#1 2016-10-21 19:25
ThisGuy1996
No connection after install
I just installed Q4OS on a desktop. Now it won't connect to network. It detects network, but won't connect. I get an error saying "Secrets were not found" or something like that.
#2 2016-10-21 20:16
ThisGuy1996
Re: No connection after install
Okay I got internet working and was able to update nvidia drivers. But now after reboot the display is small. went to display and the max size is 640 x 480! My screen is not that small! It's hooked up to a monitor.
#3 2016-10-21 22:28
Was the screen small before you installed/updated the nvidia drivers?
#4 2016-10-22 01:45
ThisGuy1996
No, but it is slightly blurry. Now thing are taking forever to load(login screen, desktop, etc.) they just don't load
#5 2016-10-22 08:16
could you post the results of inxi -F you might need to install inxi if you haven't already.
#6 2016-10-22 13:50
ThisGuy1996
I can't because it won't get to the login screen.
#7 2016-10-22 13:57
ThisGuy1996
I'm going to reinstall Q4OS and then will install inxi
#8 2016-10-22 14:10
OK, dont install video drivers yet in case they are the cause of the problem. smile
#9 2016-10-22 14:33
ThisGuy1996
Okay. Right now I'm just waiting for the login screen to show up. It just shows the mouse cursor loading.
#10 2016-10-22 15:39
Is that the new install?
#11 2016-10-22 15:41
ThisGuy1996
Yes. It has not even boot up to the login yet..
#12 2016-10-22 18:08
That is pointing the finger at hardware failure maybe?? did the live-cd run ok?
#13 2016-10-22 18:21
ThisGuy1996
There was no live option in the install menu.
#14 2016-10-22 19:12
Sorry I always use the live-cd for my installs, could you download and try using the live-cd to see if that works?
#15 2016-10-23 01:09
ThisGuy1996
Where do I download the live CD?
#16 2016-10-23 08:00
http://q4os.org/downloads1.html
half way down the page
#17 2016-10-23 14:57
ThisGuy1996
Ah, Okay. Thanks I will download that
#18 2016-10-23 15:35
ThisGuy1996
The live cd is stuck on the three dots loading screen, won't go past that.
#19 2016-10-23 15:46
This does have the hallmarks of a hardware issue of some sort, I wonder if it is a 32 bit box and you're using a 64 bit medium. I came across a range of Dells in the 2006 ish period that would run 64bit Windows but no way would they go 64 bit linux - at the time. Granted this seem unlikely as you've already had an install work.
So, please can you tell us more about the machine - make, model, age, amount of memory etc. You can get some valuable info by accessing the BIOS screen if you don't know about the RAM figure. It would also help to know if it has a sound card and network card or whether these are just off the motherboard. You can tell if they are separate cards as they'll occupy a slot in the rear of the machine.
It may just be worth you while trying a 32 bit live cd as well. How are you burning these, and do you check the md5sum values of the downloads to ensure they are good?
#20 2016-10-23 15:50
I still think this is pointing towards hardware failure, the only other thing I would do is to try another live-cd, maybe ubuntu and see if that will boot.
And one more thing to check, have you changed or reset bios settings at all? if not check to see if any values have changed or don't look right, and if you have changed anything try changing it back and see how that goes.
#21 2016-10-24 00:11
ThisGuy1996
I resetted the BIOS. That didn't work. I had tried the 32-bit live cd, and that didn't work either. Here is a full list of specs on the desktop:
Brand
    eMachines
Model
    EL1333G-01W (PT.NBG02.001)
Quick Info
Type
    Student / Home Office
Processor
    AMD Athlon 2850e 1.8GHz
Cache Per Processor
    512 KB L2 Cache
Memory
    2GB DDR2
Storage
    320GB 7200RPM SATA
Optical Drive
    16X DVD Super Multi Double-Layer Drive
Graphics
    NVIDIA GeForce 6150 SE integrated graphics
Ethernet
    Gigabit Ethernet
Power Supply
    220W
Operating System
    Windows 7 Home Premium 64-Bit
CPU
CPU Type
    Athlon
CPU Speed
    2850e (1.8 GHz)
L2 Cache Per CPU
    512 KB
Graphics
GPU/VGA Type
Graphics Interface
    Integrated video
Memory
Memory Capacity
    2 GB DDR2
Memory Spec
    1 GB x 2
Maximum Memory Supported
    4 GB
Hard Drive
HDD
    320 GB
HDD Interface
    SATA
HDD RPM
    7200rpm
Optical Drive
Optical Drive Type
    DVD Super Multi
Optical Drive Spec
Communications
LAN Speed
    10/100/1000Mbps
Front Panel Ports
Front USB
    2
Front Audio Ports
    2
Card Reader
    Multi-in-1 Digital Media Card Reader
Back Panel Ports
PS/2
    2
Video Ports
    1 VGA
Rear USB
    4
RJ45
    1 port
Rear Audio Ports
    5 ports
#22 2016-10-24 06:30
Well, in theory that should work....though the single core cpu will never be a flyer.
If you still have the bootable media that gave you the original install that sort of worked, then use that again.
When you get to the boot options use Recovery Mode and enter nomodeset at the end of the string. That should boot with a basic vesa driver for graphics.
You may need to use nomodeset xforcevesa if the above doesn't help.
If that works then at least you're on the right track to getting a working machine.
#23 2016-10-24 12:15
ThisGuy1996
You mean the OS that came with the desktop originally? Or the first Q4OS install that worked?
#24 2016-10-24 12:26
The first Q4OS that worked.
#25 2016-10-24 13:04
ThisGuy1996
Okay, i'll see how this works...
