#1 2026-02-01 15:21
globetrotterdk
Q4OS setup script no longer works with Devuan?
I have used the setup script in the past, as I prefer almost any init system to systemd. I used it to convert Devuan runit installs in the past to Q4OS. At this time, I have a Devuan Excalibur install with the sysv init and was interested in converting it to q4os. However I get the following:
# sh q4os-setup.sh
www.q4os.org
You are going to add Q4OS repositories and setup complete Q4OS system ...
... press 'Enter' to continue, 'Ctrl+C' to cancel ...
Detecting current system ...
... press 'Enter' to continue ...
[I] Distro: Devuan, excalibur
[I] Architecture: amd64
[E:] This system is not ready for Q4OS setup. Exiting ...
Is this current expected behavior, or is there a problem with the script.
I’ve had a perfectly wonderful evening, but this wasn’t it. - Groucho Marx
#2 2026-02-01 15:33
Re: Q4OS setup script no longer works with Devuan?
Yes, the script doesn't support Devuan Excalibur at the moment.
#3 2026-02-01 16:19
globetrotterdk
Thanks for the confirmation. Please post when you have a new version of the script that does support Devuan Excalibur.
#4 2026-02-01 17:53
Yes, we will do.
#5 2026-03-24 16:21
lucbertz
Nice to see this script will be updated for Devuan Excalibur. Thank you.
less is more
