#1 2026-05-17 20:57
concord
Secure Boot Certs ending June 2026, not updated via Q4OS
Hi,
Been using Q4OS for a few years on an HP EliteDesk 800 G5 mini i5-9500T system with KDE.
I wanted to check to see if Q4OS updates would assist in the cert updates that are going to expire in June.   I know Windows performs this in their updates (yes, still have to use it for Blue Iris software and also Tax software).  Some systems had issues with the Win 11 updates, like not enough space in EFI.
I checked using mokutil --sb-state, --kek and --db, and yes secure boot is enabled sad but shows the expiring certs only.   Tried fwupdmgr refresh/get-updates, but none found.
Thanks.
#2 2026-05-25 20:31
Re: Secure Boot Certs ending June 2026, not updated via Q4OS
What Q4OS version are you using ?
$ get-q4os-version
