#1 2016-09-08 19:48
ThisGuy1996
Anyone know how to aquire basicstyle widget style?
Anyone know how to aquire basicstyle.la widget style? I have some old themes but can't use them due to not having "basicstyle.la".
I see that its a plugin for widgets styles to use pixmaps in themes. I know that it was built in KDE ever since 3.2. I don't know where to find it. Its not in the repos either. I've searched and found nothing. Can anyone tell me where to get this plugin?
#2 2016-10-07 22:09
ThisGuy1996
Re: Anyone know how to aquire basicstyle widget style?
Update: Alright so I got it to show up, but it ends up looking like this(attached) What did I do wrong?
#3 2016-10-08 09:08
I'm not sure I can see what the problem is here, so I am also probably not the best person to answer your question but I cannot find the screen to which you have posted a screenshot. Where can it be found?
#4 2016-10-11 16:28
ThisGuy1996
It should be in the attachment section Under my post above. Okay, after searching, I found kdelibs 2.1 rpm package from rpmbone.net. Using alien, I extracted the files to a folder, took basicstyle.la out, and placed it in the system folder. So that works. The theme, however, doesn't generate the pixmaps needed because kthemeinstall is missing "kdeui.4.so", so the theme shows up, and is fully functional, without the pixmap generated. So It looks like the screenshot attached.
