#1 2025-09-13 01:50
Germ
Old Acer Install Q4OS 6.1 Andromeda
My install on Acer Aspire 5315-2153 vintage 2008
Went perfectly.  No available updates.  Will explore and report back tomorrow.
Specs:
germ@q4os:~$ inxi -F
System:
  Host: q4os Kernel: 6.12.43+deb13-amd64 arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.3.6 Distro: Q4OS 6.1.1-deb13u1
Machine:
  Type: Other-vm? System: Acer product: Aspire 5315 v: V1.45
    serial: <superuser required>
  Mobo: Acer model: Acadia v: V1.45 serial: <superuser required> BIOS: Acer
    v: 1.45 date: 11/10/2008
Battery:
  ID-1: BAT0 charge: 29.5 Wh (100.0%) condition: 29.5/48.8 Wh (60.4%)
CPU:
  Info: single core model: Intel Celeron 530 bits: 64 cache: L2: 1024 KiB
  Speed (MHz): 1729 min/max: N/A core: 1: 1729
Graphics:
  Device-1: Intel Mobile GM965/GL960 Integrated Graphics driver: i915
    v: kernel
  Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_wayland driver: gpu: i915 resolution: 1280x800~60Hz
  API: EGL v: 1.5 drivers: crocus,swrast
    platforms: gbm,wayland,x11,surfaceless,device
  API: OpenGL v: 4.5 compat-v: 2.1 vendor: intel mesa v: 25.0.7-2
    renderer: Mesa Intel 965GM (CL)
  API: Vulkan v: 1.4.309 drivers: llvmpipe surfaces: xcb,xlib,wayland
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo
    de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdriinfo,
    xdpyinfo, xprop, xrandr
Audio:
  Device-1: Intel 82801H HD Audio driver: snd_hda_intel
  API: ALSA v: k6.12.43+deb13-amd64 status: kernel-api
  Server-1: PipeWire v: 1.4.2 status: active
Network:
  Device-1: Broadcom NetLink BCM5906M Fast Ethernet PCI Express driver: tg3
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: 00:1b:38:62:98:4d
  Device-2: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter
    driver: ath5k
  IF: wlp6s0 state: down mac: 00:1d:d9:53:d6:0c
Drives:
  Local Storage: total: 119.24 GiB used: 8.62 GiB (7.2%)
  ID-1: /dev/sda vendor: Patriot model: P210 128GB size: 119.24 GiB
Partition:
  ID-1: / size: 116.81 GiB used: 8.62 GiB (7.4%) fs: ext4 dev: /dev/sda1
Swap:
  ID-1: swap-1 type: file size: 512 MiB used: 512 KiB (0.1%) file: /swapfile
Sensors:
  System Temperatures: cpu: 60.0 C mobo: N/A
  Fan Speeds (rpm): N/A
Info:
  Memory: total: 2 GiB available: 1.92 GiB used: 1.11 GiB (57.7%)
  Processes: 159 Uptime: 9m Shell: Bash inxi: 3.3.38
germ@q4os:~$
#2 2025-09-13 09:11
Re: Old Acer Install Q4OS 6.1 Andromeda
+1
#3 2025-09-13 13:15
Germ
Unfortunately, the behavior is the same as with the rc releases.  Whatever Q4OS tool I try crashes.  The only difference is I do not experience a logout/reboot when using them.  The screen blanks blanks for a second and the  tool crashes.  Synaptic works fine and CLI works fine.
#4 2025-09-13 13:19
What if you log into Xorg session instead of Wayland ?
#5 2025-09-13 13:44
Germ
I logged into a X11 session and the behavior is the same.  The OS itself works fine but the Q4OS tools are crashing.
#6 2025-09-13 13:48
We will continue trying to get hardware in question and reproduce, investigate and fix the issue. In anyway thanks for testing and reporting, it's really valuable for us.
#7 2025-09-13 13:52
Germ
You are most welcome.  I'm glad to help.
#8 2025-09-13 16:08
Germ
On another note, I installed 6.1 TDE and everything works perfectly.   The OS and all the Q4OS tools!
This is on the same laptop.
#9 2025-09-13 16:17
Yes, that's important info, thanks.
#10 2025-09-13 19:47
Germ
You're welcome.
