#1 2016-05-19 18:36
Two bugs: Konqueror and Krusader
1. When I download file using Chromium, and type folder name where file should be saved, Konqueror does not save file in typed location. This happens only if I try manually type download location. When I select it from side menu, everything is fine. Video:
https://files.inbox.lv/ticket/19a89e617 … or_bug.mp4
2. When I try to unpack archive using Krusader, and select destination location it shows message "Select file name for opening". Why? I need to choose folder for unpacking, not to open file.  As a result, I need manually type path, where archive should be unpacked. Video:
https://files.inbox.lv/ticket/a85704744 … ip_bug.mp4
#2 2016-05-20 10:53
Re: Two bugs: Konqueror and Krusader
We can confirm, both are reproducible TDE glitches. The first, we were able to reproduce on the common TDE file-save dialog, for ex. in Kwrite text editor, it doesn't relate specifically to Chromium browser. Please report them at https://bugs.trinitydesktop.org/
#3 2016-05-20 12:37
Bugs reported: 2654 and 2655.
#4 2016-05-21 09:08
About bug 1 2654: You should type [ENTER] after you type new folder for downloading, to force Konqueror use this new folder.
https://bugs.pearsoncomputing.net/show_ … id=2654#c1
About bug 2 2655: q4osteam, have you used English version of Krusader for reproducing this bug? TDE team member was unable to reproduce it...
https://bugs.pearsoncomputing.net/show_ … id=2655#c1
#5 2016-05-21 09:47
We have reproduced it within German environment set, so suppose all Latin environments should behave the same way. Q4OS Orion uses TDE R14.0.1, the issue could be fixed in the new stable TDE R14.0.3.
