#1 2025-08-21 14:23
About Q4OS Raspberry Pi edition
I have to use raspberry pi for a project and since there is a raspberry pi flavour of Q4OS, i want to use it instead of plain raspbian~ I've gotta install an os tomorrow. I have a couple questions regarding it
  • What's the difference between the unofficial version and the testing version?
  • Does it offer Trinity DE, if so does it offer the latest version of TDE?
  • What are the advantages of using Q4OS over plain raspbian+TDE
  • What devices are supported? Is raspberry pi 3(b+) supported?
  • What debian version is the testing and unofficial versions based on?
  • Does Q4OS raspbian allow connections over GPIO?
  • Is the os 32bit or 64bit?
#2 2025-08-21 16:03
Re: About Q4OS Raspberry Pi edition
- Unofficial means we don't guarantee support
- TDE 14.1.1, if more users would ask we can provide an upgrade to most recent stable 14.1.4
- Q4OS tools
- Any that Raspbian supports
- Raspbian Bookworm
- Yes
- 32bit as based on Raspbian Bookworm
#3 2025-08-21 17:03
Thanks!
Seems like Raspberry Pi OS Lite (64-bit) + TDE would be better for my use case~
