#1 2026-03-28 19:48
krall1q1
dpkg interrupted ı tryed sudo dpkg --configure -a but its not worked
its stuck on update-initramfs: Generating /boot/initrd.img-6.1.0-41-686-pae ı waited 45 minutes but its not worked. plz help
#2 2026-03-28 21:21
Re: dpkg interrupted ı tryed sudo dpkg --configure -a but its not worked
Please post output of commands:
$ qrepolist
$ sudo update-initramfs -u
#3 2026-04-02 14:03
krall1q1
sorry ı am on trinity aquarius
#4 2026-04-02 14:04
krall1q1
ı tryed sudo update-initramfs -u and it frozed again
#5 2026-04-02 15:45
$ qrepolist
#6 2026-04-02 16:07
krall1q1
ı try to write sudo update-initramfs -u terminal froze and grepolist says this
deb http://q4os.org/q4repo/ q4os-5-0-cn main
deb http://q4os.org/qtderepo/ bookworm main
deb http://deb.debian.org/debian/ bookworm main contrib non-free non-free-firmware
deb http://security.debian.org/ bookworm-security main contrib non-free non-free-firmware
deb http://deb.debian.org/debian/ bookworm-updates main contrib non-free non-free-firmware
deb https://dl.winehq.org/wine-builds/debian/ bookworm main
#7 2026-04-02 16:11
krall1q1
#8 2026-04-02 16:13
krall1q1
oh i tryed and sayed this
#9 2026-04-02 16:16
Please remove or disable "deb https://dl.winehq.org/wine-builds/debian/ bookworm main" repository first
Run in terminal:
$ sudo apt update
$ sudo apt full-upgrade
Now try to run:
$ sudo update-initramfs -u -v
and post the output
#10 2026-04-02 16:22
krall1q1
how to disable winehq
#11 2026-04-02 16:26
Open the sources list file for Winehq:
sudo nano /etc/apt/sources.list.d/winehq.list
Find this line:
Comment it out by adding # at the start.
#12 2026-04-02 16:37
krall1q1
wait ı write an app optimizases pc and it worked
#13 2026-04-04 09:33
krall1q1
my another pc whit q4os was having same issue and sudo update-initramfs -u -v worked thanks smile
