#1 2026-07-31 16:15
Totone
Error modprobe.d
hello everybody,
I get this error at startup:
ERROR: kmod_config_parse: /etc/modprobe.d/disable-algif.conf
nano disable-algif.con exit:
install algif_aead/bin/false
test:
lsmod | grep algif_aead
test:
rmmod algif_aead
Module algif_aead is not currently loaded
Unable to find the algif_aead package
Does anyone have a solution to fix this
regards,
#2 2026-07-31 16:34
Re: Error modprobe.d
Here are tips by AI. Please check them and post back the result.
AI generated:
A likely cause is that the line in `/etc/modprobe.d/disable-algif.conf` is malformed. `kmod_config_parse` errors usually indicate a syntax problem in a `modprobe.d` configuration file.
The error suggests that `/etc/modprobe.d/disable-algif.conf` contains an invalid `modprobe` configuration.
Please check the file with:
```bash
cat /etc/modprobe.d/disable-algif.conf
The line should be:
```text
install algif_aead /bin/false
Notice the **space** between `algif_aead` and `/bin/false`. If your file contains:
```text
it is missing that space, which would produce the `kmod_config_parse` error.
After correcting the file, reboot or simply test the configuration with:
```bash
sudo modprobe -n -v algif_aead
Regarding:
```bash
rmmod algif_aead
this is normal—it only means the module isn't currently loaded.
Also, `algif_aead` is a **kernel module**, not a Debian package, so there is no package named `algif_aead` to install.
If the configuration file already contains the correct syntax, please post the output of:
```bash
grep -R algif_aead /etc/modprobe.d/
so we can investigate further.
#3 2026-08-01 09:10
Totone
Hello everybody,
The requested result :
Amended text :
nano /etc/modprobe.d/disable-algif.conf
insmod /lib/modules/7.1.5-2-liquorix-amd64/kernel/crypto/af_alg.ko.zst
install /bin/false
/etc/modprobe.d/disable-algif.conf:install algif_aead /bin/false
Testing again same error :
rmmod algif_aead
rmmod: ERROR: Module algif_aead is not currently loaded
regards,
#4 2026-08-01 10:20
Please post the output of:
$ sudo find /etc/modprobe.d /usr/lib/modprobe.d /lib/modprobe.d -type f -exec grep -H "algif_aead" {} \;
$ sudo update-initramfs -u
$ journalctl -b | grep -i kmod
Also, please copy the exact startup error message as it appears now (or attach a photo).
#5 2026-08-01 12:04
Totone
update-initramfs: Generating /boot/initrd.img-7.1.5-2-liquorix-amd64
août 01 12:28:27 tp-atzz systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
août 01 12:28:27 tp-atzz systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
août 01 12:28:27 tp-atzz systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
août 01 12:34:20 tp-atzz dbus-daemon[533]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.115' (uid=1000 pid=2148 comm="/usr/bin/firefox -p /home/xxxxxxx/Bureau/kmod1.jpg")
https://i.postimg.cc/T3Jj7v6R/kmod.jpg
#6 Yesterday 10:19
The previous syntax error has definitely been fixed:
modprobe -n -v algif_aead recognizes the install /bin/false rule.
update-initramfs -u completed successfully.
No kmod parse errors appear in the system journal.
The remaining message shown on the splash screen is therefore unexpected. It may be caused by hidden characters (for example, Windows line endings or an invisible UTF-8 character) in the configuration file.
Could you please post the output of these commands?
$ cat -A /etc/modprobe.d/disable-algif.conf
$ file /etc/modprobe.d/disable-algif.conf
$ hexdump -C /etc/modprobe.d/disable-algif.conf
$ modprobe -c | grep -A2 algif_aead
One more question: did you create disable-algif.conf yourself, or was it installed by a package or a script? If you know which package or tutorial created it, that information may help identify the cause.
#7 Yesterday 12:27
Totone
Hello everyone,
I went through everything again from the beginning, step by step, to see if I had made a mistake somewhere, and it worked.
The error has disappeared, though I don't know how.
Thanks for your help.
Here is what was requested :
install algif_aead /bin/false$
/etc/modprobe.d/disable-algif.conf: ASCII text
00000000  69 6e 73 74 61 6c 6c 20  61 6c 67 69 66 5f 61 65  |install algif_ae|
00000010  61 64 20 2f 62 69 6e 2f  66 61 6c 73 65 0a        |ad /bin/false.|
0000001e
options snd_pcsp index=-2
options cx88_alsa index=-2
No, I didn't create this file; I think it appeared during an update, but I couldn't say when or which one.
regards
#8 Yesterday 12:31
Thanks for letting us know you solved that. That seems to have connection to Liquorix kernel, it's not Debian/Q4OS standard one.
#9 Yesterday 12:40
Totone
I think it's related to the KDE Application Platform, because in a previous post back in June, I mentioned that the update wouldn't go through due to Tor—which I had to uninstall in order to perform the update.
#10 Yesterday 12:48
Yes, all those odd issues may be connected to the Liquorix kernel or another non standard elements added. We have no similar reports or indication that this issue may arise on the default Debian/Q4OS setup. All in all, we are glad it works for you now smile
