#1 2026-04-03 18:18
SteveC
Problem installing Flacon
I have a fresh install of Q4. I have tried installing Flacon from the Discovery centre, and I've also followed CLI guides, but the install fails.
The Discovery route just hangs and never completes.
The CLI routes fail with a missing/incorrect key.
Has anyone found a reliable method?
#2 2026-04-03 19:34
Re: Problem installing Flacon
Look for Falkon in Q4OS Software Centre.
#3 2026-04-04 11:29
SteveC
Thanks, but this is a different application. I am trying to install Flacon, which can break a long flac/cue file into individual tracks.
#4 2026-04-04 11:33
Please run in terminal and post back the output:
$ sudo flatpak install com.github.Flacon
#5 2026-04-04 15:08
SteveC
SOLVED
I tried adding the flatpak in Discovery, but it just hung.
I tried sudo apt install flacon, but it couldn't get past operation 1/8.
Then I tried your suggestion of installing from github and it worked - output below:
Looking for matches…
Required runtime for com.github.Flacon/x86_64/stable (runtime/org.kde.Platform/x86_64/5.15-24.08) found in remote flathub
Do you want to install it? [Y/n]: y
com.github.Flacon permissions:
    ipc      network      fallback-x11      wayland      x11      dri      file access [1]     dbus access [2]
    [1] home, xdg-config/kdeglobals:ro, xdg-run/gvfs, xdg-run/gvfsd
    [2] com.canonical.AppMenu.Registrar, org.kde.KGlobalSettings, org.kde.kconfig.notify, org.kde.kdeconnect
        ID                                              Branch                Op            Remote             Download
1. [✓] org.freedesktop.Platform.GL.default             24.08                 i             flathub            146.1 MB / 146.7 MB
2. [✓] org.freedesktop.Platform.GL.default             24.08extra            i             flathub             24.7 MB / 146.7 MB
3. [✓] org.freedesktop.Platform.VAAPI.Intel            24.08                 i             flathub             15.4 MB / 15.5 MB
4. [✓] org.freedesktop.Platform.openh264               2.5.1                 i             flathub            913.7 kB / 971.4 kB
5. [✓] org.kde.KStyle.Adwaita                          5.15-24.08            i             flathub              6.7 MB / 6.7 MB
6. [✓] org.kde.Platform.Locale                         5.15-24.08            i             flathub             18.7 kB / 409.6 MB
7. [✓] org.kde.Platform                                5.15-24.08            i             flathub            281.5 MB / 379.4 MB
8. [✓] com.github.Flacon                               stable                i             flathub              6.9 MB / 7.6 MB
Installation complete.
I'm very grateful for your help - there is no other app that can easily replace flacon for my uses.
