#1 2016-10-07 19:50
jaws222
Sound effects
After downloading the latest update I noticed there were some really coo sound effects.  I changed the Look Switcher and they seemed to have gone away.  I went into the Sound settings but could not get the sounds back.  Am I in the right area?  Are there different sound effects with different desktops or are they all the same?
#2 2016-10-07 21:01
Re: Sound effects
You could check your sound is working correctly by following the instructions HERE. If everything is fine you should go to Settings->Control Centre->Sound & Multimedia->System Notifications and you can set the sounds to the ones you want.
AFAIK the sounds usually remain the same when you change desktop with look switcher, but I haven't checked.
HTH
#3 2016-10-07 21:14
Re: Sound effects
jaws222 wrote:
... I changed the Look Switcher and they seemed to have gone away.
We are not able to reproduce, sounds keep to work fine, even if the look has been changed using Lookswitcher. Could you report more exact steps to reproduce the issue, please ?
#4 2016-10-07 21:15
jaws222
Re: Sound effects
Thanks.  I'll give that a shot when I get home.
It is an Awesome OS by the way.
