#1 2025-02-22 19:52
goldbergeliah
How to see the other partition?
Hey to all!
KDE Plasma 5.27.5
Q4OS Aquarius latest edition.
I installed Q4OS next to Windows using Windows installer. All is fine, great system!
However, the folder (Sdb2) where Windows is rested was already a small partition of about 200 GB. The bigger chunk of the SSD drive is actually another partition ( D:) which is empty. I want to put my files in D: and use them when necessary.
I can not see D: with Dolphin file manager. (Maybe it does, but, I don't know how). Is it possible to access the other partition when you install the OS right next to Windows?
Thanks in advance
#2 2025-02-22 20:23
Re: How to see the other partition?
Yes, it's just another partition, so you only need to mount it. If it's NTFS partition:
$ sudo mkdir /mnt/windows
$ sudo mount -t ntfs-3g /dev/sda2 /mnt/windows
As a regular user to a /media subdirectory
$ udisksctl mount -b /dev/sdc1
see https://wiki.debian.org/NTFS
#3 2025-02-23 20:39
josek
Hi, I also did a Q40s installation but to an SSD from HDD
My question is if I should be alert in case the wubi installer fails?
My Windows was left on the HDD and my Q40s was on the SSD.
