#1 2016-03-07 15:47
Jerome
Update error
I got a package update notification but received this error message when downloading:
firmware-linux-nonfree: Depends: firmware-misc-nonfree (= 20160110-1~bpo8+1) but it is not going to be installed
                          Recommends: intel-microcode but it is not going to be installed
                          Recommends: amd64-microcode but it is not going to be installed
#2 2016-03-07 15:50
Re: Update error
Run in terminal and put output here:
$ uname -a
$ qrepolist
$ sudo sh /usr/share/apps/q4os_system/bin/qapt_fix.sh
#3 2016-03-07 17:09
Jerome
Re: Update error
Ok, here you go:
Linux medion 3.16.0-4-686-pae #1 SMP Debian 3.16.7-ckt20-1+deb8u3 (2016-01-17) i686 GNU/Linux
deb http://q4os.org/q4repo q4os-1-0-cn main
deb http://q4os.org/qtderepo jessie main
deb http://ftp.debian.org/debian/ jessie main contrib non-free
deb http://security.debian.org/ jessie/updates main contrib non-free
deb http://ftp.debian.org/debian/ jessie-updates main contrib non-free
deb http://ftp.debian.org/debian/ jessie-backports main contrib non-free
deb http://www.deb-multimedia.org jessie main non-free
Waiting for package system to be released ..
Seems ready, will be checked once more.
Now safe ready.
Done.
Checking package system ..
Reading package lists... Done
Building dependency tree
Package system ok.
#4 2016-03-07 20:13
Re: Update error
Run in terminal:
$ sudo apt-get update
$ sudo apt-get install firmware-misc-nonfree
$ sudo apt-get dist-upgrade
#5 2016-03-09 17:48
Jerome
Re: Update error
Thanks team, that seems to have fixed the problem.
#6 2016-04-11 13:05
Jerome
Re: Update error
I'm getting a similar error again when trying to install the most recent updates:
  rsyslog: Depends: liblognorm2 (>= 1.1.2) but it is not going to be installed
Should I follow the same procedure as recommended above?
#7 2016-04-11 15:25
Re: Update error
Run in terminal:
$ sudo apt-get remove firmware-linux-nonfree firmware-misc-nonfree
$ sudo apt-get install firmware-linux-nonfree firmware-linux
The 'firmware-misc-nonfree' package comes from backports repository and replaces 'firmware-linux-nonfree' and some other packages. You don't need it, if you use default 3.16 kernel. If you want to have 'firmware-misc-nonfree' in the system, run:
$ sudo apt-get autoremove firmware-linux-nonfree firmware-misc-nonfree
$ sudo apt-get install firmware-misc-nonfree intel-microcode amd64-microcode
#8 2016-04-11 18:43
Jerome
Re: Update error
Thanks!
