#1 2025-06-01 17:11
BrJPedro
Windows Installer - from a 32bit machine
Hello
This is not directly related to Q4OS itself but for its installation process, if someone can help me I would be glad
I own some Windows XP machines that I would like to use it connected to the internet, but (as you can imagine) it is not a good idea to use WinXP nowadays
So I thought about installing Q4OS on them. I'm sure it should run fine.
But
I can't boot it into BIOS or even USB boot, so, my only choice is to remove the disk and install using other computer, or.. maybe install directly from within XP?
Is there a way for me to achieve this? Like the Windows Installer, but for 32bit (and old) machine
Or even doing manually somehow. Installing another bootloader from within XP maybe? I don't know
If someone knows anything about this, it will help me a lot
#2 2025-06-01 18:46
Re: Windows Installer - from a 32bit machine
Do these machines have cd/dvd drives?  You could try live media install and if you use a fresh drive without WinXP it should allow the install.
I work with older hardware a lot and external usb drives work fine as long as youre using a fresh drive.
Why cant you access the bios? You could go into the system and pull the cmos battery with it unplugged and clear the bios if needed.
Q4OS KDE 5.x-  Lenovo M73 Tiny  4th gen i5 Intel cpu, 16gb ram, 256gb ssd
#3 2025-06-02 06:41
detoo
Live media option is no longer available for 32-bit machines:
https://www.q4os.org/forum/viewtopic.ph … 363#p23363
#4 2025-06-02 12:14
BrJPedro
I can access Network boot, where I can select between DHCP or PXE boot options, but as I never installed anything through network, i don't know how to setup it
I can't access the BIOS because it asks for password, and I don't know the password. These machines are old.
They're thin clients, without CD/DVD drives
Maybe I can force to boot them from USB if i unplug the internal drive first, but I never tried this yet.
I tried to use an old version of Wubi installer but it doesn't open on Windows XP.
Maybe I should try an even older version, but i don't know...
#5 2025-06-02 19:35
Sorry my vision isnt what it use to be and I missed the 32bit part.   Can you clear the bios on that thin client thru a jumper or removing the cmos battery(check service manual)?
Depending on the make of the system there may be some generic passwords such as Dell uses that would work, but that would need to be researched.
MX Linux and Debian offer 32bit with live cd which might be an option if all else fails. Finding a way to clear the bios really is a must.
You can use an external cd/dvd drive/usb  if the bios situation can be solved.
What model thin client is it?
#6 2025-06-02 20:21
Take a look at this and see if it can work,  https://wiki.debian.org/PXEBootInstall
Not havng access to your bios could still be an issue.
#7 2025-06-02 20:23
BrJPedro
It's a very very old thin client, Brazilian model, which run an AMD Geode processor.
WinXP barely runs, lol.
For now I don't have time to open it to check, so I'll only do it next weekend maybe. It is not my main machine.
#8 2025-06-02 20:34
Check out post #6 as there is a chance you may not need to get into the bios.
