#1 2016-10-07 02:04
Howard
Q4OS on an ARM Android
Has anyone ever tried to use QEMU to run Q4OS on an ARM Android tablet? If so, where can I find the installation instructions. Please make'em really simple and very basic!!!
#2 2016-10-07 07:35
Re: Q4OS on an ARM Android
Please read http://www.q4os.org/dqa012.html first.
ARM port of Q4OS runs fine under QEMU, the recommended QEMU options to run Q4OS are as follows:
qemu-system-arm -kernel zImage-vexpress -m 768 -M vexpress-a9 -no-reboot -serial stdio -append "root=/dev/mmcblk0p2 panic=0 rootfstype=ext4 rw" -dtb vexpress-v2p-ca9.dtb -net nic -net bridge,br=br0,helper=/usr/lib/qemu/qemu-bridge-helper -sd your_sd_image.img
#3 2018-07-05 10:45
lucbertz
Does anybody tried to run a version of Q4OS on a TV Box (like H96, X96, T95Z) based on Amlogic S905 or S912?
What about reliability, performance and drivers support?
I'd like to buy one of these already packed device for simple browsing, office suite, music and web video play and try to use it with something different from Android.
Thank you in advance for a reply.
less is more
