#1 2025-07-18 15:51
Q4OS 6 testing alpha
We have just released Q4OS 6 "alpha-r9", Plasma and Trinity versions. There are a few known bugs to be fixed, but it is inevitably heading towards a more stable beta version.
Download from our testing repository https://sourceforge.net/projects/q4os/files/testing/ . Testing and reporting is welcome.
#2 2025-07-19 13:35
noseph
Re: Q4OS 6 testing alpha
Installed Basic on my 11yr old Acer Chromebook R11 without issue. Wayland seems to run smother than X11. I have not experienced and issues so far. My use case is light, watch TV thru HDHomeRun using MPV, Google Sheets, and Chrome browsing and email. Excellent job. Definitely runs better on this older hardware than 5.8 Aquarius Plasma.
Quidquid Latine dictum sit, altum sonatur.
#3 2025-07-19 19:10
@noseph, if the R11 has the celeron processor and only 2gb ram, no doubt the TDE version will run better. 4gb of ram though with a i3 or better, Plasma runs very well.
#4 2025-07-19 22:26
noseph
The R11 has 4gb of ram and 32gb of storage. I have been running Q4OS Plasma on it since it went end of support on ChromeOS (~3yr now).
#5 2025-07-19 22:29
What processor is it using?
#6 2025-07-19 22:33
noseph
Celeron N3150, actually runs fairly snappy on 6.
#7 2025-07-19 22:35
Once the Q4OS 6 final comes out, I dont think you would have any issue running the Plasma version, not that you need to though.
#8 2025-07-19 22:38
noseph
Not having any issues running the 6 alpha.
#9 2025-07-19 22:41
Youre running TDE which already has lightweight resource usage. Plasma will probably run fine as well but with the final, I think it will run more stable and a bit lighter than an alpha/beta.
#10 2025-07-19 22:56
noseph
You have made the wrong assumption I installed "q4os-6.0-x64-plasma.r9-testing-alpha.iso" from the link in the initial post.
#11 2025-07-19 23:07
Sorry I missed that in post #4 nojoseph,as I sometimes read too fast for my own good. Glad to see that Plasma 6 runs well on your hardware.
#12 2025-07-21 12:51
Just been testing TDE alpha 9 in Virtualbox.
The only thing that jumps out is the default cursor size which seems to be a bit on the small side.
Swapping to my favourite DMZ-White and it is the 'normal' size.
#13 2025-07-30 10:28
Q4OS 6 "alpha-r10" has been released, download https://sourceforge.net/projects/q4os/files/testing/
#14 2025-08-02 21:24
noseph
Just a quick update. It has been 2 weeks since I installed Q4OS6 Alpha r9 Plasma on my Acer Chromebook R11. I have not experienced any failures, and the system continues to run smoothly. The system did have several updates in the past week, I assume the r10 patches. Great job guys.
I also installed Alpha r10 Plasma on a spare ThinkCentre M73, it is also running flawlessly.
#15 2025-08-02 22:12
@noseph
Thanks smile
