#1 2016-09-21 09:52
ggc
Q4os 2.2
Tried on 2 machines, i report here what i've found:
First one a Dell Inspiron 530, after loading the desktop the screen continues to blink, unusable.
System data using lubuntu:
inxi -F
System:    Host: dell Kernel: 3.13.0-76-generic x86_64 (64 bit) Desktop: LXDE (Openbox 3.5.2) Distro: Ubuntu 14.04 trusty
Machine:   System: Dell product: Inspiron 530
           Mobo: Dell model: 0K216C Bios: Dell version: 1.0.18 date: 02/24/2009
CPU:       Dual core Intel Core2 Duo CPU E8600 (-MCP-) cache: 6144 KB flags: (lm nx sse sse2 sse3 sse4_1 ssse3 vmx)
           Clock Speeds: 1: 1998.00 MHz 2: 1998.00 MHz
Graphics:  Card: Intel 82G33/G31 Express Integrated Graphics Controller
           X.Org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1680x1050@59.9hz
           GLX Renderer: Mesa DRI Intel G33 GLX Version: 1.4 Mesa 10.1.3
Audio:     Card: Intel 82801I (ICH9 Family) HD Audio Controller driver: snd_hda_intel Sound: ALSA ver: k3.13.0-76-generic
Network:   Card: Intel 82562V-2 10/100 Network Connection driver: e1000e
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: 00:1e:c9:6e:6c:6a
Sensors:   System Temperatures: cpu: 40.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
#2 2016-09-21 09:59
ggc
Re: Q4os 2.2
Acer Aspire One: seems to work fine but touchpad not working
lspci
00:00.0 Host bridge: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx DMI Bridge
	Subsystem: Acer Incorporated [ALI] Device 0349
	Flags: bus master, fast devsel, latency 0
	Capabilities: [e0] Vendor Specific Information: Len=08 <?>
	Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller (prog-if 00 [VGA controller])
	Flags: bus master, fast devsel, latency 0, IRQ 28
	Memory at 98180000 (32-bit, non-prefetchable) [size=512K]
	I/O ports at 60c0 [size=8]
	Memory at 80000000 (32-bit, prefetchable) [size=256M]
	Memory at 98000000 (32-bit, non-prefetchable) [size=1M]
	Expansion ROM at <unassigned> [disabled]
	Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [d0] Power Management version 2
	Kernel driver in use: i915
00:02.1 Display controller: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller
	Memory at 98100000 (32-bit, non-prefetchable) [size=512K]
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 02)
	Flags: bus master, fast devsel, latency 0, IRQ 27
	Memory at 98200000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [50] Power Management version 2
	Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
	Capabilities: [100] Virtual Channel
	Capabilities: [130] Root Complex Link
	Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 02) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 00005000-00005fff
	Memory behind bridge: 97000000-97ffffff
	Prefetchable memory behind bridge: 0000000090000000-0000000090ffffff
	Capabilities: [40] Express Root Port (Slot+), MSI 00
	Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [90] Subsystem: Acer Incorporated [ALI] Device 0349
	Capabilities: [a0] Power Management version 2
	Capabilities: [180] Root Complex Link
	Kernel driver in use: pcieport
00:1c.1 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 2 (rev 02) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: 00004000-00004fff
	Memory behind bridge: 96000000-96ffffff
	Prefetchable memory behind bridge: 0000000091000000-0000000091ffffff
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 02) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 18
	I/O ports at 6080 [size=32]
	Kernel driver in use: uhci_hcd
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 02) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 20
	I/O ports at 6060 [size=32]
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 02) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 21
	I/O ports at 6040 [size=32]
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 02) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 22
	I/O ports at 6020 [size=32]
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 02) (prog-if 20 [EHCI])
	Memory at 98204400 (32-bit, non-prefetchable) [size=1K]
	Capabilities: [58] Debug port: BAR=1 offset=00a0
	Kernel driver in use: ehci-pci
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2) (prog-if 01 [Subtractive decode])
	Bus: primary=00, secondary=05, subordinate=05, sec-latency=32
	Capabilities: [50] Subsystem: Acer Incorporated [ALI] Device 0349
00:1f.0 ISA bridge: Intel Corporation NM10 Family LPC Controller (rev 02)
	Capabilities: [e0] Vendor Specific Information: Len=0c <?>
	Kernel driver in use: lpc_ich
00:1f.2 SATA controller: Intel Corporation NM10/ICH7 Family SATA Controller [AHCI mode] (rev 02) (prog-if 01 [AHCI 1.0])
	Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 26
	I/O ports at 60b8 [size=8]
	I/O ports at 60cc [size=4]
	I/O ports at 60b0 [size=8]
	I/O ports at 60c8 [size=4]
	I/O ports at 60a0 [size=16]
	Memory at 98204000 (32-bit, non-prefetchable) [size=1K]
	Capabilities: [70] Power Management version 2
	Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 02)
	Flags: medium devsel, IRQ 17
	I/O ports at 6000 [size=32]
	Kernel driver in use: i801_smbus
01:00.0 Ethernet controller: Qualcomm Atheros AR8152 v2.0 Fast Ethernet (rev c1)
	Flags: bus master, fast devsel, latency 0, IRQ 29
	Memory at 97000000 (64-bit, non-prefetchable) [size=256K]
	I/O ports at 5000 [size=128]
	Capabilities: [40] Power Management version 3
	Capabilities: [48] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [58] Express Endpoint, MSI 00
	Capabilities: [6c] Vital Product Data
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [180] Device Serial Number ff-a2-d0-fa-b8-70-f4-ff
	Kernel driver in use: atl1c
02:00.0 Network controller: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) (rev 01)
	Subsystem: Lite-On Communications Inc Device 6631
	Flags: bus master, fast devsel, latency 0, IRQ 17
	Memory at 96000000 (64-bit, non-prefetchable) [size=64K]
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit-
	Capabilities: [60] Express Legacy Endpoint, MSI 00
	Capabilities: [140] Virtual Channel
	Capabilities: [160] Device Serial Number 00-15-17-ff-ff-24-14-12
	Capabilities: [170] Power Budgeting <?>
	Kernel driver in use: ath9k
$ inxi -F
System:    Host: aspire Kernel: 4.4.10-antix.1-amd64-smp x86_64 (64 bit)
           Desktop: IceWM 1.3.8
           Distro: antiX-16_x64-full Berta Cáceres 26 June 2016
Machine:   System: Acer (portable) product: AOD255 v: V3.15_Vodafone(DDR3)
           Mobo: Acer model: JE02_PT v: V3.15_Vodafone(DDR3)
           Bios: Acer v: V3.15_Vodafone(DDR3) date: 02/15/2011
Battery    BAT0: charge: 22.6 Wh 79.0% condition: 28.6/44.0 Wh (65%)
CPU:       Single core Intel Atom N455 (-HT-) cache: 512 KB
           clock speeds: max: 1666 MHz 1: 1666 MHz 2: 1666 MHz
Graphics:  Card: Intel Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller
           Display Server: X.Org 1.16.4 driver: intel
           Resolution: 1024x600@60.03hz
           GLX Renderer: Mesa DRI Intel IGD GLX Version: 2.1 Mesa 10.3.2
Audio:     Card Intel NM10/ICH7 Family High Definition Audio Controller
           Sound: ALSA v: k4.4.10-antix.1-amd64-smp
Network:   Card-1: Qualcomm Atheros AR8152 v2.0 Fast Ethernet driver: atl1c
           IF: eth0 state: down mac: b8:70:f4:a2:d0:fa
           Card-2: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express)
           driver: ath9k
           IF: wlan0 state: down mac: d0:df:9a:28:77:44
Drives:    HDD Total Size: 250.1GB (7.1% used)
           ID-1: /dev/sda model: ST9250315AS size: 250.1GB
Sensors:   System Temperatures: cpu: 44.0C mobo: N/A
#3 2016-09-21 10:24
Re: Q4os 2.2
First did you check the md5 of the iso before you used it?
I have done a few installs of scorpion although I used 2.1.1 version mostly, I have only installed the 2.2 version on my latest laptop (dell) and it worked fine.
#4 2016-09-22 13:04
Re: Q4os 2.2
UPDATE:
    I thought everything was working fine, but didn't realise I am using a usb mouse, and when checking without the mouse plugged in the touch-pad is not working. I have checked /etc/X11/xorg.conf.d/50-synaptics.conf and it is exactly the same in scorpion as it is in orion, not sure what else to check...
EDIT:
    Found the solution to touchpad, simply install xserver-xorg-input-synaptics and reboot cool Strange that it doesn't get installed by default, maybe something for the devs to look into when possiible (not very important, just inconvenient)
#5 2016-09-22 15:32
Re: Q4os 2.2
Dai_trying wrote:
... simply install xserver-xorg-input-synaptics and reboot cool Strange that it doesn't get installed by default, maybe something for the devs to look into when possiible ...
Yes, it should be installed by default, the Q4OS glitch needed to fix.
