I'm not knocking it but this is one of the reasons I do not like using KDE, too many dependencies, and it installs too many programs by default. Yes, I know large hard drives are cheap but still, I prefer a lean OS. I know most of them are small in size. All this just to add kgpg?
$ sudo apt-get install kgpg
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
akonadi-backend-mysql akonadi-server docbook-xsl kate-data katepart
kde-runtime kde-runtime-data kdelibs-bin kdelibs5-data kdelibs5-plugins
kdepim-runtime kdepimlibs-kio-plugins kdoctools libakonadi-calendar4
libakonadi-contact4 libakonadi-kabc4 libakonadi-kcal4 libakonadi-kde4
libakonadi-kmime4 libakonadi-notes4 libakonadiprotocolinternals1
libattica0.4 libboost-program-options1.55.0 libboost-thread1.55.0
libdbusmenu-qt2 libdlrestrictions1 libdmtx0a libfam0 libgpgme++2 libiodbc2
libkabc4 libkactivities-bin libkactivities-models1 libkactivities6
libkalarmcal2 libkatepartinterfaces4 libkcal4 libkcalcore4 libkcalutils4
libkcmutils4 libkde3support4 libkdeclarative5 libkdecore5 libkdesu5
libkdeui5 libkdewebkit5 libkdnssd4 libkemoticons4 libkfile4 libkgapi2-2
libkholidays4 libkhtml5 libkimap4 libkio5 libkjsapi4 libkjsembed4 libkldap4
libkmbox4 libkmediaplayer4 libkmime4 libknewstuff3-4 libknotifyconfig4
libkntlm4 libkolab0 libkolabxml1 libkparts4 libkpimidentities4
libkpimtextedit4 libkpimutils4 libkpty4 libkresources4 libkrosscore4
libktexteditor4 libkxmlrpcclient4 libmailtransport4 libmicroblog4
libnepomuk4 libnepomukcore4 libnepomukquery4a libnepomukutils4
libntrack-qt4-1 libntrack0 libphonon4 libplasma3 libpolkit-qt-1-1 libprison0
libpulse-mainloop-glib0 libqca2 libqjson0 libqrencode3 libqt4-qt3support
libsolid4 libsoprano4 libssh-gcrypt-4 libstreamanalyzer0 libstreams0
libthreadweaver4 libupower-glib3 libutempter0 libxerces-c3.1 libxml2-utils
mysql-server-core-5.5 nepomuk-core-data ntrack-module-libnl-0
oxygen-icon-theme phonon phonon-backend-vlc plasma-scriptengine-javascript
soprano-daemon upower
Suggested packages:
akonadi-backend-postgresql akonadi-backend-sqlite dbtoepub
docbook-xsl-doc-html docbook-xsl-doc-pdf docbook-xsl-doc-text
docbook-xsl-doc docbook-xsl-saxon fop libsaxon-java libxalan2-java
libxslthl-java xalan djvulibre-bin finger icoutils libcanberra-pulse
sound-theme-freedesktop fam iodbc hspell libqca2-plugin-cyrus-sasl
libqca2-plugin-gnupg libqca2-plugin-ossl media-player-info
phonon-backend-gstreamer phonon-backend-mplayer virtuoso-minimal
kdepim-runtime kdepimlibs-kio-plugins kdoctools kgpg libakonadi-calendar4
0 upgraded, 111 newly installed, 0 to remove and 0 not upgraded.
Need to get 76.7 MB of archives.
After this operation, 218 MB of additional disk space will be used.
Do you want to continue? [Y/n] n
Abort.
$ sudo apt-get install --no-install-recommends kgpg
kdelibs5-plugins kdepim-runtime kdepimlibs-kio-plugins kdoctools
libakonadi-calendar4 libakonadi-contact4 libakonadi-kabc4
libakonadi-kcal4 libakonadi-kde4 libakonadi-kmime4 libakonadi-notes4
libakonadiprotocolinternals1 libattica0.4
libboost-program-options1.55.0 libboost-thread1.55.0 libdbusmenu-qt2
libdlrestrictions1 libdmtx0a libfam0 libgpgme++2 libiodbc2 libkabc4
libkactivities6 libkalarmcal2 libkatepartinterfaces4 libkcal4
libkcalcore4 libkcalutils4 libkcmutils4 libkde3support4
libkdeclarative5 libkdecore5 libkdesu5 libkdeui5 libkdewebkit5
libkdnssd4 libkemoticons4 libkfile4 libkgapi2-2 libkholidays4
libknotifyconfig4 libkntlm4 libkolab0 libkolabxml1 libkparts4
libkpimidentities4 libkpimtextedit4 libkpimutils4 libkpty4
libkresources4 libkrosscore4 libktexteditor4 libkxmlrpcclient4
libmailtransport4 libmicroblog4 libnepomuk4 libnepomukquery4a
libnepomukutils4 libntrack-qt4-1 libntrack0 libphonon4 libplasma3
libpolkit-qt-1-1 libprison0 libpulse-mainloop-glib0 libqca2
libqjson0 libqrencode3 libqt4-qt3support libsolid4 libsoprano4
libssh-gcrypt-4 libstreamanalyzer0 libstreams0 libthreadweaver4
libutempter0 libxerces-c3.1 libxml2-utils mysql-server-core-5.5
ntrack-module-libnl-0 oxygen-icon-theme phonon phonon-backend-vlc
plasma-scriptengine-javascript soprano-daemon
Suggested packages:
Recommended packages:
libkactivities-bin upower
kgpg libakonadi-calendar4 libakonadi-contact4 libakonadi-kabc4
0 upgraded, 105 newly installed, 0 to remove and 0 not upgraded.
Need to get 76.1 MB of archives.
After this operation, 215 MB of additional disk space will be used.
Abort.
Dell Optiplex 760 - Quad Core | 4gb | 250gb | Mageia 5, Salix 14.2, Q4OS
Lenovo Thinkpad T420 | 4gb | 120gb | Mageia 5, Debian Testing
Try kgpg-trinity
dai@q4os-desktop:~$ sudo apt-get -s install kgpg-trinity
kgpg-trinity
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Inst kgpg-trinity (4:14.0.3-0debian8.0.0+0 Q4OS TDE repository:8.0/qtde-jessie-st [amd64])
Conf kgpg-trinity (4:14.0.3-0debian8.0.0+0 Q4OS TDE repository:8.0/qtde-jessie-st [amd64])Last edited by Dai_trying (2016-10-02 19:44)
Thanks, Dai_trying. I guess adding -trinity at the end makes a difference. I need to get used to how Trinity works.
You're welcome, you have to remember it's Trinity desktop not KDE, even though it is obviously based on KDE it's not quite the same. ![]()
Hi Dai, can you give me the reference page where i can see the dual boot installation win/ q4os? ( for make partitions and installing) thanks!
The main site is dsbnet.tk and you can select from either drop down or navigation menu for partitioning or installation etc. ![]()
