#1 2026-04-30 08:01
radko
Hot spot issue
Hello
How to make hot spot transparent?
I have printer with wi-fi hardware and I connect it to network with dhcp adress.
I need adress from local network 192.168.2.155 but hot spot have adress from range 10.*
#2 2026-05-01 08:57
Re: Hot spot issue
I'm not sure I understand your question.
Do you want to connect your printer having a fixed IP address 192.168.2.155 to a network having IP addresses in the range 10.xxx.xxx.xxx?
#3 2026-05-01 10:38
radko
Re: Hot spot issue
Thanks for replay
Respond to Your's question yes, but keep this in mind that my DHCP server is in network with adress 192.xxx.xxx.xxx.
#4 2026-05-01 14:20
Re: Hot spot issue
Sorry, this case is beyond my knowledge. Maybe something to configure on  your 10.xxx.xxx.xxx router.
