
Inst libaa1 (1.4p5-43 Raspbian:stable [armhf])
Inst libaacs0 (0.7.1-1+b1 Raspbian:stable [armhf])
Inst liblzo2-2 (2.08-1.2 Raspbian:stable [armhf])
Inst libarchive13 (3.1.2-11+deb8u3 Raspbian:stable [armhf])
Inst libavutil54 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Inst libavresample2 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Inst libgsm1 (1.0.13-4 Raspbian:stable [armhf])
Inst libmp3lame0 (3.99.5+repack1-7+deb8u1 Raspbian:stable [armhf])
Inst libopenjpeg5 (1:1.5.2-3 Raspbian:stable [armhf])
Inst liborc-0.4-0 (1:0.4.22-1rpi1rpi1g Raspberry Pi Foundation:stable [armhf])
Inst libschroedinger-1.0-0 (1.0.11-2.1 Raspbian:stable [armhf])
Inst libspeex1 (1.2~rc1.2-1 Raspbian:stable [armhf])
Inst libtheora0 (1.1.1+dfsg.1-6 Raspbian:stable [armhf])
Inst libva1 (1.7.3-2 Raspberry Pi Foundation:stable [armhf])
Inst libvpx1 (1.3.0-3+rvt Raspbian:stable [armhf])
Inst libx264-142 (2:0.142.2431+gita5831aa-1+rpi2 Raspbian:stable [armhf])
Inst libxvidcore4 (2:1.3.3-1 Raspbian:stable [armhf])
Inst libavcodec56 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Inst librtmp1 (2.4+20150115.gita107cef-1 Raspbian:stable [armhf])
Inst libavformat56 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Inst libcdio13 (0.83-4.2 Raspbian:stable [armhf])
Inst libcdio-cdda1 (0.83-4.2 Raspbian:stable [armhf])
Inst libcdio-paranoia1 (0.83-4.2 Raspbian:stable [armhf])
Inst libdc1394-22 (2.2.3-1 Raspbian:stable [armhf])
Inst libavdevice55 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Inst libopencv-core2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Inst libopencv-imgproc2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Inst libswscale3 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Inst libavfilter5 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Inst libcaca0 (0.99.beta19-2 Raspbian:stable [armhf])
Inst libdirectfb-1.2-9 (1.2.10.0-5.1 Raspbian:stable [armhf])
Inst libsdl1.2debian (1.2.15-10+rpi1 Raspberry Pi Foundation:stable [armhf])
Inst libav-tools (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Inst libavahi-glib1 (0.6.31-5 Raspbian:stable [armhf])
Inst libavahi-gobject0 (0.6.31-5 Raspbian:stable [armhf])
Inst libavc1394-0 (0.5.4-2 Raspbian:stable [armhf])
Inst libbasicusageenvironment0 (2014.01.13-1 Raspbian:stable [armhf])
Inst libbluray1 (1:0.6.2-1 Raspbian:stable [armhf])
Inst libboost-date-time1.55.0 (1.55.0+dfsg-3 Raspbian:stable [armhf])
Inst libboost-system1.55.0 (1.55.0+dfsg-3 Raspbian:stable [armhf])
Inst libltdl7 (2.4.2-1.11 Raspbian:stable [armhf])
Inst libcanberra0 (0.30-2.1 Raspbian:stable [armhf])
Inst libcanberra-gtk3-0 (0.30-2.1 Raspbian:stable [armhf])
Inst libcgroup1 (0.41-6+rpi1 Raspbian:stable [armhf])
Inst libchromaprint0 (1.2-1 Raspbian:stable [armhf])
Inst libclucene-core1 (2.3.3.4-4 Raspbian:stable [armhf])
Inst libclucene-contribs1 (2.3.3.4-4 Raspbian:stable [armhf])
Inst libcolamd2.8.0 (1:4.2.1-3 Raspbian:stable [armhf])
Inst libgusb2 (0.1.6-5 Raspbian:stable [armhf])
Inst libcolorhug2 (1.2.1-1+b2 Raspbian:stable [armhf])
Inst libcupscgi1 (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Inst libcupsimage2 (1.7.5-11+deb8u1 Raspbian:stable [armhf]) []
Inst libcupsfilters1 (1.0.61-5+deb8u3 Raspbian:stable [armhf])
Inst libcupsppdc1 (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Inst libssh2-1 (1.4.3-4.1+deb8u1 Raspbian:stable [armhf])
Inst libcurl3-gnutls (7.38.0-4+deb8u5 Raspbian:stable [armhf])
Inst libdca0 (0.0.5-7 Raspbian:stable [armhf])
Inst libdirac-encoder0 (1.0.2-7.1 Raspbian:stable [armhf])
Inst libdjvulibre-text (3.5.25.4-4 Raspbian:stable [all])
Inst libdjvulibre21 (3.5.25.4-4+b1 Raspbian:stable [armhf])
Inst libdv4 (1.0.0-6 Raspbian:stable [armhf])
Inst libdvbpsi9 (1.2.0-1 Raspbian:stable [armhf])
Inst libdvdnav4 (5.0.1-1 Raspbian:stable [armhf])
Inst libebml4 (1.3.0-2+deb8u1 Raspbian:stable [armhf])
Inst libenca0 (1.16-1 Raspbian:stable [armhf])
Inst emacsen-common (2.0.8 Raspbian:stable [all])
Inst dictionaries-common (1.23.17 Raspbian:stable [all])
Inst hunspell-en-us (20070829-6 Raspbian:stable [all])
Inst libhunspell-1.3-0 (1.3.3-3 Raspbian:stable [armhf])
Inst libenchant1c2a (1.6.0-10.1 Raspbian:stable [armhf])
Inst libexif12 (0.6.21-2 Raspbian:stable [armhf])
Inst libfaad2 (2.7-8 Raspbian:stable [armhf])
Inst firebird2.5-common-doc (2.5.3.26778.ds4-5 Raspbian:stable [all])
Inst firebird2.5-common (2.5.3.26778.ds4-5 Raspbian:stable [all])
Inst libfbclient2 (2.5.3.26778.ds4-5 Raspbian:stable [armhf])
Inst firebird2.5-server-common (2.5.3.26778.ds4-5 Raspbian:stable [armhf])
Inst libfbembed2.5 (2.5.3.26778.ds4-5 Raspbian:stable [armhf])
Inst libgomp1 (4.9.2-10 Raspbian:stable [armhf])
Inst libfftw3-double3 (3.3.4-2+rvt Raspbian:stable [armhf])
Inst libflite1 (1.4-release-12 Raspbian:stable [armhf])
Inst libfluidsynth1 (1.1.6-2 Raspbian:stable [armhf])
Inst libfontembed1 (1.0.61-5+deb8u3 Raspbian:stable [armhf])
Inst libwinpr-sysinfo0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libfreerdp-primitives1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-crt0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-environment0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-handle0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-heap0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-interlocked0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-path0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-thread0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-synch0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-utils0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libfreerdp-utils1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-pool0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-registry0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libfreerdp-codec1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-file0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-library0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libfreerdp-common1.1.0 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-crypto0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-sspi0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libfreerdp-crypto1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-input0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libfreerdp-locale1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-dsparse0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libwinpr-rpc0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libfreerdp-core1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libfreerdp-cache1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libfreerdp-client1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libfreerdp-gdi1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libfreerdp-rail1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Inst libfribidi0 (0.19.6-3 Raspbian:stable [armhf])
Inst libgck-1-0 (3.14.0-2+b1 Raspbian:stable [armhf])
Inst gconf2-common (3.2.6-3 Raspbian:stable [all])
Inst libgconf-2-4 (3.2.6-3 Raspbian:stable [armhf])
Inst libgcr-3-common (3.14.0-2 Raspbian:stable [all])
Inst libgcr-base-3-1 (3.14.0-2+b1 Raspbian:stable [armhf])
Inst libgcr-ui-3-1 (3.14.0-2+b1 Raspbian:stable [armhf])
Inst libgd3 (2.1.0-5+deb8u9 Raspbian:stable [armhf])
Inst libgeoclue0 (0.12.99-4+b1 Raspbian:stable [armhf])
Inst libgfortran3 (4.9.2-10 Raspbian:stable [armhf])
Inst libgles2-mesa (13.0.0-1+rpi1 Raspberry Pi Foundation:stable [armhf])
Inst libglew1.10 (1.10.0-3 Raspbian:stable [armhf])
Inst libgnome-keyring-common (3.12.0-1 Raspbian:stable [all])
Inst libgnome-keyring0 (3.12.0-1+b1 Raspbian:stable [armhf])
Inst libgphoto2-port10 (2.5.4-1.1 Raspbian:stable [armhf])
Inst libgphoto2-6 (2.5.4-1.1 Raspbian:stable [armhf])
Inst libgroupsock1 (2014.01.13-1 Raspbian:stable [armhf])
Inst libgstreamer0.10-0 (0.10.36-1.5 Raspbian:stable [armhf])
Inst iso-codes (3.57-1 Raspbian:stable [all])
Inst libgstreamer-plugins-base0.10-0 (0.10.36-2 Raspbian:stable [armhf])
Inst libgstreamer1.0-0 (1.4.4-2 Raspbian:stable [armhf])
Inst libgstreamer-plugins-base1.0-0 (1.4.4-2 Raspbian:stable [armhf])
Inst libgutenprint2 (5.2.10-3+b3 Raspbian:stable [armhf])
Inst libgxps2 (0.2.2-3 Raspbian:stable [armhf])
Inst libharfbuzz-icu0 (0.9.35-2 Raspbian:stable [armhf])
Inst libiec61883-0 (1.2.0-0.2 Raspbian:stable [armhf])
Inst libieee1284-3 (0.2.11-12 Raspbian:stable [armhf])
Inst libijs-0.35 (0.35-10 Raspbian:stable [armhf])
Inst libjavascriptcoregtk-3.0-0 (1:2.4.1-1rpi53rpi1g Raspberry Pi Foundation:stable [armhf])
Inst liblivemedia23 (2014.01.13-1 Raspbian:stable [armhf])
Inst liblua5.2-0 (5.2.3-1.1 Raspbian:stable [armhf])
Inst libmatroska6 (1.4.1-2+deb8u1 Raspbian:stable [armhf])
Inst libmhash2 (0.9.9.9-7 Raspbian:stable [armhf])
Inst libmjpegutils-2.1-0 (1:2.1.0+debian-3 Raspbian:stable [armhf])
Inst libmms0 (0.6.2-4 Raspbian:stable [armhf])
Inst libmp4v2-2 (2.0.0~dfsg0-3 Raspbian:stable [armhf])
Inst libmpcdec6 (2:0.1~r459-4.1 Raspbian:stable [armhf])
Inst libmpeg2-4 (0.5.1-7 Raspbian:stable [armhf])
Inst libmpeg2encpp-2.1-0 (1:2.1.0+debian-3 Raspbian:stable [armhf])
Inst libmpg123-0 (1.20.1-2+deb8u1 Raspbian:stable [armhf])
Inst libmplex2-2.1-0 (1:2.1.0+debian-3 Raspbian:stable [armhf])
Inst libmtp-common (1.1.8-1 Raspbian:stable [all])
Inst libmtp9 (1.1.8-1+b1 Raspbian:stable [armhf])
Inst libnotify4 (0.7.6-2 Raspbian:stable [armhf])
Inst libnspr4 (2:4.12-1+debu8u1 Raspbian:stable [armhf])
Inst libnss3 (2:3.26-1+debu8u1 Raspbian:stable [armhf])
Inst libobjc4 (4.9.2-10 Raspbian:stable [armhf])
Inst libopenal-data (1:1.15.1-5 Raspbian:stable [all])
Inst libopenal1 (1:1.15.1-5 Raspbian:stable [armhf])
Inst libopencore-amrnb0 (0.1.3-2.1 Raspbian:stable [armhf])
Inst libopencore-amrwb0 (0.1.3-2.1 Raspbian:stable [armhf])
Inst libopencv-flann2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Inst libpangox-1.0-0 (0.0.2-5 Raspbian:stable [armhf])
Inst libgtkglext1 (1.2.0-3.2 Raspbian:stable [armhf])
Inst libv4lconvert0 (1.6.0-2 Raspbian:stable [armhf])
Inst libv4l-0 (1.6.0-2 Raspbian:stable [armhf])
Inst libopencv-highgui2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Inst libopencv-features2d2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Inst libopencv-calib3d2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Inst libopencv-ml2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Inst libopencv-objdetect2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Inst libopencv-video2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Inst libopencv-contrib2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Inst libopencv-legacy2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Inst libpangoxft-1.0-0 (1.36.8-3+rpi1 Raspberry Pi Foundation:stable [armhf])
Inst libpoppler46 (0.26.5-2+deb8u1 Raspbian:stable [armhf])
Inst libpoppler-glib8 (0.26.5-2+deb8u1 Raspbian:stable [armhf])
Inst libqt5core5a (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Inst libqt5dbus5 (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Inst libxcb-icccm4 (0.4.1-1 Raspbian:stable [armhf])
Inst libxcb-util0 (0.3.8-3 Raspbian:stable [armhf])
Inst libxcb-image0 (0.4.0-1 Raspbian:stable [armhf])
Inst libxcb-keysyms1 (0.4.0-1 Raspbian:stable [armhf])
Inst libxcb-randr0 (1.10-3 Raspbian:stable [armhf])
Inst libxcb-render-util0 (0.3.9-1 Raspbian:stable [armhf])
Inst libxcb-xkb1 (1.10-3 Raspbian:stable [armhf])
Inst libxkbcommon-x11-0 (0.4.3-2 Raspbian:stable [armhf])
Inst libqt5gui5 (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Inst libqt5widgets5 (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Inst libqt5xml5 (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Inst libpoppler-qt5-1 (0.26.5-2+deb8u1 Raspbian:stable [armhf])
Inst libpython3.4 (3.4.2-1 Raspbian:stable [armhf])
Inst libqpdf13 (5.1.2-2 Raspbian:stable [armhf])
Inst qtcore4-l10n (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [all])
Inst libqtcore4 (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [armhf])
Inst libqt4-xml (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [armhf])
Inst libqt5printsupport5 (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Inst libqt5sql5 (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Inst libqt5sql5-sqlite (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Inst libqt5svg5 (5.3.2-2 Raspbian:stable [armhf])
Inst libqtdbus4 (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [armhf])
Inst libqtgui4 (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [armhf])
Inst libyajl2 (2.1.0-2 Raspbian:stable [armhf])
Inst libraptor2-0 (2.0.14-1 Raspbian:stable [armhf])
Inst librasqal3 (0.9.32-1 Raspbian:stable [armhf])
Inst librdf0 (1.0.17-1+b1 Raspbian:stable [armhf])
Inst libreoffice-style-galaxy (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [all])
Inst uno-libs3 (4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst ure (4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libreoffice-common (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [all])
Inst libsane-common (1.0.24-8+deb8u1 Raspbian:stable [all])
Inst libsane (1.0.24-8+deb8u1 Raspbian:stable [armhf])
Inst libwebp5 (0.4.1-1.2 Raspbian:stable [armhf])
Inst libsdl-image1.2 (1.2.12-5+b1 Raspbian:stable [armhf])
Inst libsecret-common (0.18-1 Raspbian:stable [all])
Inst libsecret-1-0 (0.18-1+b1 Raspbian:stable [armhf])
Inst libshine3 (3.1.0-2.1 Raspbian:stable [armhf])
Inst libshout3 (2.3.1-3 Raspbian:stable [armhf])
Inst libsoundtouch0 (1.8.0-1 Raspbian:stable [armhf])
Inst libjbig2dec0 (0.11+20120125-1 Raspbian:stable [armhf])
Inst poppler-data (0.4.7-1 Raspbian:stable [all])
Inst libgs9-common (9.06~dfsg-2+deb8u4 Raspbian:stable [all])
Inst libgs9 (9.06~dfsg-2+deb8u4 Raspbian:stable [armhf])
Inst libspectre1 (0.2.7-3 Raspbian:stable [armhf])
Inst libspeexdsp1 (1.2~rc1.2-1 Raspbian:stable [armhf])
Inst libssh-4 (0.6.3-4+deb8u2 Raspbian:stable [armhf])
Inst libstartup-notification0 (0.12-4 Raspbian:stable [armhf])
Inst libtag1-vanilla (1.9.1-2.1 Raspbian:stable [armhf])
Inst libupnp6 (1:1.6.19+git20141001-1+deb8u1 Raspbian:stable [armhf])
Inst libusageenvironment1 (2014.01.13-1 Raspbian:stable [armhf])
Inst libv4l2rds0 (1.6.0-2 Raspbian:stable [armhf])
Inst libvisual-0.4-0 (0.4.0-6 Raspbian:stable [armhf])
Inst libvncclient0 (0.9.9+dfsg2-6.1+deb8u2 Raspbian:stable [armhf])
Inst libvo-aacenc0 (0.1.3-1 Raspbian:stable [armhf])
Inst libvo-amrwbenc0 (0.1.3-1 Raspbian:stable [armhf])
Inst libwavpack1 (4.70.0-1 Raspbian:stable [armhf])
Inst libwayland-egl1-mesa (13.0.0-1+rpi1 Raspberry Pi Foundation:stable [armhf])
Inst libwebkitgtk-3.0-common (1:2.4.1-1rpi53rpi1g Raspberry Pi Foundation:stable [all])
Inst libwebkitgtk-3.0-0 (1:2.4.1-1rpi53rpi1g Raspberry Pi Foundation:stable [armhf])
Inst libwildmidi-config (0.3.7-1 Raspbian:stable [all])
Inst libwildmidi1 (0.3.7-1 Raspbian:stable [armhf])
Inst libxres1 (2:1.0.7-1 Raspbian:stable [armhf])
Inst libwnck-3-common (3.4.9-3 Raspbian:stable [all])
Inst libwnck-3-0 (3.4.9-3 Raspbian:stable [armhf])
Inst libxcb-composite0 (1.10-3 Raspbian:stable [armhf])
Inst libxcb-xv0 (1.10-3 Raspbian:stable [armhf])
Inst libzvbi-common (0.2.35-3 Raspbian:stable [all])
Inst libzvbi0 (0.2.35-3 Raspbian:stable [armhf])
Inst ntfs-3g [1:2014.2.15AR.2-1+deb8u2] (1:2014.2.15AR.2-1+deb8u3 Raspbian:stable [armhf])
Inst python-ldb (2:1.1.20-0+deb8u1 Raspbian:stable [armhf])
Inst samba-common (2:4.2.14+dfsg-0+deb8u2 Raspbian:stable [all])
Inst sgml-base (1.26+nmu4 Raspbian:stable [all])
Inst gnustep-common (2.6.6-3 Raspbian:stable [armhf])
Inst gnustep-base-common (1.24.7-1 Raspbian:stable [all])
Inst libgnustep-base1.24 (1.24.7-1 Raspbian:stable [armhf])
Inst gnustep-base-runtime (1.24.7-1 Raspbian:stable [armhf])
Inst unar (1.8.1-3+b1 Raspbian:stable [armhf])
Inst libass5 (0.10.2-3 Raspbian:stable [armhf])
Inst libcdaudio1 (0.99.12p2-13 Raspbian:stable [armhf])
Inst libgme0 (0.5.5-2+deb8u1 Raspbian:stable [armhf])
Inst libgstreamer-plugins-bad0.10-0 (0.10.23-7.4+deb8u2 Raspbian:stable [armhf])
Inst libkate1 (0.4.1-4 Raspbian:stable [armhf])
Inst libmimic0 (1.0.4-2.2 Raspbian:stable [armhf])
Inst libmodplug1 (1:0.8.8.4-4.1 Raspbian:stable [armhf])
Inst libofa0 (0.9.3-7 Raspbian:stable [armhf])
Inst libslv2-9 (0.6.6+dfsg1-2 Raspbian:stable [armhf])
Inst libspandsp2 (0.0.6-2 Raspbian:stable [armhf])
Inst libzbar0 (0.10+doc-10+b2 Raspbian:stable [armhf])
Inst gstreamer0.10-plugins-base (0.10.36-2 Raspbian:stable [armhf])
Inst gstreamer0.10-plugins-bad (0.10.23-7.4+deb8u2 Raspbian:stable [armhf])
Inst libgstreamer-plugins-bad1.0-0 (1.4.4-2.1+deb8u1 Raspbian:stable [armhf])
Inst libsbc1 (1.2-3 Raspbian:stable [armhf])
Inst libsrtp0 (1.4.5~20130609~dfsg-1.1+deb8u1 Raspbian:stable [armhf])
Inst gstreamer1.0-plugins-base (1.4.4-2 Raspbian:stable [armhf])
Inst gstreamer1.0-plugins-bad (1.4.4-2.1+deb8u1 Raspbian:stable [armhf])
Inst gettext-base (0.19.3-2 Raspbian:stable [armhf])
Inst pciutils (1:3.2.1-3 Raspbian:stable [armhf])
Inst apt-transport-https (1.0.9.8.4 Raspbian:stable [armhf])
Inst ark-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst artsbuilder-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst at-spi2-core (2.14.0-1 Raspbian:stable [armhf])
Inst cgroup-tools (0.41-6+rpi1 Raspbian:stable [armhf])
Inst colord-data (1.2.1-1 Raspbian:stable [all])
Inst colord (1.2.1-1+b2 Raspbian:stable [armhf])
Inst poppler-utils (0.26.5-2+deb8u1 Raspbian:stable [armhf])
Inst cups-filters-core-drivers (1.0.61-5+deb8u3 Raspbian:stable [armhf])
Inst cups-core-drivers (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Inst gsfonts (1:8.11+urwcyr1.0.7~pre44-4.2 Raspbian:stable [all])
Inst ghostscript (9.06~dfsg-2+deb8u4 Raspbian:stable [armhf])
Inst cups-common (1.7.5-11+deb8u1 Raspbian:stable [all])
Inst cups-server-common (1.7.5-11+deb8u1 Raspbian:stable [all])
Inst cups-client (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Inst cups-ppdc (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Inst cups-filters (1.0.61-5+deb8u3 Raspbian:stable [armhf])
Inst cups (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Inst cups-browsed (1.0.61-5+deb8u3 Raspbian:stable [armhf])
Inst xml-core (0.13+nmu2 Raspbian:stable [all])
Inst sgml-data (2.0.10 Raspbian:stable [all])
Inst docbook-xml (4.5-7.2 Raspbian:stable [all])
Inst growisofs (7.1-11 Raspbian:stable [armhf])
Inst dvd+rw-tools (7.1-11 Raspbian:stable [armhf])
Inst enchant (1.6.0-10.1 Raspbian:stable [armhf])
Inst epiphany-browser-data (1:3.8.2.0-0rpi27rpi1g Raspberry Pi Foundation:stable [all])
Inst gnome-desktop3-data (3.14.1-1 Raspbian:stable [all])
Inst libgnome-desktop-3-10 (3.14.1-1 Raspbian:stable [armhf])
Inst gnome-icon-theme (3.12.0-1 Raspbian:stable [all])
Inst gnome-icon-theme-symbolic (3.12.0-1 Raspbian:stable [all])
Inst epiphany-browser (1:3.8.2.0-0rpi27rpi1g Raspberry Pi Foundation:stable [armhf])
Inst libkpathsea6 (2014.20140926.35254-6 Raspbian:stable [armhf])
Inst libevdocument3-4 (3.14.1-2+deb8u1 Raspbian:stable [armhf])
Inst libevview3-3 (3.14.1-2+deb8u1 Raspbian:stable [armhf])
Inst libnautilus-extension1a (3.14.1-2 Raspbian:stable [armhf])
Inst evince-common (3.14.1-2+deb8u1 Raspbian:stable [all])
Inst evince (3.14.1-2+deb8u1 Raspbian:stable [armhf])
Inst exfat-fuse (1.1.0-2+deb8u1 Raspbian:stable [armhf])
Inst exfat-utils (1.1.0-2+deb8u1 Raspbian:stable [armhf])
Inst fonts-dejavu-extra (2.34-1 Raspbian:stable [all])
Inst fonts-dejavu (2.34-1 Raspbian:stable [all])
Inst fonts-freefont-ttf (20120503-4 Raspbian:stable [all])
Inst fonts-lyx (2.1.2-2 Raspbian:stable [all])
Inst fonts-opensymbol (2:102.6+LibO4.3.3-2+rpi4 Raspberry Pi Foundation:stable [all])
Inst fonts-sil-gentium (20081126:1.02-13 Raspbian:stable [all])
Inst fonts-sil-gentium-basic (1.1-7 Raspbian:stable [all])
Inst freepats (20060219-1 Raspbian:stable [all])
Inst gconf-service (3.2.6-3 Raspbian:stable [armhf])
Inst gconf2 (3.2.6-3 Raspbian:stable [armhf])
Inst gcr (3.14.0-2+b1 Raspbian:stable [armhf])
Inst geoip-database (20150317-1 Raspbian:stable [all])
Inst libgirepository-1.0-1 (1.42.0-2.2 Raspbian:stable [armhf])
Inst gir1.2-glib-2.0 (1.42.0-2.2 Raspbian:stable [armhf])
Inst libgtop2-common (2.28.5-2 Raspbian:stable [all])
Inst libgtop2-7 (2.28.5-2 Raspbian:stable [armhf])
Inst libgksu2-0 (2.0.13~pre1-8 Raspbian:stable [armhf])
Inst gksu (2.0.2-9 Raspbian:stable [armhf])
Inst gnome-accessibility-themes (3.14.2.2-1rpi1rpi1g Raspberry Pi Foundation:stable [all])
Inst p11-kit-modules (0.20.7-1 Raspbian:stable [armhf])
Inst p11-kit (0.20.7-1 Raspbian:stable [armhf])
Inst gnome-keyring (3.14.0-1+b1 Raspbian:stable [armhf])
Inst libyelp0 (3.14.1-1 Raspbian:stable [armhf])
Inst yelp-xsl (3.14.0-1 Raspbian:stable [all])
Inst yelp (3.14.1-1 Raspbian:stable [armhf])
Inst gnome-user-guide (3.14.1-1 Raspbian:stable [all])
Inst gstreamer0.10-gconf (0.10.31-3+nmu4+deb8u2 Raspbian:stable [armhf])
Inst libtag1c2a (1.9.1-2.1 Raspbian:stable [armhf])
Inst gstreamer0.10-plugins-good (0.10.31-3+nmu4+deb8u2 Raspbian:stable [armhf])
Inst liba52-0.7.4 (0.7.4-17 Raspbian:stable [armhf])
Inst libsidplay1 (1.36.59-6 Raspbian:stable [armhf])
Inst libtwolame0 (0.3.13-1.1 Raspbian:stable [armhf])
Inst gstreamer0.10-plugins-ugly (0.10.19-2.1+b1 Raspbian:stable [armhf])
Inst gstreamer0.10-x (0.10.36-2 Raspbian:stable [armhf])
Inst gstreamer1.0-alsa (1.4.4-2 Raspbian:stable [armhf])
Inst gstreamer1.0-libav (1.4.4-2 Raspbian:stable [armhf])
Inst gstreamer1.0-omx (1.0.0.1-0+rpi18rpi1g Raspberry Pi Foundation:stable [armhf])
Inst gstreamer1.0-plugins-good (1.4.4-2+deb8u2 Raspbian:stable [armhf])
Inst gstreamer1.0-plugins-ugly (1.4.4-2 Raspbian:stable [armhf])
Inst gstreamer1.0-x (1.4.4-2 Raspbian:stable [armhf])
Inst gtk2-engines (1:2.20.2-3 Raspbian:stable [armhf])
Inst gtk2-engines-pixbuf (2.24.25-3+deb8u1 Raspbian:stable [armhf])
Inst gvfs-common (1.22.2-1 Raspbian:stable [all])
Inst gvfs-libs (1.22.2-1 Raspbian:stable [armhf])
Inst gvfs-daemons (1.22.2-1 Raspbian:stable [armhf])
Inst gvfs (1.22.2-1 Raspbian:stable [armhf])
Inst libexiv2-12 (0.23-1 q4os-rpi-1-0 repository:1.0/q4os-rpi-1-0-st [armhf])
Inst libkipi0-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst gwenview-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst gwenview-i18n-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [all])
Inst hwdata (0.267-1 Raspbian:stable [all])
Inst icedove (1:45.6.0-1~deb8u1 Raspbian:stable [armhf])
Inst iceowl-extension (1:45.6.0-1~deb8u1 Raspbian:stable [armhf])
Inst jackd (5 Raspbian:stable [all])
Inst libtdegames1-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst kbounce-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst kcalc-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst kmag-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst kmines-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst kolourpaint-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst tdegames-card-data-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [all])
Inst kpat-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst krec-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst ksnapshot-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst librevenge-0.0-0 (0.0.1-3 Raspbian:stable [armhf])
Inst libabw-0.1-1 (0.1.0-2 Raspbian:stable [armhf])
Inst libakode2 (2.0.2-7raspbian7.0.0+1 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst libarts1-akode-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Inst libauthen-sasl-perl (2.1600-1 Raspbian:stable [all])
Inst libblas-common (1.2.20110419-10 Raspbian:stable [armhf])
Inst libblas3 (1.2.20110419-10 Raspbian:stable [armhf])
Inst libcairo-perl (1.104-2 Raspbian:stable [armhf])
Inst libcanberra-gtk3-module (0.30-2.1 Raspbian:stable [armhf])
Inst libcddb2 (1.3.2-5 Raspbian:stable [armhf])
Inst libcdr-0.1-1 (0.1.0-3 Raspbian:stable [armhf])
Inst libcmis-0.4-4 (0.4.1-7 Raspbian:stable [armhf])
Inst libe-book-0.1-1 (0.1.1-2 Raspbian:stable [armhf])
Inst libencode-locale-perl (1.03-1 Raspbian:stable [all])
Inst libeot0 (0.01-3 Raspbian:stable [armhf])
Inst libept1.4.12 (1.0.12.1 Raspbian:stable [armhf])
Inst libetonyek-0.1-1 (0.1.1-2 Raspbian:stable [armhf])
Inst libexttextcat-data (3.4.4-1 Raspbian:stable [all])
Inst libexttextcat-2.0-0 (3.4.4-1 Raspbian:stable [armhf])
Inst libfile-basedir-perl (0.03-1 Raspbian:stable [all])
Inst libfile-copy-recursive-perl (0.38-1 Raspbian:stable [all])
Inst libfile-desktopentry-perl (0.07-1 Raspbian:stable [all])
Inst libtimedate-perl (2.3000-2 Raspbian:stable [all])
Inst libhttp-date-perl (6.02-1 Raspbian:stable [all])
Inst libfile-listing-perl (6.04-1 Raspbian:stable [all])
Inst libfile-mimeinfo-perl (0.26-1 Raspbian:stable [all])
Inst libfont-afm-perl (1.20-1 Raspbian:stable [all])
Inst libfreehand-0.1-1 (0.1.0-2 Raspbian:stable [armhf])
Inst libglib-perl (3:1.305-2 Raspbian:stable [armhf])
Inst libgltf-0.0-0 (0.0.2-2 Raspbian:stable [armhf])
Inst libgphoto2-l10n (2.5.4-1.1 Raspbian:stable [all])
Inst libpango-perl (1.226-2 Raspbian:stable [armhf])
Inst libgtk2-perl (2:1.2492-4 Raspbian:stable [armhf])
Inst libgtk2.0-bin (2.24.25-3+deb8u1 Raspbian:stable [armhf])
Inst libservlet2.5-java (6.0.45+dfsg-1~deb8u1 Raspbian:stable [all])
Inst libhsqldb1.8.0-java (1.8.0.10+dfsg-3 Raspbian:stable [all])
Inst liburi-perl (1.64-1 Raspbian:stable [all])
Inst libhtml-tagset-perl (3.20-2 Raspbian:stable [all])
Inst libhtml-parser-perl (3.71-1+b4 Raspbian:stable [armhf])
Inst libio-html-perl (1.001-1 Raspbian:stable [all])
Inst liblwp-mediatypes-perl (6.02-1 Raspbian:stable [all])
Inst libhttp-message-perl (6.06-1 Raspbian:stable [all])
Inst libhtml-form-perl (6.03-1 Raspbian:stable [all])
Inst libhtml-tree-perl (5.03-1 Raspbian:stable [all])
Inst libhtml-format-perl (2.11-1 Raspbian:stable [all])
Inst libhttp-cookies-perl (6.01-1 Raspbian:stable [all])
Inst libhttp-daemon-perl (6.01-1 Raspbian:stable [all])
Inst libhttp-negotiate-perl (6.00-2 Raspbian:stable [all])
Inst libhyphen0 (2.8.8-1 Raspbian:stable [armhf])
Inst libnet-ssleay-perl (1.65-1+deb8u1 Raspbian:stable [armhf])
Inst libio-socket-ssl-perl (2.002-2+deb8u2 Raspbian:stable [all])
Inst libiso9660-8 (0.83-4.2 Raspbian:stable [armhf])
Inst liblangtag-common (0.5.1-3 Raspbian:stable [all])
Inst liblangtag1 (0.5.1-3 Raspbian:stable [armhf])
Inst liblapack3 (3.5.0-4 Raspbian:stable [armhf])
Inst liblircclient0 (0.9.0~pre1-1.2 Raspbian:stable [armhf])
Inst libnet-http-perl (6.07-1 Raspbian:stable [all])
Inst libwww-robotrules-perl (6.01-1 Raspbian:stable [all])
Inst libwww-perl (6.08-1 Raspbian:stable [all]) []
Inst liblwp-protocol-https-perl (6.06-2 Raspbian:stable [all])
Inst libnet-smtp-ssl-perl (1.01-3 Raspbian:stable [all])
Inst libmailtools-perl (2.13-1 Raspbian:stable [all])
Inst libmspub-0.1-1 (0.1.1-2 Raspbian:stable [armhf])
Inst libmtp-runtime (1.1.8-1+b1 Raspbian:stable [armhf])
Inst libmwaw-0.3-3 (0.3.1-2 Raspbian:stable [armhf])
Inst libmythes-1.2-0 (2:1.2.4-1 Raspbian:stable [armhf])
Inst libneon27-gnutls (0.30.1-1 Raspbian:stable [armhf])
Inst libxml-parser-perl (2.41-3 Raspbian:stable [armhf])
Inst libxml-twig-perl (1:3.48-1 Raspbian:stable [all])
Inst libnet-dbus-perl (1.0.0-2+b2 Raspbian:stable [armhf])
Inst libodfgen-0.1-1 (0.1.1-2 Raspbian:stable [armhf])
Inst liborcus-0.8-0 (0.7.0+dfsg-9 Raspbian:stable [armhf])
Inst libpam-gnome-keyring (3.14.0-1+b1 Raspbian:stable [armhf])
Inst libpaper-utils (1.1.24+nmu4 Raspbian:stable [armhf])
Inst libperl4-corelibs-perl (0.003-1 Raspbian:stable [all])
Inst libpostproc52 (6:0.git20120821-4 Raspbian:stable [armhf])
Inst libproxy-tools (0.4.11-4 Raspbian:stable [armhf])
Inst qtchooser (47-gd2b7997-2 Raspbian:stable [armhf])
Inst qdbus (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [armhf])
Inst libqt4-dbus (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [armhf])
Inst libreoffice-core (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libreoffice-base-core (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libreoffice-base-drivers (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libreoffice-base (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst lp-solve (5.5.0.13-7+b1 Raspbian:stable [armhf])
Inst coinor-libcoinutils3 (2.9.15-3 Raspbian:stable [armhf])
Inst coinor-libosi1 (0.106.9-1 Raspbian:stable [armhf])
Inst coinor-libclp1 (1.15.10-1 Raspbian:stable [armhf])
Inst coinor-libcgl1 (0.58.9-1 Raspbian:stable [armhf])
Inst coinor-libcbc3 (2.8.12-1 Raspbian:stable [armhf])
Inst coinor-libcoinmp1 (1.7.6+dfsg1-1 Raspbian:stable [armhf])
Inst libwps-0.3-3 (0.3.0-2 Raspbian:stable [armhf])
Inst libreoffice-calc (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libvisio-0.1-1 (0.1.0-2 Raspbian:stable [armhf])
Inst libwpd-0.10-10 (0.10.0-2 Raspbian:stable [armhf])
Inst libwpg-0.3-3 (0.3.0-3 Raspbian:stable [armhf])
Inst libreoffice-draw (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libreoffice-impress (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libreoffice-math (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libreoffice-report-builder-bin (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libreoffice-writer (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libreoffice-avmedia-backend-gstreamer (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libreoffice-java-common (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [all])
Inst python3-uno (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libreoffice (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libreoffice-sdbc-firebird (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libreoffice-sdbc-hsqldb (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Inst libresid-builder0c2a (2.1.1-14 Raspbian:stable [armhf])
Inst libsane-extras-common (1.0.22.3 Raspbian:stable [armhf])
Inst libsane-extras (1.0.22.3 Raspbian:stable [armhf])
Inst libsidplay2 (2.1.1-14 Raspbian:stable [armhf])
Inst libtie-ixhash-perl (1.23-1 Raspbian:stable [all])
Inst libva-drm1 (1.7.3-2 Raspberry Pi Foundation:stable [armhf])
Inst libva-x11-1 (1.7.3-2 Raspberry Pi Foundation:stable [armhf])
Inst libvcdinfo0 (0.7.24+dfsg-0.2 Raspbian:stable [armhf])
Inst libvisual-0.4-plugins (0.4.0.dfsg.1-7 Raspbian:stable [armhf])
Inst vlc-data (2.2.4-1~deb8u1 Raspbian:stable [all])
Inst libvlccore8 (2.2.4-1~deb8u1 Raspbian:stable [armhf])
Inst libvlc5 (2.2.4-1~deb8u1 Raspbian:stable [armhf])
Inst libvte-2.90-common (1:0.36.3-1 Raspbian:stable [all])
Inst libvte-2.90-9 (1:0.36.3-1 Raspbian:stable [armhf])
Inst libx11-protocol-perl (0.56-6 Raspbian:stable [all])
Inst libxml-xpathengine-perl (0.13-1 Raspbian:stable [all])
Inst ncompress (4.2.4.4-9 Raspbian:stable [armhf])
Inst notification-daemon (0.7.6-2 Raspbian:stable [armhf])
Inst squeak-vm (1:4.10.2.2614-1.1+b1 Raspbian:stable [armhf])
Inst libpango1.0-0 (1.36.8-3+rpi1 Raspberry Pi Foundation:stable [armhf])
Inst squeak-plugins-scratch (1.4.0.2~svn.r83-2 Raspbian:stable [armhf])
Inst scratch (1.4.0.6~dfsg1-5 Raspbian:stable [all])
Inst pigpio (1.30-1 Raspberry Pi Foundation:stable [armhf])
Inst nuscratch (20161021 Raspberry Pi Foundation:stable [armhf])
Inst omxplayer (0.3.7~git20160923~dfea8c9 Raspberry Pi Foundation:stable [armhf])
Inst oracle-java8-jdk (8u65 Raspberry Pi Foundation:stable [armhf])
Inst p7zip-full (9.20.1~dfsg.1-4.1+deb8u2 Raspbian:stable [armhf])
Inst policykit-1-gnome (0.105-2 Raspbian:stable [armhf])
Inst printer-driver-gutenprint (5.2.10-3+b3 Raspbian:stable [armhf])
Inst python-crypto (2.6.1-5+deb8u1 Raspbian:stable [armhf])
Inst python-gi (3.14.0-1 Raspbian:stable [armhf])
Inst python-ntdb (1.0-5 Raspbian:stable [armhf])
Inst python-tdb (1.3.6-0+deb8u1 Raspbian:stable [armhf])
Inst python-samba (2:4.2.14+dfsg-0+deb8u2 Raspbian:stable [armhf])
Inst python3-dbus (1.2.0-2+b1 Raspbian:stable [armhf])
Inst python3-gi (3.14.0-1 Raspbian:stable [armhf])
Inst python3-software-properties (0.92.25debian1 Raspbian:stable [all])
Inst qjackctl (0.3.12-1 Raspbian:stable [armhf])
Inst qpdf (5.1.2-2 Raspbian:stable [armhf])
Inst qpdfview (0.4.12-1 Raspbian:stable [armhf])
Inst qpdfview-djvu-plugin (0.4.12-1 Raspbian:stable [armhf])
Inst qpdfview-ps-plugin (0.4.12-1 Raspbian:stable [armhf])
Inst qpdfview-translations (0.4.12-1 Raspbian:stable [all])
Inst qttranslations5-l10n (5.3.2-2 Raspbian:stable [all])
Inst rsync (3.1.1-3 Raspbian:stable [armhf])
Inst samba-common-bin (2:4.2.14+dfsg-0+deb8u2 Raspbian:stable [armhf])
Inst update-inetd (4.43 Raspbian:stable [all])
Inst sane-utils (1.0.24-8+deb8u1 Raspbian:stable [armhf])
Inst software-properties-common (0.92.25debian1 Raspbian:stable [all])
Inst synaptic (0.81.2+rpi1 Raspbian:stable [armhf])
Inst twolame (0.3.13-1.1 Raspbian:stable [armhf])
Inst unrar-free (1:0.0.1+cvs20140707-1 Raspbian:stable [armhf])
Inst v4l-utils (1.6.0-2 Raspbian:stable [armhf])
Inst va-driver-all (1.7.3-2 Raspberry Pi Foundation:stable [armhf])
Inst vlc-nox (2.2.4-1~deb8u1 Raspbian:stable [armhf])
Inst vlc (2.2.4-1~deb8u1 Raspbian:stable [armhf])
Inst vlc-plugin-notify (2.2.4-1~deb8u1 Raspbian:stable [armhf])
Inst vlc-plugin-samba (2.2.4-1~deb8u1 Raspbian:stable [armhf])
Inst xdg-utils (1.1.0~rc1+git20111210-7.4 Raspbian:stable [all])
Inst xfonts-encodings (1:1.0.4-2 Raspbian:stable [all])
Inst xfonts-utils (1:7.7+2 Raspbian:stable [armhf])
Inst zenity-common (3.14.0-1 Raspbian:stable [all])
Inst zenity (3.14.0-1 Raspbian:stable [armhf])
Inst zip (3.0-8 Raspbian:stable [armhf])
Inst zoo (2.10-27 Raspbian:stable [armhf])
Inst bluej (3.1.7b Raspberry Pi Foundation:stable [all])
Inst cgroup-bin (0.41-6+rpi1 Raspbian:stable [all])
Inst fonts-stix (1.1.1-1 Raspbian:stable [all])
Inst gdisk (0.8.10-2 Raspbian:stable [armhf])
Inst librarian0 (0.8.1-6 Raspbian:stable [armhf])
Inst q4os-wallpapers (1.1.3-a1 q4os-rpi-1-0 repository:1.0/q4os-rpi-1-0-st [all])
Inst rarian-compat (0.8.1-6 Raspbian:stable [armhf])
Inst raspberrypi-artwork (20150921 Raspberry Pi Foundation:stable [all])
Inst xfonts-mathml (6 Raspbian:stable [all])
Conf libasprintf0c2 (0.19.3-2 Raspbian:stable [armhf])
Conf libgpm2 (1.20.4-6.1 Raspbian:stable [armhf])
Conf libpci3 (1:3.2.1-3 Raspbian:stable [armhf])
Conf libcupsmime1 (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Conf ssl-cert (1.0.35 Raspbian:stable [all])
Conf bc (1.06.95-9 Raspbian:stable [armhf])
Conf cups-daemon (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Conf libatk1.0-data (2.14.0-1 Raspbian:stable [all])
Conf libatk1.0-0 (2.14.0-1 Raspbian:stable [armhf])
Conf libatspi2.0-0 (2.14.0-1 Raspbian:stable [armhf])
Conf libatk-bridge2.0-0 (2.14.0-2 Raspbian:stable [armhf])
Conf libxcb-shm0 (1.10-3 Raspbian:stable [armhf])
Conf libcairo2 (1.14.0-2.1+deb8u2+rpi1 Raspberry Pi Foundation:stable [armhf])
Conf libcairo-gobject2 (1.14.0-2.1+deb8u2+rpi1 Raspberry Pi Foundation:stable [armhf])
Conf libgdk-pixbuf2.0-common (2.31.1-2+deb8u5 Raspbian:stable [all])
Conf libgdk-pixbuf2.0-0 (2.31.1-2+deb8u5 Raspbian:stable [armhf])
Conf libcolord2 (1.2.1-1+b2 Raspbian:stable [armhf])
Conf libjson-glib-1.0-common (1.0.2-1 Raspbian:stable [all])
Conf libjson-glib-1.0-0 (1.0.2-1 Raspbian:stable [armhf])
Conf libthai-data (0.1.21-1 Raspbian:stable [all])
Conf libdatrie1 (0.2.8-1 Raspbian:stable [armhf])
Conf libthai0 (0.1.21-1 Raspbian:stable [armhf])
Conf libpango-1.0-0 (1.36.8-3+rpi1 Raspberry Pi Foundation:stable [armhf])
Conf libgraphite2-3 (1.3.6-1~deb8u1 Raspbian:stable [armhf])
Conf libharfbuzz0b (0.9.35-2 Raspbian:stable [armhf])
Conf libpangoft2-1.0-0 (1.36.8-3+rpi1 Raspberry Pi Foundation:stable [armhf])
Conf libpangocairo-1.0-0 (1.36.8-3+rpi1 Raspberry Pi Foundation:stable [armhf])
Conf libsoup-gnome2.4-1 (2.48.0-1 Raspbian:stable [armhf])
Conf librest-0.7-0 (0.7.92-3 Raspbian:stable [armhf])
Conf libwayland-cursor0 (1.11.0-2 Raspberry Pi Foundation:stable [armhf])
Conf libxkbcommon0 (0.4.3-2 Raspbian:stable [armhf])
Conf libgtk-3-bin (3.14.5-1+deb8u1rpi1rpi1g Raspberry Pi Foundation:stable [armhf])
Conf libcroco3 (0.6.8-3 Raspbian:stable [armhf])
Conf librsvg2-2 (2.40.5-1+deb8u2 Raspbian:stable [armhf])
Conf librsvg2-common (2.40.5-1+deb8u2 Raspbian:stable [armhf])
Conf adwaita-icon-theme (3.14.0-2 Raspbian:stable [all])
Conf libgtk-3-common (3.14.5-1+deb8u1rpi1rpi1g Raspberry Pi Foundation:stable [all])
Conf libgtk-3-0 (3.14.5-1+deb8u1rpi1rpi1g Raspberry Pi Foundation:stable [armhf])
Conf gnome-themes-standard-data (3.14.2.2-1rpi1rpi1g Raspberry Pi Foundation:stable [all])
Conf libgtk2.0-common (2.24.25-3+deb8u1 Raspbian:stable [all])
Conf libgtk2.0-0 (2.24.25-3+deb8u1 Raspbian:stable [armhf])
Conf gnome-themes-standard (3.14.2.2-1rpi1rpi1g Raspberry Pi Foundation:stable [armhf])
Conf libopus0 (1.1-2 Raspbian:stable [armhf])
Conf libjack-jackd2-0 (1.9.10+20140719git3eb0ae6a~dfsg-2 Raspbian:stable [armhf])
Conf python-dbus-dev (1.2.0-2 Raspbian:stable [all])
Conf python-dbus (1.2.0-2+b1 Raspbian:stable [armhf])
Conf jackd2 (1.9.10+20140719git3eb0ae6a~dfsg-2 Raspbian:stable [armhf])
Conf libdvdread4 (5.0.0-1 Raspbian:stable [armhf])
Conf libflac++6 (1.3.0-3 Raspbian:stable [armhf])
Conf libk3b3-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf wodim (9:1.1.11-3 Raspbian:stable [armhf])
Conf cdparanoia (3.10.2+debian-11 Raspbian:stable [armhf])
Conf genisoimage (9:1.1.11-3 Raspbian:stable [armhf])
Conf libao-common (1.1.0-3 Raspbian:stable [armhf])
Conf libao4 (1.1.0-3 Raspbian:stable [armhf])
Conf cdrdao (1:1.2.3-2 Raspbian:stable [armhf])
Conf k3b-data-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [all])
Conf k3b-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf k3b-i18n-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [all])
Conf libaa1 (1.4p5-43 Raspbian:stable [armhf])
Conf libaacs0 (0.7.1-1+b1 Raspbian:stable [armhf])
Conf liblzo2-2 (2.08-1.2 Raspbian:stable [armhf])
Conf libarchive13 (3.1.2-11+deb8u3 Raspbian:stable [armhf])
Conf libavutil54 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Conf libavresample2 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Conf libgsm1 (1.0.13-4 Raspbian:stable [armhf])
Conf libmp3lame0 (3.99.5+repack1-7+deb8u1 Raspbian:stable [armhf])
Conf libopenjpeg5 (1:1.5.2-3 Raspbian:stable [armhf])
Conf liborc-0.4-0 (1:0.4.22-1rpi1rpi1g Raspberry Pi Foundation:stable [armhf])
Conf libschroedinger-1.0-0 (1.0.11-2.1 Raspbian:stable [armhf])
Conf libspeex1 (1.2~rc1.2-1 Raspbian:stable [armhf])
Conf libtheora0 (1.1.1+dfsg.1-6 Raspbian:stable [armhf])
Conf libva1 (1.7.3-2 Raspberry Pi Foundation:stable [armhf])
Conf libvpx1 (1.3.0-3+rvt Raspbian:stable [armhf])
Conf libx264-142 (2:0.142.2431+gita5831aa-1+rpi2 Raspbian:stable [armhf])
Conf libxvidcore4 (2:1.3.3-1 Raspbian:stable [armhf])
Conf libavcodec56 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Conf librtmp1 (2.4+20150115.gita107cef-1 Raspbian:stable [armhf])
Conf libavformat56 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Conf libcdio13 (0.83-4.2 Raspbian:stable [armhf])
Conf libcdio-cdda1 (0.83-4.2 Raspbian:stable [armhf])
Conf libcdio-paranoia1 (0.83-4.2 Raspbian:stable [armhf])
Conf libdc1394-22 (2.2.3-1 Raspbian:stable [armhf])
Conf libavdevice55 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Conf libopencv-core2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Conf libopencv-imgproc2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Conf libswscale3 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Conf libavfilter5 (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Conf libcaca0 (0.99.beta19-2 Raspbian:stable [armhf])
Conf libdirectfb-1.2-9 (1.2.10.0-5.1 Raspbian:stable [armhf])
Conf libsdl1.2debian (1.2.15-10+rpi1 Raspberry Pi Foundation:stable [armhf])
Conf libav-tools (6:11.8-1~deb8u1+rpi1 Raspbian:stable [armhf])
Conf libavahi-glib1 (0.6.31-5 Raspbian:stable [armhf])
Conf libavahi-gobject0 (0.6.31-5 Raspbian:stable [armhf])
Conf libavc1394-0 (0.5.4-2 Raspbian:stable [armhf])
Conf libbasicusageenvironment0 (2014.01.13-1 Raspbian:stable [armhf])
Conf libbluray1 (1:0.6.2-1 Raspbian:stable [armhf])
Conf libboost-date-time1.55.0 (1.55.0+dfsg-3 Raspbian:stable [armhf])
Conf libboost-system1.55.0 (1.55.0+dfsg-3 Raspbian:stable [armhf])
Conf libltdl7 (2.4.2-1.11 Raspbian:stable [armhf])
Conf libcanberra0 (0.30-2.1 Raspbian:stable [armhf])
Conf libcanberra-gtk3-0 (0.30-2.1 Raspbian:stable [armhf])
Conf libcgroup1 (0.41-6+rpi1 Raspbian:stable [armhf])
Conf libchromaprint0 (1.2-1 Raspbian:stable [armhf])
Conf libclucene-core1 (2.3.3.4-4 Raspbian:stable [armhf])
Conf libclucene-contribs1 (2.3.3.4-4 Raspbian:stable [armhf])
Conf libcolamd2.8.0 (1:4.2.1-3 Raspbian:stable [armhf])
Conf libgusb2 (0.1.6-5 Raspbian:stable [armhf])
Conf libcolorhug2 (1.2.1-1+b2 Raspbian:stable [armhf])
Conf libcupscgi1 (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Conf libcupsimage2 (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Conf libcupsfilters1 (1.0.61-5+deb8u3 Raspbian:stable [armhf])
Conf libcupsppdc1 (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Conf libssh2-1 (1.4.3-4.1+deb8u1 Raspbian:stable [armhf])
Conf libcurl3-gnutls (7.38.0-4+deb8u5 Raspbian:stable [armhf])
Conf libdca0 (0.0.5-7 Raspbian:stable [armhf])
Conf libdirac-encoder0 (1.0.2-7.1 Raspbian:stable [armhf])
Conf libdjvulibre-text (3.5.25.4-4 Raspbian:stable [all])
Conf libdjvulibre21 (3.5.25.4-4+b1 Raspbian:stable [armhf])
Conf libdv4 (1.0.0-6 Raspbian:stable [armhf])
Conf libdvbpsi9 (1.2.0-1 Raspbian:stable [armhf])
Conf libdvdnav4 (5.0.1-1 Raspbian:stable [armhf])
Conf libebml4 (1.3.0-2+deb8u1 Raspbian:stable [armhf])
Conf libenca0 (1.16-1 Raspbian:stable [armhf])
Conf emacsen-common (2.0.8 Raspbian:stable [all])
Conf dictionaries-common (1.23.17 Raspbian:stable [all])
Conf hunspell-en-us (20070829-6 Raspbian:stable [all])
Conf libhunspell-1.3-0 (1.3.3-3 Raspbian:stable [armhf])
Conf libenchant1c2a (1.6.0-10.1 Raspbian:stable [armhf])
Conf libexif12 (0.6.21-2 Raspbian:stable [armhf])
Conf libfaad2 (2.7-8 Raspbian:stable [armhf])
Conf firebird2.5-common-doc (2.5.3.26778.ds4-5 Raspbian:stable [all])
Conf firebird2.5-common (2.5.3.26778.ds4-5 Raspbian:stable [all])
Conf libfbclient2 (2.5.3.26778.ds4-5 Raspbian:stable [armhf])
Conf firebird2.5-server-common (2.5.3.26778.ds4-5 Raspbian:stable [armhf])
Conf libfbembed2.5 (2.5.3.26778.ds4-5 Raspbian:stable [armhf])
Conf libgomp1 (4.9.2-10 Raspbian:stable [armhf])
Conf libfftw3-double3 (3.3.4-2+rvt Raspbian:stable [armhf])
Conf libflite1 (1.4-release-12 Raspbian:stable [armhf])
Conf libfluidsynth1 (1.1.6-2 Raspbian:stable [armhf])
Conf libfontembed1 (1.0.61-5+deb8u3 Raspbian:stable [armhf])
Conf libwinpr-sysinfo0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libfreerdp-primitives1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-crt0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-environment0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-handle0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-heap0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-interlocked0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-path0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-thread0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-synch0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-utils0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libfreerdp-utils1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-pool0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-registry0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libfreerdp-codec1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-file0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-library0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libfreerdp-common1.1.0 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-crypto0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-sspi0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libfreerdp-crypto1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-input0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libfreerdp-locale1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-dsparse0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libwinpr-rpc0.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libfreerdp-core1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libfreerdp-cache1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libfreerdp-client1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libfreerdp-gdi1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libfreerdp-rail1.1 (1.1.0~git20140921.1.440916e+dfsg1-4 Raspbian:stable [armhf])
Conf libfribidi0 (0.19.6-3 Raspbian:stable [armhf])
Conf libgck-1-0 (3.14.0-2+b1 Raspbian:stable [armhf])
Conf gconf2-common (3.2.6-3 Raspbian:stable [all])
Conf libgconf-2-4 (3.2.6-3 Raspbian:stable [armhf])
Conf libgcr-3-common (3.14.0-2 Raspbian:stable [all])
Conf libgcr-base-3-1 (3.14.0-2+b1 Raspbian:stable [armhf])
Conf libgcr-ui-3-1 (3.14.0-2+b1 Raspbian:stable [armhf])
Conf libgd3 (2.1.0-5+deb8u9 Raspbian:stable [armhf])
Conf libgeoclue0 (0.12.99-4+b1 Raspbian:stable [armhf])
Conf libgfortran3 (4.9.2-10 Raspbian:stable [armhf])
Conf libgles2-mesa (13.0.0-1+rpi1 Raspberry Pi Foundation:stable [armhf])
Conf libglew1.10 (1.10.0-3 Raspbian:stable [armhf])
Conf libgnome-keyring-common (3.12.0-1 Raspbian:stable [all])
Conf libgnome-keyring0 (3.12.0-1+b1 Raspbian:stable [armhf])
Conf libgphoto2-port10 (2.5.4-1.1 Raspbian:stable [armhf])
Conf libgphoto2-6 (2.5.4-1.1 Raspbian:stable [armhf])
Conf libgroupsock1 (2014.01.13-1 Raspbian:stable [armhf])
Conf libgstreamer0.10-0 (0.10.36-1.5 Raspbian:stable [armhf])
Conf iso-codes (3.57-1 Raspbian:stable [all])
Conf libgstreamer-plugins-base0.10-0 (0.10.36-2 Raspbian:stable [armhf])
Conf libgstreamer1.0-0 (1.4.4-2 Raspbian:stable [armhf])
Conf libgstreamer-plugins-base1.0-0 (1.4.4-2 Raspbian:stable [armhf])
Conf libgutenprint2 (5.2.10-3+b3 Raspbian:stable [armhf])
Conf libgxps2 (0.2.2-3 Raspbian:stable [armhf])
Conf libharfbuzz-icu0 (0.9.35-2 Raspbian:stable [armhf])
Conf libiec61883-0 (1.2.0-0.2 Raspbian:stable [armhf])
Conf libieee1284-3 (0.2.11-12 Raspbian:stable [armhf])
Conf libijs-0.35 (0.35-10 Raspbian:stable [armhf])
Conf libjavascriptcoregtk-3.0-0 (1:2.4.1-1rpi53rpi1g Raspberry Pi Foundation:stable [armhf])
Conf liblivemedia23 (2014.01.13-1 Raspbian:stable [armhf])
Conf liblua5.2-0 (5.2.3-1.1 Raspbian:stable [armhf])
Conf libmatroska6 (1.4.1-2+deb8u1 Raspbian:stable [armhf])
Conf libmhash2 (0.9.9.9-7 Raspbian:stable [armhf])
Conf libmjpegutils-2.1-0 (1:2.1.0+debian-3 Raspbian:stable [armhf])
Conf libmms0 (0.6.2-4 Raspbian:stable [armhf])
Conf libmp4v2-2 (2.0.0~dfsg0-3 Raspbian:stable [armhf])
Conf libmpcdec6 (2:0.1~r459-4.1 Raspbian:stable [armhf])
Conf libmpeg2-4 (0.5.1-7 Raspbian:stable [armhf])
Conf libmpeg2encpp-2.1-0 (1:2.1.0+debian-3 Raspbian:stable [armhf])
Conf libmpg123-0 (1.20.1-2+deb8u1 Raspbian:stable [armhf])
Conf libmplex2-2.1-0 (1:2.1.0+debian-3 Raspbian:stable [armhf])
Conf libmtp-common (1.1.8-1 Raspbian:stable [all])
Conf libmtp9 (1.1.8-1+b1 Raspbian:stable [armhf])
Conf libnotify4 (0.7.6-2 Raspbian:stable [armhf])
Conf libnspr4 (2:4.12-1+debu8u1 Raspbian:stable [armhf])
Conf libnss3 (2:3.26-1+debu8u1 Raspbian:stable [armhf])
Conf libobjc4 (4.9.2-10 Raspbian:stable [armhf])
Conf libopenal-data (1:1.15.1-5 Raspbian:stable [all])
Conf libopenal1 (1:1.15.1-5 Raspbian:stable [armhf])
Conf libopencore-amrnb0 (0.1.3-2.1 Raspbian:stable [armhf])
Conf libopencore-amrwb0 (0.1.3-2.1 Raspbian:stable [armhf])
Conf libopencv-flann2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Conf libpangox-1.0-0 (0.0.2-5 Raspbian:stable [armhf])
Conf libgtkglext1 (1.2.0-3.2 Raspbian:stable [armhf])
Conf libv4lconvert0 (1.6.0-2 Raspbian:stable [armhf])
Conf libv4l-0 (1.6.0-2 Raspbian:stable [armhf])
Conf libopencv-highgui2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Conf libopencv-features2d2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Conf libopencv-calib3d2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Conf libopencv-ml2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Conf libopencv-objdetect2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Conf libopencv-video2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Conf libopencv-contrib2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Conf libopencv-legacy2.4 (2.4.9.1+dfsg-1+deb8u1 Raspbian:stable [armhf])
Conf libpangoxft-1.0-0 (1.36.8-3+rpi1 Raspberry Pi Foundation:stable [armhf])
Conf libpoppler46 (0.26.5-2+deb8u1 Raspbian:stable [armhf])
Conf libpoppler-glib8 (0.26.5-2+deb8u1 Raspbian:stable [armhf])
Conf libqt5core5a (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Conf libqt5dbus5 (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Conf libxcb-icccm4 (0.4.1-1 Raspbian:stable [armhf])
Conf libxcb-util0 (0.3.8-3 Raspbian:stable [armhf])
Conf libxcb-image0 (0.4.0-1 Raspbian:stable [armhf])
Conf libxcb-keysyms1 (0.4.0-1 Raspbian:stable [armhf])
Conf libxcb-randr0 (1.10-3 Raspbian:stable [armhf])
Conf libxcb-render-util0 (0.3.9-1 Raspbian:stable [armhf])
Conf libxcb-xkb1 (1.10-3 Raspbian:stable [armhf])
Conf libxkbcommon-x11-0 (0.4.3-2 Raspbian:stable [armhf])
Conf libqt5gui5 (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Conf libqt5widgets5 (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Conf libqt5xml5 (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Conf libpoppler-qt5-1 (0.26.5-2+deb8u1 Raspbian:stable [armhf])
Conf libpython3.4 (3.4.2-1 Raspbian:stable [armhf])
Conf libqpdf13 (5.1.2-2 Raspbian:stable [armhf])
Conf qtcore4-l10n (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [all])
Conf libqtcore4 (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [armhf])
Conf libqt4-xml (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [armhf])
Conf libqt5printsupport5 (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Conf libqt5sql5 (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Conf libqt5sql5-sqlite (5.3.2+dfsg-4+rpi1 Raspbian:stable [armhf])
Conf libqt5svg5 (5.3.2-2 Raspbian:stable [armhf])
Conf libqtdbus4 (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [armhf])
Conf libqtgui4 (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [armhf])
Conf libyajl2 (2.1.0-2 Raspbian:stable [armhf])
Conf libraptor2-0 (2.0.14-1 Raspbian:stable [armhf])
Conf librasqal3 (0.9.32-1 Raspbian:stable [armhf])
Conf librdf0 (1.0.17-1+b1 Raspbian:stable [armhf])
Conf libreoffice-style-galaxy (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [all])
Conf uno-libs3 (4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf ure (4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libreoffice-common (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [all])
Conf libsane-common (1.0.24-8+deb8u1 Raspbian:stable [all])
Conf libsane (1.0.24-8+deb8u1 Raspbian:stable [armhf])
Conf libwebp5 (0.4.1-1.2 Raspbian:stable [armhf])
Conf libsdl-image1.2 (1.2.12-5+b1 Raspbian:stable [armhf])
Conf libsecret-common (0.18-1 Raspbian:stable [all])
Conf libsecret-1-0 (0.18-1+b1 Raspbian:stable [armhf])
Conf libshine3 (3.1.0-2.1 Raspbian:stable [armhf])
Conf libshout3 (2.3.1-3 Raspbian:stable [armhf])
Conf libsoundtouch0 (1.8.0-1 Raspbian:stable [armhf])
Conf libjbig2dec0 (0.11+20120125-1 Raspbian:stable [armhf])
Conf poppler-data (0.4.7-1 Raspbian:stable [all])
Conf libgs9-common (9.06~dfsg-2+deb8u4 Raspbian:stable [all])
Conf libgs9 (9.06~dfsg-2+deb8u4 Raspbian:stable [armhf])
Conf libspectre1 (0.2.7-3 Raspbian:stable [armhf])
Conf libspeexdsp1 (1.2~rc1.2-1 Raspbian:stable [armhf])
Conf libssh-4 (0.6.3-4+deb8u2 Raspbian:stable [armhf])
Conf libstartup-notification0 (0.12-4 Raspbian:stable [armhf])
Conf libtag1-vanilla (1.9.1-2.1 Raspbian:stable [armhf])
Conf libupnp6 (1:1.6.19+git20141001-1+deb8u1 Raspbian:stable [armhf])
Conf libusageenvironment1 (2014.01.13-1 Raspbian:stable [armhf])
Conf libv4l2rds0 (1.6.0-2 Raspbian:stable [armhf])
Conf libvisual-0.4-0 (0.4.0-6 Raspbian:stable [armhf])
Conf libvncclient0 (0.9.9+dfsg2-6.1+deb8u2 Raspbian:stable [armhf])
Conf libvo-aacenc0 (0.1.3-1 Raspbian:stable [armhf])
Conf libvo-amrwbenc0 (0.1.3-1 Raspbian:stable [armhf])
Conf libwavpack1 (4.70.0-1 Raspbian:stable [armhf])
Conf libwayland-egl1-mesa (13.0.0-1+rpi1 Raspberry Pi Foundation:stable [armhf])
Conf libwebkitgtk-3.0-common (1:2.4.1-1rpi53rpi1g Raspberry Pi Foundation:stable [all])
Conf libwebkitgtk-3.0-0 (1:2.4.1-1rpi53rpi1g Raspberry Pi Foundation:stable [armhf])
Conf libwildmidi-config (0.3.7-1 Raspbian:stable [all])
Conf libwildmidi1 (0.3.7-1 Raspbian:stable [armhf])
Conf libxres1 (2:1.0.7-1 Raspbian:stable [armhf])
Conf libwnck-3-common (3.4.9-3 Raspbian:stable [all])
Conf libwnck-3-0 (3.4.9-3 Raspbian:stable [armhf])
Conf libxcb-composite0 (1.10-3 Raspbian:stable [armhf])
Conf libxcb-xv0 (1.10-3 Raspbian:stable [armhf])
Conf libzvbi-common (0.2.35-3 Raspbian:stable [all])
Conf libzvbi0 (0.2.35-3 Raspbian:stable [armhf])
Conf ntfs-3g (1:2014.2.15AR.2-1+deb8u3 Raspbian:stable [armhf])
Conf python-ldb (2:1.1.20-0+deb8u1 Raspbian:stable [armhf])
Conf samba-common (2:4.2.14+dfsg-0+deb8u2 Raspbian:stable [all])
Conf sgml-base (1.26+nmu4 Raspbian:stable [all])
Conf gnustep-common (2.6.6-3 Raspbian:stable [armhf])
Conf gnustep-base-common (1.24.7-1 Raspbian:stable [all])
Conf libgnustep-base1.24 (1.24.7-1 Raspbian:stable [armhf])
Conf gnustep-base-runtime (1.24.7-1 Raspbian:stable [armhf])
Conf unar (1.8.1-3+b1 Raspbian:stable [armhf])
Conf libass5 (0.10.2-3 Raspbian:stable [armhf])
Conf libcdaudio1 (0.99.12p2-13 Raspbian:stable [armhf])
Conf libgme0 (0.5.5-2+deb8u1 Raspbian:stable [armhf])
Conf libgstreamer-plugins-bad0.10-0 (0.10.23-7.4+deb8u2 Raspbian:stable [armhf])
Conf libkate1 (0.4.1-4 Raspbian:stable [armhf])
Conf libmimic0 (1.0.4-2.2 Raspbian:stable [armhf])
Conf libmodplug1 (1:0.8.8.4-4.1 Raspbian:stable [armhf])
Conf libofa0 (0.9.3-7 Raspbian:stable [armhf])
Conf libslv2-9 (0.6.6+dfsg1-2 Raspbian:stable [armhf])
Conf libspandsp2 (0.0.6-2 Raspbian:stable [armhf])
Conf libzbar0 (0.10+doc-10+b2 Raspbian:stable [armhf])
Conf gstreamer0.10-plugins-base (0.10.36-2 Raspbian:stable [armhf])
Conf gstreamer0.10-plugins-bad (0.10.23-7.4+deb8u2 Raspbian:stable [armhf])
Conf libgstreamer-plugins-bad1.0-0 (1.4.4-2.1+deb8u1 Raspbian:stable [armhf])
Conf libsbc1 (1.2-3 Raspbian:stable [armhf])
Conf libsrtp0 (1.4.5~20130609~dfsg-1.1+deb8u1 Raspbian:stable [armhf])
Conf gstreamer1.0-plugins-base (1.4.4-2 Raspbian:stable [armhf])
Conf gstreamer1.0-plugins-bad (1.4.4-2.1+deb8u1 Raspbian:stable [armhf])
Conf gettext-base (0.19.3-2 Raspbian:stable [armhf])
Conf pciutils (1:3.2.1-3 Raspbian:stable [armhf])
Conf apt-transport-https (1.0.9.8.4 Raspbian:stable [armhf])
Conf ark-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf artsbuilder-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf at-spi2-core (2.14.0-1 Raspbian:stable [armhf])
Conf cgroup-tools (0.41-6+rpi1 Raspbian:stable [armhf])
Conf colord-data (1.2.1-1 Raspbian:stable [all])
Conf colord (1.2.1-1+b2 Raspbian:stable [armhf])
Conf poppler-utils (0.26.5-2+deb8u1 Raspbian:stable [armhf])
Conf cups-filters-core-drivers (1.0.61-5+deb8u3 Raspbian:stable [armhf])
Conf cups-core-drivers (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Conf gsfonts (1:8.11+urwcyr1.0.7~pre44-4.2 Raspbian:stable [all])
Conf ghostscript (9.06~dfsg-2+deb8u4 Raspbian:stable [armhf])
Conf cups-common (1.7.5-11+deb8u1 Raspbian:stable [all])
Conf cups-server-common (1.7.5-11+deb8u1 Raspbian:stable [all])
Conf cups-client (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Conf cups-ppdc (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Conf cups-filters (1.0.61-5+deb8u3 Raspbian:stable [armhf])
Conf cups (1.7.5-11+deb8u1 Raspbian:stable [armhf])
Conf cups-browsed (1.0.61-5+deb8u3 Raspbian:stable [armhf])
Conf xml-core (0.13+nmu2 Raspbian:stable [all])
Conf sgml-data (2.0.10 Raspbian:stable [all])
Conf docbook-xml (4.5-7.2 Raspbian:stable [all])
Conf growisofs (7.1-11 Raspbian:stable [armhf])
Conf dvd+rw-tools (7.1-11 Raspbian:stable [armhf])
Conf enchant (1.6.0-10.1 Raspbian:stable [armhf])
Conf epiphany-browser-data (1:3.8.2.0-0rpi27rpi1g Raspberry Pi Foundation:stable [all])
Conf gnome-desktop3-data (3.14.1-1 Raspbian:stable [all])
Conf libgnome-desktop-3-10 (3.14.1-1 Raspbian:stable [armhf])
Conf gnome-icon-theme (3.12.0-1 Raspbian:stable [all])
Conf gnome-icon-theme-symbolic (3.12.0-1 Raspbian:stable [all])
Conf epiphany-browser (1:3.8.2.0-0rpi27rpi1g Raspberry Pi Foundation:stable [armhf])
Conf libkpathsea6 (2014.20140926.35254-6 Raspbian:stable [armhf])
Conf libevdocument3-4 (3.14.1-2+deb8u1 Raspbian:stable [armhf])
Conf libevview3-3 (3.14.1-2+deb8u1 Raspbian:stable [armhf])
Conf libnautilus-extension1a (3.14.1-2 Raspbian:stable [armhf])
Conf evince-common (3.14.1-2+deb8u1 Raspbian:stable [all])
Conf evince (3.14.1-2+deb8u1 Raspbian:stable [armhf])
Conf exfat-fuse (1.1.0-2+deb8u1 Raspbian:stable [armhf])
Conf exfat-utils (1.1.0-2+deb8u1 Raspbian:stable [armhf])
Conf fonts-dejavu-extra (2.34-1 Raspbian:stable [all])
Conf fonts-dejavu (2.34-1 Raspbian:stable [all])
Conf fonts-freefont-ttf (20120503-4 Raspbian:stable [all])
Conf fonts-lyx (2.1.2-2 Raspbian:stable [all])
Conf fonts-opensymbol (2:102.6+LibO4.3.3-2+rpi4 Raspberry Pi Foundation:stable [all])
Conf fonts-sil-gentium (20081126:1.02-13 Raspbian:stable [all])
Conf fonts-sil-gentium-basic (1.1-7 Raspbian:stable [all])
Conf freepats (20060219-1 Raspbian:stable [all])
Conf gconf-service (3.2.6-3 Raspbian:stable [armhf])
Conf gconf2 (3.2.6-3 Raspbian:stable [armhf])
Conf gcr (3.14.0-2+b1 Raspbian:stable [armhf])
Conf geoip-database (20150317-1 Raspbian:stable [all])
Conf libgirepository-1.0-1 (1.42.0-2.2 Raspbian:stable [armhf])
Conf gir1.2-glib-2.0 (1.42.0-2.2 Raspbian:stable [armhf])
Conf libgtop2-common (2.28.5-2 Raspbian:stable [all])
Conf libgtop2-7 (2.28.5-2 Raspbian:stable [armhf])
Conf libgksu2-0 (2.0.13~pre1-8 Raspbian:stable [armhf])
Conf gksu (2.0.2-9 Raspbian:stable [armhf])
Conf gnome-accessibility-themes (3.14.2.2-1rpi1rpi1g Raspberry Pi Foundation:stable [all])
Conf p11-kit-modules (0.20.7-1 Raspbian:stable [armhf])
Conf p11-kit (0.20.7-1 Raspbian:stable [armhf])
Conf gnome-keyring (3.14.0-1+b1 Raspbian:stable [armhf])
Conf libyelp0 (3.14.1-1 Raspbian:stable [armhf])
Conf yelp-xsl (3.14.0-1 Raspbian:stable [all])
Conf yelp (3.14.1-1 Raspbian:stable [armhf])
Conf gnome-user-guide (3.14.1-1 Raspbian:stable [all])
Conf gstreamer0.10-gconf (0.10.31-3+nmu4+deb8u2 Raspbian:stable [armhf])
Conf libtag1c2a (1.9.1-2.1 Raspbian:stable [armhf])
Conf gstreamer0.10-plugins-good (0.10.31-3+nmu4+deb8u2 Raspbian:stable [armhf])
Conf liba52-0.7.4 (0.7.4-17 Raspbian:stable [armhf])
Conf libsidplay1 (1.36.59-6 Raspbian:stable [armhf])
Conf libtwolame0 (0.3.13-1.1 Raspbian:stable [armhf])
Conf gstreamer0.10-plugins-ugly (0.10.19-2.1+b1 Raspbian:stable [armhf])
Conf gstreamer0.10-x (0.10.36-2 Raspbian:stable [armhf])
Conf gstreamer1.0-alsa (1.4.4-2 Raspbian:stable [armhf])
Conf gstreamer1.0-libav (1.4.4-2 Raspbian:stable [armhf])
Conf gstreamer1.0-omx (1.0.0.1-0+rpi18rpi1g Raspberry Pi Foundation:stable [armhf])
Conf gstreamer1.0-plugins-good (1.4.4-2+deb8u2 Raspbian:stable [armhf])
Conf gstreamer1.0-plugins-ugly (1.4.4-2 Raspbian:stable [armhf])
Conf gstreamer1.0-x (1.4.4-2 Raspbian:stable [armhf])
Conf gtk2-engines (1:2.20.2-3 Raspbian:stable [armhf])
Conf gtk2-engines-pixbuf (2.24.25-3+deb8u1 Raspbian:stable [armhf])
Conf gvfs-common (1.22.2-1 Raspbian:stable [all])
Conf gvfs-libs (1.22.2-1 Raspbian:stable [armhf])
Conf gvfs-daemons (1.22.2-1 Raspbian:stable [armhf])
Conf gvfs (1.22.2-1 Raspbian:stable [armhf])
Conf libexiv2-12 (0.23-1 q4os-rpi-1-0 repository:1.0/q4os-rpi-1-0-st [armhf])
Conf libkipi0-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf gwenview-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf gwenview-i18n-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [all])
Conf hwdata (0.267-1 Raspbian:stable [all])
Conf icedove (1:45.6.0-1~deb8u1 Raspbian:stable [armhf])
Conf iceowl-extension (1:45.6.0-1~deb8u1 Raspbian:stable [armhf])
Conf jackd (5 Raspbian:stable [all])
Conf libtdegames1-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf kbounce-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf kcalc-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf kmag-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf kmines-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf kolourpaint-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf tdegames-card-data-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [all])
Conf kpat-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf krec-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf ksnapshot-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf librevenge-0.0-0 (0.0.1-3 Raspbian:stable [armhf])
Conf libabw-0.1-1 (0.1.0-2 Raspbian:stable [armhf])
Conf libakode2 (2.0.2-7raspbian7.0.0+1 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf libarts1-akode-trinity (4:14.0.4-0raspbian7.0.0+0 Q4OS TDE repository:7.0/qtde-rpijessie-st [armhf])
Conf libauthen-sasl-perl (2.1600-1 Raspbian:stable [all])
Conf libblas-common (1.2.20110419-10 Raspbian:stable [armhf])
Conf libblas3 (1.2.20110419-10 Raspbian:stable [armhf])
Conf libcairo-perl (1.104-2 Raspbian:stable [armhf])
Conf libcanberra-gtk3-module (0.30-2.1 Raspbian:stable [armhf])
Conf libcddb2 (1.3.2-5 Raspbian:stable [armhf])
Conf libcdr-0.1-1 (0.1.0-3 Raspbian:stable [armhf])
Conf libcmis-0.4-4 (0.4.1-7 Raspbian:stable [armhf])
Conf libe-book-0.1-1 (0.1.1-2 Raspbian:stable [armhf])
Conf libencode-locale-perl (1.03-1 Raspbian:stable [all])
Conf libeot0 (0.01-3 Raspbian:stable [armhf])
Conf libept1.4.12 (1.0.12.1 Raspbian:stable [armhf])
Conf libetonyek-0.1-1 (0.1.1-2 Raspbian:stable [armhf])
Conf libexttextcat-data (3.4.4-1 Raspbian:stable [all])
Conf libexttextcat-2.0-0 (3.4.4-1 Raspbian:stable [armhf])
Conf libfile-basedir-perl (0.03-1 Raspbian:stable [all])
Conf libfile-copy-recursive-perl (0.38-1 Raspbian:stable [all])
Conf libfile-desktopentry-perl (0.07-1 Raspbian:stable [all])
Conf libtimedate-perl (2.3000-2 Raspbian:stable [all])
Conf libhttp-date-perl (6.02-1 Raspbian:stable [all])
Conf libfile-listing-perl (6.04-1 Raspbian:stable [all])
Conf libfile-mimeinfo-perl (0.26-1 Raspbian:stable [all])
Conf libfont-afm-perl (1.20-1 Raspbian:stable [all])
Conf libfreehand-0.1-1 (0.1.0-2 Raspbian:stable [armhf])
Conf libglib-perl (3:1.305-2 Raspbian:stable [armhf])
Conf libgltf-0.0-0 (0.0.2-2 Raspbian:stable [armhf])
Conf libgphoto2-l10n (2.5.4-1.1 Raspbian:stable [all])
Conf libpango-perl (1.226-2 Raspbian:stable [armhf])
Conf libgtk2-perl (2:1.2492-4 Raspbian:stable [armhf])
Conf libgtk2.0-bin (2.24.25-3+deb8u1 Raspbian:stable [armhf])
Conf libservlet2.5-java (6.0.45+dfsg-1~deb8u1 Raspbian:stable [all])
Conf libhsqldb1.8.0-java (1.8.0.10+dfsg-3 Raspbian:stable [all])
Conf liburi-perl (1.64-1 Raspbian:stable [all])
Conf libhtml-tagset-perl (3.20-2 Raspbian:stable [all])
Conf libhtml-parser-perl (3.71-1+b4 Raspbian:stable [armhf])
Conf libio-html-perl (1.001-1 Raspbian:stable [all])
Conf liblwp-mediatypes-perl (6.02-1 Raspbian:stable [all])
Conf libhttp-message-perl (6.06-1 Raspbian:stable [all])
Conf libhtml-form-perl (6.03-1 Raspbian:stable [all])
Conf libhtml-tree-perl (5.03-1 Raspbian:stable [all])
Conf libhtml-format-perl (2.11-1 Raspbian:stable [all])
Conf libhttp-cookies-perl (6.01-1 Raspbian:stable [all])
Conf libhttp-daemon-perl (6.01-1 Raspbian:stable [all])
Conf libhttp-negotiate-perl (6.00-2 Raspbian:stable [all])
Conf libhyphen0 (2.8.8-1 Raspbian:stable [armhf])
Conf libnet-ssleay-perl (1.65-1+deb8u1 Raspbian:stable [armhf])
Conf libio-socket-ssl-perl (2.002-2+deb8u2 Raspbian:stable [all])
Conf libiso9660-8 (0.83-4.2 Raspbian:stable [armhf])
Conf liblangtag-common (0.5.1-3 Raspbian:stable [all])
Conf liblangtag1 (0.5.1-3 Raspbian:stable [armhf])
Conf liblapack3 (3.5.0-4 Raspbian:stable [armhf])
Conf liblircclient0 (0.9.0~pre1-1.2 Raspbian:stable [armhf])
Conf libnet-http-perl (6.07-1 Raspbian:stable [all])
Conf libwww-robotrules-perl (6.01-1 Raspbian:stable [all])
Conf libwww-perl (6.08-1 Raspbian:stable [all])
Conf liblwp-protocol-https-perl (6.06-2 Raspbian:stable [all])
Conf libnet-smtp-ssl-perl (1.01-3 Raspbian:stable [all])
Conf libmailtools-perl (2.13-1 Raspbian:stable [all])
Conf libmspub-0.1-1 (0.1.1-2 Raspbian:stable [armhf])
Conf libmtp-runtime (1.1.8-1+b1 Raspbian:stable [armhf])
Conf libmwaw-0.3-3 (0.3.1-2 Raspbian:stable [armhf])
Conf libmythes-1.2-0 (2:1.2.4-1 Raspbian:stable [armhf])
Conf libneon27-gnutls (0.30.1-1 Raspbian:stable [armhf])
Conf libxml-parser-perl (2.41-3 Raspbian:stable [armhf])
Conf libxml-twig-perl (1:3.48-1 Raspbian:stable [all])
Conf libnet-dbus-perl (1.0.0-2+b2 Raspbian:stable [armhf])
Conf libodfgen-0.1-1 (0.1.1-2 Raspbian:stable [armhf])
Conf liborcus-0.8-0 (0.7.0+dfsg-9 Raspbian:stable [armhf])
Conf libpam-gnome-keyring (3.14.0-1+b1 Raspbian:stable [armhf])
Conf libpaper-utils (1.1.24+nmu4 Raspbian:stable [armhf])
Conf libperl4-corelibs-perl (0.003-1 Raspbian:stable [all])
Conf libpostproc52 (6:0.git20120821-4 Raspbian:stable [armhf])
Conf libproxy-tools (0.4.11-4 Raspbian:stable [armhf])
Conf qtchooser (47-gd2b7997-2 Raspbian:stable [armhf])
Conf qdbus (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [armhf])
Conf libqt4-dbus (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1 Raspbian:stable [armhf])
Conf libreoffice-core (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libreoffice-base-core (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libreoffice-base-drivers (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libreoffice-base (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf lp-solve (5.5.0.13-7+b1 Raspbian:stable [armhf])
Conf coinor-libcoinutils3 (2.9.15-3 Raspbian:stable [armhf])
Conf coinor-libosi1 (0.106.9-1 Raspbian:stable [armhf])
Conf coinor-libclp1 (1.15.10-1 Raspbian:stable [armhf])
Conf coinor-libcgl1 (0.58.9-1 Raspbian:stable [armhf])
Conf coinor-libcbc3 (2.8.12-1 Raspbian:stable [armhf])
Conf coinor-libcoinmp1 (1.7.6+dfsg1-1 Raspbian:stable [armhf])
Conf libwps-0.3-3 (0.3.0-2 Raspbian:stable [armhf])
Conf libreoffice-calc (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libvisio-0.1-1 (0.1.0-2 Raspbian:stable [armhf])
Conf libwpd-0.10-10 (0.10.0-2 Raspbian:stable [armhf])
Conf libwpg-0.3-3 (0.3.0-3 Raspbian:stable [armhf])
Conf libreoffice-draw (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libreoffice-impress (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libreoffice-math (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libreoffice-report-builder-bin (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libreoffice-writer (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libreoffice-avmedia-backend-gstreamer (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libreoffice-java-common (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [all])
Conf python3-uno (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libreoffice (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libreoffice-sdbc-firebird (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libreoffice-sdbc-hsqldb (1:4.3.3-2+rpi4 Raspberry Pi Foundation:stable [armhf])
Conf libresid-builder0c2a (2.1.1-14 Raspbian:stable [armhf])
Conf libsane-extras-common (1.0.22.3 Raspbian:stable [armhf])
Conf libsane-extras (1.0.22.3 Raspbian:stable [armhf])
Conf libsidplay2 (2.1.1-14 Raspbian:stable [armhf])
Conf libtie-ixhash-perl (1.23-1 Raspbian:stable [all])
Conf libva-drm1 (1.7.3-2 Raspberry Pi Foundation:stable [armhf])
Conf libva-x11-1 (1.7.3-2 Raspberry Pi Foundation:stable [armhf])
Conf libvcdinfo0 (0.7.24+dfsg-0.2 Raspbian:stable [armhf])
Conf libvisual-0.4-plugins (0.4.0.dfsg.1-7 Raspbian:stable [armhf])
Conf vlc-data (2.2.4-1~deb8u1 Raspbian:stable [all])
Conf libvlccore8 (2.2.4-1~deb8u1 Raspbian:stable [armhf])
Conf libvlc5 (2.2.4-1~deb8u1 Raspbian:stable [armhf])
Conf libvte-2.90-common (1:0.36.3-1 Raspbian:stable [all])
Conf libvte-2.90-9 (1:0.36.3-1 Raspbian:stable [armhf])
Conf libx11-protocol-perl (0.56-6 Raspbian:stable [all])
Conf libxml-xpathengine-perl (0.13-1 Raspbian:stable [all])
Conf ncompress (4.2.4.4-9 Raspbian:stable [armhf])
Conf notification-daemon (0.7.6-2 Raspbian:stable [armhf])
Conf squeak-vm (1:4.10.2.2614-1.1+b1 Raspbian:stable [armhf])
Conf libpango1.0-0 (1.36.8-3+rpi1 Raspberry Pi Foundation:stable [armhf])
Conf squeak-plugins-scratch (1.4.0.2~svn.r83-2 Raspbian:stable [armhf])
Conf scratch (1.4.0.6~dfsg1-5 Raspbian:stable [all])
Conf pigpio (1.30-1 Raspberry Pi Foundation:stable [armhf])
Conf nuscratch (20161021 Raspberry Pi Foundation:stable [armhf])
Conf omxplayer (0.3.7~git20160923~dfea8c9 Raspberry Pi Foundation:stable [armhf])
Conf oracle-java8-jdk (8u65 Raspberry Pi Foundation:stable [armhf])
Conf p7zip-full (9.20.1~dfsg.1-4.1+deb8u2 Raspbian:stable [armhf])
Conf policykit-1-gnome (0.105-2 Raspbian:stable [armhf])
Conf printer-driver-gutenprint (5.2.10-3+b3 Raspbian:stable [armhf])
Conf python-crypto (2.6.1-5+deb8u1 Raspbian:stable [armhf])
Conf python-gi (3.14.0-1 Raspbian:stable [armhf])
Conf python-ntdb (1.0-5 Raspbian:stable [armhf])
Conf python-tdb (1.3.6-0+deb8u1 Raspbian:stable [armhf])
Conf python-samba (2:4.2.14+dfsg-0+deb8u2 Raspbian:stable [armhf])
Conf python3-dbus (1.2.0-2+b1 Raspbian:stable [armhf])
Conf python3-gi (3.14.0-1 Raspbian:stable [armhf])
Conf python3-software-properties (0.92.25debian1 Raspbian:stable [all])
Conf qjackctl (0.3.12-1 Raspbian:stable [armhf])
Conf qpdf (5.1.2-2 Raspbian:stable [armhf])
Conf qpdfview (0.4.12-1 Raspbian:stable [armhf])
Conf qpdfview-djvu-plugin (0.4.12-1 Raspbian:stable [armhf])
Conf qpdfview-ps-plugin (0.4.12-1 Raspbian:stable [armhf])
Conf qpdfview-translations (0.4.12-1 Raspbian:stable [all])
Conf qttranslations5-l10n (5.3.2-2 Raspbian:stable [all])
Conf rsync (3.1.1-3 Raspbian:stable [armhf])
Conf samba-common-bin (2:4.2.14+dfsg-0+deb8u2 Raspbian:stable [armhf])
Conf update-inetd (4.43 Raspbian:stable [all])
Conf sane-utils (1.0.24-8+deb8u1 Raspbian:stable [armhf])
Conf software-properties-common (0.92.25debian1 Raspbian:stable [all])
Conf synaptic (0.81.2+rpi1 Raspbian:stable [armhf])
Conf twolame (0.3.13-1.1 Raspbian:stable [armhf])
Conf unrar-free (1:0.0.1+cvs20140707-1 Raspbian:stable [armhf])
Conf v4l-utils (1.6.0-2 Raspbian:stable [armhf])
Conf va-driver-all (1.7.3-2 Raspberry Pi Foundation:stable [armhf])
Conf vlc-nox (2.2.4-1~deb8u1 Raspbian:stable [armhf])
Conf vlc (2.2.4-1~deb8u1 Raspbian:stable [armhf])
Conf vlc-plugin-notify (2.2.4-1~deb8u1 Raspbian:stable [armhf])
Conf vlc-plugin-samba (2.2.4-1~deb8u1 Raspbian:stable [armhf])
Conf xdg-utils (1.1.0~rc1+git20111210-7.4 Raspbian:stable [all])
Conf xfonts-encodings (1:1.0.4-2 Raspbian:stable [all])
Conf xfonts-utils (1:7.7+2 Raspbian:stable [armhf])
Conf zenity-common (3.14.0-1 Raspbian:stable [all])
Conf zenity (3.14.0-1 Raspbian:stable [armhf])
Conf zip (3.0-8 Raspbian:stable [armhf])
Conf zoo (2.10-27 Raspbian:stable [armhf])
Conf bluej (3.1.7b Raspberry Pi Foundation:stable [all])
Conf cgroup-bin (0.41-6+rpi1 Raspbian:stable [all])
Conf fonts-stix (1.1.1-1 Raspbian:stable [all])
Conf gdisk (0.8.10-2 Raspbian:stable [armhf])
Conf librarian0 (0.8.1-6 Raspbian:stable [armhf])
Conf q4os-wallpapers (1.1.3-a1 q4os-rpi-1-0 repository:1.0/q4os-rpi-1-0-st [all])
Conf rarian-compat (0.8.1-6 Raspbian:stable [armhf])
Conf raspberrypi-artwork (20150921 Raspberry Pi Foundation:stable [all])
Conf xfonts-mathml (6 Raspbian:stable [all])
Downloading ...
Reading package lists... 100%
Reading package lists... Done
Building dependency tree
Reading state information... 0%
alsa-utils is already the newest version.
bzip2 is already the newest version.
console-setup is already the newest version.
dosfstools is already the newest version.
eject is already the newest version.
kbd is already the newest version.
nfs-common is already the newest version.
udisks2 is already the newest version.
unzip is already the newest version.
libarts1-audiofile-trinity is already the newest version.
libarts1-mpeglib-trinity is already the newest version.
The following extra packages will be installed:
adwaita-icon-theme artsbuilder-trinity at-spi2-core bc cdparanoia cdrdao
cgroup-bin cgroup-tools coinor-libcbc3 coinor-libcgl1 coinor-libclp1
coinor-libcoinmp1 coinor-libcoinutils3 coinor-libosi1 colord colord-data
cups-browsed cups-client cups-common cups-core-drivers cups-daemon
cups-filters cups-filters-core-drivers cups-ppdc cups-server-common
dictionaries-common docbook-xml dvd+rw-tools emacsen-common enchant
epiphany-browser-data evince evince-common exfat-fuse firebird2.5-common
firebird2.5-common-doc firebird2.5-server-common fonts-dejavu-extra
fonts-freefont-ttf fonts-lyx fonts-opensymbol fonts-sil-gentium
fonts-sil-gentium-basic fonts-stix freepats gconf-service gconf2
gconf2-common gcr genisoimage gettext-base ghostscript gir1.2-glib-2.0
gnome-accessibility-themes gnome-desktop3-data gnome-icon-theme
gnome-icon-theme-symbolic gnome-keyring gnome-themes-standard
gnome-themes-standard-data gnome-user-guide gnustep-base-common
gnustep-base-runtime gnustep-common growisofs gsfonts gstreamer0.10-gconf
gstreamer0.10-x gstreamer1.0-alsa gstreamer1.0-omx gstreamer1.0-x
gtk2-engines-pixbuf gvfs gvfs-common gvfs-daemons gvfs-libs hunspell-en-us
hwdata iceowl-extension iso-codes jackd2 k3b-data-trinity liba52-0.7.4
libaa1 libabw-0.1-1 libakode2 libao-common libarchive13 libasprintf0c2
libass5 libatk-bridge2.0-0 libatk1.0-0 libatk1.0-data libatspi2.0-0
libauthen-sasl-perl libavahi-glib1 libavahi-gobject0 libavc1394-0
libavcodec56 libavdevice55 libavfilter5 libavformat56 libavresample2
libavutil54 libbasicusageenvironment0 libblas-common libblas3
libboost-date-time1.55.0 libboost-system1.55.0 libcaca0 libcairo-gobject2
libcairo-perl libcairo2 libcanberra-gtk3-0 libcanberra-gtk3-module
libcanberra0 libcdaudio1 libcddb2 libcdio-cdda1 libcdio-paranoia1 libcdio13
libcdr-0.1-1 libcgroup1 libchromaprint0 libclucene-contribs1
libclucene-core1 libcmis-0.4-4 libcolamd2.8.0 libcolord2 libcolorhug2
libcroco3 libcupscgi1 libcupsfilters1 libcupsimage2 libcupsmime1
libcupsppdc1 libcurl3-gnutls libdatrie1 libdc1394-22 libdca0
libdirac-encoder0 libdirectfb-1.2-9 libdjvulibre-text libdjvulibre21 libdv4
libdvbpsi9 libe-book-0.1-1 libebml4 libenca0 libenchant1c2a
libencode-locale-perl libeot0 libept1.4.12 libetonyek-0.1-1 libevdocument3-4
libevview3-3 libexif12 libexiv2-12 libexttextcat-2.0-0 libexttextcat-data
libfbclient2 libfbembed2.5 libfftw3-double3 libfile-basedir-perl
libfile-copy-recursive-perl libfile-desktopentry-perl libfile-listing-perl
libfile-mimeinfo-perl libflac++6 libflite1 libfluidsynth1 libfont-afm-perl
libfontembed1 libfreehand-0.1-1 libfreerdp-cache1.1 libfreerdp-client1.1
libfreerdp-codec1.1 libfreerdp-common1.1.0 libfreerdp-core1.1
libfreerdp-crypto1.1 libfreerdp-gdi1.1 libfreerdp-locale1.1
libfreerdp-primitives1.1 libfreerdp-rail1.1 libfreerdp-utils1.1 libfribidi0
libgck-1-0 libgconf-2-4 libgcr-3-common libgcr-base-3-1 libgcr-ui-3-1 libgd3
libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libgeoclue0 libgfortran3
libgirepository-1.0-1 libgksu2-0 libgles1-mesa libgles2-mesa libglew1.10
libglib-perl libgltf-0.0-0 libgme0 libgnome-desktop-3-10
libgnome-keyring-common libgnome-keyring0 libgnustep-base1.24 libgomp1
libgphoto2-6 libgphoto2-l10n libgphoto2-port10 libgpm2 libgraphite2-3
libgroupsock1 libgs9 libgs9-common libgsm1 libgstreamer-plugins-bad0.10-0
libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base0.10-0
libgstreamer-plugins-base1.0-0 libgstreamer0.10-0 libgstreamer1.0-0
libgtk-3-0 libgtk-3-bin libgtk-3-common libgtk2-perl libgtk2.0-0
libgtk2.0-bin libgtk2.0-common libgtkglext1 libgtop2-7 libgtop2-common
libgusb2 libgutenprint2 libgxps2 libharfbuzz-icu0 libharfbuzz0b
libhsqldb1.8.0-java libhtml-form-perl libhtml-format-perl
libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl
libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl
libhttp-message-perl libhttp-negotiate-perl libhunspell-1.3-0 libhyphen0
libiec61883-0 libieee1284-3 libijs-0.35 libio-html-perl
libio-socket-ssl-perl libiso9660-8 libjack-jackd2-0
libjavascriptcoregtk-3.0-0 libjbig2dec0 libjson-glib-1.0-0
libjson-glib-1.0-common libk3b3-trinity libkate1 libkipi0-trinity
libkpathsea6 liblangtag-common liblangtag1 liblapack3 liblircclient0
liblivemedia23 libltdl7 liblua5.2-0 liblwp-mediatypes-perl
liblwp-protocol-https-perl liblzo2-2 libmailtools-perl libmatroska6
libmhash2 libmimic0 libmjpegutils-2.1-0 libmms0 libmodplug1 libmpcdec6
libmpeg2-4 libmpeg2encpp-2.1-0 libmpg123-0 libmplex2-2.1-0 libmspub-0.1-1
libmtp-common libmtp-runtime libmtp9 libmwaw-0.3-3 libmythes-1.2-0
libnautilus-extension1a libneon27-gnutls libnet-dbus-perl libnet-http-perl
libnet-smtp-ssl-perl libnet-ssleay-perl libnotify4 libnspr4 libnss3 libobjc4
libodfgen-0.1-1 libofa0 libopenal-data libopenal1 libopencv-calib3d2.4
libopencv-contrib2.4 libopencv-core2.4 libopencv-features2d2.4
libopencv-flann2.4 libopencv-highgui2.4 libopencv-imgproc2.4
libopencv-legacy2.4 libopencv-ml2.4 libopencv-objdetect2.4
libopencv-video2.4 libopenjpeg5 libopus0 liborc-0.4-0 liborcus-0.8-0
libpam-gnome-keyring libpango-1.0-0 libpango-perl libpango1.0-0
libpangocairo-1.0-0 libpangoft2-1.0-0 libpangox-1.0-0 libpangoxft-1.0-0
libpci3 libperl4-corelibs-perl libpoppler-glib8 libpoppler-qt5-1
libpoppler46 libpostproc52 libproxy-tools libpython3.4 libqpdf13 libqt4-dbus
libqt4-xml libqt5core5a libqt5dbus5 libqt5gui5 libqt5printsupport5
libqt5sql5 libqt5sql5-sqlite libqt5svg5 libqt5widgets5 libqt5xml5 libqtcore4
libqtdbus4 libqtgui4 libraptor2-0 librarian0 librasqal3 librdf0
libreoffice-avmedia-backend-gstreamer libreoffice-base libreoffice-base-core
libreoffice-base-drivers libreoffice-calc libreoffice-common
libreoffice-core libreoffice-draw libreoffice-impress
libreoffice-java-common libreoffice-math libreoffice-report-builder-bin
libreoffice-sdbc-firebird libreoffice-sdbc-hsqldb libreoffice-style-galaxy
libreoffice-writer libresid-builder0c2a librest-0.7-0 librevenge-0.0-0
librsvg2-2 librsvg2-common librtmp1 libsane libsane-common libsane-extras
libsane-extras-common libsbc1 libschroedinger-1.0-0 libsdl-image1.2
libsdl1.2debian libsecret-1-0 libsecret-common libservlet2.5-java libshine3
libshout3 libsidplay1 libsidplay2 libslv2-9 libsoundtouch0
libsoup-gnome2.4-1 libspandsp2 libspectre1 libspeex1 libspeexdsp1 libsrtp0
libssh-4 libssh2-1 libstartup-notification0 libswscale3 libtag1-vanilla
libtag1c2a libtdegames1-trinity libthai-data libthai0 libtheora0
libtie-ixhash-perl libtimedate-perl libtwolame0 libupnp6 liburi-perl
libusageenvironment1 libv4l-0 libv4l2rds0 libv4lconvert0 libva-drm1
libva-x11-1 libva1 libvcdinfo0 libvisio-0.1-1 libvisual-0.4-0
libvisual-0.4-plugins libvlc5 libvlccore8 libvncclient0 libvo-aacenc0
libvo-amrwbenc0 libvpx1 libvte-2.90-9 libvte-2.90-common libwavpack1
libwayland-cursor0 libwayland-egl1-mesa libwebkitgtk-3.0-0
libwebkitgtk-3.0-common libwebp5 libwildmidi-config libwildmidi1
libwinpr-crt0.1 libwinpr-crypto0.1 libwinpr-dsparse0.1
libwinpr-environment0.1 libwinpr-file0.1 libwinpr-handle0.1 libwinpr-heap0.1
libwinpr-input0.1 libwinpr-interlocked0.1 libwinpr-library0.1
libwinpr-path0.1 libwinpr-pool0.1 libwinpr-registry0.1 libwinpr-rpc0.1
libwinpr-sspi0.1 libwinpr-synch0.1 libwinpr-sysinfo0.1 libwinpr-thread0.1
libwinpr-utils0.1 libwnck-3-0 libwnck-3-common libwpd-0.10-10 libwpg-0.3-3
libwps-0.3-3 libwww-perl libwww-robotrules-perl libx11-protocol-perl
libx264-142 libxcb-composite0 libxcb-icccm4 libxcb-image0 libxcb-keysyms1
libxcb-randr0 libxcb-render-util0 libxcb-shm0 libxcb-util0 libxcb-xkb1
libxcb-xv0 libxkbcommon-x11-0 libxkbcommon0 libxml-parser-perl
libxml-twig-perl libxml-xpathengine-perl libxres1 libxvidcore4 libyajl2
libyelp0 libzbar0 libzvbi-common libzvbi0 lp-solve ncompress
notification-daemon p11-kit p11-kit-modules p7zip-full pciutils pigpio
poppler-data poppler-utils printer-driver-gutenprint python-crypto
python-dbus python-dbus-dev python-gi python-ldb python-ntdb python-samba
python-tdb python3-dbus python3-gi python3-software-properties python3-uno
qdbus qjackctl qpdf qpdfview-djvu-plugin qpdfview-ps-plugin qtchooser
qtcore4-l10n qttranslations5-l10n rarian-compat samba-common-bin sane-utils
sgml-base sgml-data squeak-plugins-scratch squeak-vm ssl-cert
tdegames-card-data-trinity unar uno-libs3 update-inetd ure vlc-data vlc-nox
vlc-plugin-notify vlc-plugin-samba wodim xdg-utils xfonts-encodings
xfonts-mathml xfonts-utils xml-core yelp yelp-xsl zenity zenity-common zoo
Suggested packages:
rar cups-bsd printer-driver-hpcups hplip cups-pdf smbclient xpp ispell
aspell hunspell wordlist docbook docbook-dsssl docbook-xsl docbook-defguide
cdrskin unrar nautilus gconf-defaults-service cdrkit-doc ghostscript-x
gnustep-base-doc frei0r-plugins gvfs-backends gwenview-i18n
openoffice.org-hunspell openoffice.org-core calendar-google-provider
isoquery jack-tools meterbridge normalize-audio toolame sox movixmaker-2
vcdimager libesd0 libesd-alsa0 lrzip libdigest-hmac-perl libgssapi-perl
libbluray-bdj libfont-freetype-perl libcanberra-gtk0 libcanberra-pulse
libchromaprint-tools python-acoustid libdv-bin oss-compat libdvdcss2
libenchant-voikko exiv2 libfftw3-bin libfftw3-dev freerdp-x11 libgd-tools
geoclue glew-utils gphoto2 gtkam gpm gstreamer-codec-install
gnome-codec-install gstreamer0.10-tools gstreamer1.0-tools libgtk2-perl-doc
gutenprint-locales java-virtual-machine libhsqldb1.8.0-java-gcj
libdata-dump-perl lirc libcrypt-ssleay-perl libportaudio2 opus-tools
qt4-qtconfig raptor2-utils rasqal-utils librdf-storage-postgresql
librdf-storage-mysql librdf-storage-sqlite librdf-storage-virtuoso
redland-utils hyphen-hyphenation-patterns imagemagick
graphicsmagick-imagemagick-compat libreoffice-gnome libreoffice-kde
libreoffice-grammarcheck libreoffice-help-4.3 libreoffice-l10n-4.3
mythes-thesaurus openclipart-libreoffice pstoedit unixodbc
gstreamer1.0-ffmpeg default-jre gcj-jre openjdk-7-jre openjdk-6-jre
java5-runtime jre libreoffice-officebean libreoffice-gcj
libreoffice-report-builder libjtds-java libreoffice-mysql-connector
libmyodbc libmysql-java libreoffice-sdbc-postgresql odbc-postgresql
libpg-java libsqliteodbc tdsodbc mdbtools ocl-icd-libopencl1
libreoffice-style-crystal libreoffice-style-hicontrast
libreoffice-style-oxygen libreoffice-style-sifr libreoffice-style-tango
fonts-crosextra-caladea fonts-crosextra-carlito librsvg2-bin hpoj
sidplay-base xsidplay slv2-jack libspectre1-dbg speex srtp-utils
libauthen-ntlm-perl libunicode-map8-perl libunicode-string-perl
xml-twig-tools p7zip-rar fonts-japanese-mincho fonts-ipafont-mincho
fonts-japanese-gothic fonts-ipafont-gothic fonts-arphic-ukai
fonts-arphic-uming fonts-nanum gutenprint-doc python-crypto-dbg
python-crypto-doc python-dbus-doc python-dbus-dbg python-gi-cairo
python3-dbus-dbg pulseaudio-utils heimdal-clients unpaper pulseaudio
sgml-base-doc perlsgml w3-recs opensp libxml2-utils
squeak-plugins-scratch-dbg etoys openssl-blacklist dwww menu deborphan
apt-xapian-index tasksel software-properties-gtk pike7.8 pike7.6 pike
videolan-doc gvfs-bin debhelper
Recommended packages:
tdegraphics-tdefile-plugins-trinity kipi-plugins-trinity myspell-en-us
hunspell-dictionary myspell-dictionary libk3b3-extracodecs-trinity
adwaita-icon-theme apt-transport-https ark-trinity artsbuilder-trinity
at-spi2-core bc bluej cdparanoia cdrdao cgroup-bin cgroup-tools
coinor-libcbc3 coinor-libcgl1 coinor-libclp1 coinor-libcoinmp1
coinor-libcoinutils3 coinor-libosi1 colord colord-data cups cups-browsed
cups-client cups-common cups-core-drivers cups-daemon cups-filters
cups-filters-core-drivers cups-ppdc cups-server-common dictionaries-common
docbook-xml dvd+rw-tools emacsen-common enchant epiphany-browser
epiphany-browser-data evince evince-common exfat-fuse exfat-utils
firebird2.5-common firebird2.5-common-doc firebird2.5-server-common
fonts-dejavu fonts-dejavu-extra fonts-freefont-ttf fonts-lyx
fonts-opensymbol fonts-sil-gentium fonts-sil-gentium-basic fonts-stix
freepats gconf-service gconf2 gconf2-common gcr gdisk genisoimage
geoip-database gettext-base ghostscript gir1.2-glib-2.0 gksu
gstreamer0.10-plugins-bad gstreamer0.10-plugins-base
gstreamer0.10-plugins-good gstreamer0.10-plugins-ugly gstreamer0.10-x
gstreamer1.0-alsa gstreamer1.0-libav gstreamer1.0-omx
gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good
gstreamer1.0-plugins-ugly gstreamer1.0-x gtk2-engines gtk2-engines-pixbuf
gvfs gvfs-common gvfs-daemons gvfs-libs gwenview-i18n-trinity
gwenview-trinity hunspell-en-us hwdata icedove iceowl-extension iso-codes
jackd jackd2 k3b-data-trinity k3b-i18n-trinity k3b-trinity kbounce-trinity
kcalc-trinity kmag-trinity kmines-trinity kolourpaint-trinity kpat-trinity
krec-trinity ksnapshot-trinity liba52-0.7.4 libaa1 libaacs0 libabw-0.1-1
libakode2 libao-common libao4 libarchive13 libarts1-akode-trinity
libasprintf0c2 libass5 libatk-bridge2.0-0 libatk1.0-0 libatk1.0-data
libatspi2.0-0 libauthen-sasl-perl libav-tools libavahi-glib1
libavahi-gobject0 libavc1394-0 libavcodec56 libavdevice55 libavfilter5
libavformat56 libavresample2 libavutil54 libbasicusageenvironment0
libblas-common libblas3 libbluray1 libboost-date-time1.55.0
libboost-system1.55.0 libcaca0 libcairo-gobject2 libcairo-perl libcairo2
libcanberra-gtk3-0 libcanberra-gtk3-module libcanberra0 libcdaudio1 libcddb2
libcdio-cdda1 libcdio-paranoia1 libcdio13 libcdr-0.1-1 libcgroup1
libchromaprint0 libclucene-contribs1 libclucene-core1 libcmis-0.4-4
libcolamd2.8.0 libcolord2 libcolorhug2 libcroco3 libcupscgi1 libcupsfilters1
libcupsimage2 libcupsmime1 libcupsppdc1 libcurl3-gnutls libdatrie1
libdc1394-22 libdca0 libdirac-encoder0 libdirectfb-1.2-9 libdjvulibre-text
libdjvulibre21 libdv4 libdvbpsi9 libdvdnav4 libdvdread4 libe-book-0.1-1
libebml4 libenca0 libenchant1c2a libencode-locale-perl libeot0 libept1.4.12
libetonyek-0.1-1 libevdocument3-4 libevview3-3 libexif12 libexiv2-12
libexttextcat-2.0-0 libexttextcat-data libfaad2 libfbclient2 libfbembed2.5
libfftw3-double3 libfile-basedir-perl libfile-copy-recursive-perl
libfile-desktopentry-perl libfile-listing-perl libfile-mimeinfo-perl
libflac++6 libflite1 libfluidsynth1 libfont-afm-perl libfontembed1
libmhash2 libmimic0 libmjpegutils-2.1-0 libmms0 libmodplug1 libmp3lame0
libmp4v2-2 libmpcdec6 libmpeg2-4 libmpeg2encpp-2.1-0 libmpg123-0
libmplex2-2.1-0 libmspub-0.1-1 libmtp-common libmtp-runtime libmtp9
libmwaw-0.3-3 libmythes-1.2-0 libnautilus-extension1a libneon27-gnutls
libnet-dbus-perl libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl
libnotify4 libnspr4 libnss3 libobjc4 libodfgen-0.1-1 libofa0 libopenal-data
libopenal1 libopencore-amrnb0 libopencore-amrwb0 libopencv-calib3d2.4
libpaper-utils libpci3 libperl4-corelibs-perl libpoppler-glib8
libpoppler-qt5-1 libpoppler46 libpostproc52 libproxy-tools libpython3.4
libqpdf13 libqt4-dbus libqt4-xml libqt5core5a libqt5dbus5 libqt5gui5
libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite libqt5svg5 libqt5widgets5
libqt5xml5 libqtcore4 libqtdbus4 libqtgui4 libraptor2-0 librarian0
librasqal3 librdf0 libreoffice libreoffice-avmedia-backend-gstreamer
libreoffice-base libreoffice-base-core libreoffice-base-drivers
libreoffice-calc libreoffice-common libreoffice-core libreoffice-draw
libreoffice-impress libreoffice-java-common libreoffice-math
libreoffice-report-builder-bin libreoffice-sdbc-firebird
libreoffice-sdbc-hsqldb libreoffice-style-galaxy libreoffice-writer
libresid-builder0c2a librest-0.7-0 librevenge-0.0-0 librsvg2-2
notification-daemon nuscratch omxplayer oracle-java8-jdk p11-kit
p11-kit-modules p7zip-full pciutils pigpio policykit-1-gnome poppler-data
poppler-utils printer-driver-gutenprint python-crypto python-dbus
python-dbus-dev python-gi python-ldb python-ntdb python-samba python-tdb
q4os-wallpapers qdbus qjackctl qpdf qpdfview qpdfview-djvu-plugin
qpdfview-ps-plugin qpdfview-translations qtchooser qtcore4-l10n
qttranslations5-l10n rarian-compat raspberrypi-artwork rsync samba-common
samba-common-bin sane-utils scratch sgml-base sgml-data
software-properties-common squeak-plugins-scratch squeak-vm ssl-cert
synaptic tdegames-card-data-trinity twolame unar uno-libs3 unrar-free
update-inetd ure v4l-utils va-driver-all vlc vlc-data vlc-nox
xfonts-mathml xfonts-utils xml-core yelp yelp-xsl zenity zenity-common zip
zoo
The following packages will be upgraded:
ntfs-3g
1 upgraded, 622 newly installed, 0 to remove and 21 not upgraded.
Need to get 526 MB of archives.
After this operation, 1,494 MB of additional disk space will be used.
0% [Working]
Get:1 http://archive.raspberrypi.org/debian/ jessie/main libcairo2 armhf 1.14.0-2.1+deb8u2+rpi1 [662 kB]
0% [Waiting for headers] [1 libcairo2 1,448 B/662 kB 0%] [Waiting for headers]
Get:2 http://q4os.org/qtderepo/ raspbian-jessie/main libk3b3-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [722 kB]
0% [Waiting for headers] [1 libcairo2 13.0 kB/662 kB 2%] [2 libk3b3-trinity 1,0
0% [1 libcairo2 13.0 kB/662 kB 2%] [2 libk3b3-trinity 13.4 kB/722 kB 2%]
0% [Connecting to mirror.nbtelecom.com.br] [Waiting for headers] [1 libcairo2 1
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main libasprintf0c2 armhf 0.19.3-2 [31.1 kB]
0% [3 libasprintf0c2 1,173 B/31.1 kB 4%] [Waiting for headers] [1 libcairo2 224
0% [3 libasprintf0c2 14.2 kB/31.1 kB 46%] [Waiting for headers] [1 libcairo2 23
0% [Waiting for headers] [1 libcairo2 249 kB/662 kB 38%] [2 libk3b3-trinity 191
Get:4 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgpm2 armhf 1.20.4-6.1 [35.1 kB]
0% [4 libgpm2 1,173 B/35.1 kB 3%] [Waiting for headers] [1 libcairo2 254 kB/662
0% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Waiting for headers]
0% [Waiting for headers] [Waiting for headers] [1 libcairo2 299 kB/662 kB 45%]
Get:5 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpci3 armhf 1:3.2.1-3 [48.2 kB]
0% [5 libpci3 1,175 B/48.2 kB 2%] [Waiting for headers] [1 libcairo2 303 kB/662
0% [Waiting for headers] [1 libcairo2 350 kB/662 kB 53%] [2 libk3b3-trinity 264
Get:6 http://mirrordirector.raspbian.org/raspbian/ jessie/main libcupsmime1 armhf 1.7.5-11+deb8u1 [112 kB]
0% [6 libcupsmime1 0 B/112 kB 0%] [Waiting for headers] [1 libcairo2 381 kB/662
0% [6 libcupsmime1 9,861 B/112 kB 9%] [Waiting for headers] [1 libcairo2 381 kB
0% [6 libcupsmime1 96.7 kB/112 kB 87%] [Waiting for headers] [1 libcairo2 493 k
0% [6 libcupsmime1 107 kB/112 kB 96%] [Waiting for headers] [1 libcairo2 559 kB
0% [Waiting for headers] [1 libcairo2 559 kB/662 kB 85%] [2 libk3b3-trinity 298
Get:7 http://mirrordirector.raspbian.org/raspbian/ jessie/main ssl-cert all 1.0.35 [20.9 kB]
0% [7 ssl-cert 1,173 B/20.9 kB 6%] [Waiting for headers] [1 libcairo2 559 kB/66
0% [Waiting for headers] [1 libcairo2 638 kB/662 kB 96%] [2 libk3b3-trinity 532
Get:8 http://mirrordirector.raspbian.org/raspbian/ jessie/main bc armhf 1.06.95-9 [96.3 kB]
0% [8 bc 0 B/96.3 kB 0%] [Waiting for headers] [1 libcairo2 648 kB/662 kB 98%]
0% [8 bc 21.4 kB/96.3 kB 22%] [Waiting for headers] [2 libk3b3-trinity 532 kB/7
0% [8 bc 27.2 kB/96.3 kB 28%] [Waiting for headers] [Connecting to archive.rasp
0% [Waiting for headers] [Waiting for headers] [2 libk3b3-trinity 559 kB/722 kB
0% [Waiting for headers] [Waiting for headers] [Waiting for headers] [2 libk3b3
Get:9 http://mirrordirector.raspbian.org/raspbian/ jessie/main cups-daemon armhf 1.7.5-11+deb8u1 [362 kB]
0% [9 cups-daemon 0 B/362 kB 0%] [Waiting for headers] [Waiting for headers] [2
Get:10 http://archive.raspberrypi.org/debian/ jessie/main libcairo-gobject2 armhf 1.14.0-2.1+deb8u2+rpi1 [304 kB]
0% [9 cups-daemon 96.7 kB/362 kB 27%] [Waiting for headers] [10 libcairo-gobjec
0% [9 cups-daemon 133 kB/362 kB 37%] [Waiting for headers] [10 libcairo-gobject
Get:11 http://q4os.org/qtderepo/ raspbian-jessie/main k3b-data-trinity all 4:14.0.4-0raspbian7.0.0+0 [3,064 kB]
0% [9 cups-daemon 337 kB/362 kB 93%] [Waiting for headers] [10 libcairo-gobject
0% [Waiting for headers] [10 libcairo-gobject2 55.0 kB/304 kB 18%] [11 k3b-data
Get:12 http://mirrordirector.raspbian.org/raspbian/ jessie/main libatk1.0-data all 2.14.0-1 [181 kB]
0% [12 libatk1.0-data 1,171 B/181 kB 1%] [Waiting for headers] [10 libcairo-gob
0% [12 libatk1.0-data 14.2 kB/181 kB 8%] [Waiting for headers] [10 libcairo-gob
0% [Waiting for headers] [10 libcairo-gobject2 114 kB/304 kB 38%] [11 k3b-data-
Get:13 http://mirrordirector.raspbian.org/raspbian/ jessie/main libatk1.0-0 armhf 2.14.0-1 [84.2 kB]
0% [13 libatk1.0-0 1,172 B/84.2 kB 1%] [Waiting for headers] [10 libcairo-gobje
0% [13 libatk1.0-0 30.1 kB/84.2 kB 36%] [Waiting for headers] [10 libcairo-gobj
1% [Waiting for headers] [10 libcairo-gobject2 168 kB/304 kB 55%] [11 k3b-data-
Get:14 http://mirrordirector.raspbian.org/raspbian/ jessie/main libatspi2.0-0 armhf 2.14.0-1 [49.8 kB]
1% [14 libatspi2.0-0 1,173 B/49.8 kB 2%] [Waiting for headers] [10 libcairo-gob
1% [Waiting for headers] [10 libcairo-gobject2 216 kB/304 kB 71%] [11 k3b-data-
1% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Waiting for headers]
Get:15 http://mirrordirector.raspbian.org/raspbian/ jessie/main libatk-bridge2.0-0 armhf 2.14.0-2 [45.6 kB]
1% [15 libatk-bridge2.0-0 2,621 B/45.6 kB 6%] [Waiting for headers] [10 libcair
1% [Waiting for headers] [10 libcairo-gobject2 253 kB/304 kB 83%] [11 k3b-data-
Get:16 http://mirrordirector.raspbian.org/raspbian/ jessie/main libxcb-shm0 armhf 1.10-3 [11.0 kB]
1% [16 libxcb-shm0 1,173 B/11.0 kB 11%] [Waiting for headers] [10 libcairo-gobj
1% [Waiting for headers] [10 libcairo-gobject2 256 kB/304 kB 84%] [11 k3b-data-
Get:17 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgdk-pixbuf2.0-common all 2.31.1-2+deb8u5 [294 kB]
1% [17 libgdk-pixbuf2.0-common 1,171 B/294 kB 0%] [Waiting for headers] [10 lib
1% [17 libgdk-pixbuf2.0-common 40.3 kB/294 kB 14%] [Waiting for headers] [Conne
1% [17 libgdk-pixbuf2.0-common 117 kB/294 kB 40%] [Waiting for headers] [Waitin
Get:18 http://archive.raspberrypi.org/debian/ jessie/main libgtk-3-common all 3.14.5-1+deb8u1rpi1rpi1g [3,061 kB]
1% [17 libgdk-pixbuf2.0-common 246 kB/294 kB 84%] [Waiting for headers] [18 lib
1% [Waiting for headers] [18 libgtk-3-common 29.0 kB/3,061 kB 1%] [11 k3b-data-
Get:19 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgdk-pixbuf2.0-0 armhf 2.31.1-2+deb8u5 [148 kB]
1% [19 libgdk-pixbuf2.0-0 1,171 B/148 kB 1%] [Waiting for headers] [18 libgtk-3
1% [19 libgdk-pixbuf2.0-0 110 kB/148 kB 74%] [Waiting for headers] [18 libgtk-3
1% [Waiting for headers] [18 libgtk-3-common 155 kB/3,061 kB 5%] [11 k3b-data-t
Get:20 http://mirrordirector.raspbian.org/raspbian/ jessie/main libcolord2 armhf 1.2.1-1+b2 [215 kB]
1% [20 libcolord2 9,861 B/215 kB 5%] [Waiting for headers] [18 libgtk-3-common
1% [20 libcolord2 182 kB/215 kB 85%] [Waiting for headers] [18 libgtk-3-common
1% [Waiting for headers] [18 libgtk-3-common 358 kB/3,061 kB 12%] [11 k3b-data-
Get:21 http://mirrordirector.raspbian.org/raspbian/ jessie/main libjson-glib-1.0-common all 1.0.2-1 [147 kB]
1% [21 libjson-glib-1.0-common 1,171 B/147 kB 1%] [Waiting for headers] [18 lib
1% [21 libjson-glib-1.0-common 88.1 kB/147 kB 60%] [Waiting for headers] [18 li
1% [Waiting for headers] [18 libgtk-3-common 528 kB/3,061 kB 17%] [11 k3b-data-
Get:22 http://mirrordirector.raspbian.org/raspbian/ jessie/main libjson-glib-1.0-0 armhf 1.0.2-1 [151 kB]
1% [22 libjson-glib-1.0-0 0 B/151 kB 0%] [Waiting for headers] [18 libgtk-3-com
1% [22 libjson-glib-1.0-0 92.4 kB/151 kB 61%] [Waiting for headers] [18 libgtk-
1% [Waiting for headers] [18 libgtk-3-common 679 kB/3,061 kB 22%] [11 k3b-data-
Get:23 http://mirrordirector.raspbian.org/raspbian/ jessie/main libthai-data all 0.1.21-1 [159 kB]
1% [23 libthai-data 0 B/159 kB 0%] [Waiting for headers] [18 libgtk-3-common 68
1% [23 libthai-data 4,069 B/159 kB 3%] [Waiting for headers] [18 libgtk-3-commo
1% [23 libthai-data 79.4 kB/159 kB 50%] [Waiting for headers] [18 libgtk-3-comm
1% [23 libthai-data 130 kB/159 kB 82%] [Waiting for headers] [18 libgtk-3-commo
1% [Waiting for headers] [18 libgtk-3-common 814 kB/3,061 kB 27%] [11 k3b-data-
Get:24 http://mirrordirector.raspbian.org/raspbian/ jessie/main libdatrie1 armhf 0.2.8-1 [29.1 kB]
1% [24 libdatrie1 1,175 B/29.1 kB 4%] [Waiting for headers] [18 libgtk-3-common
1% [24 libdatrie1 24.3 kB/29.1 kB 84%] [Waiting for headers] [18 libgtk-3-commo
1% [Waiting for headers] [18 libgtk-3-common 859 kB/3,061 kB 28%] [11 k3b-data-
Get:25 http://mirrordirector.raspbian.org/raspbian/ jessie/main libthai0 armhf 0.1.21-1 [43.4 kB]
1% [25 libthai0 1,175 B/43.4 kB 3%] [Waiting for headers] [18 libgtk-3-common 8
1% [Waiting for headers] [18 libgtk-3-common 902 kB/3,061 kB 29%] [11 k3b-data-
1% [Waiting for headers] [Waiting for headers] [18 libgtk-3-common 905 kB/3,061
Get:26 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgraphite2-3 armhf 1.3.6-1~deb8u1 [62.5 kB]
1% [26 libgraphite2-3 1,175 B/62.5 kB 2%] [Waiting for headers] [18 libgtk-3-co
1% [26 libgraphite2-3 59.1 kB/62.5 kB 95%] [Waiting for headers] [18 libgtk-3-c
1% [Waiting for headers] [18 libgtk-3-common 937 kB/3,061 kB 31%] [11 k3b-data-
2% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [18 libgtk-3-common 1,
2% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Waiting for headers]
Get:27 http://q4os.org/qtderepo/ raspbian-jessie/main k3b-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [705 kB]
2% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [18 libgtk-3-common 2,
Get:28 http://q4os.org/qtderepo/ raspbian-jessie/main k3b-i18n-trinity all 4:14.0.4-0raspbian7.0.0+0 [4,466 kB]
2% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [18 libgtk-3-common 3,
Get:29 http://archive.raspberrypi.org/debian/ jessie/ui libpango-1.0-0 armhf 1.36.8-3+rpi1 [274 kB]
3% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Waiting for headers]
Get:30 http://archive.raspberrypi.org/debian/ jessie/ui libpangoft2-1.0-0 armhf 1.36.8-3+rpi1 [208 kB]
3% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [30 libpangoft2-1.0-0
3% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Connecting to archive
Get:31 http://archive.raspberrypi.org/debian/ jessie/ui libpangocairo-1.0-0 armhf 1.36.8-3+rpi1 [197 kB]
3% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [31 libpangocairo-1.0-
Get:32 http://archive.raspberrypi.org/debian/ jessie/main libwayland-cursor0 armhf 1.11.0-2 [11.9 kB]
Get:33 http://q4os.org/qtderepo/ raspbian-jessie/main ark-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [263 kB]
Get:34 http://archive.raspberrypi.org/debian/ jessie/main libgtk-3-0 armhf 3.14.5-1+deb8u1rpi1rpi1g [1,884 kB]
3% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [34 libgtk-3-0 50.7 kB
3% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [34 libgtk-3-0 73.8 kB
Get:35 http://q4os.org/qtderepo/ raspbian-jessie/main artsbuilder-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [1,620 kB]
3% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [34 libgtk-3-0 91.2 kB
3% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [34 libgtk-3-0 200 kB/
3% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [34 libgtk-3-0 615 kB/
3% [Connecting to raspbian.c3sl.ufpr.br] [Connecting to mirror.nbtelecom.com.br
Get:36 http://mirrordirector.raspbian.org/raspbian/ jessie/main gconf2-common all 3.2.6-3 [1,040 kB]
3% [36 gconf2-common 2,658 B/1,040 kB 0%] [Connecting to mirror.nbtelecom.com.b
4% [36 gconf2-common 414 kB/1,040 kB 40%] [Connecting to mirror.nbtelecom.com.b
Get:37 http://q4os.org/q4repo/ q4os-rpi-1-0-cn/main libexiv2-12 armhf 0.23-1 [742 kB]
4% [36 gconf2-common 958 kB/1,040 kB 92%] [Connecting to mirror.nbtelecom.com.b
4% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Waiting for headers]
4% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [34 libgtk-3-0 1,641 k
Get:38 http://q4os.org/qtderepo/ raspbian-jessie/main libkipi0-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [97.6 kB]
4% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [34 libgtk-3-0 1,840 k
4% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Connecting to archive
Get:39 http://q4os.org/qtderepo/ raspbian-jessie/main gwenview-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [650 kB]
Get:40 http://archive.raspberrypi.org/debian/ jessie/main libgtk-3-bin armhf 3.14.5-1+deb8u1rpi1rpi1g [91.8 kB]
4% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [40 libgtk-3-bin 62.3
Get:41 http://archive.raspberrypi.org/debian/ jessie/main gnome-themes-standard-data all 3.14.2.2-1rpi1rpi1g [534 kB]
4% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [41 gnome-themes-stand
Get:42 http://q4os.org/qtderepo/ raspbian-jessie/main gwenview-i18n-trinity all 4:14.0.4-0raspbian7.0.0+0 [1,417 kB]
Get:43 http://archive.raspberrypi.org/debian/ jessie/main gnome-themes-standard armhf 3.14.2.2-1rpi1rpi1g [484 kB]
5% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [43 gnome-themes-stand
5% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Waiting for headers]
5% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Connecting to mirrord
Get:44 http://archive.raspberrypi.org/debian/ jessie/main liborc-0.4-0 armhf 1:0.4.22-1rpi1rpi1g [123 kB]
Get:45 http://q4os.org/qtderepo/ raspbian-jessie/main libtdegames1-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [252 kB]
Get:46 http://archive.raspberrypi.org/debian/ jessie/main libva1 armhf 1.7.3-2 [46.7 kB]
Get:47 http://q4os.org/qtderepo/ raspbian-jessie/main kbounce-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [164 kB]
Get:48 http://archive.raspberrypi.org/debian/ jessie/main libsdl1.2debian armhf 1.2.15-10+rpi1 [162 kB]
Get:49 http://q4os.org/qtderepo/ raspbian-jessie/main kcalc-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [167 kB]
Get:50 http://q4os.org/qtderepo/ raspbian-jessie/main kmag-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [263 kB]
Get:51 http://archive.raspberrypi.org/debian/ jessie/main libgles1-mesa armhf 13.0.0-1+rpi1 [46.1 kB]
Get:52 http://archive.raspberrypi.org/debian/ jessie/main libgles2-mesa armhf 13.0.0-1+rpi1 [52.4 kB]
Get:53 http://q4os.org/qtderepo/ raspbian-jessie/main kmines-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [189 kB]
Get:54 http://archive.raspberrypi.org/debian/ jessie/main libjavascriptcoregtk-3.0-0 armhf 1:2.4.1-1rpi53rpi1g [1,716 kB]
Get:55 http://q4os.org/qtderepo/ raspbian-jessie/main kolourpaint-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [956 kB]
5% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [54 libjavascriptcoreg
Get:56 http://q4os.org/qtderepo/ raspbian-jessie/main tdegames-card-data-trinity all 4:14.0.4-0raspbian7.0.0+0 [2,002 kB]
Get:57 http://mirrordirector.raspbian.org/raspbian/ jessie/main poppler-data all 0.4.7-1 [1,491 kB]
5% [57 poppler-data 2,657 B/1,491 kB 0%] [Connecting to mirror.nbtelecom.com.br
6% [57 poppler-data 977 kB/1,491 kB 66%] [Connecting to mirror.nbtelecom.com.br
6% [57 poppler-data 1,484 kB/1,491 kB 100%] [Connecting to mirror.nbtelecom.com
6% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Waiting for headers]
6% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Connecting to archive
Get:58 http://archive.raspberrypi.org/debian/ jessie/ui libpangoxft-1.0-0 armhf 1.36.8-3+rpi1 [193 kB]
6% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [58 libpangoxft-1.0-0
Get:59 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-style-galaxy all 1:4.3.3-2+rpi4 [1,711 kB]
Get:60 http://q4os.org/qtderepo/ raspbian-jessie/main kpat-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [340 kB]
Get:61 http://q4os.org/qtderepo/ raspbian-jessie/main krec-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [250 kB]
6% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [59 libreoffice-style-
Get:62 http://q4os.org/qtderepo/ raspbian-jessie/main ksnapshot-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [139 kB]
Get:63 http://q4os.org/qtderepo/ raspbian-jessie/main libakode2 armhf 2.0.2-7raspbian7.0.0+1 [75.0 kB]
Get:64 http://q4os.org/qtderepo/ raspbian-jessie/main libarts1-akode-trinity armhf 4:14.0.4-0raspbian7.0.0+0 [124 kB]
Get:65 http://q4os.org/q4repo/ q4os-rpi-1-0-cn/main q4os-wallpapers all 1.1.3-a1 [20.8 MB]
7% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [59 libreoffice-style-
7% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Waiting for headers]
7% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Connecting to archive
Get:66 http://archive.raspberrypi.org/debian/ jessie/ui uno-libs3 armhf 4.3.3-2+rpi4 [675 kB]
7% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [66 uno-libs3 5,792 B/
7% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [66 uno-libs3 198 kB/6
8% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Waiting for headers]
8% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [66 uno-libs3 491 kB/6
Get:67 http://archive.raspberrypi.org/debian/ jessie/ui ure armhf 4.3.3-2+rpi4 [1,665 kB]
9% [Connecting to mirror.nbtelecom.com.br (189.45.5.90)] [Waiting for headers]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libharfbuzz0b armhf 0.9.35-2
Could not connect to mirror.nbtelecom.com.br:80 (189.45.5.90), connection timed out
9% [Waiting for headers] [67 ure 672 kB/1,665 kB 40%] [65 q4os-wallpapers 8,548
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsoup-gnome2.4-1 armhf 2.48.0-1
Unable to connect to mirror.nbtelecom.com.br:http:
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main librest-0.7-0 armhf 0.7.92-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxkbcommon0 armhf 0.4.3-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcroco3 armhf 0.6.8-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main librsvg2-2 armhf 2.40.5-1+deb8u2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main librsvg2-common armhf 2.40.5-1+deb8u2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main adwaita-icon-theme all 3.14.0-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgtk2.0-common all 2.24.25-3+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgtk2.0-0 armhf 2.24.25-3+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopus0 armhf 1.1-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libjack-jackd2-0 armhf 1.9.10+20140719git3eb0ae6a~dfsg-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python-dbus-dev all 1.2.0-2
9% [Waiting for headers] [67 ure 682 kB/1,665 kB 41%] [65 q4os-wallpapers 8,561
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python-dbus armhf 1.2.0-2+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main jackd2 armhf 1.9.10+20140719git3eb0ae6a~dfsg-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libdvdread4 armhf 5.0.0-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libflac++6 armhf 1.3.0-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main wodim armhf 9:1.1.11-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main cdparanoia armhf 3.10.2+debian-11
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main genisoimage armhf 9:1.1.11-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libao-common armhf 1.1.0-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libao4 armhf 1.1.0-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main cdrdao armhf 1:1.2.3-2
9% [Waiting for headers] [67 ure 685 kB/1,665 kB 41%] [65 q4os-wallpapers 8,570
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libaa1 armhf 1.4p5-43
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libaacs0 armhf 0.7.1-1+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main liblzo2-2 armhf 2.08-1.2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libarchive13 armhf 3.1.2-11+deb8u3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavutil54 armhf 6:11.8-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavresample2 armhf 6:11.8-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgsm1 armhf 1.0.13-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmp3lame0 armhf 3.99.5+repack1-7+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopenjpeg5 armhf 1:1.5.2-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libschroedinger-1.0-0 armhf 1.0.11-2.1
9% [Waiting for headers] [67 ure 691 kB/1,665 kB 41%] [65 q4os-wallpapers 8,577
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libspeex1 armhf 1.2~rc1.2-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libtheora0 armhf 1.1.1+dfsg.1-6
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvpx1 armhf 1.3.0-3+rvt
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libx264-142 armhf 2:0.142.2431+gita5831aa-1+rpi2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxvidcore4 armhf 2:1.3.3-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavcodec56 armhf 6:11.8-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main librtmp1 armhf 2.4+20150115.gita107cef-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavformat56 armhf 6:11.8-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcdio13 armhf 0.83-4.2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcdio-cdda1 armhf 0.83-4.2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcdio-paranoia1 armhf 0.83-4.2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libdc1394-22 armhf 2.2.3-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavdevice55 armhf 6:11.8-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopencv-core2.4 armhf 2.4.9.1+dfsg-1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopencv-imgproc2.4 armhf 2.4.9.1+dfsg-1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libswscale3 armhf 6:11.8-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavfilter5 armhf 6:11.8-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcaca0 armhf 0.99.beta19-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libdirectfb-1.2-9 armhf 1.2.10.0-5.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libav-tools armhf 6:11.8-1~deb8u1+rpi1
9% [Waiting for headers] [67 ure 691 kB/1,665 kB 41%] [65 q4os-wallpapers 8,578
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-glib1 armhf 0.6.31-5
9% [Waiting for headers] [67 ure 691 kB/1,665 kB 41%] [65 q4os-wallpapers 8,580
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-gobject0 armhf 0.6.31-5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavc1394-0 armhf 0.5.4-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libbasicusageenvironment0 armhf 2014.01.13-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libbluray1 armhf 1:0.6.2-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libboost-date-time1.55.0 armhf 1.55.0+dfsg-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libboost-system1.55.0 armhf 1.55.0+dfsg-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libltdl7 armhf 2.4.2-1.11
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcanberra0 armhf 0.30-2.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcanberra-gtk3-0 armhf 0.30-2.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcgroup1 armhf 0.41-6+rpi1
9% [Waiting for headers] [67 ure 692 kB/1,665 kB 42%] [65 q4os-wallpapers 8,580
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libchromaprint0 armhf 1.2-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libclucene-core1 armhf 2.3.3.4-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libclucene-contribs1 armhf 2.3.3.4-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcolamd2.8.0 armhf 1:4.2.1-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgusb2 armhf 0.1.6-5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcolorhug2 armhf 1.2.1-1+b2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcupscgi1 armhf 1.7.5-11+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcupsimage2 armhf 1.7.5-11+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcupsfilters1 armhf 1.0.61-5+deb8u3
9% [Waiting for headers] [67 ure 692 kB/1,665 kB 42%] [65 q4os-wallpapers 8,581
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcupsppdc1 armhf 1.7.5-11+deb8u1
9% [Waiting for headers] [67 ure 694 kB/1,665 kB 42%] [65 q4os-wallpapers 8,581
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libssh2-1 armhf 1.4.3-4.1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcurl3-gnutls armhf 7.38.0-4+deb8u5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libdca0 armhf 0.0.5-7
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libdirac-encoder0 armhf 1.0.2-7.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libdjvulibre-text all 3.5.25.4-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libdjvulibre21 armhf 3.5.25.4-4+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libdv4 armhf 1.0.0-6
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libdvbpsi9 armhf 1.2.0-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libdvdnav4 armhf 5.0.1-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libebml4 armhf 1.3.0-2+deb8u1
9% [Waiting for headers] [67 ure 694 kB/1,665 kB 42%] [65 q4os-wallpapers 8,583
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libenca0 armhf 1.16-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main emacsen-common all 2.0.8
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main dictionaries-common all 1.23.17
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main hunspell-en-us all 20070829-6
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libhunspell-1.3-0 armhf 1.3.3-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libenchant1c2a armhf 1.6.0-10.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libexif12 armhf 0.6.21-2
9% [Waiting for headers] [67 ure 695 kB/1,665 kB 42%] [65 q4os-wallpapers 8,584
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfaad2 armhf 2.7-8
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main firebird2.5-common-doc all 2.5.3.26778.ds4-5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main firebird2.5-common all 2.5.3.26778.ds4-5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfbclient2 armhf 2.5.3.26778.ds4-5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main firebird2.5-server-common armhf 2.5.3.26778.ds4-5
9% [Waiting for headers] [67 ure 696 kB/1,665 kB 42%] [65 q4os-wallpapers 8,584
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfbembed2.5 armhf 2.5.3.26778.ds4-5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgomp1 armhf 4.9.2-10
9% [Waiting for headers] [67 ure 698 kB/1,665 kB 42%] [65 q4os-wallpapers 8,585
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfftw3-double3 armhf 3.3.4-2+rvt
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libflite1 armhf 1.4-release-12
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfluidsynth1 armhf 1.1.6-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfontembed1 armhf 1.0.61-5+deb8u3
9% [Waiting for headers] [67 ure 698 kB/1,665 kB 42%] [65 q4os-wallpapers 8,587
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-sysinfo0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfreerdp-primitives1.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-crt0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-environment0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-handle0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-heap0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
9% [Waiting for headers] [67 ure 699 kB/1,665 kB 42%] [65 q4os-wallpapers 8,588
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-interlocked0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
9% [Waiting for headers] [67 ure 701 kB/1,665 kB 42%] [65 q4os-wallpapers 8,588
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-path0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-thread0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-synch0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-utils0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfreerdp-utils1.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-pool0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-registry0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfreerdp-codec1.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-file0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
9% [Waiting for headers] [67 ure 704 kB/1,665 kB 42%] [65 q4os-wallpapers 8,591
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-library0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfreerdp-common1.1.0 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-crypto0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-sspi0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfreerdp-crypto1.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-input0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfreerdp-locale1.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-dsparse0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-rpc0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfreerdp-core1.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
9% [Waiting for headers] [67 ure 705 kB/1,665 kB 42%] [65 q4os-wallpapers 8,592
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfreerdp-cache1.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfreerdp-client1.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfreerdp-gdi1.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfreerdp-rail1.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfribidi0 armhf 0.19.6-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgck-1-0 armhf 3.14.0-2+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgconf-2-4 armhf 3.2.6-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgcr-3-common all 3.14.0-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgcr-base-3-1 armhf 3.14.0-2+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgcr-ui-3-1 armhf 3.14.0-2+b1
9% [Waiting for headers] [67 ure 708 kB/1,665 kB 43%] [65 q4os-wallpapers 8,595
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgd3 armhf 2.1.0-5+deb8u9
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgeoclue0 armhf 0.12.99-4+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgfortran3 armhf 4.9.2-10
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libglew1.10 armhf 1.10.0-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgnome-keyring-common all 3.12.0-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgnome-keyring0 armhf 3.12.0-1+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgphoto2-port10 armhf 2.5.4-1.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgphoto2-6 armhf 2.5.4-1.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgroupsock1 armhf 2014.01.13-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgstreamer0.10-0 armhf 0.10.36-1.5
9% [Waiting for headers] [67 ure 710 kB/1,665 kB 43%] [65 q4os-wallpapers 8,596
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main iso-codes all 3.57-1
9% [Waiting for headers] [67 ure 710 kB/1,665 kB 43%] [65 q4os-wallpapers 8,598
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgstreamer-plugins-base0.10-0 armhf 0.10.36-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgstreamer1.0-0 armhf 1.4.4-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgstreamer-plugins-base1.0-0 armhf 1.4.4-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgutenprint2 armhf 5.2.10-3+b3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgxps2 armhf 0.2.2-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libharfbuzz-icu0 armhf 0.9.35-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libiec61883-0 armhf 1.2.0-0.2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libieee1284-3 armhf 0.2.11-12
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libijs-0.35 armhf 0.35-10
9% [Waiting for headers] [67 ure 711 kB/1,665 kB 43%] [65 q4os-wallpapers 8,599
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main liblivemedia23 armhf 2014.01.13-1
9% [Waiting for headers] [67 ure 711 kB/1,665 kB 43%] [65 q4os-wallpapers 8,600
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main liblua5.2-0 armhf 5.2.3-1.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmatroska6 armhf 1.4.1-2+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmhash2 armhf 0.9.9.9-7
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmjpegutils-2.1-0 armhf 1:2.1.0+debian-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmms0 armhf 0.6.2-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmp4v2-2 armhf 2.0.0~dfsg0-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmpcdec6 armhf 2:0.1~r459-4.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmpeg2-4 armhf 0.5.1-7
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmpeg2encpp-2.1-0 armhf 1:2.1.0+debian-3
9% [Waiting for headers] [67 ure 711 kB/1,665 kB 43%] [65 q4os-wallpapers 8,603
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmpg123-0 armhf 1.20.1-2+deb8u1
9% [Waiting for headers] [67 ure 711 kB/1,665 kB 43%] [65 q4os-wallpapers 8,604
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmplex2-2.1-0 armhf 1:2.1.0+debian-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmtp-common all 1.1.8-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmtp9 armhf 1.1.8-1+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libnotify4 armhf 0.7.6-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libnspr4 armhf 2:4.12-1+debu8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libnss3 armhf 2:3.26-1+debu8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libobjc4 armhf 4.9.2-10
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopenal-data all 1:1.15.1-5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopenal1 armhf 1:1.15.1-5
9% [Waiting for headers] [67 ure 713 kB/1,665 kB 43%] [65 q4os-wallpapers 8,606
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopencore-amrnb0 armhf 0.1.3-2.1
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,606
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopencore-amrwb0 armhf 0.1.3-2.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopencv-flann2.4 armhf 2.4.9.1+dfsg-1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libpangox-1.0-0 armhf 0.0.2-5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgtkglext1 armhf 1.2.0-3.2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libv4lconvert0 armhf 1.6.0-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libv4l-0 armhf 1.6.0-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopencv-highgui2.4 armhf 2.4.9.1+dfsg-1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopencv-features2d2.4 armhf 2.4.9.1+dfsg-1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopencv-calib3d2.4 armhf 2.4.9.1+dfsg-1+deb8u1
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,607
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopencv-ml2.4 armhf 2.4.9.1+dfsg-1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopencv-objdetect2.4 armhf 2.4.9.1+dfsg-1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopencv-video2.4 armhf 2.4.9.1+dfsg-1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopencv-contrib2.4 armhf 2.4.9.1+dfsg-1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libopencv-legacy2.4 armhf 2.4.9.1+dfsg-1+deb8u1
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,609
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libpoppler46 armhf 0.26.5-2+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libpoppler-glib8 armhf 0.26.5-2+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqt5core5a armhf 5.3.2+dfsg-4+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqt5dbus5 armhf 5.3.2+dfsg-4+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxcb-icccm4 armhf 0.4.1-1
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,610
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxcb-util0 armhf 0.3.8-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxcb-image0 armhf 0.4.0-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxcb-keysyms1 armhf 0.4.0-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxcb-randr0 armhf 1.10-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxcb-render-util0 armhf 0.3.9-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxcb-xkb1 armhf 1.10-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxkbcommon-x11-0 armhf 0.4.3-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqt5gui5 armhf 5.3.2+dfsg-4+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqt5widgets5 armhf 5.3.2+dfsg-4+rpi1
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,611
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqt5xml5 armhf 5.3.2+dfsg-4+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libpoppler-qt5-1 armhf 0.26.5-2+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libpython3.4 armhf 3.4.2-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqpdf13 armhf 5.1.2-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main qtcore4-l10n all 4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqtcore4 armhf 4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqt4-xml armhf 4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqt5printsupport5 armhf 5.3.2+dfsg-4+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqt5sql5 armhf 5.3.2+dfsg-4+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqt5sql5-sqlite armhf 5.3.2+dfsg-4+rpi1
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,614
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqt5svg5 armhf 5.3.2-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqtdbus4 armhf 4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqtgui4 armhf 4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libyajl2 armhf 2.1.0-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libraptor2-0 armhf 2.0.14-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main librasqal3 armhf 0.9.32-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main librdf0 armhf 1.0.17-1+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsane-common all 1.0.24-8+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsane armhf 1.0.24-8+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwebp5 armhf 0.4.1-1.2
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,617
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsdl-image1.2 armhf 1.2.12-5+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsecret-common all 0.18-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsecret-1-0 armhf 0.18-1+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libshine3 armhf 3.1.0-2.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libshout3 armhf 2.3.1-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsoundtouch0 armhf 1.8.0-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libjbig2dec0 armhf 0.11+20120125-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgs9-common all 9.06~dfsg-2+deb8u4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgs9 armhf 9.06~dfsg-2+deb8u4
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,618
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libspectre1 armhf 0.2.7-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libspeexdsp1 armhf 1.2~rc1.2-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libssh-4 armhf 0.6.3-4+deb8u2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libstartup-notification0 armhf 0.12-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libtag1-vanilla armhf 1.9.1-2.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libupnp6 armhf 1:1.6.19+git20141001-1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libusageenvironment1 armhf 2014.01.13-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libv4l2rds0 armhf 1.6.0-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvisual-0.4-0 armhf 0.4.0-6
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvncclient0 armhf 0.9.9+dfsg2-6.1+deb8u2
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,621
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvo-aacenc0 armhf 0.1.3-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvo-amrwbenc0 armhf 0.1.3-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwavpack1 armhf 4.70.0-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwildmidi-config all 0.3.7-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwildmidi1 armhf 0.3.7-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxres1 armhf 2:1.0.7-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwnck-3-common all 3.4.9-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwnck-3-0 armhf 3.4.9-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxcb-composite0 armhf 1.10-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxcb-xv0 armhf 1.10-3
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,624
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libzvbi-common all 0.2.35-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libzvbi0 armhf 0.2.35-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main ntfs-3g armhf 1:2014.2.15AR.2-1+deb8u3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python-ldb armhf 2:1.1.20-0+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main samba-common all 2:4.2.14+dfsg-0+deb8u2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main sgml-base all 1.26+nmu4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gnustep-common armhf 2.6.6-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gnustep-base-common all 1.24.7-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgnustep-base1.24 armhf 1.24.7-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gnustep-base-runtime armhf 1.24.7-1
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,626
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main unar armhf 1.8.1-3+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libass5 armhf 0.10.2-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcdaudio1 armhf 0.99.12p2-13
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgme0 armhf 0.5.5-2+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgstreamer-plugins-bad0.10-0 armhf 0.10.23-7.4+deb8u2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libkate1 armhf 0.4.1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmimic0 armhf 1.0.4-2.2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmodplug1 armhf 1:0.8.8.4-4.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libofa0 armhf 0.9.3-7
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libslv2-9 armhf 0.6.6+dfsg1-2
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,628
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libspandsp2 armhf 0.0.6-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libzbar0 armhf 0.10+doc-10+b2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer0.10-plugins-base armhf 0.10.36-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer0.10-plugins-bad armhf 0.10.23-7.4+deb8u2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgstreamer-plugins-bad1.0-0 armhf 1.4.4-2.1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsbc1 armhf 1.2-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsrtp0 armhf 1.4.5~20130609~dfsg-1.1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer1.0-plugins-base armhf 1.4.4-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer1.0-plugins-bad armhf 1.4.4-2.1+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gettext-base armhf 0.19.3-2
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,630
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main pciutils armhf 1:3.2.1-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main apt-transport-https armhf 1.0.9.8.4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main at-spi2-core armhf 2.14.0-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main cgroup-tools armhf 0.41-6+rpi1
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,632
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main colord-data all 1.2.1-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main colord armhf 1.2.1-1+b2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main poppler-utils armhf 0.26.5-2+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main cups-filters-core-drivers armhf 1.0.61-5+deb8u3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main cups-core-drivers armhf 1.7.5-11+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gsfonts all 1:8.11+urwcyr1.0.7~pre44-4.2
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,633
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main ghostscript armhf 9.06~dfsg-2+deb8u4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main cups-common all 1.7.5-11+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main cups-server-common all 1.7.5-11+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main cups-client armhf 1.7.5-11+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main cups-ppdc armhf 1.7.5-11+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main cups-filters armhf 1.0.61-5+deb8u3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main cups armhf 1.7.5-11+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main cups-browsed armhf 1.0.61-5+deb8u3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main xml-core all 0.13+nmu2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main sgml-data all 2.0.10
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,635
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main docbook-xml all 4.5-7.2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main growisofs armhf 7.1-11
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main dvd+rw-tools armhf 7.1-11
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main enchant armhf 1.6.0-10.1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gnome-desktop3-data all 3.14.1-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgnome-desktop-3-10 armhf 3.14.1-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gnome-icon-theme all 3.12.0-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gnome-icon-theme-symbolic all 3.12.0-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libkpathsea6 armhf 2014.20140926.35254-6
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libevdocument3-4 armhf 3.14.1-2+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libevview3-3 armhf 3.14.1-2+deb8u1
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,636
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libnautilus-extension1a armhf 3.14.1-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main evince-common all 3.14.1-2+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main evince armhf 3.14.1-2+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main exfat-fuse armhf 1.1.0-2+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main exfat-utils armhf 1.1.0-2+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main fonts-dejavu-extra all 2.34-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main fonts-dejavu all 2.34-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main fonts-freefont-ttf all 20120503-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main fonts-lyx all 2.1.2-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main fonts-sil-gentium all 20081126:1.02-13
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,637
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main fonts-sil-gentium-basic all 1.1-7
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main freepats all 20060219-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gconf-service armhf 3.2.6-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gconf2 armhf 3.2.6-3
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gcr armhf 3.14.0-2+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main geoip-database all 20150317-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgirepository-1.0-1 armhf 1.42.0-2.2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gir1.2-glib-2.0 armhf 1.42.0-2.2
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,639
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgtop2-common all 2.28.5-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgtop2-7 armhf 2.28.5-2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgksu2-0 armhf 2.0.13~pre1-8
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gksu armhf 2.0.2-9
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main p11-kit-modules armhf 0.20.7-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main p11-kit armhf 0.20.7-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gnome-keyring armhf 3.14.0-1+b1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libyelp0 armhf 3.14.1-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main yelp-xsl all 3.14.0-1
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,640
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main yelp armhf 3.14.1-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gnome-user-guide all 3.14.1-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer0.10-gconf armhf 0.10.31-3+nmu4+deb8u2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libtag1c2a armhf 1.9.1-2.1
9% [Waiting for headers] [67 ure 714 kB/1,665 kB 43%] [65 q4os-wallpapers 8,641
9% [67 ure 744 kB/1,665 kB 45%] [65 q4os-wallpapers 8,684 kB/20.8 MB 42%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer0.10-plugins-good armhf 0.10.31-3+nmu4+deb8u2
9% [Waiting for headers] [67 ure 744 kB/1,665 kB 45%] [65 q4os-wallpapers 8,684
9% [67 ure 757 kB/1,665 kB 45%] [65 q4os-wallpapers 8,789 kB/20.8 MB 42%]
Get:68 http://mirrordirector.raspbian.org/raspbian/ jessie/main liba52-0.7.4 armhf 0.7.4-17 [28.9 kB]
9% [68 liba52-0.7.4 1,213 B/28.9 kB 4%] [Waiting for headers] [67 ure 846 kB/1,
9% [68 liba52-0.7.4 22.9 kB/28.9 kB 79%] [67 ure 862 kB/1,665 kB 52%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsidplay1 armhf 1.36.59-6
9% [68 liba52-0.7.4 22.9 kB/28.9 kB 79%] [Waiting for headers] [67 ure 862 kB/1
9% [Waiting for headers] [67 ure 869 kB/1,665 kB 52%] [65 q4os-wallpapers 8,871
9% [67 ure 915 kB/1,665 kB 55%] [65 q4os-wallpapers 8,890 kB/20.8 MB 43%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libtwolame0 armhf 0.3.13-1.1
9% [Waiting for headers] [67 ure 915 kB/1,665 kB 55%] [65 q4os-wallpapers 8,890
9% [67 ure 976 kB/1,665 kB 59%] [65 q4os-wallpapers 8,890 kB/20.8 MB 43%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer0.10-plugins-ugly armhf 0.10.19-2.1+b1
9% [Waiting for headers] [67 ure 976 kB/1,665 kB 59%] [65 q4os-wallpapers 8,890
9% [67 ure 1,021 kB/1,665 kB 61%] [65 q4os-wallpapers 8,997 kB/20.8 MB 43%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer0.10-x armhf 0.10.36-2
9% [Waiting for headers] [67 ure 1,021 kB/1,665 kB 61%] [65 q4os-wallpapers 8,9
9% [67 ure 1,069 kB/1,665 kB 64%] [65 q4os-wallpapers 9,131 kB/20.8 MB 44%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer1.0-alsa armhf 1.4.4-2
9% [Waiting for headers] [67 ure 1,069 kB/1,665 kB 64%] [65 q4os-wallpapers 9,1
9% [67 ure 1,118 kB/1,665 kB 67%] [65 q4os-wallpapers 9,190 kB/20.8 MB 44%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer1.0-libav armhf 1.4.4-2
9% [Waiting for headers] [67 ure 1,118 kB/1,665 kB 67%] [65 q4os-wallpapers 9,1
9% [67 ure 1,157 kB/1,665 kB 70%] [65 q4os-wallpapers 9,193 kB/20.8 MB 44%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer1.0-plugins-good armhf 1.4.4-2+deb8u2
9% [Waiting for headers] [67 ure 1,157 kB/1,665 kB 70%] [65 q4os-wallpapers 9,1
9% [67 ure 1,215 kB/1,665 kB 73%] [65 q4os-wallpapers 9,246 kB/20.8 MB 44%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer1.0-plugins-ugly armhf 1.4.4-2
9% [Waiting for headers] [67 ure 1,215 kB/1,665 kB 73%] [65 q4os-wallpapers 9,2
9% [67 ure 1,253 kB/1,665 kB 75%] [65 q4os-wallpapers 9,310 kB/20.8 MB 45%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer1.0-x armhf 1.4.4-2
9% [Waiting for headers] [67 ure 1,253 kB/1,665 kB 75%] [65 q4os-wallpapers 9,3
9% [67 ure 1,300 kB/1,665 kB 78%] [65 q4os-wallpapers 9,433 kB/20.8 MB 45%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gtk2-engines armhf 1:2.20.2-3
9% [Waiting for headers] [67 ure 1,373 kB/1,665 kB 82%] [65 q4os-wallpapers 9,5
9% [67 ure 1,386 kB/1,665 kB 83%] [65 q4os-wallpapers 9,518 kB/20.8 MB 46%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gtk2-engines-pixbuf armhf 2.24.25-3+deb8u1
9% [Waiting for headers] [67 ure 1,386 kB/1,665 kB 83%] [65 q4os-wallpapers 9,5
9% [67 ure 1,435 kB/1,665 kB 86%] [65 q4os-wallpapers 9,572 kB/20.8 MB 46%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gvfs-common all 1.22.2-1
9% [Waiting for headers] [67 ure 1,435 kB/1,665 kB 86%] [65 q4os-wallpapers 9,5
9% [67 ure 1,481 kB/1,665 kB 89%] [65 q4os-wallpapers 9,611 kB/20.8 MB 46%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gvfs-libs armhf 1.22.2-1
9% [Waiting for headers] [67 ure 1,481 kB/1,665 kB 89%] [65 q4os-wallpapers 9,6
9% [67 ure 1,525 kB/1,665 kB 92%] [65 q4os-wallpapers 9,611 kB/20.8 MB 46%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gvfs-daemons armhf 1.22.2-1
9% [Waiting for headers] [67 ure 1,525 kB/1,665 kB 92%] [65 q4os-wallpapers 9,6
9% [67 ure 1,574 kB/1,665 kB 95%] [65 q4os-wallpapers 9,704 kB/20.8 MB 47%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gvfs armhf 1.22.2-1
9% [Waiting for headers] [67 ure 1,574 kB/1,665 kB 95%] [65 q4os-wallpapers 9,7
9% [67 ure 1,626 kB/1,665 kB 98%] [65 q4os-wallpapers 9,755 kB/20.8 MB 47%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main hwdata all 0.267-1
9% [Waiting for headers] [67 ure 1,626 kB/1,665 kB 98%] [65 q4os-wallpapers 9,7
9% [Waiting for headers] [65 q4os-wallpapers 9,797 kB/20.8 MB 47%]
9% [Connecting to archive.raspberrypi.org (93.93.128.133)] [65 q4os-wallpapers
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main icedove armhf 1:45.6.0-1~deb8u1
9% [Waiting for headers] [Connecting to archive.raspberrypi.org (93.93.128.133)
9% [Waiting for headers] [65 q4os-wallpapers 9,868 kB/20.8 MB 47%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main iceowl-extension armhf 1:45.6.0-1~deb8u1
9% [Waiting for headers] [Waiting for headers] [65 q4os-wallpapers 9,868 kB/20.
Get:69 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-common all 1:4.3.3-2+rpi4 [21.7 MB]
9% [Waiting for headers] [69 libreoffice-common 0 B/21.7 MB 0%] [65 q4os-wallpa
Get:70 http://mirrordirector.raspbian.org/raspbian/ jessie/main jackd all 5 [2,020 B]
9% [70 jackd 2,020 B/2,020 B 100%] [69 libreoffice-common 13.0 kB/21.7 MB 0%] [
9% [Waiting for headers] [69 libreoffice-common 56.5 kB/21.7 MB 0%] [65 q4os-wa
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main librevenge-0.0-0 armhf 0.0.1-3
9% [Waiting for headers] [69 libreoffice-common 97.0 kB/21.7 MB 0%] [65 q4os-wa
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libabw-0.1-1 armhf 0.1.0-2
9% [Waiting for headers] [69 libreoffice-common 139 kB/21.7 MB 1%] [65 q4os-wal
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libauthen-sasl-perl all 2.1600-1
9% [Waiting for headers] [69 libreoffice-common 167 kB/21.7 MB 1%] [65 q4os-wal
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libblas-common armhf 1.2.20110419-10
9% [Waiting for headers] [69 libreoffice-common 197 kB/21.7 MB 1%] [65 q4os-wal
Get:71 http://mirrordirector.raspbian.org/raspbian/ jessie/main libblas3 armhf 1.2.20110419-10 [120 kB]
9% [71 libblas3 1,211 B/120 kB 1%] [Waiting for headers] [69 libreoffice-common
9% [71 libblas3 22.9 kB/120 kB 19%] [Waiting for headers] [69 libreoffice-commo
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcairo-perl armhf 1.104-2
9% [71 libblas3 103 kB/120 kB 86%] [69 libreoffice-common 271 kB/21.7 MB 1%] [6
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcanberra-gtk3-module armhf 0.30-2.1
9% [71 libblas3 103 kB/120 kB 86%] [Waiting for headers] [69 libreoffice-common
9% [Waiting for headers] [69 libreoffice-common 284 kB/21.7 MB 1%] [65 q4os-wal
9% [69 libreoffice-common 306 kB/21.7 MB 1%] [65 q4os-wallpapers 10.4 MB/20.8 M
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcddb2 armhf 1.3.2-5
9% [Waiting for headers] [69 libreoffice-common 330 kB/21.7 MB 2%] [65 q4os-wal
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcdr-0.1-1 armhf 0.1.0-3
9% [69 libreoffice-common 365 kB/21.7 MB 2%] [65 q4os-wallpapers 10.5 MB/20.8 M
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcmis-0.4-4 armhf 0.4.1-7
9% [Waiting for headers] [69 libreoffice-common 365 kB/21.7 MB 2%] [65 q4os-wal
9% [69 libreoffice-common 395 kB/21.7 MB 2%] [65 q4os-wallpapers 10.6 MB/20.8 M
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libe-book-0.1-1 armhf 0.1.1-2
9% [Waiting for headers] [69 libreoffice-common 418 kB/21.7 MB 2%] [65 q4os-wal
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libencode-locale-perl all 1.03-1
9% [Waiting for headers] [69 libreoffice-common 459 kB/21.7 MB 2%] [65 q4os-wal
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libeot0 armhf 0.01-3
9% [Waiting for headers] [69 libreoffice-common 479 kB/21.7 MB 2%] [65 q4os-wal
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libept1.4.12 armhf 1.0.12.1
9% [Waiting for headers] [69 libreoffice-common 517 kB/21.7 MB 2%] [65 q4os-wal
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libetonyek-0.1-1 armhf 0.1.1-2
9% [69 libreoffice-common 540 kB/21.7 MB 2%] [65 q4os-wallpapers 11.1 MB/20.8 M
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libexttextcat-data all 3.4.4-1
9% [Waiting for headers] [69 libreoffice-common 592 kB/21.7 MB 3%] [65 q4os-wal
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libexttextcat-2.0-0 armhf 3.4.4-1
9% [Waiting for headers] [69 libreoffice-common 627 kB/21.7 MB 3%] [65 q4os-wal
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfile-basedir-perl all 0.03-1
9% [Waiting for headers] [69 libreoffice-common 659 kB/21.7 MB 3%] [65 q4os-wal
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfile-copy-recursive-perl all 0.38-1
10% [69 libreoffice-common 696 kB/21.7 MB 3%] [65 q4os-wallpapers 11.6 MB/20.8
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfile-desktopentry-perl all 0.07-1
10% [Waiting for headers] [69 libreoffice-common 728 kB/21.7 MB 3%] [65 q4os-wa
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libtimedate-perl all 2.3000-2
10% [Waiting for headers] [69 libreoffice-common 760 kB/21.7 MB 4%] [65 q4os-wa
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libhttp-date-perl all 6.02-1
10% [Waiting for headers] [69 libreoffice-common 795 kB/21.7 MB 4%] [65 q4os-wa
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfile-listing-perl all 6.04-1
10% [Waiting for headers] [69 libreoffice-common 827 kB/21.7 MB 4%] [65 q4os-wa
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfile-mimeinfo-perl all 0.26-1
10% [Waiting for headers] [69 libreoffice-common 859 kB/21.7 MB 4%] [65 q4os-wa
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfont-afm-perl all 1.20-1
10% [Waiting for headers] [69 libreoffice-common 893 kB/21.7 MB 4%] [65 q4os-wa
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfreehand-0.1-1 armhf 0.1.0-2
10% [Waiting for headers] [69 libreoffice-common 922 kB/21.7 MB 4%] [65 q4os-wa
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libglib-perl armhf 3:1.305-2
10% [Waiting for headers] [69 libreoffice-common 967 kB/21.7 MB 4%] [65 q4os-wa
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgltf-0.0-0 armhf 0.0.2-2
10% [Waiting for headers] [69 libreoffice-common 980 kB/21.7 MB 5%] [65 q4os-wa
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgphoto2-l10n all 2.5.4-1.1
10% [Waiting for headers] [69 libreoffice-common 1,012 kB/21.7 MB 5%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libpango-perl armhf 1.226-2
10% [Waiting for headers] [69 libreoffice-common 1,035 kB/21.7 MB 5%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgtk2-perl armhf 2:1.2492-4
10% [Waiting for headers] [69 libreoffice-common 1,064 kB/21.7 MB 5%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgtk2.0-bin armhf 2.24.25-3+deb8u1
10% [Waiting for headers] [69 libreoffice-common 1,090 kB/21.7 MB 5%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libservlet2.5-java all 6.0.45+dfsg-1~deb8u1
10% [Waiting for headers] [69 libreoffice-common 1,122 kB/21.7 MB 5%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libhsqldb1.8.0-java all 1.8.0.10+dfsg-3
10% [Waiting for headers] [69 libreoffice-common 1,151 kB/21.7 MB 5%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main liburi-perl all 1.64-1
10% [Waiting for headers] [69 libreoffice-common 1,183 kB/21.7 MB 5%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libhtml-tagset-perl all 3.20-2
10% [Waiting for headers] [69 libreoffice-common 1,212 kB/21.7 MB 6%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libhtml-parser-perl armhf 3.71-1+b4
10% [Waiting for headers] [69 libreoffice-common 1,242 kB/21.7 MB 6%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libio-html-perl all 1.001-1
10% [69 libreoffice-common 1,273 kB/21.7 MB 6%] [65 q4os-wallpapers 15.0 MB/20.
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main liblwp-mediatypes-perl all 6.02-1
10% [Waiting for headers] [69 libreoffice-common 1,273 kB/21.7 MB 6%] [65 q4os-
10% [69 libreoffice-common 1,296 kB/21.7 MB 6%] [65 q4os-wallpapers 15.2 MB/20.
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libhttp-message-perl all 6.06-1
10% [Waiting for headers] [69 libreoffice-common 1,350 kB/21.7 MB 6%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libhtml-form-perl all 6.03-1
10% [Waiting for headers] [69 libreoffice-common 1,371 kB/21.7 MB 6%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libhtml-tree-perl all 5.03-1
10% [Waiting for headers] [69 libreoffice-common 1,392 kB/21.7 MB 6%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libhtml-format-perl all 2.11-1
10% [Waiting for headers] [69 libreoffice-common 1,423 kB/21.7 MB 7%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libhttp-cookies-perl all 6.01-1
10% [Waiting for headers] [69 libreoffice-common 1,449 kB/21.7 MB 7%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libhttp-daemon-perl all 6.01-1
11% [Waiting for headers] [69 libreoffice-common 1,473 kB/21.7 MB 7%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libhttp-negotiate-perl all 6.00-2
11% [Waiting for headers] [69 libreoffice-common 1,497 kB/21.7 MB 7%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libhyphen0 armhf 2.8.8-1
11% [69 libreoffice-common 1,525 kB/21.7 MB 7%] [65 q4os-wallpapers 16.2 MB/20.
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libnet-ssleay-perl armhf 1.65-1+deb8u1
11% [Waiting for headers] [69 libreoffice-common 1,525 kB/21.7 MB 7%] [65 q4os-
11% [69 libreoffice-common 1,542 kB/21.7 MB 7%] [65 q4os-wallpapers 16.3 MB/20.
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libio-socket-ssl-perl all 2.002-2+deb8u2
11% [Waiting for headers] [69 libreoffice-common 1,542 kB/21.7 MB 7%] [65 q4os-
11% [69 libreoffice-common 1,573 kB/21.7 MB 7%] [65 q4os-wallpapers 16.4 MB/20.
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libiso9660-8 armhf 0.83-4.2
11% [Waiting for headers] [69 libreoffice-common 1,573 kB/21.7 MB 7%] [65 q4os-
11% [69 libreoffice-common 1,588 kB/21.7 MB 7%] [65 q4os-wallpapers 16.5 MB/20.
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main liblangtag-common all 0.5.1-3
11% [Waiting for headers] [69 libreoffice-common 1,588 kB/21.7 MB 7%] [65 q4os-
11% [69 libreoffice-common 1,615 kB/21.7 MB 7%] [65 q4os-wallpapers 16.6 MB/20.
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main liblangtag1 armhf 0.5.1-3
11% [Waiting for headers] [69 libreoffice-common 1,641 kB/21.7 MB 8%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main liblapack3 armhf 3.5.0-4
11% [Waiting for headers] [69 libreoffice-common 1,661 kB/21.7 MB 8%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main liblircclient0 armhf 0.9.0~pre1-1.2
11% [Waiting for headers] [69 libreoffice-common 1,693 kB/21.7 MB 8%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libnet-http-perl all 6.07-1
11% [Waiting for headers] [69 libreoffice-common 1,707 kB/21.7 MB 8%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwww-robotrules-perl all 6.01-1
11% [Waiting for headers] [69 libreoffice-common 1,736 kB/21.7 MB 8%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwww-perl all 6.08-1
11% [Waiting for headers] [69 libreoffice-common 1,754 kB/21.7 MB 8%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main liblwp-protocol-https-perl all 6.06-2
11% [Waiting for headers] [69 libreoffice-common 1,756 kB/21.7 MB 8%] [65 q4os-
11% [69 libreoffice-common 1,780 kB/21.7 MB 8%] [65 q4os-wallpapers 17.3 MB/20.
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libnet-smtp-ssl-perl all 1.01-3
11% [Waiting for headers] [69 libreoffice-common 1,804 kB/21.7 MB 8%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmailtools-perl all 2.13-1
11% [Waiting for headers] [69 libreoffice-common 1,823 kB/21.7 MB 8%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmspub-0.1-1 armhf 0.1.1-2
11% [Waiting for headers] [69 libreoffice-common 1,852 kB/21.7 MB 9%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmtp-runtime armhf 1.1.8-1+b1
11% [Waiting for headers] [69 libreoffice-common 1,872 kB/21.7 MB 9%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmwaw-0.3-3 armhf 0.3.1-2
11% [Waiting for headers] [69 libreoffice-common 1,904 kB/21.7 MB 9%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmythes-1.2-0 armhf 2:1.2.4-1
11% [Waiting for headers] [69 libreoffice-common 1,939 kB/21.7 MB 9%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libneon27-gnutls armhf 0.30.1-1
11% [Waiting for headers] [69 libreoffice-common 1,959 kB/21.7 MB 9%] [65 q4os-
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxml-parser-perl armhf 2.41-3
11% [69 libreoffice-common 1,977 kB/21.7 MB 9%] [65 q4os-wallpapers 18.3 MB/20.
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxml-twig-perl all 1:3.48-1
11% [Waiting for headers] [69 libreoffice-common 1,977 kB/21.7 MB 9%] [65 q4os-
11% [Connecting to mirrordirector.raspbian.org (93.93.128.193)] [69 libreoffice
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libnet-dbus-perl armhf 1.0.0-2+b2
11% [Waiting for headers] [69 libreoffice-common 2,046 kB/21.7 MB 9%] [65 q4os-
11% [69 libreoffice-common 2,046 kB/21.7 MB 9%] [65 q4os-wallpapers 18.8 MB/20.
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libodfgen-0.1-1 armhf 0.1.1-2
11% [Waiting for headers] [69 libreoffice-common 2,072 kB/21.7 MB 10%] [65 q4os
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main liborcus-0.8-0 armhf 0.7.0+dfsg-9
11% [Waiting for headers] [69 libreoffice-common 2,074 kB/21.7 MB 10%] [65 q4os
11% [69 libreoffice-common 2,110 kB/21.7 MB 10%] [65 q4os-wallpapers 19.3 MB/20
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libpam-gnome-keyring armhf 3.14.0-1+b1
11% [Waiting for headers] [69 libreoffice-common 2,144 kB/21.7 MB 10%] [65 q4os
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libpaper-utils armhf 1.1.24+nmu4
11% [69 libreoffice-common 2,156 kB/21.7 MB 10%] [65 q4os-wallpapers 19.8 MB/20
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libperl4-corelibs-perl all 0.003-1
11% [Waiting for headers] [69 libreoffice-common 2,156 kB/21.7 MB 10%] [65 q4os
11% [69 libreoffice-common 2,220 kB/21.7 MB 10%] [65 q4os-wallpapers 20.1 MB/20
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libpostproc52 armhf 6:0.git20120821-4
11% [Waiting for headers] [69 libreoffice-common 2,220 kB/21.7 MB 10%] [65 q4os
11% [69 libreoffice-common 2,257 kB/21.7 MB 10%] [65 q4os-wallpapers 20.4 MB/20
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libproxy-tools armhf 0.4.11-4
11% [Waiting for headers] [69 libreoffice-common 2,257 kB/21.7 MB 10%] [65 q4os
12% [69 libreoffice-common 2,295 kB/21.7 MB 11%] [65 q4os-wallpapers 20.6 MB/20
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main qtchooser armhf 47-gd2b7997-2
12% [Waiting for headers] [69 libreoffice-common 2,295 kB/21.7 MB 11%] [65 q4os
12% [69 libreoffice-common 2,337 kB/21.7 MB 11%] [65 q4os-wallpapers 20.7 MB/20
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main qdbus armhf 4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1
12% [Waiting for headers] [69 libreoffice-common 2,337 kB/21.7 MB 11%] [65 q4os
12% [69 libreoffice-common 2,376 kB/21.7 MB 11%] [65 q4os-wallpapers 20.7 MB/20
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libqt4-dbus armhf 4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1
12% [Waiting for headers] [69 libreoffice-common 2,376 kB/21.7 MB 11%] [65 q4os
12% [69 libreoffice-common 2,420 kB/21.7 MB 11%] [65 q4os-wallpapers 20.7 MB/20
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main lp-solve armhf 5.5.0.13-7+b1
12% [Waiting for headers] [69 libreoffice-common 2,420 kB/21.7 MB 11%] [65 q4os
12% [69 libreoffice-common 2,457 kB/21.7 MB 11%] [65 q4os-wallpapers 20.7 MB/20
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main coinor-libcoinutils3 armhf 2.9.15-3
12% [Waiting for headers] [69 libreoffice-common 2,457 kB/21.7 MB 11%] [65 q4os
12% [69 libreoffice-common 2,492 kB/21.7 MB 11%] [65 q4os-wallpapers 20.7 MB/20
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main coinor-libosi1 armhf 0.106.9-1
12% [Waiting for headers] [69 libreoffice-common 2,492 kB/21.7 MB 11%] [65 q4os
12% [69 libreoffice-common 2,537 kB/21.7 MB 12%] [65 q4os-wallpapers 20.8 MB/20
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main coinor-libclp1 armhf 1.15.10-1
12% [Waiting for headers] [69 libreoffice-common 2,537 kB/21.7 MB 12%] [65 q4os
12% [Waiting for headers] [69 libreoffice-common 2,567 kB/21.7 MB 12%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main coinor-libcgl1 armhf 0.58.9-1
12% [Waiting for headers] [69 libreoffice-common 2,611 kB/21.7 MB 12%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main coinor-libcbc3 armhf 2.8.12-1
12% [Waiting for headers] [69 libreoffice-common 2,648 kB/21.7 MB 12%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main coinor-libcoinmp1 armhf 1.7.6+dfsg1-1
12% [Waiting for headers] [69 libreoffice-common 2,686 kB/21.7 MB 12%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwps-0.3-3 armhf 0.3.0-2
12% [Waiting for headers] [69 libreoffice-common 2,727 kB/21.7 MB 13%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvisio-0.1-1 armhf 0.1.0-2
12% [Waiting for headers] [69 libreoffice-common 2,767 kB/21.7 MB 13%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwpd-0.10-10 armhf 0.10.0-2
12% [Waiting for headers] [69 libreoffice-common 2,813 kB/21.7 MB 13%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwpg-0.3-3 armhf 0.3.0-3
12% [Waiting for headers] [69 libreoffice-common 2,845 kB/21.7 MB 13%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libresid-builder0c2a armhf 2.1.1-14
12% [Waiting for headers] [69 libreoffice-common 2,890 kB/21.7 MB 13%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsane-extras-common armhf 1.0.22.3
Unable to connect to mirror.nbtelecom.com.br:http:
12% [Waiting for headers] [69 libreoffice-common 2,924 kB/21.7 MB 13%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsane-extras armhf 1.0.22.3
12% [Waiting for headers] [69 libreoffice-common 2,981 kB/21.7 MB 14%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsidplay2 armhf 2.1.1-14
12% [Waiting for headers] [69 libreoffice-common 3,031 kB/21.7 MB 14%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libtie-ixhash-perl all 1.23-1
12% [Waiting for headers] [69 libreoffice-common 3,068 kB/21.7 MB 14%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvcdinfo0 armhf 0.7.24+dfsg-0.2
12% [Waiting for headers] [69 libreoffice-common 3,115 kB/21.7 MB 14%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvisual-0.4-plugins armhf 0.4.0.dfsg.1-7
12% [Waiting for headers] [69 libreoffice-common 3,118 kB/21.7 MB 14%]
12% [69 libreoffice-common 3,152 kB/21.7 MB 15%] 131 kB/s 59min 5s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main vlc-data all 2.2.4-1~deb8u1
12% [Waiting for headers] [69 libreoffice-common 3,152 kB/21.7 MB 15%]
12% [69 libreoffice-common 3,197 kB/21.7 MB 15%] 131 kB/s 59min 4s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvlccore8 armhf 2.2.4-1~deb8u1
12% [Waiting for headers] [69 libreoffice-common 3,197 kB/21.7 MB 15%]
12% [69 libreoffice-common 3,236 kB/21.7 MB 15%] 131 kB/s 59min 4s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvlc5 armhf 2.2.4-1~deb8u1
12% [Waiting for headers] [69 libreoffice-common 3,236 kB/21.7 MB 15%]
12% [69 libreoffice-common 3,277 kB/21.7 MB 15%] 131 kB/s 59min 4s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvte-2.90-common all 1:0.36.3-1
12% [Waiting for headers] [69 libreoffice-common 3,277 kB/21.7 MB 15%]
12% [69 libreoffice-common 3,323 kB/21.7 MB 15%] 131 kB/s 59min 3s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvte-2.90-9 armhf 1:0.36.3-1
12% [Waiting for headers] [69 libreoffice-common 3,323 kB/21.7 MB 15%]
12% [69 libreoffice-common 3,333 kB/21.7 MB 15%] 131 kB/s 59min 3s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libx11-protocol-perl all 0.56-6
12% [Waiting for headers] [69 libreoffice-common 3,333 kB/21.7 MB 15%]
12% [69 libreoffice-common 3,401 kB/21.7 MB 16%] 131 kB/s 59min 3s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libxml-xpathengine-perl all 0.13-1
12% [Waiting for headers] [69 libreoffice-common 3,433 kB/21.7 MB 16%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main ncompress armhf 4.2.4.4-9
12% [Waiting for headers] [69 libreoffice-common 3,474 kB/21.7 MB 16%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main notification-daemon armhf 0.7.6-2
12% [Waiting for headers] [69 libreoffice-common 3,520 kB/21.7 MB 16%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main squeak-vm armhf 1:4.10.2.2614-1.1+b1
12% [Waiting for headers] [69 libreoffice-common 3,546 kB/21.7 MB 16%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main squeak-plugins-scratch armhf 1.4.0.2~svn.r83-2
12% [Waiting for headers] [69 libreoffice-common 3,600 kB/21.7 MB 17%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main scratch all 1.4.0.6~dfsg1-5
12% [Waiting for headers] [69 libreoffice-common 3,633 kB/21.7 MB 17%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main p7zip-full armhf 9.20.1~dfsg.1-4.1+deb8u2
12% [Waiting for headers] [69 libreoffice-common 3,674 kB/21.7 MB 17%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main policykit-1-gnome armhf 0.105-2
12% [Waiting for headers] [69 libreoffice-common 3,720 kB/21.7 MB 17%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main printer-driver-gutenprint armhf 5.2.10-3+b3
12% [Waiting for headers] [69 libreoffice-common 3,763 kB/21.7 MB 17%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python-crypto armhf 2.6.1-5+deb8u1
12% [69 libreoffice-common 3,810 kB/21.7 MB 18%] 131 kB/s 59min 0s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python-gi armhf 3.14.0-1
12% [Waiting for headers] [69 libreoffice-common 3,810 kB/21.7 MB 18%]
12% [69 libreoffice-common 3,859 kB/21.7 MB 18%] 131 kB/s 58min 59s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python-ntdb armhf 1.0-5
12% [Waiting for headers] [69 libreoffice-common 3,859 kB/21.7 MB 18%]
12% [69 libreoffice-common 3,902 kB/21.7 MB 18%] 124 kB/s 1h 2min 19s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python-tdb armhf 1.3.6-0+deb8u1
12% [Waiting for headers] [69 libreoffice-common 3,902 kB/21.7 MB 18%]
12% [69 libreoffice-common 3,943 kB/21.7 MB 18%] 124 kB/s 1h 2min 19s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python-samba armhf 2:4.2.14+dfsg-0+deb8u2
12% [Waiting for headers] [69 libreoffice-common 4,001 kB/21.7 MB 18%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python3-dbus armhf 1.2.0-2+b1
12% [Waiting for headers] [69 libreoffice-common 4,044 kB/21.7 MB 19%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python3-gi armhf 3.14.0-1
12% [Waiting for headers] [69 libreoffice-common 4,085 kB/21.7 MB 19%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python3-software-properties all 0.92.25debian1
12% [Waiting for headers] [69 libreoffice-common 4,130 kB/21.7 MB 19%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main qjackctl armhf 0.3.12-1
12% [Waiting for headers] [69 libreoffice-common 4,138 kB/21.7 MB 19%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main qpdf armhf 5.1.2-2
12% [Waiting for headers] [69 libreoffice-common 4,191 kB/21.7 MB 19%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main qpdfview armhf 0.4.12-1
12% [Waiting for headers] [69 libreoffice-common 4,192 kB/21.7 MB 19%]
12% [69 libreoffice-common 4,218 kB/21.7 MB 19%] 124 kB/s 1h 2min 17s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main qpdfview-djvu-plugin armhf 0.4.12-1
12% [Waiting for headers] [69 libreoffice-common 4,218 kB/21.7 MB 19%]
12% [69 libreoffice-common 4,247 kB/21.7 MB 20%] 124 kB/s 1h 2min 17s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main qpdfview-ps-plugin armhf 0.4.12-1
12% [Waiting for headers] [69 libreoffice-common 4,247 kB/21.7 MB 20%]
12% [69 libreoffice-common 4,264 kB/21.7 MB 20%] 124 kB/s 1h 2min 17s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main qpdfview-translations all 0.4.12-1
12% [Waiting for headers] [69 libreoffice-common 4,264 kB/21.7 MB 20%]
12% [69 libreoffice-common 4,296 kB/21.7 MB 20%] 124 kB/s 1h 2min 16s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main qttranslations5-l10n all 5.3.2-2
12% [Waiting for headers] [69 libreoffice-common 4,296 kB/21.7 MB 20%]
12% [69 libreoffice-common 4,325 kB/21.7 MB 20%] 124 kB/s 1h 2min 16s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main rsync armhf 3.1.1-3
12% [Waiting for headers] [69 libreoffice-common 4,325 kB/21.7 MB 20%]
12% [69 libreoffice-common 4,348 kB/21.7 MB 20%] 124 kB/s 1h 2min 16s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main samba-common-bin armhf 2:4.2.14+dfsg-0+deb8u2
12% [Waiting for headers] [69 libreoffice-common 4,348 kB/21.7 MB 20%]
12% [69 libreoffice-common 4,380 kB/21.7 MB 20%] 124 kB/s 1h 2min 16s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main update-inetd all 4.43
12% [Waiting for headers] [69 libreoffice-common 4,380 kB/21.7 MB 20%]
12% [69 libreoffice-common 4,409 kB/21.7 MB 20%] 124 kB/s 1h 2min 15s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main sane-utils armhf 1.0.24-8+deb8u1
12% [Waiting for headers] [69 libreoffice-common 4,409 kB/21.7 MB 20%]
12% [69 libreoffice-common 4,441 kB/21.7 MB 20%] 124 kB/s 1h 2min 15s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main software-properties-common all 0.92.25debian1
12% [Waiting for headers] [69 libreoffice-common 4,441 kB/21.7 MB 20%]
12% [69 libreoffice-common 4,470 kB/21.7 MB 21%] 124 kB/s 1h 2min 15s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main synaptic armhf 0.81.2+rpi1
12% [Waiting for headers] [69 libreoffice-common 4,470 kB/21.7 MB 21%]
12% [69 libreoffice-common 4,499 kB/21.7 MB 21%] 96.0 kB/s 1h 20min 24s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main twolame armhf 0.3.13-1.1
12% [Waiting for headers] [69 libreoffice-common 4,499 kB/21.7 MB 21%]
12% [69 libreoffice-common 4,528 kB/21.7 MB 21%] 96.0 kB/s 1h 20min 23s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main unrar-free armhf 1:0.0.1+cvs20140707-1
12% [Waiting for headers] [69 libreoffice-common 4,528 kB/21.7 MB 21%]
12% [69 libreoffice-common 4,554 kB/21.7 MB 21%] 96.0 kB/s 1h 20min 23s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main v4l-utils armhf 1.6.0-2
12% [Waiting for headers] [69 libreoffice-common 4,554 kB/21.7 MB 21%]
12% [69 libreoffice-common 4,586 kB/21.7 MB 21%] 96.0 kB/s 1h 20min 23s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main vlc-nox armhf 2.2.4-1~deb8u1
12% [Waiting for headers] [69 libreoffice-common 4,586 kB/21.7 MB 21%]
12% [69 libreoffice-common 4,621 kB/21.7 MB 21%] 96.0 kB/s 1h 20min 22s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main vlc armhf 2.2.4-1~deb8u1
12% [Waiting for headers] [69 libreoffice-common 4,621 kB/21.7 MB 21%]
12% [69 libreoffice-common 4,650 kB/21.7 MB 21%] 96.0 kB/s 1h 20min 22s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main vlc-plugin-notify armhf 2.2.4-1~deb8u1
12% [Waiting for headers] [69 libreoffice-common 4,673 kB/21.7 MB 22%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main vlc-plugin-samba armhf 2.2.4-1~deb8u1
12% [Waiting for headers] [69 libreoffice-common 4,707 kB/21.7 MB 22%]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main xdg-utils all 1.1.0~rc1+git20111210-7.4
12% [69 libreoffice-common 4,736 kB/21.7 MB 22%] 96.0 kB/s 1h 20min 21s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main xfonts-encodings all 1:1.0.4-2
12% [Waiting for headers] [69 libreoffice-common 4,783 kB/21.7 MB 22%]
12% [69 libreoffice-common 4,797 kB/21.7 MB 22%] 96.0 kB/s 1h 20min 21s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main xfonts-utils armhf 1:7.7+2
12% [Waiting for headers] [69 libreoffice-common 4,800 kB/21.7 MB 22%]
12% [69 libreoffice-common 4,825 kB/21.7 MB 22%] 96.0 kB/s 1h 20min 20s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main zenity-common all 3.14.0-1
12% [Waiting for headers] [69 libreoffice-common 4,828 kB/21.7 MB 22%]
12% [69 libreoffice-common 4,861 kB/21.7 MB 22%] 96.0 kB/s 1h 20min 20s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main zenity armhf 3.14.0-1
12% [Waiting for headers] [69 libreoffice-common 4,861 kB/21.7 MB 22%]
12% [69 libreoffice-common 4,883 kB/21.7 MB 22%] 96.0 kB/s 1h 20min 20s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main zip armhf 3.0-8
12% [Waiting for headers] [69 libreoffice-common 4,883 kB/21.7 MB 22%]
12% [69 libreoffice-common 4,919 kB/21.7 MB 23%] 96.0 kB/s 1h 20min 19s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main zoo armhf 2.10-27
12% [Waiting for headers] [69 libreoffice-common 4,919 kB/21.7 MB 23%]
12% [69 libreoffice-common 4,951 kB/21.7 MB 23%] 96.0 kB/s 1h 20min 19s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main cgroup-bin all 0.41-6+rpi1
12% [Waiting for headers] [69 libreoffice-common 4,951 kB/21.7 MB 23%]
12% [69 libreoffice-common 4,977 kB/21.7 MB 23%] 96.0 kB/s 1h 20min 19s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main fonts-stix all 1.1.1-1
12% [Waiting for headers] [69 libreoffice-common 4,977 kB/21.7 MB 23%]
12% [69 libreoffice-common 5,016 kB/21.7 MB 23%] 96.0 kB/s 1h 20min 18s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main gdisk armhf 0.8.10-2
12% [Waiting for headers] [69 libreoffice-common 5,016 kB/21.7 MB 23%]
12% [69 libreoffice-common 5,038 kB/21.7 MB 23%] 96.0 kB/s 1h 20min 18s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main librarian0 armhf 0.8.1-6
12% [Waiting for headers] [69 libreoffice-common 5,038 kB/21.7 MB 23%]
12% [69 libreoffice-common 5,067 kB/21.7 MB 23%] 91.2 kB/s 1h 24min 32s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main rarian-compat armhf 0.8.1-6
12% [Waiting for headers] [69 libreoffice-common 5,067 kB/21.7 MB 23%]
12% [69 libreoffice-common 5,098 kB/21.7 MB 23%] 91.2 kB/s 1h 24min 32s
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main xfonts-mathml all 6
13% [69 libreoffice-common 7,438 kB/21.7 MB 34%] 93.4 kB/s 1h 22min 6s
13% [69 libreoffice-common 8,701 kB/21.7 MB 40%] 133 kB/s 57min 20s
13% [69 libreoffice-common 9,972 kB/21.7 MB 46%] 96.3 kB/s 1h 19min 11s
13% [69 libreoffice-common 11.2 MB/21.7 MB 52%] 87.2 kB/s 1h 27min 17s
14% [69 libreoffice-common 12.8 MB/21.7 MB 59%] 152 kB/s 49min 58s
14% [69 libreoffice-common 14.5 MB/21.7 MB 67%] 103 kB/s 1h 13min 27s
15% [69 libreoffice-common 20.0 MB/21.7 MB 92%] 182 kB/s 40min 55s
15% [69 libreoffice-common 21.7 MB/21.7 MB 100%] 84.8 kB/s 1h 27min 42s
15% [Working] 84.8 kB/s 1h 27min 41s
Get:72 http://archive.raspberrypi.org/debian/ jessie/main libwayland-egl1-mesa armhf 13.0.0-1+rpi1 [41.9 kB]
15% [72 libwayland-egl1-mesa 1,448 B/41.9 kB 3%] 84.8 kB/s 1h 27min 41s
15% [Waiting for headers] 84.8 kB/s 1h 27min 41s
Get:73 http://archive.raspberrypi.org/debian/ jessie/main libwebkitgtk-3.0-common all 1:2.4.1-1rpi53rpi1g [462 kB]
15% [73 libwebkitgtk-3.0-common 0 B/462 kB 0%] 84.8 kB/s 1h 27min 41s
15% [73 libwebkitgtk-3.0-common 436 kB/462 kB 94%] 87.4 kB/s 1h 24min 59s
15% [Working] 87.4 kB/s 1h 24min 59s
Get:74 http://archive.raspberrypi.org/debian/ jessie/main libwebkitgtk-3.0-0 armhf 1:2.4.1-1rpi53rpi1g [5,212 kB]
15% [74 libwebkitgtk-3.0-0 0 B/5,212 kB 0%] 87.4 kB/s 1h 24min 59s
16% [74 libwebkitgtk-3.0-0 3,215 kB/5,212 kB 62%] 87.0 kB/s 1h 24min 46s
16% [74 libwebkitgtk-3.0-0 3,731 kB/5,212 kB 72%] 198 kB/s 37min 9s
16% [74 libwebkitgtk-3.0-0 5,203 kB/5,212 kB 100%] 105 kB/s 1h 10min 1s
16% [Working] 105 kB/s 1h 10min 1s
Get:75 http://archive.raspberrypi.org/debian/ jessie/main epiphany-browser-data all 1:3.8.2.0-0rpi27rpi1g [2,123 kB]
16% [75 epiphany-browser-data 0 B/2,123 kB 0%] 105 kB/s 1h 10min 1s
17% [75 epiphany-browser-data 2,098 kB/2,123 kB 99%] 81.4 kB/s 1h 29min 43s
17% [Working] 81.4 kB/s 1h 29min 43s
Get:76 http://archive.raspberrypi.org/debian/ jessie/main epiphany-browser armhf 1:3.8.2.0-0rpi27rpi1g [1,497 kB]
17% [76 epiphany-browser 1,448 B/1,497 kB 0%] 55.7 kB/s 2h 11min 0s
17% [76 epiphany-browser 807 kB/1,497 kB 54%] 55.7 kB/s 2h 10min 46s
17% [76 epiphany-browser 1,394 kB/1,497 kB 93%] 166 kB/s 43min 52s
17% [Working] 166 kB/s 43min 52s
17% [Waiting for headers] 166 kB/s 43min 52s
Get:77 http://archive.raspberrypi.org/debian/ jessie/ui fonts-opensymbol all 2:102.6+LibO4.3.3-2+rpi4 [147 kB]
17% [77 fonts-opensymbol 0 B/147 kB 0%] 166 kB/s 43min 52s
17% [77 fonts-opensymbol 46.3 kB/147 kB 32%] 166 kB/s 43min 51s
17% [Working] 166 kB/s 43min 51s
Get:78 http://archive.raspberrypi.org/debian/ jessie/main gnome-accessibility-themes all 3.14.2.2-1rpi1rpi1g [2,920 kB]
17% [78 gnome-accessibility-themes 0 B/2,920 kB 0%] 166 kB/s 43min 51s
18% [78 gnome-accessibility-themes 2,855 kB/2,920 kB 98%] 283 kB/s 25min 31s
18% [Working] 283 kB/s 25min 30s
Get:79 http://archive.raspberrypi.org/debian/ jessie/main gstreamer1.0-omx armhf 1.0.0.1-0+rpi18rpi1g [95.9 kB]
18% [79 gstreamer1.0-omx 1,448 B/95.9 kB 2%] 283 kB/s 25min 30s
18% [79 gstreamer1.0-omx 79.6 kB/95.9 kB 83%] 283 kB/s 25min 30s
Get:80 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-core armhf 1:4.3.3-2+rpi4 [25.2 MB]
18% [80 libreoffice-core 0 B/25.2 MB 0%] 283 kB/s 25min 30s
20% [80 libreoffice-core 9,880 kB/25.2 MB 39%] 324 kB/s 21min 49s
20% [80 libreoffice-core 14.1 MB/25.2 MB 56%] 160 kB/s 43min 42s
21% [80 libreoffice-core 15.9 MB/25.2 MB 63%] 98.3 kB/s 1h 10min 51s
21% [80 libreoffice-core 17.2 MB/25.2 MB 69%] 119 kB/s 58min 12s
21% [80 libreoffice-core 18.2 MB/25.2 MB 73%] 109 kB/s 1h 3min 18s
22% [80 libreoffice-core 25.1 MB/25.2 MB 100%] 142 kB/s 48min 5s
22% [Working] 142 kB/s 48min 5s
Get:81 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-base-core armhf 1:4.3.3-2+rpi4 [682 kB]
22% [81 libreoffice-base-core 0 B/682 kB 0%] 142 kB/s 48min 5s
23% [81 libreoffice-base-core 488 kB/682 kB 72%] 142 kB/s 48min 1s
23% [81 libreoffice-base-core 665 kB/682 kB 97%] 90.8 kB/s 1h 14min 50s
23% [Working] 90.8 kB/s 1h 14min 50s
Get:82 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-base-drivers armhf 1:4.3.3-2+rpi4 [498 kB]
23% [82 libreoffice-base-drivers 0 B/498 kB 0%] 90.8 kB/s 1h 14min 50s
23% [82 libreoffice-base-drivers 436 kB/498 kB 87%] 90.8 kB/s 1h 14min 45s
23% [Working] 90.8 kB/s 1h 14min 44s
Get:83 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-base armhf 1:4.3.3-2+rpi4 [1,391 kB]
23% [83 libreoffice-base 0 B/1,391 kB 0%] 106 kB/s 1h 3min 44s
23% [83 libreoffice-base 727 kB/1,391 kB 52%] 106 kB/s 1h 3min 37s
23% [83 libreoffice-base 1,335 kB/1,391 kB 96%] 134 kB/s 50min 33s
23% [Working] 134 kB/s 50min 33s
Get:84 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-calc armhf 1:4.3.3-2+rpi4 [5,201 kB]
23% [84 libreoffice-calc 0 B/5,201 kB 0%] 134 kB/s 50min 33s
23% [84 libreoffice-calc 833 kB/5,201 kB 16%] 130 kB/s 51min 59s
23% [84 libreoffice-calc 1,641 kB/5,201 kB 32%] 109 kB/s 1h 1min 54s
24% [84 libreoffice-calc 3,810 kB/5,201 kB 73%] 123 kB/s 54min 15s
24% [84 libreoffice-calc 5,084 kB/5,201 kB 98%] 98.1 kB/s 1h 8min 4s
24% [84 libreoffice-calc 5,184 kB/5,201 kB 100%] 114 kB/s 58min 29s
24% [Working] 114 kB/s 58min 29s
Get:85 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-draw armhf 1:4.3.3-2+rpi4 [2,135 kB]
24% [85 libreoffice-draw 0 B/2,135 kB 0%] 114 kB/s 58min 29s
24% [85 libreoffice-draw 2,046 kB/2,135 kB 96%] 133 kB/s 50min 7s
24% [Working] 133 kB/s 50min 7s
Get:86 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-impress armhf 1:4.3.3-2+rpi4 [910 kB]
24% [86 libreoffice-impress 0 B/910 kB 0%] 133 kB/s 50min 7s
24% [86 libreoffice-impress 42.0 kB/910 kB 5%] 133 kB/s 50min 6s
24% [86 libreoffice-impress 905 kB/910 kB 99%] 73.7 kB/s 1h 29min 55s
24% [Working] 73.7 kB/s 1h 29min 55s
Get:87 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-math armhf 1:4.3.3-2+rpi4 [352 kB]
24% [87 libreoffice-math 0 B/352 kB 0%] 73.7 kB/s 1h 29min 55s
25% [87 libreoffice-math 307 kB/352 kB 87%] 80.1 kB/s 1h 22min 40s
25% [Working] 80.1 kB/s 1h 22min 39s
Get:88 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-report-builder-bin armhf 1:4.3.3-2+rpi4 [734 kB]
25% [88 libreoffice-report-builder-bin 0 B/734 kB 0%] 80.1 kB/s 1h 22min 39s
25% [88 libreoffice-report-builder-bin 401 kB/734 kB 55%]
25% [88 libreoffice-report-builder-bin 679 kB/734 kB 92%] 121 kB/s 54min 36s
25% [Working] 121 kB/s 54min 35s
Get:89 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-writer armhf 1:4.3.3-2+rpi4 [6,395 kB]
25% [89 libreoffice-writer 0 B/6,395 kB 0%] 121 kB/s 54min 35s
25% [89 libreoffice-writer 966 kB/6,395 kB 15%] 133 kB/s 49min 23s
25% [89 libreoffice-writer 3,689 kB/6,395 kB 58%] 69.9 kB/s 1h 33min 37s
26% [89 libreoffice-writer 6,391 kB/6,395 kB 100%] 174 kB/s 37min 17s
26% [Connecting to archive.raspberrypi.org (93.93.128.133)] 174 kB/s 37min 17s
Get:90 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-avmedia-backend-gstreamer armhf 1:4.3.3-2+rpi4 [76.9 kB]
26% [90 libreoffice-avmedia-backend-gstreamer 0 B/76.9 kB 0%]
26% [90 libreoffice-avmedia-backend-gstreamer 62.3 kB/76.9 kB 81%]
26% [Working] 138 kB/s 47min 11s
Get:91 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-java-common all 1:4.3.3-2+rpi4 [1,944 kB]
26% [91 libreoffice-java-common 0 B/1,944 kB 0%] 138 kB/s 47min 11s
26% [91 libreoffice-java-common 1,911 kB/1,944 kB 98%] 141 kB/s 45min 44s
26% [Working] 141 kB/s 45min 44s
Get:92 http://archive.raspberrypi.org/debian/ jessie/ui python3-uno armhf 1:4.3.3-2+rpi4 [157 kB]
26% [92 python3-uno 152 kB/157 kB 97%] 141 kB/s 45min 43s
26% [Working] 141 kB/s 45min 43s
Get:93 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice armhf 1:4.3.3-2+rpi4 [70.5 kB]
26% [93 libreoffice 0 B/70.5 kB 0%] 141 kB/s 45min 43s
26% [93 libreoffice 56.5 kB/70.5 kB 80%] 141 kB/s 45min 43s
26% [Working] 113 kB/s 57min 24s
26% [Waiting for headers] 113 kB/s 57min 24s
Get:94 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-sdbc-firebird armhf 1:4.3.3-2+rpi4 [151 kB]
26% [94 libreoffice-sdbc-firebird 0 B/151 kB 0%] 113 kB/s 57min 24s
26% [94 libreoffice-sdbc-firebird 140 kB/151 kB 93%] 113 kB/s 57min 22s
26% [Working] 113 kB/s 57min 22s
Get:95 http://archive.raspberrypi.org/debian/ jessie/ui libreoffice-sdbc-hsqldb armhf 1:4.3.3-2+rpi4 [159 kB]
26% [95 libreoffice-sdbc-hsqldb 0 B/159 kB 0%] 113 kB/s 57min 22s
26% [95 libreoffice-sdbc-hsqldb 103 kB/159 kB 65%] 113 kB/s 57min 21s
26% [Working] 113 kB/s 57min 21s
Get:96 http://archive.raspberrypi.org/debian/ jessie/main libva-drm1 armhf 1.7.3-2 [14.5 kB]
26% [96 libva-drm1 0 B/14.5 kB 0%] 113 kB/s 57min 21s
Get:97 http://archive.raspberrypi.org/debian/ jessie/main libva-x11-1 armhf 1.7.3-2 [18.1 kB]
26% [97 libva-x11-1 0 B/18.1 kB 0%] 113 kB/s 57min 21s
Get:98 http://archive.raspberrypi.org/debian/ jessie/ui libpango1.0-0 armhf 1.36.8-3+rpi1 [183 kB]
26% [98 libpango1.0-0 0 B/183 kB 0%] 113 kB/s 57min 21s
26% [98 libpango1.0-0 146 kB/183 kB 80%] 61.8 kB/s 1h 44min 30s
26% [Working] 61.8 kB/s 1h 44min 29s
Get:99 http://archive.raspberrypi.org/debian/ jessie/main pigpio armhf 1.30-1 [229 kB]
26% [99 pigpio 0 B/229 kB 0%] 61.8 kB/s 1h 44min 29s
26% [99 pigpio 207 kB/229 kB 90%] 61.8 kB/s 1h 44min 26s
26% [Working] 61.8 kB/s 1h 44min 26s
Get:100 http://archive.raspberrypi.org/debian/ jessie/main nuscratch armhf 20161021 [11.9 MB]
26% [100 nuscratch 0 B/11.9 MB 0%] 61.8 kB/s 1h 44min 26s
27% [100 nuscratch 1,665 kB/11.9 MB 14%] 69.1 kB/s 1h 32min 56s
28% [100 nuscratch 9,958 kB/11.9 MB 83%] 152 kB/s 41min 25s
29% [100 nuscratch 11.9 MB/11.9 MB 100%] 109 kB/s 57min 26s
29% [Working] 109 kB/s 57min 26s
Get:101 http://archive.raspberrypi.org/debian/ jessie/main omxplayer armhf 0.3.7~git20160923~dfea8c9 [4,330 kB]
29% [101 omxplayer 0 B/4,330 kB 0%] 109 kB/s 57min 26s
29% [101 omxplayer 1,913 kB/4,330 kB 44%] 145 kB/s 42min 46s
29% [101 omxplayer 2,822 kB/4,330 kB 65%] 43.8 kB/s 2h 21min 34s
30% [101 omxplayer 4,282 kB/4,330 kB 99%] 130 kB/s 47min 42s
30% [Working] 130 kB/s 47min 41s
Get:102 http://archive.raspberrypi.org/debian/ jessie/main oracle-java8-jdk armhf 8u65 [62.2 MB]
30% [102 oracle-java8-jdk 0 B/62.2 MB 0%] 102 kB/s 1h 0min 29s
30% [102 oracle-java8-jdk 2,211 kB/62.2 MB 4%] 84.4 kB/s 1h 12min 45s
30% [102 oracle-java8-jdk 2,819 kB/62.2 MB 5%] 123 kB/s 49min 51s
30% [102 oracle-java8-jdk 3,546 kB/62.2 MB 6%] 101 kB/s 1h 0min 20s
31% [102 oracle-java8-jdk 5,458 kB/62.2 MB 9%] 103 kB/s 59min 4s
31% [102 oracle-java8-jdk 7,351 kB/62.2 MB 12%] 72.2 kB/s 1h 23min 50s
31% [102 oracle-java8-jdk 9,971 kB/62.2 MB 16%] 139 kB/s 43min 18s
32% [102 oracle-java8-jdk 11.0 MB/62.2 MB 18%] 112 kB/s 53min 40s
32% [102 oracle-java8-jdk 12.6 MB/62.2 MB 20%] 93.3 kB/s 1h 3min 59s
33% [102 oracle-java8-jdk 19.9 MB/62.2 MB 32%] 98.4 kB/s 59min 25s
34% [102 oracle-java8-jdk 23.1 MB/62.2 MB 37%] 78.5 kB/s 1h 13min 48s
34% [102 oracle-java8-jdk 24.4 MB/62.2 MB 39%] 151 kB/s 38min 10s
35% [102 oracle-java8-jdk 27.1 MB/62.2 MB 44%] 68.4 kB/s 1h 23min 45s
35% [102 oracle-java8-jdk 27.7 MB/62.2 MB 44%] 196 kB/s 29min 9s
35% [102 oracle-java8-jdk 29.4 MB/62.2 MB 47%] 93.8 kB/s 1h 0min 40s
36% [102 oracle-java8-jdk 31.5 MB/62.2 MB 51%] 108 kB/s 52min 25s
36% [102 oracle-java8-jdk 32.3 MB/62.2 MB 52%] 91.9 kB/s 1h 1min 23s
36% [102 oracle-java8-jdk 34.0 MB/62.2 MB 55%] 103 kB/s 54min 44s
36% [102 oracle-java8-jdk 35.3 MB/62.2 MB 57%] 51.5 kB/s 1h 48min 30s
36% [102 oracle-java8-jdk 36.5 MB/62.2 MB 59%] 115 kB/s 48min 38s
37% [102 oracle-java8-jdk 38.6 MB/62.2 MB 62%] 77.5 kB/s 1h 11min 24s
37% [102 oracle-java8-jdk 41.2 MB/62.2 MB 66%] 101 kB/s 54min 20s
38% [102 oracle-java8-jdk 43.7 MB/62.2 MB 70%] 64.3 kB/s 1h 24min 48s
38% [102 oracle-java8-jdk 44.7 MB/62.2 MB 72%] 103 kB/s 52min 44s
38% [102 oracle-java8-jdk 45.6 MB/62.2 MB 73%] 62.1 kB/s 1h 27min 14s
39% [102 oracle-java8-jdk 47.5 MB/62.2 MB 76%] 94.6 kB/s 56min 55s
39% [102 oracle-java8-jdk 48.3 MB/62.2 MB 78%] 87.4 kB/s 1h 1min 29s
39% [102 oracle-java8-jdk 52.3 MB/62.2 MB 84%] 135 kB/s 39min 24s
40% [102 oracle-java8-jdk 53.0 MB/62.2 MB 85%] 50.7 kB/s 1h 44min 25s
41% [102 oracle-java8-jdk 58.0 MB/62.2 MB 93%] 139 kB/s 37min 23s
41% [102 oracle-java8-jdk 58.5 MB/62.2 MB 94%] 69.6 kB/s 1h 14min 46s
41% [102 oracle-java8-jdk 62.0 MB/62.2 MB 100%] 110 kB/s 46min 52s
41% [102 oracle-java8-jdk 62.2 MB/62.2 MB 100%] 57.8 kB/s 1h 28min 59s
41% [Working] 57.8 kB/s 1h 28min 59s
Get:103 http://archive.raspberrypi.org/debian/ jessie/main va-driver-all armhf 1.7.3-2 [11.2 kB]
41% [103 va-driver-all 4,344 B/11.2 kB 39%] 57.8 kB/s 1h 28min 59s
Get:104 http://archive.raspberrypi.org/debian/ jessie/main bluej all 3.1.7b [10.1 MB]
41% [104 bluej 0 B/10.1 MB 0%] 57.8 kB/s 1h 28min 59s
42% [104 bluej 1,334 kB/10.1 MB 13%] 61.2 kB/s 1h 23min 42s
42% [104 bluej 2,498 kB/10.1 MB 25%] 116 kB/s 44min 8s
42% [104 bluej 3,911 kB/10.1 MB 39%] 66.6 kB/s 1h 16min 13s
42% [104 bluej 4,357 kB/10.1 MB 43%] 91.8 kB/s 55min 14s
43% [104 bluej 7,244 kB/10.1 MB 72%] 65.5 kB/s 1h 16min 39s
43% [104 bluej 7,783 kB/10.1 MB 77%] 128 kB/s 39min 7s
43% [104 bluej 8,678 kB/10.1 MB 86%] 60.2 kB/s 1h 23min 1s
43% [104 bluej 9,945 kB/10.1 MB 98%] 162 kB/s 30min 39s
43% [104 bluej 10.1 MB/10.1 MB 100%] 162 kB/s 30min 38s
43% [Working] 162 kB/s 30min 38s
Get:105 http://archive.raspberrypi.org/debian/ jessie/main raspberrypi-artwork all 20150921 [75.1 kB]
43% [105 raspberrypi-artwork 8,688 B/75.1 kB 12%] 162 kB/s 30min 38s
43% [105 raspberrypi-artwork 57.9 kB/75.1 kB 77%] 162 kB/s 30min 38s
Fetched 228 MB in 26min 15s (145 kB/s)
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/h/harfbuzz/libharfbuzz0b_0.9.35-2_armhf.deb Could not connect to mirror.nbtelecom.com.br:80 (189.45.5.90), connection timed out
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libs/libsoup2.4/libsoup-gnome2.4-1_2.48.0-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libr/librest/librest-0.7-0_0.7.92-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libx/libxkbcommon/libxkbcommon0_0.4.3-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcroco/libcroco3_0.6.8-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libr/librsvg/librsvg2-2_2.40.5-1+deb8u2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libr/librsvg/librsvg2-common_2.40.5-1+deb8u2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/a/adwaita-icon-theme/adwaita-icon-theme_3.14.0-2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gtk+2.0/libgtk2.0-common_2.24.25-3+deb8u1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gtk+2.0/libgtk2.0-0_2.24.25-3+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opus/libopus0_1.1-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/j/jackd2/libjack-jackd2-0_1.9.10+20140719git3eb0ae6a~dfsg-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/d/dbus-python/python-dbus-dev_1.2.0-2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/d/dbus-python/python-dbus_1.2.0-2+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/j/jackd2/jackd2_1.9.10+20140719git3eb0ae6a~dfsg-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libd/libdvdread/libdvdread4_5.0.0-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/flac/libflac++6_1.3.0-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cdrkit/wodim_1.1.11-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cdparanoia/cdparanoia_3.10.2+debian-11_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cdrkit/genisoimage_1.1.11-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libao/libao-common_1.1.0-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libao/libao4_1.1.0-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cdrdao/cdrdao_1.2.3-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/a/aalib/libaa1_1.4p5-43_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libaacs/libaacs0_0.7.1-1+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/l/lzo2/liblzo2-2_2.08-1.2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libarchive/libarchive13_3.1.2-11+deb8u3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libav/libavutil54_11.8-1~deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libav/libavresample2_11.8-1~deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgsm/libgsm1_1.0.13-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/l/lame/libmp3lame0_3.99.5+repack1-7+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/openjpeg/libopenjpeg5_1.5.2-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/schroedinger/libschroedinger-1.0-0_1.0.11-2.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/speex/libspeex1_1.2~rc1.2-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libt/libtheora/libtheora0_1.1.1+dfsg.1-6_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libv/libvpx/libvpx1_1.3.0-3+rvt_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/x/x264/libx264-142_0.142.2431+gita5831aa-1+rpi2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/x/xvidcore/libxvidcore4_1.3.3-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libav/libavcodec56_11.8-1~deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/r/rtmpdump/librtmp1_2.4+20150115.gita107cef-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libav/libavformat56_11.8-1~deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcdio/libcdio13_0.83-4.2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcdio/libcdio-cdda1_0.83-4.2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcdio/libcdio-paranoia1_0.83-4.2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libd/libdc1394-22/libdc1394-22_2.2.3-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libav/libavdevice55_11.8-1~deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opencv/libopencv-core2.4_2.4.9.1+dfsg-1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opencv/libopencv-imgproc2.4_2.4.9.1+dfsg-1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libav/libswscale3_11.8-1~deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libav/libavfilter5_11.8-1~deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcaca/libcaca0_0.99.beta19-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/d/directfb/libdirectfb-1.2-9_1.2.10.0-5.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libav/libav-tools_11.8-1~deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/a/avahi/libavahi-glib1_0.6.31-5_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/a/avahi/libavahi-gobject0_0.6.31-5_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libavc1394/libavc1394-0_0.5.4-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libl/liblivemedia/libbasicusageenvironment0_2014.01.13-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libb/libbluray/libbluray1_0.6.2-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/b/boost1.55/libboost-date-time1.55.0_1.55.0+dfsg-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/b/boost1.55/libboost-system1.55.0_1.55.0+dfsg-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libt/libtool/libltdl7_2.4.2-1.11_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcanberra/libcanberra0_0.30-2.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcanberra/libcanberra-gtk3-0_0.30-2.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcgroup/libcgroup1_0.41-6+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/chromaprint/libchromaprint0_1.2-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/clucene-core/libclucene-core1_2.3.3.4-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/clucene-core/libclucene-contribs1_2.3.3.4-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/suitesparse/libcolamd2.8.0_4.2.1-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgusb/libgusb2_0.1.6-5_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/colord/libcolorhug2_1.2.1-1+b2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups/libcupscgi1_1.7.5-11+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups/libcupsimage2_1.7.5-11+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups-filters/libcupsfilters1_1.0.61-5+deb8u3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups/libcupsppdc1_1.7.5-11+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libs/libssh2/libssh2-1_1.4.3-4.1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/curl/libcurl3-gnutls_7.38.0-4+deb8u5_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libd/libdca/libdca0_0.0.5-7_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/d/dirac/libdirac-encoder0_1.0.2-7.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/d/djvulibre/libdjvulibre-text_3.5.25.4-4_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/d/djvulibre/libdjvulibre21_3.5.25.4-4+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libd/libdv/libdv4_1.0.0-6_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libd/libdvbpsi/libdvbpsi9_1.2.0-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libd/libdvdnav/libdvdnav4_5.0.1-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libe/libebml/libebml4_1.3.0-2+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/e/enca/libenca0_1.16-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/e/emacsen-common/emacsen-common_2.0.8_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/d/dictionaries-common/dictionaries-common_1.23.17_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/h/hunspell-en-us/hunspell-en-us_20070829-6_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/h/hunspell/libhunspell-1.3-0_1.3.3-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/e/enchant/libenchant1c2a_1.6.0-10.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libe/libexif/libexif12_0.6.21-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/faad2/libfaad2_2.7-8_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/firebird2.5/firebird2.5-common-doc_2.5.3.26778.ds4-5_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/firebird2.5/firebird2.5-common_2.5.3.26778.ds4-5_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/firebird2.5/libfbclient2_2.5.3.26778.ds4-5_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/firebird2.5/firebird2.5-server-common_2.5.3.26778.ds4-5_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/firebird2.5/libfbembed2.5_2.5.3.26778.ds4-5_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gcc-4.9/libgomp1_4.9.2-10_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/fftw3/libfftw3-double3_3.3.4-2+rvt_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/flite/libflite1_1.4-release-12_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/fluidsynth/libfluidsynth1_1.1.6-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups-filters/libfontembed1_1.0.61-5+deb8u3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-sysinfo0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libfreerdp-primitives1.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-crt0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-environment0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-handle0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-heap0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-interlocked0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-path0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-thread0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-synch0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-utils0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libfreerdp-utils1.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-pool0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-registry0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libfreerdp-codec1.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-file0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-library0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libfreerdp-common1.1.0_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-crypto0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-sspi0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libfreerdp-crypto1.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-input0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libfreerdp-locale1.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-dsparse0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libwinpr-rpc0.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libfreerdp-core1.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libfreerdp-cache1.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libfreerdp-client1.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libfreerdp-gdi1.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freerdp/libfreerdp-rail1.1_1.1.0~git20140921.1.440916e+dfsg1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/fribidi/libfribidi0_0.19.6-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gcr/libgck-1-0_3.14.0-2+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gconf/libgconf-2-4_3.2.6-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gcr/libgcr-3-common_3.14.0-2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gcr/libgcr-base-3-1_3.14.0-2+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gcr/libgcr-ui-3-1_3.14.0-2+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgd2/libgd3_2.1.0-5+deb8u9_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/geoclue/libgeoclue0_0.12.99-4+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gcc-4.9/libgfortran3_4.9.2-10_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/glew/libglew1.10_1.10.0-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgnome-keyring/libgnome-keyring-common_3.12.0-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgnome-keyring/libgnome-keyring0_3.12.0-1+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgphoto2/libgphoto2-port10_2.5.4-1.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgphoto2/libgphoto2-6_2.5.4-1.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libl/liblivemedia/libgroupsock1_2014.01.13-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gstreamer0.10/libgstreamer0.10-0_0.10.36-1.5_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/i/iso-codes/iso-codes_3.57-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-base0.10/libgstreamer-plugins-base0.10-0_0.10.36-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gstreamer1.0/libgstreamer1.0-0_1.4.4-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-base1.0/libgstreamer-plugins-base1.0-0_1.4.4-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gutenprint/libgutenprint2_5.2.10-3+b3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgxps/libgxps2_0.2.2-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/h/harfbuzz/libharfbuzz-icu0_0.9.35-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libi/libiec61883/libiec61883-0_1.2.0-0.2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libi/libieee1284/libieee1284-3_0.2.11-12_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/i/ijs/libijs-0.35_0.35-10_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libl/liblivemedia/liblivemedia23_2014.01.13-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/l/lua5.2/liblua5.2-0_5.2.3-1.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmatroska/libmatroska6_1.4.1-2+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/mhash/libmhash2_0.9.9.9-7_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/mjpegtools/libmjpegutils-2.1-0_2.1.0+debian-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmms/libmms0_0.6.2-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/mp4v2/libmp4v2-2_2.0.0~dfsg0-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmpc/libmpcdec6_0.1~r459-4.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/mpeg2dec/libmpeg2-4_0.5.1-7_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/mjpegtools/libmpeg2encpp-2.1-0_2.1.0+debian-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/mpg123/libmpg123-0_1.20.1-2+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/mjpegtools/libmplex2-2.1-0_2.1.0+debian-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmtp/libmtp-common_1.1.8-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmtp/libmtp9_1.1.8-1+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libn/libnotify/libnotify4_0.7.6-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/n/nspr/libnspr4_4.12-1+debu8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/n/nss/libnss3_3.26-1+debu8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gcc-4.9/libobjc4_4.9.2-10_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/openal-soft/libopenal-data_1.15.1-5_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/openal-soft/libopenal1_1.15.1-5_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opencore-amr/libopencore-amrnb0_0.1.3-2.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opencore-amr/libopencore-amrwb0_0.1.3-2.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opencv/libopencv-flann2.4_2.4.9.1+dfsg-1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/pangox-compat/libpangox-1.0-0_0.0.2-5_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gtkglext/libgtkglext1_1.2.0-3.2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/v4l-utils/libv4lconvert0_1.6.0-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/v4l-utils/libv4l-0_1.6.0-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opencv/libopencv-highgui2.4_2.4.9.1+dfsg-1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opencv/libopencv-features2d2.4_2.4.9.1+dfsg-1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opencv/libopencv-calib3d2.4_2.4.9.1+dfsg-1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opencv/libopencv-ml2.4_2.4.9.1+dfsg-1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opencv/libopencv-objdetect2.4_2.4.9.1+dfsg-1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opencv/libopencv-video2.4_2.4.9.1+dfsg-1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opencv/libopencv-contrib2.4_2.4.9.1+dfsg-1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/o/opencv/libopencv-legacy2.4_2.4.9.1+dfsg-1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/poppler/libpoppler46_0.26.5-2+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/poppler/libpoppler-glib8_0.26.5-2+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qtbase-opensource-src/libqt5core5a_5.3.2+dfsg-4+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qtbase-opensource-src/libqt5dbus5_5.3.2+dfsg-4+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/x/xcb-util-wm/libxcb-icccm4_0.4.1-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/x/xcb-util/libxcb-util0_0.3.8-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/x/xcb-util-image/libxcb-image0_0.4.0-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/x/xcb-util-keysyms/libxcb-keysyms1_0.4.0-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libx/libxcb/libxcb-randr0_1.10-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/x/xcb-util-renderutil/libxcb-render-util0_0.3.9-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libx/libxcb/libxcb-xkb1_1.10-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libx/libxkbcommon/libxkbcommon-x11-0_0.4.3-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qtbase-opensource-src/libqt5gui5_5.3.2+dfsg-4+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qtbase-opensource-src/libqt5widgets5_5.3.2+dfsg-4+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qtbase-opensource-src/libqt5xml5_5.3.2+dfsg-4+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/poppler/libpoppler-qt5-1_0.26.5-2+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/python3.4/libpython3.4_3.4.2-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qpdf/libqpdf13_5.1.2-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qt4-x11/qtcore4-l10n_4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qt4-x11/libqtcore4_4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qt4-x11/libqt4-xml_4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qtbase-opensource-src/libqt5printsupport5_5.3.2+dfsg-4+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qtbase-opensource-src/libqt5sql5_5.3.2+dfsg-4+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qtbase-opensource-src/libqt5sql5-sqlite_5.3.2+dfsg-4+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qtsvg-opensource-src/libqt5svg5_5.3.2-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qt4-x11/libqtdbus4_4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qt4-x11/libqtgui4_4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/y/yajl/libyajl2_2.1.0-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/r/raptor2/libraptor2-0_2.0.14-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/r/rasqal/librasqal3_0.9.32-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/r/redland/librdf0_1.0.17-1+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/sane-backends/libsane-common_1.0.24-8+deb8u1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/sane-backends/libsane_1.0.24-8+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libw/libwebp/libwebp5_0.4.1-1.2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/sdl-image1.2/libsdl-image1.2_1.2.12-5+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libs/libsecret/libsecret-common_0.18-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libs/libsecret/libsecret-1-0_0.18-1+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/shine/libshine3_3.1.0-2.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libs/libshout/libshout3_2.3.1-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/soundtouch/libsoundtouch0_1.8.0-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/j/jbig2dec/libjbig2dec0_0.11+20120125-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/ghostscript/libgs9-common_9.06~dfsg-2+deb8u4_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/ghostscript/libgs9_9.06~dfsg-2+deb8u4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libs/libspectre/libspectre1_0.2.7-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/speex/libspeexdsp1_1.2~rc1.2-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libs/libssh/libssh-4_0.6.3-4+deb8u2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/startup-notification/libstartup-notification0_0.12-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/t/taglib/libtag1-vanilla_1.9.1-2.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libu/libupnp/libupnp6_1.6.19+git20141001-1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libl/liblivemedia/libusageenvironment1_2014.01.13-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/v4l-utils/libv4l2rds0_1.6.0-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libv/libvisual/libvisual-0.4-0_0.4.0-6_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libv/libvncserver/libvncclient0_0.9.9+dfsg2-6.1+deb8u2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/vo-aacenc/libvo-aacenc0_0.1.3-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/vo-amrwbenc/libvo-amrwbenc0_0.1.3-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/w/wavpack/libwavpack1_4.70.0-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/w/wildmidi/libwildmidi-config_0.3.7-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/w/wildmidi/libwildmidi1_0.3.7-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libx/libxres/libxres1_1.0.7-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libw/libwnck3/libwnck-3-common_3.4.9-3_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libw/libwnck3/libwnck-3-0_3.4.9-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libx/libxcb/libxcb-composite0_1.10-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libx/libxcb/libxcb-xv0_1.10-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/z/zvbi/libzvbi-common_0.2.35-3_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/z/zvbi/libzvbi0_0.2.35-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/n/ntfs-3g/ntfs-3g_2014.2.15AR.2-1+deb8u3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/l/ldb/python-ldb_1.1.20-0+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/samba/samba-common_4.2.14+dfsg-0+deb8u2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/sgml-base/sgml-base_1.26+nmu4_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gnustep-make/gnustep-common_2.6.6-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gnustep-base/gnustep-base-common_1.24.7-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gnustep-base/libgnustep-base1.24_1.24.7-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gnustep-base/gnustep-base-runtime_1.24.7-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/u/unar/unar_1.8.1-3+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libass/libass5_0.10.2-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcdaudio/libcdaudio1_0.99.12p2-13_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/game-music-emu/libgme0_0.5.5-2+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-bad0.10/libgstreamer-plugins-bad0.10-0_0.10.23-7.4+deb8u2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libk/libkate/libkate1_0.4.1-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmimic/libmimic0_1.0.4-2.2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmodplug/libmodplug1_0.8.8.4-4.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libo/libofa/libofa0_0.9.3-7_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/slv2/libslv2-9_0.6.6+dfsg1-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/spandsp/libspandsp2_0.0.6-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/z/zbar/libzbar0_0.10+doc-10+b2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-base0.10/gstreamer0.10-plugins-base_0.10.36-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-bad0.10/gstreamer0.10-plugins-bad_0.10.23-7.4+deb8u2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-bad1.0/libgstreamer-plugins-bad1.0-0_1.4.4-2.1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/sbc/libsbc1_1.2-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/srtp/libsrtp0_1.4.5~20130609~dfsg-1.1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-base1.0/gstreamer1.0-plugins-base_1.4.4-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-bad1.0/gstreamer1.0-plugins-bad_1.4.4-2.1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gettext/gettext-base_0.19.3-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/pciutils/pciutils_3.2.1-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/a/apt/apt-transport-https_1.0.9.8.4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/a/at-spi2-core/at-spi2-core_2.14.0-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcgroup/cgroup-tools_0.41-6+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/colord/colord-data_1.2.1-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/colord/colord_1.2.1-1+b2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/poppler/poppler-utils_0.26.5-2+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups-filters/cups-filters-core-drivers_1.0.61-5+deb8u3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups/cups-core-drivers_1.7.5-11+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gsfonts/gsfonts_8.11+urwcyr1.0.7~pre44-4.2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/ghostscript/ghostscript_9.06~dfsg-2+deb8u4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups/cups-common_1.7.5-11+deb8u1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups/cups-server-common_1.7.5-11+deb8u1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups/cups-client_1.7.5-11+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups/cups-ppdc_1.7.5-11+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups-filters/cups-filters_1.0.61-5+deb8u3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups/cups_1.7.5-11+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups-filters/cups-browsed_1.0.61-5+deb8u3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/x/xml-core/xml-core_0.13+nmu2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/sgml-data/sgml-data_2.0.10_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/d/docbook-xml/docbook-xml_4.5-7.2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/d/dvd+rw-tools/growisofs_7.1-11_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/d/dvd+rw-tools/dvd+rw-tools_7.1-11_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/e/enchant/enchant_1.6.0-10.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gnome-desktop3/gnome-desktop3-data_3.14.1-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gnome-desktop3/libgnome-desktop-3-10_3.14.1-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gnome-icon-theme/gnome-icon-theme_3.12.0-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gnome-icon-theme-symbolic/gnome-icon-theme-symbolic_3.12.0-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/t/texlive-bin/libkpathsea6_2014.20140926.35254-6_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/e/evince/libevdocument3-4_3.14.1-2+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/e/evince/libevview3-3_3.14.1-2+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/n/nautilus/libnautilus-extension1a_3.14.1-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/e/evince/evince-common_3.14.1-2+deb8u1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/e/evince/evince_3.14.1-2+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/fuse-exfat/exfat-fuse_1.1.0-2+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/e/exfat-utils/exfat-utils_1.1.0-2+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/fonts-dejavu/fonts-dejavu-extra_2.34-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/fonts-dejavu/fonts-dejavu_2.34-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/fonts-freefont/fonts-freefont-ttf_20120503-4_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/l/lyx/fonts-lyx_2.1.2-2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/fonts-sil-gentium/fonts-sil-gentium_1.02-13_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/fonts-sil-gentium-basic/fonts-sil-gentium-basic_1.1-7_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/freepats/freepats_20060219-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gconf/gconf-service_3.2.6-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gconf/gconf2_3.2.6-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gcr/gcr_3.14.0-2+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/geoip-database/geoip-database_20150317-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gobject-introspection/libgirepository-1.0-1_1.42.0-2.2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gobject-introspection/gir1.2-glib-2.0_1.42.0-2.2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgtop2/libgtop2-common_2.28.5-2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgtop2/libgtop2-7_2.28.5-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgksu/libgksu2-0_2.0.13~pre1-8_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gksu/gksu_2.0.2-9_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/p11-kit/p11-kit-modules_0.20.7-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/p11-kit/p11-kit_0.20.7-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gnome-keyring/gnome-keyring_3.14.0-1+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/y/yelp/libyelp0_3.14.1-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/y/yelp-xsl/yelp-xsl_3.14.0-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/y/yelp/yelp_3.14.1-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gnome-user-docs/gnome-user-guide_3.14.1-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-good0.10/gstreamer0.10-gconf_0.10.31-3+nmu4+deb8u2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/t/taglib/libtag1c2a_1.9.1-2.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-good0.10/gstreamer0.10-plugins-good_0.10.31-3+nmu4+deb8u2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libs/libsidplay/libsidplay1_1.36.59-6_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/t/twolame/libtwolame0_0.3.13-1.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-ugly0.10/gstreamer0.10-plugins-ugly_0.10.19-2.1+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-base0.10/gstreamer0.10-x_0.10.36-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-base1.0/gstreamer1.0-alsa_1.4.4-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-libav1.0/gstreamer1.0-libav_1.4.4-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-good1.0/gstreamer1.0-plugins-good_1.4.4-2+deb8u2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-ugly1.0/gstreamer1.0-plugins-ugly_1.4.4-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gst-plugins-base1.0/gstreamer1.0-x_1.4.4-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gtk2-engines/gtk2-engines_2.20.2-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gtk+2.0/gtk2-engines-pixbuf_2.24.25-3+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gvfs/gvfs-common_1.22.2-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gvfs/gvfs-libs_1.22.2-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gvfs/gvfs-daemons_1.22.2-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gvfs/gvfs_1.22.2-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/h/hwdata/hwdata_0.267-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/i/icedove/icedove_45.6.0-1~deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/i/icedove/iceowl-extension_45.6.0-1~deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libr/librevenge/librevenge-0.0-0_0.0.1-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libabw/libabw-0.1-1_0.1.0-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/liba/libauthen-sasl-perl/libauthen-sasl-perl_2.1600-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/b/blas/libblas-common_1.2.20110419-10_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcairo-perl/libcairo-perl_1.104-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcanberra/libcanberra-gtk3-module_0.30-2.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcddb/libcddb2_1.3.2-5_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcdr/libcdr-0.1-1_0.1.0-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcmis/libcmis-0.4-4_0.4.1-7_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libe/libe-book/libe-book-0.1-1_0.1.1-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libe/libencode-locale-perl/libencode-locale-perl_1.03-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libe/libeot/libeot0_0.01-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libe/libept/libept1.4.12_1.0.12.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libe/libetonyek/libetonyek-0.1-1_0.1.1-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libe/libexttextcat/libexttextcat-data_3.4.4-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libe/libexttextcat/libexttextcat-2.0-0_3.4.4-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libf/libfile-basedir-perl/libfile-basedir-perl_0.03-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libf/libfile-copy-recursive-perl/libfile-copy-recursive-perl_0.38-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libf/libfile-desktopentry-perl/libfile-desktopentry-perl_0.07-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libt/libtimedate-perl/libtimedate-perl_2.3000-2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libh/libhttp-date-perl/libhttp-date-perl_6.02-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libf/libfile-listing-perl/libfile-listing-perl_6.04-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libf/libfile-mimeinfo-perl/libfile-mimeinfo-perl_0.26-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libf/libfont-afm-perl/libfont-afm-perl_1.20-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libf/libfreehand/libfreehand-0.1-1_0.1.0-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libglib-perl/libglib-perl_1.305-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgltf/libgltf-0.0-0_0.0.2-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgphoto2/libgphoto2-l10n_2.5.4-1.1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libp/libpango-perl/libpango-perl_1.226-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libg/libgtk2-perl/libgtk2-perl_1.2492-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gtk+2.0/libgtk2.0-bin_2.24.25-3+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/t/tomcat6/libservlet2.5-java_6.0.45+dfsg-1~deb8u1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/h/hsqldb1.8.0/libhsqldb1.8.0-java_1.8.0.10+dfsg-3_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libu/liburi-perl/liburi-perl_1.64-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libh/libhtml-tagset-perl/libhtml-tagset-perl_3.20-2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libh/libhtml-parser-perl/libhtml-parser-perl_3.71-1+b4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libi/libio-html-perl/libio-html-perl_1.001-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libl/liblwp-mediatypes-perl/liblwp-mediatypes-perl_6.02-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libh/libhttp-message-perl/libhttp-message-perl_6.06-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libh/libhtml-form-perl/libhtml-form-perl_6.03-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libh/libhtml-tree-perl/libhtml-tree-perl_5.03-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libh/libhtml-format-perl/libhtml-format-perl_2.11-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libh/libhttp-cookies-perl/libhttp-cookies-perl_6.01-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libh/libhttp-daemon-perl/libhttp-daemon-perl_6.01-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libh/libhttp-negotiate-perl/libhttp-negotiate-perl_6.00-2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/h/hyphen/libhyphen0_2.8.8-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libn/libnet-ssleay-perl/libnet-ssleay-perl_1.65-1+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libi/libio-socket-ssl-perl/libio-socket-ssl-perl_2.002-2+deb8u2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcdio/libiso9660-8_0.83-4.2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libl/liblangtag/liblangtag-common_0.5.1-3_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libl/liblangtag/liblangtag1_0.5.1-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/l/lapack/liblapack3_3.5.0-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/l/lirc/liblircclient0_0.9.0~pre1-1.2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libn/libnet-http-perl/libnet-http-perl_6.07-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libw/libwww-robotrules-perl/libwww-robotrules-perl_6.01-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libw/libwww-perl/libwww-perl_6.08-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libl/liblwp-protocol-https-perl/liblwp-protocol-https-perl_6.06-2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libn/libnet-smtp-ssl-perl/libnet-smtp-ssl-perl_1.01-3_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmailtools-perl/libmailtools-perl_2.13-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmspub/libmspub-0.1-1_0.1.1-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmtp/libmtp-runtime_1.1.8-1+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmwaw/libmwaw-0.3-3_0.3.1-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/mythes/libmythes-1.2-0_1.2.4-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/n/neon27/libneon27-gnutls_0.30.1-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libx/libxml-parser-perl/libxml-parser-perl_2.41-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libx/libxml-twig-perl/libxml-twig-perl_3.48-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libn/libnet-dbus-perl/libnet-dbus-perl_1.0.0-2+b2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libo/libodfgen/libodfgen-0.1-1_0.1.1-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libo/liborcus/liborcus-0.8-0_0.7.0+dfsg-9_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gnome-keyring/libpam-gnome-keyring_3.14.0-1+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libp/libpaper/libpaper-utils_1.1.24+nmu4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libp/libperl4-corelibs-perl/libperl4-corelibs-perl_0.003-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libp/libpostproc/libpostproc52_0.git20120821-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libp/libproxy/libproxy-tools_0.4.11-4_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qtchooser/qtchooser_47-gd2b7997-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qt4-x11/qdbus_4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qt4-x11/libqt4-dbus_4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/l/lp-solve/lp-solve_5.5.0.13-7+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/coinutils/coinor-libcoinutils3_2.9.15-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/coinor-osi/coinor-libosi1_0.106.9-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/clp/coinor-libclp1_1.15.10-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/coinor-cgl/coinor-libcgl1_0.58.9-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/coinor-cbc/coinor-libcbc3_2.8.12-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/coinmp/coinor-libcoinmp1_1.7.6+dfsg1-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libw/libwps/libwps-0.3-3_0.3.0-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libv/libvisio/libvisio-0.1-1_0.1.0-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libw/libwpd/libwpd-0.10-10_0.10.0-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libw/libwpg/libwpg-0.3-3_0.3.0-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/sidplay-libs/libresid-builder0c2a_2.1.1-14_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/sane-backends-extras/libsane-extras-common_1.0.22.3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/sane-backends-extras/libsane-extras_1.0.22.3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/sidplay-libs/libsidplay2_2.1.1-14_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libt/libtie-ixhash-perl/libtie-ixhash-perl_1.23-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/vcdimager/libvcdinfo0_0.7.24+dfsg-0.2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libv/libvisual-plugins/libvisual-0.4-plugins_0.4.0.dfsg.1-7_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/vlc/vlc-data_2.2.4-1~deb8u1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/vlc/libvlccore8_2.2.4-1~deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/vlc/libvlc5_2.2.4-1~deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/vte3/libvte-2.90-common_0.36.3-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/vte3/libvte-2.90-9_0.36.3-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libx/libx11-protocol-perl/libx11-protocol-perl_0.56-6_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libx/libxml-xpathengine-perl/libxml-xpathengine-perl_0.13-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/n/ncompress/ncompress_4.2.4.4-9_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/n/notification-daemon/notification-daemon_0.7.6-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/squeak-vm/squeak-vm_4.10.2.2614-1.1+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/squeak-plugins-scratch/squeak-plugins-scratch_1.4.0.2~svn.r83-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/scratch/scratch_1.4.0.6~dfsg1-5_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/p7zip/p7zip-full_9.20.1~dfsg.1-4.1+deb8u2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/policykit-1-gnome/policykit-1-gnome_0.105-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gutenprint/printer-driver-gutenprint_5.2.10-3+b3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/python-crypto/python-crypto_2.6.1-5+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/pygobject/python-gi_3.14.0-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/n/ntdb/python-ntdb_1.0-5_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/t/tdb/python-tdb_1.3.6-0+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/samba/python-samba_4.2.14+dfsg-0+deb8u2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/d/dbus-python/python3-dbus_1.2.0-2+b1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/p/pygobject/python3-gi_3.14.0-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/software-properties/python3-software-properties_0.92.25debian1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qjackctl/qjackctl_0.3.12-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qpdf/qpdf_5.1.2-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qpdfview/qpdfview_0.4.12-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qpdfview/qpdfview-djvu-plugin_0.4.12-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qpdfview/qpdfview-ps-plugin_0.4.12-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qpdfview/qpdfview-translations_0.4.12-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/q/qttranslations-opensource-src/qttranslations5-l10n_5.3.2-2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/r/rsync/rsync_3.1.1-3_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/samba/samba-common-bin_4.2.14+dfsg-0+deb8u2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/u/update-inetd/update-inetd_4.43_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/sane-backends/sane-utils_1.0.24-8+deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/software-properties/software-properties-common_0.92.25debian1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/synaptic/synaptic_0.81.2+rpi1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/t/twolame/twolame_0.3.13-1.1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/u/unrar-free/unrar-free_0.0.1+cvs20140707-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/v4l-utils/v4l-utils_1.6.0-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/vlc/vlc-nox_2.2.4-1~deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/vlc/vlc_2.2.4-1~deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/vlc/vlc-plugin-notify_2.2.4-1~deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/v/vlc/vlc-plugin-samba_2.2.4-1~deb8u1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/x/xdg-utils/xdg-utils_1.1.0~rc1+git20111210-7.4_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/x/xfonts-encodings/xfonts-encodings_1.0.4-2_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/x/xfonts-utils/xfonts-utils_7.7+2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/z/zenity/zenity-common_3.14.0-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/z/zenity/zenity_3.14.0-1_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/z/zip/zip_3.0-8_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/z/zoo/zoo_2.10-27_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libc/libcgroup/cgroup-bin_0.41-6+rpi1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/f/fonts-stix/fonts-stix_1.1.1-1_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/gdisk/gdisk_0.8.10-2_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/r/rarian/librarian0_0.8.1-6_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/r/rarian/rarian-compat_0.8.1-6_armhf.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/x/xfonts-mathml/xfonts-mathml_6_all.deb Unable to connect to mirror.nbtelecom.com.br:http:
E: Some files failed to download
Error: Packages couldn't be retreived.
#7 2017-02-24 15:01
rafaelramos
Re: Error 70 when install Full Profile in 1.8.2 version on Raspberry Pi 3
There are known occassional issues with 'mirror.nbtelecom.com.br' Raspbian mirror, see for example https://www.raspberrypi.org/forums/view … 6&t=142736 . Unfortunately this is completely outside of Q4OS, you could report a Raspbian bug here https://bugs.launchpad.net/raspbian
Thanks, I will see this issue...
#8 2017-02-27 08:04
If the mirror 'mirror.nbtelecom.com.br' still fails, you could manually change the apt mirror repository in the '/etc/apt/sources.list' file. Modify line:
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
to:
deb http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
You can find list of alternative mirrors here https://www.raspbian.org/RaspbianMirrors
#9 2017-02-28 20:26
rafaelramos
Thanks for the sugestion.
I will test it when I return to work on 2017-03-06, and post the result here.
Greetings.
#10 2017-03-03 18:49
rafaelramos
to:
It worked !!! big_smile
I edited the "sources.list" file, and replaced the problematic "mirrordirector" with the mirror of the Federal University of Paraná (ftp://raspbian.c3sl.ufpr.br/raspbian/raspbian/), one of the best free software development agencies in Brazil...
Desktop Profiler is now updating correctly and with great speed!
Thank you guys!
