#1 2025-12-12 07:55
Bogy
Virtual keyboard
Q4OS is a very good operating system. With one observation: there is no virtual keyboard option that works. A simple but very useful thing. How do you solve this problem?
#2 2025-12-12 08:38
Re: Virtual keyboard
There's onboard, you can install it with
sudo apt install onboard
#3 2025-12-15 09:04
Bogy
No, I'm talking about the on-screen keyboard.
#4 2025-12-15 09:17
Bogy
This doesn't work. For example, you can't type anything in the browser, the search box. Anyway, thanks for the reply. Any other suggestions, advice?
#5 2025-12-15 12:14
Bogy
Sorry,
Me again, here is the solution for Wayland:
https://github.com/mdev588/vboard
Now working.
All the best to everyone.
#6 2025-12-15 12:16
Thanks for sharing the solution smile
