#1 2026-02-07 15:10
itsoulos
.gtkrc-q4os
Hello all,
can I alter this file in my home directory to change the appearance  of gtk apps such as Firefox and Thunderbird?
Regards
#2 2026-02-07 15:18
Re: .gtkrc-q4os
This file would affect Gtk2 applications, what is not the case of Firefox and Thunderbird.
#3 2026-02-07 15:25
itsoulos
Re: .gtkrc-q4os
Is there any file or setting to change the appearance of Firefox and Thunderbird to match the kde settings?
#4 2026-02-07 15:35
Re: .gtkrc-q4os
Firefox and Thunderbird are GTK apps, not Qt ones. Here are some tips by AI, as we have checked:
1. Use KDE’s GTK integration
Open System Settings → Appearance → Application Style → Configure GNOME/GTK Application Style
Make sure:
GTK theme is set to Breeze (or Breeze Dark)
Icons match your KDE icon theme
Font matches your Plasma font
2. Install the Breeze GTK theme (if missing)
$ sudo apt install breeze-gtk-theme
Once installed, re-select it in the GTK settings above.
3. Make sure xdg-desktop-portal-kde is active
This helps Firefox/Thunderbird respect KDE dialogs, file pickers, and theming.
Install packages:
xdg-desktop-portal
Then log out and back in.
You can check it’s working by opening a file dialog in Firefox — it should look like a KDE dialog, not GNOME’s.
4. Firefox-specific tweaks (very useful)
Open Firefox and go to:
about:config
Check or set these:
Force GTK theme usage
widget.gtk.theme.override = Breeze
(or Breeze-Dark)
Prefer system dialogs
widget.use-xdg-desktop-portal = true
Restart Firefox after changing these.
5. Thunderbird (same engine, fewer knobs)
Thunderbird uses the same GTK stack, so:
It follows the GTK theme automatically
No equivalent about:config tweaks are usually needed
Just restart it after GTK changes
If it still looks off, make sure it’s not using a custom Thunderbird theme.
6. Colors & dark mode gotchas
If dark mode isn’t syncing:
Plasma: Appearance → Colors
GTK: must also be Breeze Dark
Firefox: set theme to System theme – auto
Firefox won’t follow KDE accent colors perfectly, but it’ll get close somehow.
#5 2026-02-07 15:44
itsoulos
Re: .gtkrc-q4os
Thank you very much
I had to set the widget.use-xdg-desktop-portal  to 1  in order to use the native dialogs of kde
Best regards
#6 2026-02-08 08:52
Re: .gtkrc-q4os
In Firefox Customise Toolbar and bottom left click Title Bar - that way it will use the same window controls as Plasma.
#7 2026-02-08 10:04
itsoulos
Re: .gtkrc-q4os
Where are these settings?
#8 2026-02-08 12:39
Re: .gtkrc-q4os
Right click on the tab area - say, to the right of a new tab button. Then go down to Customise Toolbar
#9 2026-02-08 16:41
itsoulos
Re: .gtkrc-q4os
I have already done this and I have installed the plasma addon
#10 2026-02-08 16:54
itsoulos
Re: .gtkrc-q4os
I think that is solved now.
