#1 2017-02-18 01:55
Off-line Installation updates (Scorpion 2.3)
I have a machine that is off-line (no internet connection at all) and wanted to be able to install packages easily and thought I would try apt-offline as it seems to be the right tool.
I started by copying the required .deb file and dependencies to get apt-offline installed using dpkg, which went well and I now have it working on isolated system.
I created the (apt-offline) signature file for update and then downloaded them using the signature file on another machine, this gave many warnings but appeared to download the files I needed.
I then "installed" them onto the isolated machine using apt-offline install (I used a bundle file). I expected to be able to now install packages by creating a new signature file but when attempting to create it I get Unable to locate package XYZ.
I was wondering if this might have something to do with the fact that I have not been able to install the language-pack (due to no internet available).
It could also be that I have done something wrong or not done something that I should have (wouldn't be the first time smile )
Any ideas?
#2 2017-02-18 14:45
Re: Off-line Installation updates (Scorpion 2.3)
I just set-up a Virtualbox installation without networking and I have managed to get it working... I'm not sure what I have done differently but will re-install the off-line machine and try again.
#3 2017-02-18 17:02
Ok I think I found out what I did wrong and thought I would share it in case it helps anyone else.
First some background...
I wanted to set-up Scorpion on a machine that is not connected by cable and the wireless card I have available does not work out of the box. In order to use the wireless card I have to install the fixed firmware from github which is a problem when you cannot  update the system and then install the required packages to add the firmware. My solution was to update the system by using apt-offline to initially populate apt with the correct up-to-date information and then install some packages (dkms, build-essential, linux-headers) in order to use my wifi card.
To install apt-offline I had to copy some deb-files from my working machine onto USB and then install them onto the non-networked machine. The packages needed for a fresh Scorpion installation are as follows:-
  1. python-wstools
  2. python-defusedxml
  3. python-soappy
  4. python-magic
  5. python-lzma
  6. apt-offline
Then install them using sudo dpkg -i package_name (order can be important!)
Now apt-offline is installed and you will need to run it according to the useful debian handbook instructions.
I first performed an update, then a dist-upgrade, and then installed my extra packages.
Now I could get everything I needed installed and am typing from my "problem" machine which now has working wifi smile
One reason I am posting is to allow anyone with a problematic wifi card get their system installed, updated and allow new packages to be installed until they find a resolution for wifi problem. Hopefully this will help some one.
