#1 2015-12-27 17:55
Desktop Profiler List
Is there a full list of what is installed for the Basic and Full featured environments?
Dai
#2 2015-12-27 18:55
Re: Desktop Profiler List
You can list in terminal:
$ cat /usr/share/apps/q4os_system/q4os_swprofiler/q4os-basic.qdprrc | grep packages
$ cat /usr/share/apps/q4os_system/q4os_swprofiler/q4os-desktop.qdprrc | grep packages
#3 2015-12-28 15:11
Many thanks, just what I wanted.
#4 2015-12-28 15:30
Anyone can easily modify desktop profiles or create his own creating .qdprrc files with the correct syntax. Custom profiles will be offered in the Desktop Profiler list.
#5 2016-05-13 22:44
I thought I would create my own installer set-up as I seem to do quite a few of them, and have been looking at the desktop profile with a view to copying it and then removing / adding packages. I have a couple of questions...
1.)  "hwreq" I am guessing but is this is a parameter that checks for available free space to ensure there is sufficient room to install?
2.)  "profile_parent" will this be installed as well as current profile?
#6 2016-05-14 07:33
hwreq .. amount of operating memory in megabytes recommended for the profile
profile_parent .. not active parameter - it's prepared for the future use
#7 2016-05-14 11:22
Ok thank you. smile
#8 2016-05-14 12:50
Is it possible to add q4os-dev-pack to a profile for installation?
#9 2016-05-14 13:14
Yes it is, add 'q4os-devpack' into the 'packages_esh' dependencies.
#10 2016-05-14 13:35
Thanks, I wasn't sure if it would work as it is not in the software centre. smile
#11 2016-05-14 18:57
Is it possible to run a script after the installation?
I have added command-not-found to a profile script, but I need to run update-command-not-found (as root) after the installation. I have tried putting the script in the profiles directory and entered the name of the script in the "script_post" variable but it doesn't appear to run, that is I can see no indication of it failing (which I expected because of root requirement) so I don't even know if the script was processed. Any suggestions?
