Hi All,
I just got Orion booted on the above hardware. Only sticky point seems to be achieving 1920x1080 resolution.
The chipset is correctly recognised in 'Hardware Devices' but its running at 1280 x 1024.
Any tips on how to get this to match my monitor? [1920x1080]
Thanks!
I have a similar question (not trying to hijack thread) after setting correct resolution in above question.
How do you lock the resolution once its changed to the correct resolution.
Each time I reboot my HP Laptop, it reverts back to 1024 x 768 and its distorted.
I find that 1440 x ... is perfect but, it always reverts to lower resolution.
Thanks,
Bobby
No Longer Using Q4OS
My resolution (1920x1080) is set automatically, but if it wasn't I would start by looking at the results of
xrandrto see what that says, and if there is a resolution available that you want it could be set in xorg.conf, but settings can be a bit fiddly in my experiance.
Been goofing around with an xorg.conf for ages - but cant get this to work ![]()
what does xrandr return?
One thing you could check, Are you a member of the video group? I have read that it matters in some cases,
groups
dai adm dialout fax cdrom floppy tape sudo audio dip video plugdev users netdev lpadmin scanner vboxusersif not just
sudo -a -G video <username> Obviously you put your own user name in place of <username>. It might make a difference.
And if you are having problems getting the ModeLine values for xorg.conf ther is a site that will work them out for you here:- http://xtiming.sourceforge.net/cgi-bin/xtiming.pl
sysadmin@q4os-desktop:~$ xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 640 x 480, current 1280 x 1024, maximum 1280 x 1024
default connected 1280x1024+0+0 0mm x 0mm
1280x1024 0.00*
1024x768 0.00
800x600 0.00
640x480 0.00
To See all groups available:
cut -d: -f1 /etc/groupNo Longer Using Q4OS
I'm in the video group
sysadmin@q4os-desktop:~$ groups
sysadmin cdrom floppy sudo audio dip video plugdev netdev lpadmin
The more I look at this the more I think that the Dell FX160, whilst a nice looking box, is entirely let down by crappy SiS!
I would try CC's suggestion and look to see if they have any information available, and check the specs for the video card to make sure it is capable of hd output, I had an old box that was capable of 1280x960 but without my custom xorg.conf would never display that res, so if you are sure your card supports it, get the ModeLine settings from the link i posted earlier and set that into xorg.conf and it should get you where you want top be.
I just checked sis website and they offer (for linux) two drivers, one for the SiS650 & SiS740 and the other for the SiS630 & SiS730 chips, would either of these be any use?
Saw those too and tried the 630 to no avail. This is my xorg.conf ;
Section "Monitor"
Identifier "Monitor0"
DisplaySize 520 290 # In millimeters
HorizSync 24-83
VertRefresh 50-76
ModelName "G2410HD"
Option "DPMS"
VendorName "BenQ"
Modeline "1920x1080" 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync
EndSection
Section "Device"
Identifier "Device0"
Driver "vesa"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1920x1080"
EndSubSection
EndSection
and here is xorg log file
[ 2132.458]
X.Org X Server 1.16.4
Release Date: 2014-12-20
[ 2132.458] X Protocol Version 11, Revision 0
[ 2132.458] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian
[ 2132.458] Current Operating System: Linux q4os-desktop 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt20-1+deb8u4 (2016-02-29) x86_64
[ 2132.458] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.16.0-4-amd64 root=UUID=748862fa-4a6a-4645-b7c0-e20e7cc15648 ro quiet loglevel=3 TERM=dumb
[ 2132.458] Build Date: 11 February 2015 12:32:02AM
[ 2132.458] xorg-server 2:1.16.4-1 (http://www.debian.org/support)
[ 2132.458] Current version of pixman: 0.32.6
[ 2132.458] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 2132.458] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 2132.459] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Mar 14 20:53:30 2016
[ 2132.459] (==) Using config file: "/etc/X11/xorg.conf"
[ 2132.459] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 2132.459] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 2132.460] (==) No Layout section. Using the first Screen section.
[ 2132.460] (**) |-->Screen "Screen0" (0)
[ 2132.460] (**) | |-->Monitor "Monitor0"
[ 2132.461] (**) | |-->Device "Device0"
[ 2132.461] (==) Automatically adding devices
[ 2132.461] (==) Automatically enabling devices
[ 2132.461] (==) Automatically adding GPU devices
[ 2132.461] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[ 2132.461] Entry deleted from font path.
[ 2132.461] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 2132.461] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 2132.461] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 2132.461] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[ 2132.461] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 2132.461] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 2132.461] (==) FontPath set to:
built-ins
[ 2132.461] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 2132.462] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 2132.462] (II) Loader magic: 0x7f5498a2ad80
[ 2132.462] (II) Module ABI versions:
[ 2132.462] X.Org ANSI C Emulation: 0.4
[ 2132.462] X.Org Video Driver: 18.0
[ 2132.462] X.Org XInput driver : 21.0
[ 2132.462] X.Org Server Extension : 8.0
[ 2132.464] (--) PCI:*(0:1:0:0) 1039:6351:1028:0281 rev 16, Mem @ 0xd0000000/268435456, 0xfeae0000/131072, I/O @ 0x0000ec00/128
[ 2132.464] (II) LoadModule: "glx"
[ 2132.465] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 2132.469] (II) Module glx: vendor="X.Org Foundation"
[ 2132.469] compiled for 1.16.4, module version = 1.0.0
[ 2132.470] ABI class: X.Org Server Extension, version 8.0
[ 2132.470] (==) AIGLX enabled
[ 2132.470] (II) LoadModule: "vesa"
[ 2132.470] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 2132.470] (II) Module vesa: vendor="X.Org Foundation"
[ 2132.470] compiled for 1.15.99.904, module version = 2.3.3
[ 2132.470] Module class: X.Org Video Driver
[ 2132.470] ABI class: X.Org Video Driver, version 18.0
[ 2132.470] (II) VESA: driver for VESA chipsets: vesa
[ 2132.470] (++) using VT number 7
[ 2132.472] (II) Loading sub module "vbe"
[ 2132.472] (II) LoadModule: "vbe"
[ 2132.473] (II) Loading /usr/lib/xorg/modules/libvbe.so
[ 2132.474] (II) Module vbe: vendor="X.Org Foundation"
[ 2132.474] compiled for 1.16.4, module version = 1.1.0
[ 2132.474] ABI class: X.Org Video Driver, version 18.0
[ 2132.474] (II) Loading sub module "int10"
[ 2132.474] (II) LoadModule: "int10"
[ 2132.475] (II) Loading /usr/lib/xorg/modules/libint10.so
[ 2132.475] (II) Module int10: vendor="X.Org Foundation"
[ 2132.475] compiled for 1.16.4, module version = 1.0.0
[ 2132.475] ABI class: X.Org Video Driver, version 18.0
[ 2132.476] (II) VESA(0): initializing int10
[ 2132.478] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[ 2132.480] (II) VESA(0): VESA BIOS detected
[ 2132.480] (II) VESA(0): VESA VBE Version 3.0
[ 2132.480] (II) VESA(0): VESA VBE Total Mem: 131072 kB
[ 2132.480] (II) VESA(0): VESA VBE OEM: SiS
[ 2132.480] (II) VESA(0): VESA VBE OEM Software Rev: 1.0
[ 2132.480] (II) VESA(0): VESA VBE OEM Vendor: Silicon Integrated Systems Corp.
[ 2132.480] (II) VESA(0): VESA VBE OEM Product: 6330
[ 2132.480] (II) VESA(0): VESA VBE OEM Product Rev: 3.74.29
[ 2132.494] (**) VESA(0): Depth 24, (--) framebuffer bpp 32
[ 2132.494] (==) VESA(0): RGB weight 888
[ 2132.495] (==) VESA(0): Default visual is TrueColor
[ 2132.495] (==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 2132.495] (II) Loading sub module "ddc"
[ 2132.495] (II) LoadModule: "ddc"
[ 2132.495] (II) Module "ddc" already built-in
[ 2132.513] (II) VESA(0): VESA VBE DDC supported
[ 2132.514] (II) VESA(0): VESA VBE DDC Level 2
[ 2132.514] (II) VESA(0): VESA VBE DDC transfer in appr. 1 sec.
[ 2132.594] (II) VESA(0): VESA VBE DDC read successfully
[ 2132.595] (II) VESA(0): Manufacturer: BNQ Model: 7822 Serial#: 21573
[ 2132.595] (II) VESA(0): Year: 2009 Week: 20
[ 2132.595] (II) VESA(0): EDID Version: 1.3
[ 2132.595] (II) VESA(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
[ 2132.595] (II) VESA(0): Sync: Separate Composite SyncOnGreen
[ 2132.595] (II) VESA(0): Max Image Size [cm]: horiz.: 52 vert.: 29
[ 2132.595] (II) VESA(0): Gamma: 2.20
[ 2132.595] (II) VESA(0): DPMS capabilities: Off; RGB/Color Display
[ 2132.595] (II) VESA(0): Default color space is primary color space
[ 2132.595] (II) VESA(0): First detailed timing is preferred mode
[ 2132.595] (II) VESA(0): redX: 0.647 redY: 0.334 greenX: 0.284 greenY: 0.607
[ 2132.595] (II) VESA(0): blueX: 0.151 blueY: 0.071 whiteX: 0.313 whiteY: 0.329
[ 2132.595] (II) VESA(0): Supported established timings:
[ 2132.595] (II) VESA(0): 720x400@70Hz
[ 2132.595] (II) VESA(0): 640x480@60Hz
[ 2132.595] (II) VESA(0): 640x480@75Hz
[ 2132.595] (II) VESA(0): 800x600@60Hz
[ 2132.595] (II) VESA(0): 800x600@75Hz
[ 2132.595] (II) VESA(0): 832x624@75Hz
[ 2132.595] (II) VESA(0): 1024x768@60Hz
[ 2132.595] (II) VESA(0): 1024x768@75Hz
[ 2132.595] (II) VESA(0): 1280x1024@75Hz
[ 2132.595] (II) VESA(0): 1152x864@75Hz
[ 2132.595] (II) VESA(0): Manufacturer's mask: 0
[ 2132.595] (II) VESA(0): Supported standard timings:
[ 2132.595] (II) VESA(0): #0: hsize: 1152 vsize 720 refresh: 60 vid: 113
[ 2132.596] (II) VESA(0): #1: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 2132.596] (II) VESA(0): #2: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 2132.596] (II) VESA(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 2132.596] (II) VESA(0): #4: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 2132.596] (II) VESA(0): #5: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 2132.596] (II) VESA(0): #6: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 2132.596] (II) VESA(0): Supported detailed timing:
[ 2132.596] (II) VESA(0): clock: 148.5 MHz Image Size: 477 x 268 mm
[ 2132.596] (II) VESA(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 2132.596] (II) VESA(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 2132.596] (II) VESA(0): Serial No: D5909699SL000
[ 2132.596] (II) VESA(0): Ranges: V min: 50 V max: 76 Hz, H min: 24 H max: 83 kHz, PixClock max 175 MHz
[ 2132.596] (II) VESA(0): Monitor name: BenQ G2410HD
[ 2132.596] (II) VESA(0): EDID (in hex):
[ 2132.596] (II) VESA(0): 00ffffffffffff0009d1227845540000
[ 2132.596] (II) VESA(0): 141301030e341d782eeed5a555489b26
[ 2132.596] (II) VESA(0): 125054a56b80710081c081408180a9c0
[ 2132.596] (II) VESA(0): b300d1c00101023a801871382d40582c
[ 2132.596] (II) VESA(0): 4500dd0c1100001e000000ff00443539
[ 2132.596] (II) VESA(0): 3039363939534c303030000000fd0032
[ 2132.596] (II) VESA(0): 4c185311000a202020202020000000fc
[ 2132.596] (II) VESA(0): 0042656e5120473234313048440a00f7
[ 2132.596] (II) VESA(0): EDID vendor "BNQ", prod id 30754
[ 2132.597] (II) VESA(0): Using hsync ranges from config file
[ 2132.597] (II) VESA(0): Using vrefresh ranges from config file
[ 2132.597] (II) VESA(0): Printing DDC gathered Modelines:
[ 2132.597] (II) VESA(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 2132.597] (II) VESA(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 2132.597] (II) VESA(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 2132.597] (II) VESA(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 2132.597] (II) VESA(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 2132.597] (II) VESA(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 2132.597] (II) VESA(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 2132.597] (II) VESA(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 2132.597] (II) VESA(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 2132.597] (II) VESA(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 2132.597] (II) VESA(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 2132.597] (II) VESA(0): Modeline "1152x720"x60.0 67.32 1152 1208 1328 1504 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 2132.597] (II) VESA(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 2132.597] (II) VESA(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 2132.597] (II) VESA(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 2132.597] (II) VESA(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 2132.597] (II) VESA(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 2132.597] (II) VESA(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[ 2132.597] (II) VESA(0): Searching for matching VESA mode(s):
[ 2132.598] Mode: 101 (640x480)
Lots of text cut for sake of brevity
[ 2132.652]
[ 2132.652] (II) VESA(0): Total Memory: 2048 64KB banks (131072kB)
[ 2132.652] (II) VESA(0): Monitor0: Using hsync range of 24.00-83.00 kHz
[ 2132.652] (II) VESA(0): Monitor0: Using vrefresh range of 50.00-76.00 Hz
[ 2132.652] (II) VESA(0): Monitor0: Using maximum pixel clock of 175.00 MHz
Next two lines are interesting....
[ 2132.652] (II) VESA(0): Not using mode "1920x1080" (no mode of this name)
[ 2132.652] (II) VESA(0): Not using built-in mode "1600x1200" (no mode of this name)
[ 2132.653] (--) VESA(0): Virtual size is 1280x1024 (pitch 1280)
[ 2132.653] (**) VESA(0): Built-in mode "1280x1024"
[ 2132.653] (**) VESA(0): Built-in mode "1024x768"
[ 2132.653] (**) VESA(0): Built-in mode "800x600"
[ 2132.653] (**) VESA(0): Built-in mode "640x480"
[ 2132.653] (++) VESA(0): DPI set to (96, 96)
[ 2132.653] (**) VESA(0): Using "Shadow Framebuffer"
[ 2132.653] (II) Loading sub module "shadow"
[ 2132.653] (II) LoadModule: "shadow"
[ 2132.654] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 2132.654] (II) Module shadow: vendor="X.Org Foundation"
[ 2132.654] compiled for 1.16.4, module version = 1.1.0
[ 2132.655] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2132.655] (II) Loading sub module "fb"
[ 2132.655] (II) LoadModule: "fb"
[ 2132.655] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 2132.655] (II) Module fb: vendor="X.Org Foundation"
[ 2132.655] compiled for 1.16.4, module version = 1.0.0
[ 2132.656] (==) Depth 24 pixmap format is 32 bpp
[ 2132.656] (II) Loading sub module "int10"
[ 2132.656] (II) LoadModule: "int10"
[ 2132.656] (II) Loading /usr/lib/xorg/modules/libint10.so
[ 2132.657] (II) Module int10: vendor="X.Org Foundation"
[ 2132.657] compiled for 1.16.4, module version = 1.0.0
[ 2132.657] ABI class: X.Org Video Driver, version 18.0
[ 2132.657] (II) VESA(0): initializing int10
[ 2132.658] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[ 2132.659] (II) VESA(0): VESA BIOS detected
[ 2132.659] (II) VESA(0): VESA VBE Version 3.0
[ 2132.659] (II) VESA(0): VESA VBE Total Mem: 131072 kB
[ 2132.659] (II) VESA(0): VESA VBE OEM: SiS
[ 2132.659] (II) VESA(0): VESA VBE OEM Software Rev: 1.0
[ 2132.659] (II) VESA(0): VESA VBE OEM Vendor: Silicon Integrated Systems Corp.
[ 2132.659] (II) VESA(0): VESA VBE OEM Product: 6330
[ 2132.659] (II) VESA(0): VESA VBE OEM Product Rev: 3.74.29
[ 2132.660] (II) VESA(0): virtual address = 0x7f5489fd9000,
physical address = 0xd0000000, size = 134217728
[ 2132.672] (II) VESA(0): Setting up VESA Mode 0x11B (1280x1024)
[ 2132.721] (==) VESA(0): Default visual is TrueColor
[ 2132.722] (==) VESA(0): Backing store enabled
[ 2132.722] (**) VESA(0): DPMS enabled
[ 2132.722] (==) RandR enabled
[ 2132.741] (II) SELinux: Disabled on system
[ 2132.743] (II) AIGLX: Screen 0 is not DRI2 capable
[ 2132.743] (EE) AIGLX: reverting to software rendering
[ 2132.801] (II) AIGLX: Loaded and initialized swrast
[ 2132.802] (II) GLX: Initialized DRISWRAST GL provider for screen 0
I read somewhere that you can add extra modes using xrand?
Xorg has a driver xserver-xorg-video-sis that should support it if its installed and should be in the repository. If its already installed and causing this issue then youll have to look for a driver alternative.
sysadmin@q4os-desktop:~$ sudo apt-get install xserver-xorg-video-sis
Reading package lists... Done
Building dependency tree
E: Unable to locate package xserver-xorg-video-sis
Take a look at this website even though it doesnt directly apply but the driver you use must be for the 771/671.
Log file ID's it as ;
I didn't have much luck with that either ![]()
Try synaptic instead and see if you spot anything as im not on Q4OS at the moment so I cant check for you.
Hate to say... tried that already... thanks for suggestions though ![]()
I can see "xserver-xorg-video-sisusb - X.Org X server -- SiS USB display driver" in the repo's but looks like it relates to usb?
I can't see anything wrong with your xorg.conf although mine does look slightly different, I'll paste mine here (not for a hi res screen though) in case it holds any clues for you.
Section "Device"
Identifier "Configured Video Device"
Boardname "NVIDIA GeForce2 Integrated (generic)"
Busid "PCI:1:0:0"
Driver "nv"
Screen 0
Vendorname "NVIDIA"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
Vendorname "Compaq"
Modelname "Compaq 7500 Color Monitor"
Horizsync 30.0-70.0
Vertrefresh 50.0-140.0
modeline "800x600@60" 40.0 800 840 968 1056 600 601 605 628 +hsync +vsync
modeline "1024x768@75" 78.8 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
modeline "1024x768@70" 75.0 1024 1048 1184 1328 768 771 777 806 -vsync -hsync
modeline "1024x768@60" 65.0 1024 1048 1184 1344 768 771 777 806 -vsync -hsync
modeline "1280x1024@60" 108.0 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Gamma 1.0
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
Device "Configured Video Device"
Defaultdepth 24
Depth 24
Modes "1280x1024@60" "1024x768@60" "1024x768@70" "1024x768@75" "800x600@60"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
screen 0 "Default Screen" 0 0
EndSectionAs you can see I have an extra section at the end, but I don't know what difference that will make. Could be worth a try though?
Take a look at this, http://forums.debian.net/viewtopic.php?f=6&t=120734
One guy claims the 0.10.8 new driver from Xorg works.
This worked ![]()
http://forums.debian.net/viewtopic.php? … 34#p601888
I have to admit that several hours ago I read that and thought... nah, I shouldn't have to go through all _that_!!!
Anyway, as this SIS chipset is quite old and less common these days one hopes no one else will have to go through
this too lol!
Another bazookie whacky night on Q4OS!
Another good find CC +1
