#1 2025-08-13 00:25
TDE: Improvement Developers' Discussion
Post TDE related program ideas and discuss about development here!
#2 2025-08-13 13:18
Re: TDE: Improvement Developers' Discussion
Hello again !
Besides the projects we talked about, I thought maybe it will be a good thing to create something like a "tips & tricks" or "TDE improvements" app center, or something like that for TDE.
The idea behind this, is to have every good tweaks, tricks and usefull additionnal apps (I'm thinking for example of your tiler program, 'windows' button for menu and combinations like win+r, win+d like you do with xscape, and other things like that. I almost finished qsidebar now (spent some times this night to correct the 'extend' mode sidebar positionning which was bugged), maybe this will be something to integrate too, etc...)
I'm thinking of some small things too, like touchpad configuration, konqueror actions etc...
Everything in the same place, ready to be selected and installed. This will be a good place to have all these little usefull apps, scripts and tweaks, and easier to install than searching the forum and doing it 'manually' for standard users, with some description of what it does, and maybe screenshots if relevant. Only apps that are not in the Q4os center, to avoid useless duplicates.
Something like Pi-Apps if you know it, but not as an "app store", because there's already the q4os app center for that, but more a "TDE tweaks" store or something like that. Everyone will be welcome to propose what must be integrated in it and what is not really usefull. This way, it will be easier to customize/improve TDE for everyone using it, with a single tool.
It can be made in python if you want (this will be a work for you in this case :-p ) or in c (I can do that), or shell script with yad (can do that too).
What you do think about that ?
#3 2025-08-13 21:10
We're running on the same wavelength~ I am making a "superapp" named "setuzuna" which does add various apps tweaks etc
So for I've developed
- virtual monitor app(~60fps on my laptop, access over localhost via mjpeg, written in cpp)
- battery monitor app
- resource and network monitor app (a systray icon app)
- music player app (includes scrobbler, fetching lyrics from Spotify(does not work anymore), lrclib, gotta add genius n stuff)
- pomodoro app (currently it's the music player's plugin, easy to detach)
- notification daemon (wip, as we know)
Also wanna do
- magnification tool (like docked on top of screen like windows, easy to do as it'd use some part from my virtual monitor app)
- on screen keyboard (docked on bottom on screen)
- sidebar (to integrate every app in one, sounds weird but it'd work out good)
- smartphone connect app (currently learning how apps like kdeconnect and dcnnt works, would definitely implement one later)
- gui tiler (based on tiler, we talked about it in other post)
- ai chat app
- telegram chat app (look at brackets below)
- matrix chat app (too hard for me, gotta maintain it regularly and I don't have that much time.. also matrix's python api doesn't work that well yet)
... (and more if i needed more things, yes i dev apps if I need one and available options aren't good enough for me)
Since I use TDE as my primary desktop environment, I'd definitely make integration with tde way better
#4 2025-08-13 21:15
Unrelated, but can anyone sync bluetooth between Android-x86 based distro's and debian based distro's?
Bt-dualboot works well with syncing windows and debian but can't get things to work with Android x86.. tried everything i can think of (combinations of config values to and forth between the two os, including link key, type, length, class, service.. I just wanna sync my headphones sad)
#5 2025-08-13 22:32
Thanks for your answer ! I will take time to search every good tweak/apps related to TDE "improvements" and propose it here.
By the way, I'm really interested about your virtual monitor app ! Is it on github ?..
About the  smartphone connect app, I have tested Qtsrcpy, which is very good and works well with trinity !
*For your headphones problem, I'm not sure I understood, what do you want to achieve ? (I've got bluetooth headset too, but it connects whithout problems with blueman manager and my android phone too, but maybe your question is more specific ?)
#6 2025-08-13 23:47
thanks, and I'll try to implement whatever i could wink
[redacted with reason: I was too sleepy when I wrote the original message] Refer to Updated Reply
oh yea i like scrcpy too, but since my tablet runs android 8.1, i cant connect via wireless adb so i dont always use it, had some issues with kdeconnect and dolphin in only debian 12 which lead me to try to make my own app (failure, currently using mixplorer and thunar, clip_share and usb tethering for most stuff)
ah i have android-x86 installed on my laptop in multiboot, so trying to connect bluetooth devices on different os on same hardware.. doesnt really work out well.. theres a solution to fix this issue if youre dual booting windows and linux but no solution i could find for linux and android-x86
i need to android often so i often try out different ways to run it on my laptop (tablet has some issues), and well ive come to the conclusion that my laptop is too weak.. so i'd be giving up now
#7 2025-08-14 18:03
BrJPedro wrote:
@q4osteam
Improve multi-screens experience big_smile
Specifically, tiling a window to the border without moving to the next screen. Like other DE handles it, maybe a grace area for snapping the window without moving to the next monitor outright.
I guess i gotta do this next for tiler, feels simple enough but ain't got no physical monitors so gotta use that virtual monitor app
- Grace area for snapping + preview
- keyboard tiling to integrate with multi monitor configuration
#8 2025-08-17 00:09
Update: I got it working with python finallyyyyyyy using pybind11
Performance: Raw Images captured at ~130 FPS (77% CPU) (using Xshm, that I had issue with) (with cursor drawing using Xfixes)
It can be optimised further to work at over 200 FPS (i think)
Previously used mjpeg server to serve the stream after encoding n compression using turbojpeg, ran at ~60 FPS
Currently tried implementing rtsp server to serve the steam after encoding using ffmpeg, runs at ~28 FPS
I will try to optimise rtsp server as much as possible as well as reimplement turbojpeg/mjpeg server in python (or just use pybind11 again coz it's great) too see which runs better
wink
UPDATE:
- now capturing raw images at max of ~ 214 FPS with 84% CPU
UPDATE - 2 :
- now capturing raw images at max of ~ 517 FPS with 51% CPU
- dropping rtsp and reimplementing turbojpeg/mjpeg sever
UPDATE - 3:
- now returning images only when updates are available, reducing cpu load to 0~9%
- tried using xcb-shm, which turned out to be more resource intensive, sticking to mit-shm (xshm)
#9 2025-08-19 00:13
a quick preview :3
(needs lots of tweaking n optimizations.. circular tk windows are kinda buggy..)
#10 2025-08-19 15:05
theasmitkid wrote:
a quick preview :3
https://iili.io/FpATRSf.md.png
really cool !
#11 2025-08-19 20:57
(make somewhat of a EWMH panel for this, which took more time than expected because seems like twin doesnt seem to support ewmh.. this should work for everything except keyboard inputs in that panel.. due to a tkinter bug)
#12 2025-08-21 16:12
Okay, I've kind of given birth to a monster tongue I wanted to integrate your trick for the Win key into my "q4rescue" project (a rescue live Linux based on Q4OS Trinity) as well, for which I'm trying to stay as minimalist as possible in terms of resources and running processes (for maximum responsiveness and overall lightness). Using xcape bothered me in the sense that it's just to intercept the Super_L key after all... So I modified xcape to only handle that key, making it even lighter. (the code is in qwincap.c if you're interested, it's xcape but only for Super_L tongue, with the "Super_L=" part being implicit).
Then, in a second step, I also wanted to integrate the tiler. And so I thought to myself, since I'm already intercepting Super_L, why not directly integrate the tiler's functionalities? So I won't even need khotkeys running (which I don't use for anything else in fact) and no /.tiler.sock file... The result is the "frankencode" qsuperl.c, which does exactly this (intercepts Super_L like xcape to replace it with a chosen sequence passed as an argument, and directly includes the tiler functionalities associated with the usual keys). This way, I don't need the daemon or the shell script, everything is more direct and lighter smile
Now, I realize this might not be interesting to everyone, but on my end I think it's nice to combine these two "tips/improvements" into one, since they both concern behaviors of Super_L tongue
If you find this interesting, a possible improvement would be to also pass the desired tiler key combinations with Super_L as arguments... but I find the default configuration to be very logical.... AND I'm not sure that would necessarily be interesting; this "integrated" solution mostly meets my personal wants and needs wink
*just realized I can't upload more than 3 files, if you want the qwincap.c code, just ask me (=xcape with only Super_L detection, and no tiler integrated)
qsuperl.c
tiler.h
qsuperl
#13 2025-08-21 17:20
Wow we are running on the same wavelength afterall, I've also done this on my system (not released because it's not perfect)
I would probably not hard code the keybinding for tiler in case some user want to use other keys for tiling. I use Khotkeys a lot i think, to bind htop to ctrl+shift+esc, to bind your version lxtask(manager) to alt+shift+esc, to bind brightness control and ofcourse, tiler. I'll see if my implement comes out to be lighte than Khotkeys i might release it with more customisability
That would be another module though, which can use used by various programs internally so tiler can be more efficient.. it's just a thought for now, i will look into it later
I mean I'm glad they're useful to you but again, users might use Super_L's binding outside tiler too
this makes sense~ I'll try out later wink
Yeah do share that code too~ I'm still learning c/c++ so it'll be helpful tongue
#14 2025-08-21 21:53
Right, I hardcoded the keys because the combinations you proposed seem logical to me smile (But I can adapt to take tiler keys combination in arguments or maybe use a conf file if anyone interested) . It doesn't prevent khotkeys to work, even if you map windows key + something to any action (only don't use the hardcoded ones).
I joined the "qwincap" code (xcape with only Super_L) wink
qwincap.c
#15 2025-09-25 07:04
Hey seb why don't you try using tdeui/ksystemtray instead of gtk? i learnt tqt recently and it's quite powerful~
#16 2025-12-27 23:39
Thoughts? tongue
#17 2026-03-31 07:40
seb3773 wrote:
theasmitkid wrote:
Wow that's greatt, I use proton vpn.. which only has a gtk client, i wonder if it could be porter to tqt aswell
Thank you very much smile smile
About protonvpn gui, yes it could be! I took a quick look, and it seems to use Python with the GTK toolkit, so it should be doable. smile Maybe we could work on a project together? I’m happy to code the interface and I’ll leave the business logic coding and wiring to you if you want ^^
By the way, you were right about tqt3—I should have looked into it sooner. It’s exactly the kind of graphics toolkit that suits me, except maybe for the requirement to use C++ :-p  But that’s not really a problem and actually makes sense for building complex GUIs (let’s be honest, C isn’t really ‘made’ for that). It’s straightforward, no frills, and works like a well-oiled precision machine. So, expect more TQt3 ports for TDE—I’m really enjoying it and I’ve got a couple of fun projects in the works ^^^^
That's wonderful that you found tqt3 cool, I've always preferred gui development in python, and since tqt3 has the most straightforward python bindings, i enjoyed developing with it too.
As for right now, I'm a little busy so not working on any projects. But I do have some goals prepped. First off i wanna port gmenudbusproxy to tqt from qty.. though I've never worked on this api so it's gonna be really hard for me. Next up i wanna create a svg renderer for kicker, something like generic monitor from xfce4's genmon plugin. I've also found nm-tray from lxqt, which is so much better than every other gui network manager, so i wanna port it to tqt— preferably a kicker applet. So yup all I'm planning to do in future for starters are kicker applets. Also made this kdeconnectd client, as well as a sidepanel (#16)
#18 2026-04-07 11:51
I’m not a heavy Python user—I mainly use it for small scripts to automate a few operations when I’m developing—but I admit I’m not very up-to-date on using TQt3 resources in Python. However, I’m interested in learning. Over the past few months, as I’ve been getting more familiar with TQt3, I’ve gradually started creating a set of “mini-libs” for TQt3 through various projects, trials, errors, and experiments. These are meant to address specific or general needs, and to have ready-to-use “building blocks” for TQt3. I’m not trying to “extend” its core functionality, but rather to meet certain specific needs—for example, converting code from Qt5/6 to TQt3.
I really like the fact that TQt3 is relatively minimalist, and I appreciate that it stays that way. We don’t need a “bloated” toolkit with millions of features that are only useful once in a hundred times. I find it more relevant to occasionally add various functionalities as needed. (I don’t want to start a debate, but what I dislike about toolkits like GTK4, for example, is the desire to include everything and anything, to the point where the toolkit becomes a real mess. This affects loading times and overall usability. One of the reasons I think GNOME has become a monstrous pile of crap, but that’s another topic...)
Anyway, I’ll be posting all this on GitHub soon, and probably here too for reference. I’d be thrilled to be able to “convert” or “adapt” these libs so they can be used just as easily in Python (and I’ll probably need your help with that wink )
“A SVG renderer for kicker” — great idea! Actually, I was wondering if I should try to create a lib for exactly that (not specifically for kicker).
“nm-tray from LXQt” — I took a quick look, and it’s indeed a great base! It would be a fantastic addition to TDE. I’m up for working on this with you if you want smile
I find all of this very exciting, and I can’t wait for us to work on things together!
In the meantime, I’ll keep doing small ports to TQt3. I just finished tdediskmark (a port of kdiskmark with some extra features ^^), and I’m almost done with “tdeparted,” based on gparted but with a LOT more functions. My goal is to make it the best and most complete Linux partition manager out there—nothing less! (I’ve incorporated all the features of GNOME Disks, of course the whole gparted base, plus cloning, disk image management, secure erase for devices/partitions, SMART info, quick benchmarks, notifications, etc...)
TDE Rulezzzz ^^
