#1 2015-12-26 10:22
Seeker
How to install an Offical TeamViewer 11.0(32 bits) on Q4OS 64 bits
For anyone who want to run TeamViewer 11.0 on Q4OS.
Video Tutorials:
https://www.youtube.com/watch?v=OhgRqC7 … e=youtu.be
I suggest watch the VDO together with what I've write in this thread to understand the VDO tutorial together.
Before able to run this software don't forget to:
1. Have Gdebi installer to install this .deb installer.
    If you don't have yet install it from synaptic or open terminal & type:
    sudo apt-get install gdebi
2. Then go to this page to download the official installer:
https://www.teamviewer.com/en/download/linux.aspx
3. Once download before to install don't forget to open terminal unlock i386 architect with 2 sudo spell:
sudo dpkg --add-architecture i386
sudo apt-get update
4. Once done install it with Gdebi & it'll install.
5. If it's error missing libjpeg32 file like from my video. Get back to terminal & type
sudo apt-get install -f
& it'll install the missing dependency libjpeg32
After that now you can run TeamViewer from your start menu at
Programs>Accessories>Internet>TeamViewer
Note: If you've stuck can't closed Gdebi. Just logout & login to get back or restart your PC.
PS. I may still green, clumsy person & trip over on screencasting skills. So don't be harsh on me.
      But my methods effectively worked!
#2 2015-12-26 11:17
Re: How to install an Offical TeamViewer 11.0(32 bits) on Q4OS 64 bits
Q4OS official TeamViewer installer is now updated to the latest version 11.0.53191, everyone can install easily from Q4OS Software Centre.
#3 2015-12-26 16:34
Seeker
Thank you! big_smile
#4 2015-12-26 21:36
bobby
Pat on back smile very glad to help.
crosscut,  do have a question for you on this above install procedure.
Can your install procedure above be used for other debian jessee compiled .deb files ?
No Longer Using Q4OS
#5 2015-12-27 01:41
bobby
cc, Thanks for shortcuts smile
