#1 2026-03-21 10:19
Totone
[Resolved] Clipboard Presse-papiers
Hello everyone.
I'd like to know how to delete the clipboard. It saves everything, even passwords, which is a security concern.
At least disable it.
regards
[Resolved]
#2 2026-03-21 10:35
Re: [Resolved] Clipboard Presse-papiers
Disable clipboard history:
Right-click the clipboard icon in the system tray (Klipper icon).
Click Configure Clipboard…
Uncheck:
“Save clipboard contents”
Apply → OK
This completely stops Plasma from storing clipboard history.
or
Clear clipboard history manually
Click the clipboard icon → Clear history
or press:
Meta + V - then click the trash icon
#3 2026-03-23 00:45
Q1derous
Another option if you're interested is CopyQ - "Advanced clipboard manager with editing and scripting features".
https://hluk.github.io/CopyQ/
Also available in Discover.
Lots of features and customizable options.
