#1 2025-06-06 17:23
padota1663
Packagekit errors in syslog
Hi,
does someone know what is this error (spammed multiple times) in my syslog? It appears when the Packagekit daemon starts automatically:
2025-06-01T22:05:39.934004+02:00 scatorrrciooo-sorrrciooo systemd[1]: Started packagekit.service - PackageKit Daemon.
2025-06-01T22:05:41.060505+02:00 scatorrrciooo-sorrrciooo packagekitd[2213744]: pk_package_set_update_severity: assertion 'update_severity == PK_INFO_ENUM_U
NKNOWN || update_severity == PK_INFO_ENUM_LOW || update_severity == PK_INFO_ENUM_NORMAL || update_severity == PK_INFO_ENUM_IMPORTANT || update_severity == P
K_INFO_ENUM_CRITICAL' failed
2025-06-01T22:05:41.060895+02:00 scatorrrciooo-sorrrciooo packagekitd[2213744]: pk_package_set_update_severity: assertion 'update_severity == PK_INFO_ENUM_U
------ ***logs cut for clarity*** ------
2025-06-01T22:05:41.087083+02:00 scatorrrciooo-sorrrciooo packagekitd[2213744]: pk_package_set_update_severity: assertion 'update_severity == PK_INFO_ENUM_UNKNOWN || update_severity == PK_INFO_ENUM_LOW || update_severity == PK_INFO_ENUM_NORMAL || update_severity == PK_INFO_ENUM_IMPORTANT || update_severity == PK_INFO_ENUM_CRITICAL' failed
2025-06-01T22:05:41.092286+02:00 scatorrrciooo-sorrrciooo PackageKit: get-updates transaction /543_bededdbb from uid 1000 finished with success after 1120ms
2025-06-01T22:10:44.762258+02:00 scatorrrciooo-sorrrciooo PackageKit: daemon quit
2025-06-01T22:10:44.791540+02:00 scatorrrciooo-sorrrciooo systemd[1]: packagekit.service: Deactivated successfully.
2025-06-01T22:10:44.791763+02:00 scatorrrciooo-sorrrciooo systemd[1]: packagekit.service: Consumed 1.200s CPU time.
How can I solve it? And, more importantly, is it something to be afraid of? The PC behaves normally anyways.
Thanks
#2 2025-06-11 21:07
padota1663
Re: Packagekit errors in syslog
Hello, can anyone help me?
Thanks
#3 2025-06-11 21:18
Run in terminal:
$ sudo apt update
and post the output
#4 2025-07-09 13:38
padota1663
Hi q4osteam,
sorry for the late reply, but I was away for work and I lost your last message.
Here's the result of "sudo apt update":
root@scatorrrciooo-sorrrciooo:~# sudo apt update
Trovato:1 http://security.debian.org bookworm-security InRelease
Trovato:2 http://deb.debian.org/debian bookworm InRelease
Trovato:3 http://deb.debian.org/debian bookworm-updates InRelease
Trovato:8 https://dl.google.com/linux/chrome/deb stable InRelease
Trovato:9 https://packages.mozilla.org/apt mozilla InRelease
Trovato:4 https://q4os.org/q4repo q4os-5-0-cn InRelease
Scaricamento di:5 https://q4os.org/qtderepo bookworm InRelease [4.637 B]
Scaricamento di:6 https://q4os.org/qextrepo bookworm-chrome-cn InRelease [1.844 B]
Scaricamento di:7 https://q4os.org/qextrepo bookworm-firefox-cn InRelease [3.224 B]
Trovato:10 https://boinc.berkeley.edu/dl/linux/stable/bookworm bookworm InRelease
Recuperati 9.705 B in 4s (2.562 B/s)
Lettura elenco dei pacchetti... Fatto
Generazione albero delle dipendenze... Fatto
Lettura informazioni sullo stato... Fatto
254 pacchetti possono essere aggiornati: eseguire "apt list --upgradable" per vederli.
W: https://boinc.berkeley.edu/dl/linux/stable/bookworm/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
Thank you in advance.
#5 2025-07-09 14:02
You need to update your system first. Do you perform updates manually ? Have you installed update manager ?
#6 2025-07-16 23:53
padota1663
Hi, yes I know, I have to update my system (it's since the 12th of February that it's never been turned off or restarted, or even updated to avoid restarts) but at the moment I'm not able, as I have important pages opened in Firefox which I cannot close right now.
Let's put this question on hold then, I'll update it as soon as I'll be able to close FF, update everything and restart.
Thanks for now.
#7 2025-09-08 13:04
padota1663
Hi, I updated in the end, as my PC froze and I had to restart, so I caught the opportunity to update everything, but the issue persists.
Anyways, it doesn't matter anymore to me, as I decided to quit Q4OS and wipe the PC as explained in this post: https://www.q4os.org/forum/viewtopic.ph … 823#p31823
Thanks for all your support.
#8 2025-09-08 13:51
padota1663 wrote:
I updated in the end, as my PC froze and I had to restart...
That may be a hardware issue as it looks like that.
