#26 2025-05-14 13:59
Re: File Transfert too slow
minuccio63 wrote:
Installed Plasma... both in Trinity and Plasma file transfer OK even in Trinity now it is faster than Plasma, should I leave it like this?
Yes, you can safely keep Plasma within your system now. We are going to perform some investigation and post the results here. We may need some additional info as the investigation goes further.
Are you using Quarkos now ? You may also install Q4OS in the same manner to get the proper transfer speeds.
As soon as we fix the issue, you can remove Plasma or make a fresh Trinity desktop install.
Anyway, thanks for the valuable reporting.
#27 2025-05-14 16:43
minuccio63
No now I'm using Q4OS with a basic Trinity installation and the addition of Plasma, the desktop I use is Trinity... ok I remain available for any other tests even if I would like to do one now, how can I remove Plasma and leave only Trinity to see if the problem occurs again?
#28 2025-05-14 17:05
minuccio63 wrote:
... how can I remove Plasma and leave only Trinity to see if the problem occurs again?
Just run in terminal:
$ sudo apt --purge autoremove *plasma* *sddm*
$ sudo dpkg-reconfigure tdm-trinity
It will not remove all of, but most of.Plasma components.
Reboot and report what happens.
Edit:
You also need to run:
to get TDM login screen active
#29 2025-05-14 17:48
minuccio63
Thanks I try
#30 2025-05-14 18:42
minuccio63
After removing Plasma file transfer = slow.
Reinstalling Plasma on Trinity, speed = fast
#31 2025-05-14 19:04
So we need to find the specific package that makes the difference. If you notice anything valuable, let us know.
#32 2025-05-14 19:25
Could this be an issue regarding file managers? Trinity uses Konqueror, KDE uses Dolphin. It may indirectly affect how the file transfers are managed.
#33 2025-05-14 19:46
Possible, but not very likely. Dolphin could install some dependency that would affect low level "rsync" command, maybe.
The "fuse3" and "libfuse3-3" packages are suspicious.
#34 2025-05-14 20:19
minuccio63
I had thought about this too and tried to install Nemo, Dolphin and Nautilus... the result did not change, the file manager is not the problem
#35 2025-05-14 21:18
There may be a difference between the trinity-dolphin package and the dolphin package(or any trinity- package versus a non-trinity package file manager) used in KDE.  I run Plasma exclusively and have never had issues with slow file transfer.
Whats interesting is KDE that Ive used with other distros well in the past, has also had issues with slow file transfers.
#36 2025-05-15 14:37
minuccio63
In fact, that's what we're trying to solve... if I install Q4OS Trinity I have file transfer problems, but if I install Plasma I have no speed problems and I even did another test, I installed Q4OS Trinity and updated the Desktop Environment in Gnome... file transfer speed = high!
The problem is only in "pure" Trinity
#37 2025-05-15 15:09
You could also try to install packages "fuse3" and "libfuse3-3" and see if it affects the speed:
$ sudo apt install fuse3 libfuse3-3
@crosscourt
Interesting fact is, that transfer speeds are low if you stop Trinity desktop completely too. Just with "rsync" command, see https://www.q4os.org/forum/viewtopic.ph … 609#p29609
#38 2025-05-15 16:44
minuccio63
Sorry should I try on Trinity with slow transfer or now that the transfer is fast?
Thanks
#39 2025-05-15 16:50
Try to install packages on the Trinity with slow speed, reboot and see if it makes speed higher,
#40 2025-05-15 18:20
@q4osteam, I missed that in the discussion, thanks for the link.
#41 2025-05-16 08:19
minuccio63
Update:
New fresh installation Q4OS Trinity 64bit Basic
test transfert file = slow
installation fuse 3 and libfuse 3-3 : always present
root@mino-6730s:/home/mino# apt install fuse3 libfuse3-3
Lettura elenco dei pacchetti... Fatto
Generazione albero delle dipendenze... Fatto
Lettura informazioni sullo stato... Fatto
fuse3 è già alla versione più recente (3.14.0-4).
È stato impostato fuse3 per l'installazione manuale.
libfuse3-3 è già alla versione più recente (3.14.0-4).
È stato impostato libfuse3-3 per l'installazione manuale.
0 aggiornati, 0 installati, 0 da rimuovere e 0 non aggiornati.
Sorry for respons in italian but I'm Italian
#42 2025-05-16 08:39
Thanks, so we need to check another libraries, that could affect the USB data transfer.
Yes,that is fine, no need to translate system messages smile
#43 2025-05-16 14:47
minuccio63
Just to complete the information, after installing Plasma or Gnome on Trinity and verifying that the file copy was fast, without uninstalling Gnome or Plasma I ran the command: sudo dpkg-reconfigure tdm-trinity
the copy speed is slow again
#44 2025-05-16 15:00
minuccio63 wrote:
Just to complete the information, after installing Plasma or Gnome on Trinity and verifying that the file copy was fast, without uninstalling Gnome or Plasma I ran the command: sudo dpkg-reconfigure tdm-trinity the copy speed is slow again
Is it reproducible anytime you configure Trinity display manager as default ? Great, this is very important info, we seem getting closer to a resolution.
So would you now run the following test please ?
- Start with Trinity desktop with slow speed and Trinity TDM display manager as the default. Checkpoint-1
- Install sddm display manager, but no Plasma:
$ sudo apt install sddm-theme-breeze sddm
Make SDDM the default display manager:
$ sudo dpkg-reconfigure sddm
- Reboot and login to Trinity desktop
- Check the speed, Checkpoint-2
Make Trinity TDM the default display manager:
- Check the speed, Checkpoint-3
Report back transfer speeds.
#45 2025-05-17 13:56
minuccio63
Result.
After Checkpoint-1 velocity = Slow
After Checkpoint-2 velocity = Slow
After Checkpoint-3:
ino@mino-6730s:~$ rsync -ah --progress /home/mino/Prova/Andor.avi /media/mino/TOSHIBA\ EXT/prova
sending incremental file list
Andor.avi
          1,67M   0%   62,19kB/s    2:04:51
#46 2025-05-18 09:59
Slow for all checkpoints. It's also helpful, however we haven't reveal the culprit so far. Investigating continues.
Would you perform another try please ?
Install Q4OS 6 Andromeda Trinity edition https://sourceforge.net/projects/q4os/files/testing/ , Basic profile.. Test the transfer speeds in both, the live media and installed system.
Warning, Q4OS 6 is testing alpha and not usable for production. Expect some things may not work well at the moment.
#47 2025-05-19 06:46
minuccio63
ok I'll try again for science and the future big_smile
#48 2025-05-19 08:18
minuccio63
test done 2 times for safety:
Live = fast copy 40 MB/s
Installed = slow copy 56 KB/s
I'm just curious, since I don't format the HOME partition but always use the same one, could it be some configuration file that I installed in my HOME that is causing problems?
#49 2025-05-19 09:05
What system ? Q4OS 6 or 5 ?
Maybe, however it's easy to test it. Stop Gui completely:
$ sudo systemctl stop tdm.service
Login to console as "root" and run the "rsync" test as "root" superuser.
We would be inclined to believe that it has something to do with initramfs, i.e. with the kernel. We are now investigating the interaction of Trinity and the kernel. Unfortunately, we haven't found the culprit yet, but your observations and reports are very useful, thanks for them.
So another test on the slow system would be refreshing initramfs, so run:
$ sudo update-initramfs -u
Reboot and test the speed.
#50 2025-05-19 13:29
minuccio63
System is Q4OS 6 (Andromeda Alfa)
All tests Fail = velocity slow
update initramfs Kernel 6.12.27-amd64
