#1 2026-03-17 03:26
tdeFlasher
Hello !
Here’s the app that probably nobody was waiting for, but I made it anyway :-p
In my quest to learn tqt3 and its subtleties, I’ve been having fun trying to port a few applications (your suggestions are welcome, by the way ^^) to tqt3, to have “native” Trinity versions. My latest “victim” is balena Etcher, a very popular tool for flashing ISOs, disk images, etc.
Why port it to tqt3 when it already works under Trinity? Simple answer: balena Etcher, despite its obvious strengths—ease of use and robust security checks—is an Electron app… which means it often consumes hundreds of megabytes of RAM just sitting idle… Not very “Trinity DE” philosophy, is it?
Since fully porting an Electron app is generally a monstrous task, I took a different approach: I decided to clone the graphical interface (which, by the way, was a fun tqt3 exercise, since Etcher’s UI isn’t exactly “standard”). I then rewrote everything in C++, carefully following Etcher’s logic and methods to preserve not just its looks, but also its qualities and features. The result is a near-perfect clone, with a few intentional visual tweaks (some icons are slightly different or reimagined for this Trinity-only version), all in a 140 KB binary (compared to… 228 MB for balena Etcher ^^).
https://github.com/seb3773/tdeflasher
Debian package attached. Feedback and criticism welcome smile
screenshots:
tdeflasher_1.0.0_amd64.deb
#2 2026-03-17 05:08
Re: tdeFlasher
That's really cool.  Good work.
#3 2026-03-17 19:58
Re: tdeFlasher
Uber-cool, indeed. I'm partial to Rufus for this purpose (under Windows) but really appreciate your achievement. cool
#4 2026-03-17 20:08
Re: tdeFlasher
+1 .. Really cool
#5 2026-03-20 01:25
Re: tdeFlasher
seb3773 wrote:
Hello !
Here’s the app that probably nobody was waiting for...
That's not correct wink - i did wait for it!
Until now i did the flashing allway with Rufus... will utilize it at the end of the year, when the support for Gemini runs out.
However, at this moment i'm not at all sure, whether it will then be Q4OS 5, 6,... or maybe even 7 cool
#6 2026-09-06 09:24
Re: tdeFlasher
As promised above, and since "Gemini" reached it's "EoL" lately (see https://www.q4os.org/forum/viewtopic.php?id=6241), i tried to prepare a USB installer of a more recent version of Q4OS with the latest tdeflasher_1.0.0_amd64.deb from github.
Unfortunately it doesn't start:
~/Portable\> ./tdeflasher.AppImage
/tmp/.mount_tdefladMCeJf/usr/bin/tdeflasher: error while loading shared libraries:
libidn.so.12: cannot open shared object file: No such file or directory
#7 2026-09-06 18:10
Re: tdeFlasher
Fixed, thanks for the report smile Appimage updated ( https://github.com/seb3773/tdeflasher/releases/tag/v1)
#8 2026-09-06 22:43
Re: tdeFlasher
Thank you, seb3773! But it still fails to start - with the next lib missing:
/tmp/.mount_tdeflaDefAil/usr/bin/tdeflasher: error while loading shared libraries:
libssl.so.3: cannot open shared object file: No such file or directory
#9 2026-09-07 00:38
Re: tdeFlasher
Sorry for this! and thank you very much for reporting this new problem.
I just understood the issue occurred because the AppImage was built on my system, Debian 12, which strictly required OpenSSL 3 (libssl.so.3), whereas it seems your system uses a different OpenSSL version (like OpenSSL 1.1 for example).
So ! As I didn't want to package libssl.so.3 too in the appimage because it will be >10MB, (not acceptable at my opinion for this kind of tool), I updated network support (libcurl) to load dynamically at runtime via dlopen. It should seamlessly uses your host system's native SSL library without enforcing OpenSSL 3.
Updated AppImage re-uploaded to the release page:
Could you please download it again and give it a try? Let me know if it's ok now
#10 2026-09-07 12:17
Re: tdeFlasher
Absolutely nothing to apologize for - i have to thank you!
Tbh: i already thought that the cause is the now old-old-old Debian 11 versions of libraries still here.
Well, i just inteded to test-install the brand new Perseus testing version, just for curiosity, and, for the very first time create the USB directly in Linux (still Gemini). (Before installing Aquarius - with a stick already prepared on Windows (XP wink) )
Now, the lates versions produces:
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by /tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher)
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by /tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher)
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher)
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by /tmp/.mount_tdeflamokfMg/usr/lib/libtqt-mt.so.3)
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by /tmp/.mount_tdeflamokfMg/usr/lib/libtqt-mt.so.3)
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by /tmp/.mount_tdeflamokfMg/usr/lib/libtdecore.so.14)
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by /tmp/.mount_tdeflamokfMg/usr/lib/libtdecore.so.14)
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.36' not found (required by /tmp/.mount_tdeflamokfMg/usr/lib/libarchive.so.13)
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by /tmp/.mount_tdeflamokfMg/usr/lib/libarchive.so.13)
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by /tmp/.mount_tdeflamokfMg/usr/lib/libgcrypt.so.20)
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by /tmp/.mount_tdeflamokfMg/usr/lib/libDCOP.so.14)
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libm.so.6: version `GLIBC_2.35' not found (required by /tmp/.mount_tdeflamokfMg/usr/lib/libart_lgpl_2.so.2)
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.32' not found (required by /tmp/.mount_tdeflamokfMg/usr/lib/libgpg-error.so.0)
/tmp/.mount_tdeflamokfMg/usr/bin/tdeflasher: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by /tmp/.mount_tdeflamokfMg/usr/lib/libgpg-error.so.0)
But PLEASE don't bother if it's getting too complcated to get it runnable on an old-old-old system like mine! wink
#11 2026-09-07 14:59
Re: tdeFlasher
I understand, it's a retro compability problem, my build machine runs on Debian 12 (Bookworm), which uses GLIBC 2.36 and GCC 12. And this is the fundamental rule of AppImage and the Linux world: 'A binary compiled on a recent Linux can NEVER run on an older Linux.'
(GLIBC ensures forward compatibility— a binary built on Ubuntu 20.04 will run on Ubuntu 24.04—but never the reverse.)
So, to solve this, I have built a dedicated legacy-compatible AppImage built on an older toolchain (GLIBC 2.31 / Ubuntu 20.04 base) to support older distributions like yours.
You can try tdeflasher-legacy-x86_64.AppImage directly here:
https://github.com/seb3773/tdeflasher/r … 4.AppImage
hope this time it's ok smile
(one last thing: you maybe need to launch with root privileges to write on the usb device)
#12 2026-09-07 21:55
Re: tdeFlasher
WOW, that is so kind - MANY thanks! Now it runs and works flawlessly here on Gemini!
I was able to prepare the stick with latest Perseus-(TDE! smile)-testing.iso  and start it from USB on my machine (looks & works absolutely familiarly)... but didn't install it.
As said above, i'll firstly now install Aquarius (beside Gemini) - one step after the other... wink
But in 2027, when Forky/Perseus have become stable, i plan do swich to it asap - utilizing your nice TDE-flasher!
Many thanks again, @seb3773!
#13 2026-09-08 09:27
Re: tdeFlasher
All the pleasure is mine! If this can be usefull for the community, I'm very happy about it :-)
