1. Darkonair and debonaire themes require kde-style-qtcurvre-qt5 which requires kio6 which requires kwallet6.. it's unnecessary i think because qtcurve on Trinity should be using tde-style-qtcurve-trinity.. These unnecessary packages are using 45mb ram for no reason.. can't even remove it or else would have to remove the theme as well
2. Also is there any way to disable obexd? I know I'd never use it and can't remove it as blueman requires it.. using 18mb ram for no reason
3. MTP & smb4k still doesn't work. Dolphin ( qt6 ) still can't detect MTP devices (I think I could in other device.. still a no on asus-e202sa) (I guess would stay on thunar+konqueror as before)
4. Using basic installation removes pipewire wireplumber and bluetooth too completely.. that was unexpected, the install cd comes with too much "junk" that's removed when using basic installation, but it doesn't remove this switchroo control.. weird
5. Wifi still doesn't always work.. need to remove and add via modprobe few times.. bluetooth's cool (asus-e202sa, don't have this in other device, also don't have this issue on Android-x86 and windows)
6. Paint is kolourpaint, color picker is kcolorpicker and kcoloredit.. can't their name be in the same format.. irritating to search them up
1. Yes, it's required for a reason. The reason is Qt5 applications needs kde-style-qtcurvre-qt5 package to follow Trinity Debonaire theme properly. We will consider move to the "recommend" dependency.
2. We will check
3a. MTP works fine here. Please post specific and exact steps to reproduce the issue for us to be able to investigate.
3b. Trinity version of smb4k is buggy and doesn't work properly due to upstream TDE bugs. Debian Samba works fine.
4. Yes, we will remove some packages from the install-cd media, they can be installed within a profile
5. Wifi works fine here. We would guess hardware related drivers problem connected to Debian upstream
6. Upstream one
Oh i had no idea it was also theming qt5 apps! It makes much more sense now.. except for the need for kwallet and kio for just themes....
But dolphin is qt6 i guess.. it wasn't themed when I was testing it out
No app except aft-mtp-mount detects my android devices, it works great but I just wish there was an inbuilt gui interface for it in dolphin-trinity like dolphin (qt6).. i'd prolly make a thunar plugin to get it working.. gvfs-mtp can't detect my android tablet either, just aft-mtp-mount
Yes.. though I wish there was smb support in dolphin-trinity like dolphin (qt6)
These are provided by kio-extras i think? Is there a tdeio-extras I'm unaware about..?
I guess so.. it's the only reason I got windows/Android-x86 in multiboot.. sometimes I just can't afford the network to drop while I'm in midst of something important..
6. Upstream one
Any workarounds? Like putting an alternative name in the .desktop entry or making symlinks to have the names same-ish?
I am not even able to make an account on trinitydesktop.org's gitea instance(not getting verification email).. I know there is a bugzilla entry for this but not on the repo, can @q4osteam post an issue on https://mirror.git.trinitydesktop.org/gitea/TDE/smb4k
Maybe some package missing ? In anyway smb4k-trinity is not much reliable and have a few bugs. We will take a look.
Or maybe it needs some extra configs.. since all I use is smbv1, it'd be best if i could get it working in konqueror!
Also the icon style for back and forward is completely different in waterleaf dark theme, see in konqueror for example
Also when waterleaf dark extras is installed and you try to open icon chooser in any Trinity app (eg kmenuedit) it stops responding, cpu usage spikes to 100% and after a few complete minutes of freeze, the icon selector menu shows up (maybe because it has to load all of the icons....... I think). This was also happening in Q4OS 5
hey q4osteam are you sure this is how qt apps are supposed to look..? they look pretty weird to me
@q4osteam look at this, kdenlive should also be a modern kde program.. and theming in it seems a little broken
... look at ... theming in it seems a little broken
This issue has been already resolved.
theasmitkid wrote:... look at ... theming in it seems a little broken
QtCurve doesn't theme qt6 programs
@Welcome to the forum @Faris000
Right
